楼主 #1 2018-11-28 11:07:14
pqfeng
已发帖子: 129
请教一下,为什么我没有用到dock,却会报dock错误。
CC      lib/random32.o
  DTC     arch/arm/boot/dts/sun8i-v3s-licheepi-zero-dock.dtb
  AR      arch/arm/lib/lib.a
Error: arch/arm/boot/dts/sun8i-v3s-licheepi-zero-dock.dts:62.1-7 Label or path codec not found
Error: arch/arm/boot/dts/sun8i-v3s-licheepi-zero-dock.dts:82.1-7 Label or path lradc not found
FATAL ERROR: Syntax error parsing input tree
scripts/Makefile.lib:325: recipe for target 'arch/arm/boot/dts/sun8i-v3s-licheepi-zero-dock.dtb' failed
make[1]: *** [arch/arm/boot/dts/sun8i-v3s-licheepi-zero-dock.dtb] Error 1
arch/arm/Makefile:346: recipe for target 'dtbs' failed
make: *** [dtbs] Error 2
make: *** Waiting for unfinished jobs....
  EXPORTS arch/arm/lib/lib-ksyms.o
  CC      lib/bