楼主 #1 2018-11-25 21:16:47
billnie
已发帖子: 47
zero v3s mx25l256 32MB flash linux系统无法识别
U-Boot SPL 2017.01-rc2 (Nov 25 2018 - 14:49:54)
DRAM: 64 MiB
Trying to boot from sunxi SPI
U-Boot 2017.01-rc2 (Nov 25 2018 - 14:49:54 +0800) Allwinner Technology
Model: Lichee Pi Zero
DRAM:  64 MiB
MMC:   SUNXI SD/MMC: 0
SF: Detected mx25l25635f with page size 256 Bytes, erase size 64 KiB, total 32 MiB
dotclock: 10000kHz = 10000kHz: (1 * 3MHz * 20) / 6
In:    serial@01c28000
Out:   serial@01c28000
Err:   serial@01c28000
DRAM:  64 MiB
In:    serial@01c28000
Net:   No ethernet found.
No controllers found
=> boot
   Loading Device Tree to 42dfa000, end 42dffed1 ... OK
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.13.16-licheepi-zero (root@billnie) (gcc version 6.3.1 20170109 (Linaro GCC 6.3-2017.02)) #11 SMP Sun Nov 25 15:15:03 CST 2018
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: Lichee Pi Zero with Dock
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] percpu: Embedded 16 pages/cpu @c3edf000 s33868 r8192 d23476 u65536
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16129
[    0.000000] Kernel command line: console=ttyS0,115200 earlyprintk panic=5 rootwait mtdparts=spi32766.0:1M(uboot)ro,64k(dtb)ro,4M(kernel)ro,-(rootfs) root=31:03 rw rootfstype=jffs2
[    0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[    0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[    0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Memory: 54568K/65024K available (6144K kernel code, 217K rwdata, 1456K rodata, 1024K init, 264K bss, 10456K reserved, 0K cma-reserved, 0K highmem)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xc4000000 - 0xff800000   ( 952 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xc3f80000   (  63 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0700000   (7136 kB)
[    0.000000]       .init : 0xc0900000 - 0xc0a00000   (1024 kB)
[    0.000000]       .data : 0xc0a00000 - 0xc0a367c0   ( 218 kB)
[    0.000000]        .bss : 0xc0a3daf0 - 0xc0a7fcac   ( 265 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000]     RCU event tracing is enabled.
[    0.000000]     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000008] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000020] Switching to timer-based delay loop, resolution 41ns
[    0.000180] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000402] Console: colour dummy device 80x30
[    0.000438] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000453] pid_max: default: 32768 minimum: 301
[    0.000579] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000592] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.001186] CPU: Testing write buffer coherency: ok
[    0.001556] /cpus/cpu@0 missing clock-frequency property
[    0.001578] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.001997] Setting up static identity map for 0x40100000 - 0x40100060
[    0.002174] Hierarchical SRCU implementation.
[    0.002673] smp: Bringing up secondary CPUs ...
[    0.002688] smp: Brought up 1 node, 1 CPU
[    0.002698] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[    0.002705] CPU: All CPU(s) started in SVC mode.
[    0.003459] devtmpfs: initialized
[    0.006581] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.006870] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.006897] futex hash table entries: 256 (order: 2, 16384 bytes)
[    0.007055] pinctrl core: initialized pinctrl subsystem
[    0.007906] random: get_random_u32 called from bucket_table_alloc+0xf4/0x244 with crng_init=0
[    0.008037] NET: Registered protocol family 16
[    0.008505] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.009632] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.009649] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.023048] SCSI subsystem initialized
[    0.023348] usbcore: registered new interface driver usbfs
[    0.023410] usbcore: registered new interface driver hub
[    0.023507] usbcore: registered new device driver usb
[    0.023754] pps_core: LinuxPPS API ver. 1 registered
[    0.023764] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.023785] PTP clock support registered
[    0.024022] Advanced Linux Sound Architecture Driver Initialized.
[    0.025873] clocksource: Switched to clocksource arch_sys_counter
[    0.036244] led_trigger_register 0 kbd-scrolllock
[    0.036261] led_trigger_register 1 kbd-numlock
[    0.036268] led_trigger_register 2 kbd-capslock
[    0.036274] led_trigger_register 3 kbd-kanalock
[    0.036279] led_trigger_register 4 kbd-shiftlock
[    0.036285] led_trigger_register 5 kbd-altgrlock
[    0.036291] led_trigger_register 6 kbd-ctrllock
[    0.036297] led_trigger_register 7 kbd-altlock
[    0.036303] led_trigger_register 8 kbd-shiftllock
[    0.036310] led_trigger_register 9 kbd-shiftrlock
[    0.036316] led_trigger_register 10 kbd-ctrlllock
[    0.036322] led_trigger_register 11 kbd-ctrlrlock
[    0.036768] NET: Registered protocol family 2
[    0.037344] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    0.037377] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[    0.037401] TCP: Hash tables configured (established 1024 bind 1024)
[    0.037527] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.037575] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.037788] NET: Registered protocol family 1
[    0.038372] RPC: Registered named UNIX socket transport module.
[    0.038390] RPC: Registered udp transport module.
[    0.038397] RPC: Registered tcp transport module.
[    0.038403] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.040493] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[    0.049383] NFS: Registering the id_resolver key type
[    0.049432] Key type id_resolver registered
[    0.049439] Key type id_legacy registered
[    0.049483] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    0.050999] random: fast init done
[    0.053835] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    0.053855] io scheduler noop registered
[    0.053862] io scheduler deadline registered
[    0.054134] io scheduler cfq registered (default)
[    0.054146] io scheduler mq-deadline registered
[    0.054153] io scheduler kyber registered
[    0.058491] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.128110] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.131331] console [ttyS0] disabled
[    0.151602] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 36, base_baud = 1500000) is a U6_16550A
[    0.795735] console [ttyS0] enabled
[    0.803496] spi_nor_scan:(null)
[    0.806939] m25p80 spi32766.0: unrecognized JEDEC id bytes: 00, 00, 00
[    0.813472] m25p80 spi32766.0: unrecognized JEDEC id bytes: 00, 00, 00
[    0.820067] m25p80: probe of spi32766.0 failed with error -2
[    0.826158] libphy: Fixed MDIO Bus: probed
[    0.830755] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[    0.836633] dwmac-sun8i 1c30000.ethernet: No regulator found
[    0.842343] dwmac-sun8i 1c30000.ethernet: Will use internal PHY
[    0.848523] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[    0.854185] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[    0.861440] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[    0.867111] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[    0.874324] dwmac-sun8i 1c30000.ethernet: COE Type 2
[    0.879297] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[    0.886289] libphy: stmmac: probed
[    0.891562] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.898220] ehci-platform: EHCI generic platform driver
[    0.903740] ehci-platform 1c1a000.usb: EHCI Host Controller
[    0.909428] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[    0.917359] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000
[    0.945895] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    0.953100] hub 1-0:1.0: USB hub found
[    0.957044] hub 1-0:1.0: 1 port detected
[    0.961538] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.967836] ohci-platform: OHCI generic platform driver
[    0.973374] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    0.980097] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[    0.988062] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400
[    1.061013] hub 2-0:1.0: USB hub found
[    1.064845] hub 2-0:1.0: 1 port detected
[    1.072428] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[    1.081998] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input0
[    1.090968] sun6i-rtc 1c20400.rtc: rtc core: registered rtc-sun6i as rtc0
[    1.097877] sun6i-rtc 1c20400.rtc: RTC enabled
[    1.102419] i2c /dev entries driver
[    1.107454] input: ns2009_ts as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0048/input/input1
[    1.116960] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    1.126462] led_trigger_register_simple mmc0
[    1.126482] led_trigger_register 12 mmc0
[    1.185919] sunxi-mmc 1c0f000.mmc: base:0xc407b000 irq:23
[    1.192386] led_trigger_register_simple mmc1
[    1.192405] led_trigger_register 13 mmc1
[    1.255905] sunxi-mmc 1c10000.mmc: base:0xc4144000 irq:24
[    1.261626] led_trigger_register 14 heartbeat
[    1.266044] led_trigger_register 15 default-on
[    1.271147] usbcore: registered new interface driver usbhid
[    1.276780] usbhid: USB HID core driver
[    1.282179] sun4i-codec 1c22c00.codec: ASoC: /soc/codec-analog@01c23000 not registered
[    1.290220] sun4i-codec 1c22c00.codec: Failed to register our card
[    1.297689] NET: Registered protocol family 17
[    1.302271] Key type dns_resolver registered
[    1.306807] Registering SWP/SWPB emulation handler
[    1.319307] simple-framebuffer 43f80000.framebuffer: framebuffer at 0x43f80000, 0x7f800 bytes, mapped to 0xc4300000
[    1.329925] simple-framebuffer 43f80000.framebuffer: format=x8r8g8b8, mode=480x272x32, linelength=1920
[    1.342206] Console: switching to colour frame buffer device 60x34
[    1.350669] simple-framebuffer 43f80000.framebuffer: fb0: simplefb registered!
[    1.359181] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    1.370550] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    1.376389] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[    1.385435] hub 3-0:1.0: USB hub found
[    1.389412] hub 3-0:1.0: 1 port detected
[    1.394551] using random self ethernet address
[    1.399124] using random host ethernet address
[    1.404647] usb0: HOST MAC ea:26:5e:0b:a9:73
[    1.409113] usb0: MAC 52:f9:25:c2:8a:3b
[    1.412995] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[    1.420522] g_cdc gadget: g_cdc ready
[    1.426834] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
[    1.436329] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01 00:00:23 UTC (23)
[    1.444580] vcc3v3: disabling
[    1.447621] vcc5v0: disabling
[    1.450591] ALSA device list:
[    1.453554]   #0: V3s Audio Codec
[    1.457723] VFS: Cannot open root device "31:03" or unknown-block(31,3): error -19
[    1.465292] Please append a correct "root=" boot option; here are the available partitions:
[    1.473737] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,3)
[    1.482086] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.13.16-licheepi-zero #11
[    1.489382] Hardware name: Allwinner sun8i Family
[    1.494120] [<c010e5cc>] (unwind_backtrace) from [<c010b2b0>] (show_stack+0x10/0x14)
[    1.501867] [<c010b2b0>] (show_stack) from [<c06788fc>] (dump_stack+0x84/0x98)
[    1.509091] [<c06788fc>] (dump_stack) from [<c011b788>] (panic+0xdc/0x248)
[    1.515968] [<c011b788>] (panic) from [<c09011d0>] (mount_block_root+0x188/0x25c)
[    1.523446] [<c09011d0>] (mount_block_root) from [<c09013c4>] (mount_root+0x120/0x128)
[    1.531358] [<c09013c4>] (mount_root) from [<c090151c>] (prepare_namespace+0x150/0x194)
[    1.539355] [<c090151c>] (prepare_namespace) from [<c0900e20>] (kernel_init_freeable+0x1bc/0x1cc)
[    1.548221] [<c0900e20>] (kernel_init_freeable) from [<c068b7d4>] (kernel_init+0x8/0x108)
[    1.556393] [<c068b7d4>] (kernel_init) from [<c0107638>] (ret_from_fork+0x14/0x3c)
[    1.563965] Rebooting in 5 seconds..
楼主 #2 2018-11-25 21:18:20
billnie
已发帖子: 47
Re: zero v3s mx25l256 32MB flash linux系统无法识别
关键点,看起来linux驱动无法识别,
sunxi-fel 能识别
u-boot 也能识别
#3 2018-11-25 22:25:51
已发帖子: 9,342
你的 dts 如何配置的?
有没有添加spi 驱动?dts 配置的 flash 时钟频率是多少?
楼主 #4 2018-11-25 23:39:58
billnie
已发帖子: 47
改成16MHZ了
&spi0 {
        status ="okay";
        mx25l25635e:mx25l25635e@0 {
                compatible = "jedec,spi-nor";
                reg = <0x0>;
                spi-max-frequency = <16000000>;
                #address-cells = <1>;
                #size-cells = <1>;
现在可以识别flash,但是rootfs有问题
楼主 #5 2018-11-25 23:41:50
billnie
已发帖子: 47
[    0.000000] Linux version 4.13.16-licheepi-zero (root@billnie) (gcc version 6.3.1 20170109 (Linaro GCC 6.3-2017.02)) #17 SMP Sun Nov 25 23:23:00 CST 2018
[    0.000019] Switching to timer-based delay loop, resolution 41ns
[    0.000181] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000409] Console: colour dummy device 80x30
[    0.000443] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000457] pid_max: default: 32768 minimum: 301
[    0.000583] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000597] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.001184] CPU: Testing write buffer coherency: ok
[    0.001550] /cpus/cpu@0 missing clock-frequency property
[    0.001573] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.002169] Hierarchical SRCU implementation.
[    0.002671] smp: Bringing up secondary CPUs ...
[    0.002683] smp: Brought up 1 node, 1 CPU
[    0.002691] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[    0.002699] CPU: All CPU(s) started in SVC mode.
[    0.003447] devtmpfs: initialized
[    0.006567] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.006853] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.006878] futex hash table entries: 256 (order: 2, 16384 bytes)
[    0.007042] pinctrl core: initialized pinctrl subsystem
[    0.007911] random: get_random_u32 called from bucket_table_alloc+0xf4/0x244 with crng_init=0
[    0.008044] NET: Registered protocol family 16
[    0.008513] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.009626] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.009644] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.023088] SCSI subsystem initialized
[    0.023390] usbcore: registered new interface driver usbfs
[    0.023457] usbcore: registered new interface driver hub
[    0.023552] usbcore: registered new device driver usb
[    0.023798] pps_core: LinuxPPS API ver. 1 registered
[    0.023807] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.023828] PTP clock support registered
[    0.024055] Advanced Linux Sound Architecture Driver Initialized.
[    0.025899] clocksource: Switched to clocksource arch_sys_counter
[    0.036306] led_trigger_register 0 kbd-scrolllock
[    0.036324] led_trigger_register 1 kbd-numlock
[    0.036330] led_trigger_register 2 kbd-capslock
[    0.036336] led_trigger_register 3 kbd-kanalock
[    0.036342] led_trigger_register 4 kbd-shiftlock
[    0.036348] led_trigger_register 5 kbd-altgrlock
[    0.036354] led_trigger_register 6 kbd-ctrllock
[    0.036360] led_trigger_register 7 kbd-altlock
[    0.036366] led_trigger_register 8 kbd-shiftllock
[    0.036372] led_trigger_register 9 kbd-shiftrlock
[    0.036378] led_trigger_register 10 kbd-ctrlllock
[    0.036385] led_trigger_register 11 kbd-ctrlrlock
[    0.036835] NET: Registered protocol family 2
[    0.037405] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    0.037440] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[    0.037465] TCP: Hash tables configured (established 1024 bind 1024)
[    0.037590] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.037638] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.037859] NET: Registered protocol family 1
[    0.038441] RPC: Registered named UNIX socket transport module.
[    0.038458] RPC: Registered udp transport module.
[    0.038464] RPC: Registered tcp transport module.
[    0.038470] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.040559] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[    0.049490] NFS: Registering the id_resolver key type
[    0.049539] Key type id_resolver registered
[    0.049545] Key type id_legacy registered
[    0.049590] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    0.051113] random: fast init done
[    0.053969] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    0.053991] io scheduler noop registered
[    0.053999] io scheduler deadline registered
[    0.054271] io scheduler cfq registered (default)
[    0.054282] io scheduler mq-deadline registered
[    0.054288] io scheduler kyber registered
[    0.058618] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.128112] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.131320] console [ttyS0] disabled
[    0.151595] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 36, base_baud = 1500000) is a U6_16550A
[    0.795739] console [ttyS0] enabled
[    0.802530] sun6i_spi_probe
[    0.806393] m25p_probe:
[    0.809090] m25p80 spi32766.0: unrecognized JEDEC id bytes: c2, 20, 19
[    0.815619] spi_nor_scan 2:(null)
[    0.818990] spi_nor_init_params:
[    0.822358] m25p80 spi32766.0: mx25l25635e (32768 Kbytes)
[    0.827811] spi32766.0: parser cmdlinepart: 4
[    0.832165] 4 cmdlinepart partitions found on MTD device spi32766.0
[    0.838444] Creating 4 MTD partitions on "spi32766.0":
[    0.843585] 0x000000000000-0x000000100000 : "uboot"
[    0.849004] 0x000000100000-0x000000110000 : "dtb"
[    0.854108] 0x000000110000-0x000000510000 : "kernel"
[    0.859524] 0x000000510000-0x000002000000 : "rootfs"
[    0.865275] libphy: Fixed MDIO Bus: probed
[    0.869960] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[    0.875755] dwmac-sun8i 1c30000.ethernet: No regulator found
[    0.881531] dwmac-sun8i 1c30000.ethernet: Will use internal PHY
[    0.887716] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[    0.893377] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[    0.900631] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[    0.906300] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[    0.913514] dwmac-sun8i 1c30000.ethernet: COE Type 2
[    0.918486] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[    0.925447] libphy: stmmac: probed
[    0.930789] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.937446] ehci-platform: EHCI generic platform driver
[    0.942960] ehci-platform 1c1a000.usb: EHCI Host Controller
[    0.948645] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[    0.956581] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000
[    0.985917] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    0.993155] hub 1-0:1.0: USB hub found
[    0.997108] hub 1-0:1.0: 1 port detected
[    1.001624] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.007922] ohci-platform: OHCI generic platform driver
[    1.013490] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    1.020234] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[    1.028188] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400
[    1.101025] hub 2-0:1.0: USB hub found
[    1.104850] hub 2-0:1.0: 1 port detected
[    1.112462] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[    1.122041] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input0
[    1.130977] sun6i-rtc 1c20400.rtc: rtc core: registered rtc-sun6i as rtc0
[    1.137883] sun6i-rtc 1c20400.rtc: RTC enabled
[    1.142422] i2c /dev entries driver
[    1.147273] input: ns2009_ts as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0048/input/input1
[    1.156766] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    1.166182] led_trigger_register_simple mmc0
[    1.166200] led_trigger_register 12 mmc0
[    1.225949] sunxi-mmc 1c0f000.mmc: base:0xc407b000 irq:23
[    1.232404] led_trigger_register_simple mmc1
[    1.232421] led_trigger_register 13 mmc1
[    1.295928] sunxi-mmc 1c10000.mmc: base:0xc4144000 irq:24
[    1.301673] led_trigger_register 14 heartbeat
[    1.306101] led_trigger_register 15 default-on
[    1.311220] usbcore: registered new interface driver usbhid
[    1.316841] usbhid: USB HID core driver
[    1.322297] sun4i-codec 1c22c00.codec: ASoC: /soc/codec-analog@01c23000 not registered
[    1.330339] sun4i-codec 1c22c00.codec: Failed to register our card
[    1.337794] NET: Registered protocol family 17
[    1.342371] Key type dns_resolver registered
[    1.346908] Registering SWP/SWPB emulation handler
[    1.359402] simple-framebuffer 43f80000.framebuffer: framebuffer at 0x43f80000, 0x7f800 bytes, mapped to 0xc4300000
[    1.370020] simple-framebuffer 43f80000.framebuffer: format=x8r8g8b8, mode=480x272x32, linelength=1920
[    1.382296] Console: switching to colour frame buffer device 60x34
[    1.390757] simple-framebuffer 43f80000.framebuffer: fb0: simplefb registered!
[    1.399299] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    1.410649] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    1.416489] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[    1.425626] hub 3-0:1.0: USB hub found
[    1.429621] hub 3-0:1.0: 1 port detected
[    1.434689] using random self ethernet address
[    1.439241] using random host ethernet address
[    1.444812] usb0: HOST MAC fa:2c:1b:ee:06:bc
[    1.449235] usb0: MAC 62:22:20:4c:8f:06
[    1.453116] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[    1.460634] g_cdc gadget: g_cdc ready
[    1.466985] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
[    1.476595] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01 00:00:15 UTC (15)
[    1.484847] vcc3v3: disabling
[    1.487889] vcc5v0: disabling
[    1.490858] ALSA device list:
[    1.493822]   #0: V3s Audio Codec
[    1.505669] jffs2: jffs2_scan_inode_node(): CRC failed on node at 0x000020a8: Read 0x4594b5b8, calculated 0x798d4761
[    1.518660] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000a0f8: 0xe666 instead
[    1.528208] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000a0fc: 0x633f instead
[    1.537898] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000a100: 0xc64f instead
[    1.547406] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000a104: 0xa56f instead
[    1.556888] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000a108: 0x81c9 instead
[    1.566362] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000a10c: 0x84a3 instead
[    1.575827] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000a110: 0x9eb6 instead
[    1.585303] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000a114: 0x2e06 instead
[    1.594830] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000a118: 0x0e2b instead
[    1.604317] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000a11c: 0xa5f3 instead
[    1.613794] jffs2: Further such events for this erase block will not be printed
[    1.632729] random: crng init done
[    1.636180] sun4i_lradc_irq voltage = 11 349206!
[    1.927519] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0008d868: 0x8cc2 instead
[    1.937086] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0008d86c: 0x0019 instead
[    1.946579] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0008d870: 0x3735 instead
[    1.956057] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0008d874: 0x808b instead
[    1.965521] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0008d878: 0x0376 instead
[    1.974997] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0008d87c: 0xc476 instead
[    1.984474] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0008d884: 0x2676 instead
[    1.993948] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0008d888: 0xb05d instead
[    2.003424] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0008d88c: 0xb0dd instead
[    2.012942] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0008d890: 0xb0dd instead
[    2.022423] jffs2: Further such events for this erase block will not be printed
[    2.043923] sun4i_lradc_irq voltage = 13 412698!
[    2.201264] jffs2: jffs2_scan_inode_node(): CRC failed on node at 0x000d6064: Read 0x6b91f9a1, calculated 0x83c9f10a
[    2.211889] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000d60dc: 0x265d instead
[    2.221420] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000d60e0: 0x1467 instead
[    2.230910] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000d60e4: 0x0501 instead
[    2.240389] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000d60e8: 0x4c4d instead
[    2.249865] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000d60ec: 0x911a instead
[    2.259340] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000d60f0: 0xa11b instead
[    2.268815] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000d60f4: 0xb44b instead
[    2.278290] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000d60f8: 0x4e01 instead
[    2.287765] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000d60fc: 0x2059 instead
[    2.297240] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000d6100: 0xa9ff instead
[    2.306712] jffs2: Further such events for this erase block will not be printed
[    2.329067] sun4i_lradc_irq voltage = 11 349206!
[    2.382457] jffs2: jffs2_scan_inode_node(): CRC failed on node at 0x000f10d4: Read 0x311c7253, calculated 0xf37a7290
[    2.393108] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000f114c: 0x1dae instead
[    2.402635] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000f1150: 0x3197 instead
[    2.413181] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000f1154: 0x61e3 instead
[    2.424719] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000f1158: 0x15d5 instead
[    2.434257] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000f115c: 0x917a instead
[    2.443767] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000f1160: 0x1283 instead
[    2.453261] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000f1164: 0x1d8e instead
[    2.462753] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000f1168: 0x0470 instead
[    2.472251] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000f116c: 0x4bbd instead
[    2.481746] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000f1170: 0x0d7e instead
[    2.491241] jffs2: Further such events for this erase block will not be printed
[    2.512655] sun4i_lradc_irq voltage = 11 349206!
[    2.740209] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00154298: 0x8cc2 instead
[    2.749784] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0015429c: 0x0022 instead
[    2.759308] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001542a0: 0x4815 instead
[    2.768792] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001542a4: 0x00cb instead
[    2.778270] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001542a8: 0x8032 instead
[    2.787746] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001542ac: 0xc076 instead
[    2.797222] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001542b4: 0x703e instead
[    2.806697] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001542b8: 0xb05d instead
[    2.816170] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001542bc: 0xb0dd instead
[    2.825634] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001542c0: 0xb0dd instead
[    2.835107] jffs2: Further such events for this erase block will not be printed
[    2.856384] sun4i_lradc_irq voltage = 11 349206!
[    2.881320] jffs2: Empty flash at 0x0016225c ends at 0x0016227c
[    2.887273] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0016227c: 0x61bb instead
[    2.896807] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00162280: 0x61bb instead
[    2.906289] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00162284: 0x61bb instead
[    2.915754] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00162288: 0x1000 instead
[    2.925234] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0016228c: 0x0100 instead
[    2.934711] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00162290: 0x0100 instead
[    2.944187] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00162298: 0xf429 instead
[    2.953661] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0016229c: 0x8928 instead
[    2.963136] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001622a0: 0xe92d instead
[    2.972610] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001622a4: 0xf04f instead
[    2.982084] jffs2: Further such events for this erase block will not be printed
[    3.004814] sun4i_lradc_irq voltage = 11 349206!
[    3.228563] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c92d8: 0x8cc2 instead
[    3.238163] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c92dc: 0x0022 instead
[    3.247663] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c92e0: 0x4815 instead
[    3.257143] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c92e4: 0x00ce instead
[    3.266662] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c92e8: 0x0246 instead
[    3.276168] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c92ec: 0xc076 instead
[    3.285634] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c92f4: 0x5350 instead
[    3.295117] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c92f8: 0xb05d instead
[    3.304594] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c92fc: 0xb0dd instead
[    3.314069] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c9300: 0xb0dd instead
[    3.323541] jffs2: Further such events for this erase block will not be printed
[    3.344644] sun4i_lradc_irq voltage = 11 349206!
[    3.364173] sun4i_lradc_irq voltage = 14 444444!
[    3.390871] jffs2: Empty flash at 0x001de7c0 ends at 0x001de7e0
[    3.396870] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001de7e0: 0x61bb instead
[    3.406357] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001de7e4: 0x61bb instead
[    3.415822] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001de7e8: 0x61bb instead
[    3.425302] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001de7ec: 0x64fe instead
[    3.434778] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001de7f0: 0x0002 instead
[    3.444252] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001de7f4: 0x0002 instead
[    3.453727] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001de7fc: 0x20c8 instead
[    3.463201] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001de800: 0x6743 instead
[    3.472675] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001de804: 0x2000 instead
[    3.496979] sun4i_lradc_irq voltage = 11 349206!
[    3.545011] jffs2: jffs2_scan_inode_node(): CRC failed on node at 0x001f89a8: Read 0x590164a2, calculated 0x8c8c1899
[    3.555621] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001f8ae8: 0x8c42 instead
[    3.565176] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001f8aec: 0x0023 instead
[    3.574660] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001f8af0: 0x194b instead
[    3.584138] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001f8af4: 0x004e instead
[    3.593645] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001f8af8: 0x830d instead
[    3.603151] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001f8afc: 0xc076 instead
[    3.613738] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001f8b04: 0x5350 instead
[    3.625277] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001f8b08: 0xb05d instead
[    3.634780] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001f8b0c: 0xb0dd instead
[    3.644316] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001f8b10: 0xb0dd instead
[    3.653803] jffs2: Further such events for this erase block will not be printed
[    3.676661] sun4i_lradc_irq voltage = 11 349206!
[    3.714930] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0020c680: 0x8cc2 instead
[    3.724509] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0020c684: 0x0022 instead
[    3.734089] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0020c688: 0x4815 instead
[    3.743603] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0020c68c: 0x00ce instead
[    3.753102] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0020c690: 0x0413 instead
[    3.762604] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0020c694: 0xc076 instead
[    3.772101] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0020c69c: 0x5350 instead
[    3.781597] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0020c6a0: 0xb05d instead
[    3.791091] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0020c6a4: 0xb0dd instead
[    3.800655] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0020c6a8: 0xb0dd instead
[    3.810148] jffs2: Further such events for this erase block will not be printed
[    3.832903] sun4i_lradc_irq voltage = 11 349206!
[    4.220014] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002bb7a0: 0x8cc2 instead
[    4.229590] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002bb7a4: 0x0022 instead
[    4.239081] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002bb7a8: 0x4815 instead
[    4.248562] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002bb7ac: 0x00d2 instead
[    4.258037] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002bb7b0: 0x0117 instead
[    4.267514] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002bb7b4: 0xc076 instead
[    4.276989] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002bb7bc: 0x4a24 instead
[    4.286462] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002bb7c0: 0xb05d instead
[    4.295936] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002bb7c4: 0xb0dd instead
[    4.305400] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002bb7c8: 0xb0dd instead
[    4.314872] jffs2: Further such events for this erase block will not be printed
[    4.336784] sun4i_lradc_irq voltage = 13 412698!
[    4.470704] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002fb578: 0x8cc2 instead
[    4.480264] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002fb57c: 0x000b instead
[    4.489754] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002fb580: 0xab01 instead
[    4.499232] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002fb584: 0x0052 instead
[    4.508710] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002fb588: 0x0234 instead
[    4.518185] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002fb58c: 0xc076 instead
[    4.527703] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002fb594: 0x4a24 instead
[    4.537185] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002fb598: 0xb05d instead
[    4.546662] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002fb59c: 0xb0dd instead
[    4.556136] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002fb5a0: 0xb0dd instead
[    4.565599] jffs2: Further such events for this erase block will not be printed
[    4.586773] sun4i_lradc_irq voltage = 11 349206!
[    4.978032] jffs2: Empty flash at 0x003a72a4 ends at 0x003a72c4
[    4.985009] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003a72c4: 0x61bb instead
[    4.994577] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003a72c8: 0x61bb instead
[    5.004067] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003a72cc: 0x61bb instead
[    5.013547] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003a72d0: 0x43fe instead
[    5.023024] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003a72d4: 0x0002 instead
[    5.032499] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003a72d8: 0x0002 instead
[    5.041973] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003a72e0: 0x32ac instead
[    5.051448] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003a72e4: 0xe3f0 instead
[    5.060922] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003a72e8: 0x0908 instead
[    5.082843] sun4i_lradc_irq voltage = 11 349206!
[    5.116234] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003b91a0: 0x401b instead
[    5.125763] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003b91a4: 0xed28 instead
[    5.135289] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003b91a8: 0xa043 instead
[    5.144772] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003b91ac: 0xce94 instead
[    5.154248] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003b91b0: 0x5015 instead
[    5.163762] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003b91b4: 0x4f4a instead
[    5.173245] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003b91b8: 0xa073 instead
[    5.182721] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003b91bc: 0xbd28 instead
[    5.192196] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003b91c0: 0x0403 instead
[    5.201671] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003b91c4: 0x7d28 instead
[    5.211144] jffs2: Further such events for this erase block will not be printed
[    5.231273] sun4i_lradc_irq voltage = 11 349206!
[    5.465645] jffs2: ofs 0x00423104 has already been seen. Skipping
[    5.474218] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004240fc: 0x0379 instead
[    5.483777] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00424100: 0x81ed instead
[    5.493266] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00424108: 0x7ddc instead
[    5.502745] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0042410c: 0x61bb instead
[    5.512221] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00424110: 0x61bb instead
[    5.521695] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00424114: 0x61bb instead
[    5.531170] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00424118: 0x7800 instead
[    5.540645] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0042411c: 0x0098 instead
[    5.550119] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00424120: 0x0100 instead
[    5.559593] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00424124: 0x0006 instead
[    5.569064] jffs2: Further such events for this erase block will not be printed
[    5.590631] sun4i_lradc_irq voltage = 11 349206!
[    6.067337] jffs2: ofs 0x004f830c has already been seen. Skipping
[    6.076997] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004f9304: 0xe5e6 instead
[    6.088644] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004f9308: 0xbb8b instead
[    6.098167] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004f930c: 0x9c04 instead
[    6.107664] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004f9310: 0xbbf7 instead
[    6.117159] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004f9314: 0xc8a0 instead
[    6.126652] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004f9318: 0x7b92 instead
[    6.136167] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004f931c: 0xda4f instead
[    6.145652] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004f9320: 0x818b instead
[    6.155153] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004f9324: 0xba30 instead
[    6.164649] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004f9328: 0x1e34 instead
[    6.174131] jffs2: Further such events for this erase block will not be printed
[    6.196073] sun4i_lradc_irq voltage = 12 380952!
[    7.003915] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00660000: 0x8cc2 instead
[    7.013508] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00660004: 0x0006 instead
[    7.023003] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00660008: 0xd858 instead
[    7.032519] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0066000c: 0x8c42 instead
[    7.042031] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00660010: 0x005f instead
[    7.052610] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00660014: 0x066f instead
[    7.064157] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00660018: 0x00aa instead
[    7.073660] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0066001c: 0x0003 instead
[    7.083158] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00660020: 0xc076 instead
[    7.092652] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00660028: 0x4302 instead
[    7.102133] jffs2: Further such events for this erase block will not be printed
[    7.121811] sun4i_lradc_irq voltage = 11 349206!
[    7.400354] jffs2: jffs2_scan_inode_node(): CRC failed on node at 0x006da568: Read 0xffffffff, calculated 0xf09e7845
[    7.410972] jffs2: ofs 0x006da568 has already been seen. Skipping
[    7.419403] jffs2: Empty flash at 0x006da56c ends at 0x006da588
[    7.425321] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006da588: 0x61bb instead
[    7.434817] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006da58c: 0x61bb instead
[    7.444328] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006da590: 0x61bb instead
[    7.453811] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006da594: 0x0b00 instead
[    7.463287] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006da598: 0x00fa instead
[    7.472799] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006da59c: 0x00fd instead
[    7.482282] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006da5a0: 0x0006 instead
[    7.491758] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006da5a4: 0x0c44 instead
[    7.501235] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006da5a8: 0xc124 instead
[    7.510710] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006da5ac: 0x5e78 instead
[    7.520182] jffs2: Further such events for this erase block will not be printed
[    7.539759] sun4i_lradc_irq voltage = 11 349206!
[    7.761107] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00740000: 0x8cc2 instead
[    7.770680] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00740004: 0x0006 instead
[    7.780174] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00740008: 0xd858 instead
[    7.789652] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0074000c: 0x8c42 instead
[    7.799129] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00740010: 0x8016 instead
[    7.808605] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00740014: 0x9451 instead
[    7.818081] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00740018: 0x00ab instead
[    7.827556] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0074001c: 0x8124 instead
[    7.837030] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00740020: 0xc076 instead
[    7.846504] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00740028: 0x132a instead
[    7.855976] jffs2: Further such events for this erase block will not be printed
[    7.875682] sun4i_lradc_irq voltage = 11 349206!
[    8.018658] jffs2: ofs 0x00781150 has already been seen. Skipping
[    8.027261] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00782148: 0x0072 instead
[    8.036758] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0078214c: 0x0100 instead
[    8.046237] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00782150: 0x0006 instead
[    8.055702] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00782154: 0x19ad instead
[    8.065179] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00782158: 0xed84 instead
[    8.074655] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0078215c: 0x5e78 instead
[    8.084130] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00782160: 0x8080 instead
[    8.093636] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00782164: 0x0c0c instead
[    8.103155] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00782168: 0x1ca1 instead
[    8.112638] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0078216c: 0x8d9e instead
[    8.122113] jffs2: Further such events for this erase block will not be printed
[    8.145200] sun4i_lradc_irq voltage = 11 349206!
[    8.189205] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0079a2c8: 0x8cc2 instead
[    8.198827] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0079a2cc: 0x8063 instead
[    8.208322] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0079a2d0: 0x7164 instead
[    8.217833] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0079a2d4: 0x80bd instead
[    8.227348] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0079a2d8: 0x807e instead
[    8.236859] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0079a2dc: 0xc076 instead
[    8.247392] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0079a2e4: 0x702a instead
[    8.258926] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0079a2e8: 0xb05d instead
[    8.268423] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0079a2ec: 0xb0dd instead
[    8.277918] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0079a2f0: 0xb0dd instead
[    8.287399] jffs2: Further such events for this erase block will not be printed
[    8.308386] jffs2: jffs2_scan_inode_node(): CRC failed on node at 0x007a00e4: Read 0xe1ed246a, calculated 0x1e76b02b
[    8.318925] sun4i_lradc_irq voltage = 11 349206!
[    8.326087] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x007a8144: 0xe940 instead
[    8.335631] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x007a8148: 0x100d instead
[    8.345157] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x007a814c: 0x4c77 instead
[    8.354661] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x007a8150: 0x0100 instead
[    8.364243] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x007a8154: 0xc36e instead
[    8.387378] sun4i_lradc_irq voltage = 11 349206!
[    8.497972] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x007da2d4: 0x8cc2 instead
[    8.507532] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x007da2d8: 0x0022 instead
[    8.517064] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x007da2dc: 0x4815 instead
[    8.526547] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x007da2e0: 0x80bd instead
[    8.536026] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x007da2e4: 0x032b instead
[    8.545490] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x007da2e8: 0xc076 instead
[    8.554966] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x007da2f0: 0x702a instead
[    8.564441] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x007da2f4: 0xb05d instead
[    8.573916] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x007da2f8: 0xb0dd instead
[    8.583391] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x007da2fc: 0xb0dd instead
[    8.592864] jffs2: Further such events for this erase block will not be printed
[    8.613931] sun4i_lradc_irq voltage = 11 349206!
[    8.887862] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0085746c: 0x8cc2 instead
[    8.897428] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00857470: 0x8022 instead
[    8.906921] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00857474: 0x4e3c instead
[    8.916395] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00857478: 0x803d instead
[    8.925871] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0085747c: 0x0628 instead
[    8.935336] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00857480: 0xc076 instead
[    8.944852] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00857488: 0x702a instead
[    8.954335] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0085748c: 0xb05d instead
[    8.963813] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00857490: 0xb0dd instead
[    8.973288] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00857494: 0xb0dd instead
[    8.982762] jffs2: Further such events for this erase block will not be printed
[    9.004536] sun4i_lradc_irq voltage = 11 349206!
[    9.321599] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x008e7470: 0x6001 instead
[    9.331171] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x008e7474: 0x7005 instead
[    9.340659] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x008e7478: 0x0006 instead
[    9.350137] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x008e747c: 0x81f0 instead
[    9.359656] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x008e7480: 0x3028 instead
[    9.369140] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x008e7484: 0x0105 instead
[    9.378616] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x008e7488: 0xffe8 instead
[    9.388090] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x008e748c: 0x3028 instead
[    9.397565] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x008e7490: 0x7105 instead
[    9.407040] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x008e7494: 0x5001 instead
[    9.416510] jffs2: Further such events for this erase block will not be printed
[    9.438111] sun4i_lradc_irq voltage = 11 349206!
[    9.735107] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0096a58c: 0x8cc2 instead
[    9.744687] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0096a590: 0x801d instead
[    9.754180] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0096a594: 0x1070 instead
[    9.763659] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0096a598: 0x8040 instead
[    9.773134] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0096a59c: 0x0060 instead
[    9.782662] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0096a5a0: 0xc076 instead
[    9.792149] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0096a5a8: 0x444e instead
[    9.801627] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0096a5ac: 0xb05d instead
[    9.811102] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0096a5b0: 0xb0dd instead
[    9.820577] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0096a5b4: 0xb0dd instead
[    9.830050] jffs2: Further such events for this erase block will not be printed
[    9.852153] sun4i_lradc_irq voltage = 12 380952!
[   10.351966] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a4a4d0: 0x8cc2 instead
[   10.361544] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a4a4d4: 0x800b instead
[   10.371036] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a4a4d8: 0x1833 instead
[   10.380515] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a4a4dc: 0x8047 instead
[   10.389990] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a4a4e0: 0x806c instead
[   10.399466] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a4a4e4: 0xc076 instead
[   10.408984] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a4a4ec: 0x1826 instead
[   10.418466] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a4a4f0: 0xb05d instead
[   10.427943] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a4a4f4: 0xb0dd instead
[   10.437418] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a4a4f8: 0xb0dd instead
[   10.446891] jffs2: Further such events for this erase block will not be printed
[   10.469312] sun4i_lradc_irq voltage = 11 349206!
[   10.545353] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a7013c: 0x8cc2 instead
[   10.554920] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a70140: 0x8005 instead
[   10.564441] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a70144: 0xec20 instead
[   10.574039] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a70148: 0x8048 instead
[   10.583524] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a7014c: 0x005e instead
[   10.593002] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a70150: 0xc064 instead
[   10.602576] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a70158: 0x3326 instead
[   10.612061] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a7015c: 0xb05d instead
[   10.621584] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a70160: 0xb0dd instead
[   10.631105] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a70164: 0xb0dd instead
[   10.640609] jffs2: Further such events for this erase block will not be printed
[   10.660710] sun4i_lradc_irq voltage = 11 349206!
[   10.891651] jffs2: ofs 0x00ad52e4 has already been seen. Skipping
[   10.900218] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00ad62dc: 0x7389 instead
[   10.909783] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00ad62e0: 0x9cfc instead
[   10.919272] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00ad62e4: 0x355a instead
[   10.928750] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00ad62e8: 0x3d98 instead
[   10.938224] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00ad62ec: 0x29ab instead
[   10.947699] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00ad62f0: 0xd2af instead
[   10.957174] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00ad62f4: 0xa8fd instead
[   10.966648] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00ad62f8: 0xd99d instead
[   10.976120] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00ad62fc: 0x0cb4 instead
[   10.985584] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00ad6300: 0x6ed4 instead
[   10.995059] jffs2: Further such events for this erase block will not be printed
[   11.016160] sun4i_lradc_irq voltage = 11 349206!
[   11.084405] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00af8434: 0x8cc2 instead
[   11.093973] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00af8438: 0x801e instead
[   11.103465] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00af843c: 0x3f1e instead
[   11.112943] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00af8440: 0x00c9 instead
[   11.122417] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00af8444: 0x8150 instead
[   11.131919] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00af8448: 0xc076 instead
[   11.141400] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00af8450: 0x326c instead
[   11.150875] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00af8454: 0xb05d instead
[   11.160350] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00af8458: 0xb0dd instead
[   11.169824] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00af845c: 0xb0dd instead
[   11.179296] jffs2: Further such events for this erase block will not be printed
[   11.199746] sun4i_lradc_irq voltage = 11 349206!
[   11.448925] jffs2: Empty flash at 0x00b68490 ends at 0x00b684b0
[   11.454903] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00b684b0: 0x61bb instead
[   11.464441] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00b684b4: 0x61bb instead
[   11.473931] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00b684b8: 0x61bb instead
[   11.483410] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00b684bc: 0x5500 instead
[   11.492886] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00b684c0: 0x00ec instead
[   11.502363] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00b684c4: 0x0100 instead
[   11.511840] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00b684c8: 0x0006 instead
[   11.521315] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00b684cc: 0x06d2 instead
[   11.530790] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00b684d0: 0x588c instead
[   11.540265] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00b684d4: 0x5e78 instead
[   11.549737] jffs2: Further such events for this erase block will not be printed
[   11.570823] sun4i_lradc_irq voltage = 11 349206!
[   21.166671] VFS: Mounted root (jffs2 filesystem) on device 31:3.
[   21.174228] devtmpfs: mounted
[   21.178493] Freeing unused kernel memory: 1024K
[   21.198403] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x0c22b8. {8cc2,f080,00008017,79a2fc58}
[   21.209223] sun4i_lradc_irq voltage = 63 2000000!
[   21.237691] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x0bd924. {8cc2,7081,00808000,9aff9c12}
[   21.252289] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x0bc87c. {8cc2,7081,00808006,bf14c34e}
[   21.263944] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x0bc650. {8cc2,7081,00808015,7d38bb3f}
[   21.279719] jffs2: notice: (1) jffs2_get_inode_nodes: Wrong magic bitmask 0x0000 in node header at 0x0baf08.
[   21.296626] jffs2: notice: (1) jffs2_get_inode_nodes: Wrong magic bitmask 0x0000 in node header at 0x0b91ec.
[   21.320378] sun4i_lradc_irq voltage = 18 571428!
[   21.336448] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x0b1874. {8cc2,7081,00800009,bba9602a}
[   21.349071] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x0b1570: read 0xffffffff, calculated 0xab8eb808
[   21.367616] jffs2: notice: (1) jffs2_get_inode_nodes: Wrong magic bitmask 0x0000 in node header at 0x0af1a8.
[   21.390688] sun4i_lradc_irq voltage = 19 603174!
[   21.405915] jffs2: notice: (1) jffs2_get_inode_nodes: Wrong magic bitmask 0x0000 in node header at 0x0a7d38.
[   21.424060] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x0a59d0: read 0xffffffff, calculated 0x130fc27d
[   21.438588] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x0a4a24: read 0xcc2a58fd, calculated 0x15ff82a4
[   21.464903] sun4i_lradc_irq voltage = 19 603174!
[   21.480640] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x09cb44. {8cc2,7081,00800022,cc9a4815}
[   21.496574] jffs2: notice: (1) jffs2_get_inode_nodes: Wrong magic bitmask 0x0000 in node header at 0x09b110.
[   21.512135] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x0993e4: read 0x832f4800, calculated 0x3c499f22
[   21.529915] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x097160: read 0xffffffff, calculated 0x546c62b3
[   21.549617] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x093bb4: read 0x364fbc11, calculated 0x8eac1e0f
[   21.560434] sun4i_lradc_irq voltage = 11 349206!
[   21.571902] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x09167c: read 0xffffffff, calculated 0x458ca19a
[   21.586778] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x090534. {8cc2,7081,00800013,040d5751}
[   21.597730] jffs2: Node totlen on flash (0xffffffff) != totlen from node ref (0x00000128)
[   21.613546] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x08c584. {ffff,ffff,ffffffff,ffffffff}
[   21.624368] sun4i_lradc_irq voltage = 11 349206!
[   21.639070] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x0889b8: read 0xe94d79a4, calculated 0xe384ba1c
[   21.670470] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x08014c: read 0x8cb9a0ca, calculated 0x1b9ef8b3
[   21.683541] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x07fbf8. {8cc2,7081,0080001e,1bdf8c2c}
[   21.698842] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x07e900: read 0xffffffff, calculated 0x4aaafcd0
[   21.709662] sun4i_lradc_irq voltage = 11 349206!
[   21.716999] jffs2: notice: (1) jffs2_get_inode_nodes: Wrong magic bitmask 0x0000 in node header at 0x07e2a0.
[   21.750331] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x074644. {8cc2,7081,0080001b,ac81fc1e}
[   21.769320] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x0718a0: read 0xc2d01fcc, calculated 0xe02cc193
[   21.797681] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x06a924. {8cc2,7081,0080800c,5029a32a}
[   21.810189] jffs2: notice: (58) read_dnode: node CRC failed on dnode at 0x99000c: read 0xdc2680e2, calculated 0xe8254409
[   21.835978] sun4i_lradc_irq voltage = 11 349206!
[   21.870807] jffs2: notice: (1) jffs2_get_inode_nodes: Wrong magic bitmask 0x0000 in node header at 0x05abd4.
[   21.882394] jffs2: notice: (58) read_dnode: node CRC failed on dnode at 0x98fd58: read 0x91ddcb3a, calculated 0xde2cd5b3
[   21.897885] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x0589f8: read 0xffffffff, calculated 0xa0cf9bd0
[   21.908695] sun4i_lradc_irq voltage = 11 349206!
[   21.921175] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x055c20: read 0xf52dd8d2, calculated 0xf4b6f1b6
[   21.936623] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x05450c. {8cc2,7081,0080001a,7985185b}
[   21.951828] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x053018. {8cc2,7081,0080801c,00b0f435}
[   21.966514] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x05202c: read 0x64bda6ee, calculated 0x32f0bdcd
[   21.990448] jffs2: notice: (1) jffs2_get_inode_nodes: Wrong magic bitmask 0x0000 in node header at 0x04c9cc.
[   22.003668] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x04be78: read 0x42d6f509, calculated 0xddee9636
[   22.014645] jffs2: Node totlen on flash (0x0080001a) != totlen from node ref (0x00000134)
[   22.027522] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x04a870. {8cc2,7081,00800022,cc9a4815}
[   22.038329] sun4i_lradc_irq voltage = 11 349206!
[   22.049394] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x048a20: read 0xffffffff, calculated 0x77d66a2a
[   22.079147] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x040d30: read 0xffffffff, calculated 0x3dad47b3
[   22.120023] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x033ee8: read 0xaaba1f6e, calculated 0x4cf48d18
[   22.137956] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x03190c. {ffff,ffff,ffffffff,ffffffff}
[   22.156859] jffs2: notice: (1) jffs2_get_inode_nodes: Wrong magic bitmask 0x0000 in node header at 0x02eb58.
[   22.172579] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x02cd68. {8cc2,7081,00808013,58d3e463}
[   22.186059] jffs2: notice: (1) jffs2_get_inode_nodes: Wrong magic bitmask 0x0000 in node header at 0x02c6e0.
[   22.199396] jffs2: notice: (1) jffs2_get_inode_nodes: Wrong magic bitmask 0x0000 in node header at 0x02b970.
[   22.216265] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x0292d8: read 0x9234705, calculated 0xa4361300
[   22.244071] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x022100. {8cc2,7081,0080801f,9205db5b}
[   22.263529] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x01ed8c. {8cc2,7081,0080801e,47013f1e}
[   22.280973] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x01ca5c. {8cc2,7081,00000074,4fa52e50}
[   22.298746] jffs2: notice: (1) jffs2_get_inode_nodes: Wrong magic bitmask 0x0000 in node header at 0x01a7f0.
[   22.315543] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x017f8c: read 0xffffffff, calculated 0xb9b2a6f
[   22.341021] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x011d98. {8cc2,7081,00800004,a47bbb57}
[   22.353518] jffs2: notice: (58) read_dnode: node CRC failed on dnode at 0x98da0c: read 0xffffffff, calculated 0xf5adcc23
[   22.374649] jffs2: notice: (1) jffs2_get_inode_nodes: Wrong magic bitmask 0x0000 in node header at 0x00cfb8.
[   22.384509] sun4i_lradc_irq voltage = 11 349206!
[   22.389855] jffs2: notice: (58) jffs2_get_inode_nodes: Node header CRC failed at 0x98d9a4. {8cc2,7081,00000034,b989f54d}
[   22.410562] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x0014a0: read 0xb688f34b, calculated 0xb6a738b1
[   22.421380] sun4i_lradc_irq voltage = 11 349206!
[   22.428653] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x0010e8: read 0xffffffff, calculated 0x7ff83b64
[   22.444865] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x000bf740: read 0xdb96ecb4, calculated 0x56ec5c97.
[   22.467446] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x000bbda8: read 0x34f3fd34, calculated 0x4d70874c.
[   22.481903] jffs2: notice: (58) jffs2_get_inode_nodes: Node header CRC failed at 0x98d340. {8cc2,7081,0000003f,83b0716c}
[   22.501614] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x000b8200: read 0x53c1e86f, calculated 0xc1971dc5.
[   22.513377] sun4i_lradc_irq voltage = 11 349206!
[   22.524590] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x000b6560: read 0x74910c4e, calculated 0xe85e87ac.
[   22.576844] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x000a77d8: read 0x28b2839c, calculated 0x4d70874c.
[   22.605463] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x000a1b20: read 0x7fdacfd7, calculated 0xb6e18d66.
[   22.668317] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x0008d384: read 0xda91a43b, calculated 0x1ac79bbe.
[   22.682797] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x0008cc74: read 0xb1a8f672, calculated 0xda628297.
[   22.707034] sun4i_lradc_irq voltage = 12 380952!
[   22.724331] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x0008422c: read 0xec7d2b2e, calculated 0xa499524e.
[   22.740679] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x00083194: read 0x867943db, calculated 0x625412b7.
[   22.803521] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x0006feac: read 0x6c5de4f, calculated 0x12d14834.
[   22.816698] jffs2: notice: (58) read_dnode: node CRC failed on dnode at 0x98c3e4: read 0x6f78613a, calculated 0xe94edb4
[   22.836082] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x0006ca08: read 0x6eaa6145, calculated 0xd65d9a2.
[   22.847751] sun4i_lradc_irq voltage = 11 349206!
[   22.867687] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x00067550: read 0x59a41497, calculated 0xd437ce4.
[   22.883457] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x00066744: read 0x877a125d, calculated 0xf2ae01c7.
[   22.921356] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x0005d50c: read 0x97040f2b, calculated 0xa63a84b5.
[   22.938232] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x0005c130: read 0xa9597bed, calculated 0xbe2612ff.
[   22.996379] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x0004dd40: read 0xf0a687d8, calculated 0x1d4fc3eb.
[   23.042928] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x00040f90: read 0xffa059d9, calculated 0x8c26d8be.
[   23.060183] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x0003f608: read 0x9d07b33b, calculated 0x7510aefe.
[   23.090987] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x00038c38: read 0xb45f0203, calculated 0xd526385c.
[   23.107204] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x00037c54: read 0xbcba8ac9, calculated 0x52f7fe23.
[   23.121408] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x00037670: read 0xe4202fa9, calculated 0xf0f0a300.
[   23.147204] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x00032b48: read 0xbe32d3e2, calculated 0x93537575.
[   23.158967] sun4i_lradc_irq voltage = 11 349206!
[   23.236949] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x00016c38: read 0xdf64cb72, calculated 0xe16e94fe.
[   23.258570] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x00013b20: read 0xf1550a82, calculated 0x57d49e3c.
[   23.281627] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x0000ff00: read 0xa4fcc682, calculated 0xbe2612ff.
[   23.300409] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x0000de24: read 0xda9799da, calculated 0x4de9cd9d.
[   23.315847] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x0000d218: read 0x5fa6d049, calculated 0xfb10b256.
[   23.352026] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x16cfdc: read 0x8064dd7f, calculated 0x88614930
[   23.367019] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x16c110. {8cc2,7081,0000807e,fc46fd06}
[   23.385397] jffs2: notice: (1) jffs2_get_inode_nodes: Wrong magic bitmask 0x0000 in node header at 0x16a060.
[   23.403836] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x168200: read 0xffffffff, calculated 0x47d41ade
[   23.418612] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x167300: read 0x5b92c6fc, calculated 0x275e1e
[   23.443569] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x161c4c: read 0x51e468fc, calculated 0x85c3f6ce
[   23.458563] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x160934: read 0xc6bd9075, calculated 0x8da3750e
[   23.472386] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x15fed4: read 0xffffffff, calculated 0x4f8caa0f
[   23.486863] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x15ef68: read 0xdeb3560b, calculated 0x15ae7ec9
[   23.501622] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x15dd44. {8cc2,7081,00800022,cc9a4815}
[   23.529621] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x153d88. {8cc2,7081,00800022,cc9a4815}
[   23.547065] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x151454. {8cc2,7081,00800022,cc9a4815}
[   23.558033] jffs2: Node totlen on flash (0x00800022) != totlen from node ref (0x00000144)
[   23.581991] sun4i_lradc_irq voltage = 11 349206!
[   23.600991] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x00166ce4: read 0xc534a724, calculated 0xccd25876.
[   23.626422] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x001624e4: read 0xfb73bffb, calculated 0xf33e2d79.
[   23.680072] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x001501c4: read 0x83fcf0ef, calculated 0xf33e2d79.
[   23.718497] jffs2: Data CRC b62e8215 != calculated CRC 00000000 for node at 001516dc
[   23.727064] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000007
[   23.727064]
[   23.736201] CPU: 0 PID: 1 Comm: init Not tainted 4.13.16-licheepi-zero #17
[   23.743065] Hardware name: Allwinner sun8i Family
[   23.747804] [<c010e5cc>] (unwind_backtrace) from [<c010b2b0>] (show_stack+0x10/0x14)
[   23.755551] [<c010b2b0>] (show_stack) from [<c067897c>] (dump_stack+0x84/0x98)
[   23.762775] [<c067897c>] (dump_stack) from [<c011b788>] (panic+0xdc/0x248)
[   23.769649] [<c011b788>] (panic) from [<c011e2f4>] (do_exit+0xa68/0xa98)
[   23.776346] [<c011e2f4>] (do_exit) from [<c011f170>] (do_group_exit+0x3c/0xd0)
[   23.783562] [<c011f170>] (do_group_exit) from [<c0128e7c>] (get_signal+0x284/0x5cc)
[   23.791212] [<c0128e7c>] (get_signal) from [<c010a76c>] (do_signal+0xc4/0x420)
[   23.798430] [<c010a76c>] (do_signal) from [<c010ac6c>] (do_work_pending+0x94/0xa4)
[   23.805994] [<c010ac6c>] (do_work_pending) from [<c01075d4>] (slow_work_pending+0xc/0x20)
[   23.814174] Rebooting in 5 seconds..
#6 2018-11-26 08:18:36
已发帖子: 9,342
Re: zero v3s mx25l256 32MB flash linux系统无法识别
你的 jffs2 文件系统有问题, 内核load不起来你的jffs2
楼主 #7 2018-11-26 10:31:50
billnie
已发帖子: 47
总空间是32M-1M-64K-4M=0x1AF0000
mkfs.jffs2 -s 0x100 -e 0x10000 -p 0x1AF0000 -d rootfs/ -o jffs2.img
mkfs.jffs2 我是系统带的,没有特别去指定,这个不对吗?晕哥
#8 2018-11-26 10:37:45
已发帖子: 9,342
billnie 说:
先用前面 16M 吧, 方便排除问题。
楼主 #9 2018-11-27 21:59:58
billnie
已发帖子: 47
[    1.493757]   #0: V3s Audio Codec
[    1.512589] sun4i_lradc_irq voltage = 11 349206!
[    1.523048] random: crng init done
[    1.532108] sun4i_lradc_irq voltage = 11 349206!
[    1.594310] jffs2: jffs2_scan_inode_node(): CRC failed on node at 0x00023180: Read 0xa0124471, calculated 0x208cb662
[    1.604896] jffs2: Dirty space 0x808020 larger then free_size 0xce80 (wasted 0x0)
[    1.612419] ------------[ cut here ]------------
[    1.617033] kernel BUG at fs/jffs2/nodelist.c:670!
[    1.621816] Internal error: Oops - BUG: 0 [#1] SMP ARM
[    1.626947] Modules linked in:
[    1.630005] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.13.16-licheepi-zero #18
[    1.637300] Hardware name: Allwinner sun8i Family
[    1.641998] task: c382c000 task.stack: c3830000
[    1.646535] PC is at jffs2_scan_dirty_space+0xc0/0xc4
[    1.651582] LR is at jffs2_scan_dirty_space+0xc0/0xc4
[    1.656625] pc : [<c02fd0e0>]    lr : [<c02fd0e0>]    psr: 60000013
[    1.662881] sp : c3831cd8  ip : 00000000  fp : c381c000
[    1.668097] r10: 00001000  r9 : c3bee400  r8 : 00023180
[    1.673313] r7 : c381c000  r6 : 00020000  r5 : 0000008b  r4 : c3bf8068
[    1.679830] r3 : c0a0c418  r2 : c0a0c418  r1 : 03596000  r0 : 00000045
[    1.686348] Flags: nZCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment none
[    1.693472] Control: 10c5387d  Table: 4000406a  DAC: 00000051
[    1.699208] Process swapper/0 (pid: 1, stack limit = 0xc3830210)
[    1.705205] Stack: (0xc3831cd8 to 0xc3832000)
[    1.709557] 1cc0:                                                       c381c000 c0302930
[    1.717725] 1ce0: c07f27dc c3bf8068 0000008b c030289c 208cb662 c3831d48 c381c000 00000000
[    1.725892] 1d00: c3eef040 00023180 00000068 00000002 00001000 0000000a 00000000 00000000
[    1.734059] 1d20: 0000e002 00001985 c0a6f9b8 ffffc000 c07f29b4 c3bf6030 0000000d c381c000
[    1.742226] 1d40: 00000000 00001000 00001000 e0021985 0000013f c3bee400 c3bee400 c3bee4cc
[    1.750394] 1d60: c3bee400 00000000 00000001 01f00003 00008000 00000001 c3bf4000 c0304d1c
[    1.758561] 1d80: c0704a70 00000000 c0a65e5c 014280c0 3b9aca00 00000000 c382b588 c3bee400
[    1.766729] 1da0: 00010000 c3be4400 01af0000 01f00003 00008000 00000001 c3bf4000 c0307208
[    1.774897] 1dc0: c3be4400 00008000 c3b79400 00000000 01f00003 00008000 00000001 c04592ec
[    1.783064] 1de0: c3b79400 c04586a4 c3bec780 c3bec780 00008000 00000000 c0a106c4 c045942c
[    1.791232] 1e00: c0307730 0000000d c0a6caa8 c0a6caa8 c03073c4 c3bec780 00008000 c0a106c4
[    1.799399] 1e20: c0a106c4 c03073dc c0307730 c0214a60 00000000 c01f92f8 c3bec780 00008000
[    1.807567] 1e40: c3bcf300 c3bec780 00008000 c0a106c4 00000000 c0214cec c0a106c4 00000000
[    1.815734] 1e60: c3bec780 c3bec740 00000020 c0217af8 00000000 00000051 c3805d10 c340d4c8
[    1.823901] 1e80: 0000000a 00000000 0000000a c01c4cd0 0000000a c3bec780 c3bec740 00000000
[    1.832069] 1ea0: c07d40d8 00008000 00008000 c07d40d4 c3bf4000 c0218900 00000000 c0a3db64
[    1.840236] 1ec0: c3bf4000 c3f71e80 c3bf4006 c07d40d8 c093785c c0901148 00000000 ffffff9c
[    1.848404] 1ee0: c3481000 00006000 00006180 00000000 ffffff9c c0204e8c c3805d10 c340d2a8
[    1.856571] 1f00: 00000000 01f00003 c0a0668c c0a3db64 c0937838 000000c4 00000008 c093783c
[    1.864739] 1f20: c3ef12c0 c09013c4 000000c4 c093785c c093786c 00000008 c0a3db64 c093786c
[    1.872906] 1f40: 00000008 c0937838 000000c4 00000008 c093783c c090151c c0937838 000000c4
[    1.881074] 1f60: 00000008 c0a3db40 c0a3db40 c0900e20 00000007 00000007 00000000 c09005ac
[    1.889240] 1f80: 00000000 00000000 c068ceac 00000000 00000000 00000000 00000000 00000000
[    1.897407] 1fa0: 00000000 c068ceb4 00000000 c0107638 00000000 00000000 00000000 00000000
[    1.905574] 1fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.913740] 1fe0: 00000000 00000000 00000000 00000000 00000013 00000000 2215a9e0 000000c9
[    1.921930] [<c02fd0e0>] (jffs2_scan_dirty_space) from [<c030289c>] (jffs2_scan_medium+0xe30/0x100c)
[    1.931059] [<c030289c>] (jffs2_scan_medium) from [<c0304d1c>] (jffs2_do_mount_fs+0x164/0x754)
[    1.939665] [<c0304d1c>] (jffs2_do_mount_fs) from [<c0307208>] (jffs2_do_fill_super+0xc4/0x234)
[    1.948360] [<c0307208>] (jffs2_do_fill_super) from [<c04592ec>] (mount_mtd_aux.constprop.0+0x80/0xc8)
[    1.957660] [<c04592ec>] (mount_mtd_aux.constprop.0) from [<c045942c>] (mount_mtd+0xf8/0x158)
[    1.966178] [<c045942c>] (mount_mtd) from [<c03073dc>] (jffs2_mount+0x18/0x20)
[    1.973398] [<c03073dc>] (jffs2_mount) from [<c01f92f8>] (mount_fs+0x14/0xa4)
[    1.980533] [<c01f92f8>] (mount_fs) from [<c0214cec>] (vfs_kern_mount+0x48/0x100)
[    1.988013] [<c0214cec>] (vfs_kern_mount) from [<c0217af8>] (do_mount+0x154/0xbc4)
[    1.995577] [<c0217af8>] (do_mount) from [<c0218900>] (SyS_mount+0x8c/0xb4)
[    2.002539] [<c0218900>] (SyS_mount) from [<c0901148>] (mount_block_root+0x100/0x25c)
[    2.010365] [<c0901148>] (mount_block_root) from [<c09013c4>] (mount_root+0x120/0x128)
[    2.018276] [<c09013c4>] (mount_root) from [<c090151c>] (prepare_namespace+0x150/0x194)
[    2.026272] [<c090151c>] (prepare_namespace) from [<c0900e20>] (kernel_init_freeable+0x1bc/0x1cc)
[    2.035140] [<c0900e20>] (kernel_init_freeable) from [<c068ceb4>] (kernel_init+0x8/0x108)
[    2.043316] [<c068ceb4>] (kernel_init) from [<c0107638>] (ret_from_fork+0x14/0x3c)
[    2.050880] Code: e591301c e34c007f e1a0100c ebf98aff (e7f001f2)
[    2.056968] ---[ end trace 97129af179694986 ]---
[    2.061746] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[    2.061746]
[    2.070884] Rebooting in 5 seconds..
#10 2018-11-27 22:03:09
已发帖子: 9,342
https://whycan.cn/t_491.html#p1295
1. 把你制作的jffs2文件系统挂到ubuntu试一试.
2. 从TF卡启动, 用TF卡第二个分区ext4作为根文件系统登录进系统,再手动挂载 jffs2 分区, 看是什么情况.
楼主 #11 2018-11-27 22:36:34
billnie
已发帖子: 47
我使用tf卡启动 v3s,然后在v3s上挂载 mtdblock3 发现能挂载成功,文件也是对,就是spi中启动时不成功,不知道 为啥
# mount -t jffs2 /dev/mtdblock3 /mnt/c
# cd /mnt/cc
# ls
bin      dev      etc      lib      lib32    linuxrc  media    mnt      opt      proc     root     run      sbin     sys      tmp      usr      var
#12 2018-11-27 22:38:37
已发帖子: 9,342
再不行, 试了一下我这个固件吧:
V3s_W25Q256_MX25L256_Qt5_9_1.7z
很久以前打包的, 不一定完全可以.
楼主 #13 2018-11-27 23:17:59
billnie
已发帖子: 47
卡在start kernel
U-Boot 2017.01-rc2-00073-gdd6e874-dirty (Jul 15 2018 - 23:15:30 +0800) Allwinner Technology
Model: Lichee Pi Zero
DRAM:  64 MiB
MMC:   SUNXI SD/MMC: 0
SF: Detected mx25l25635f with page size 256 Bytes, erase size 64 KiB, total 32 MiB
In:    serial@01c28000
Out:   serial@01c28000
Err:   serial@01c28000
Net:   No ethernet found.
No controllers found
device 0 offset 0x110000, size 0x600000
SF: 6291456 bytes @ 0x110000 Read: OK
## Flattened Device Tree blob at 41000000
   Booting using the fdt blob at 0x41000000
   Loading Device Tree to 42dfa000, end 42dffd8e ... OK
#14 2018-11-27 23:22:52
已发帖子: 9,342
这。。。。我明天帮你试一试
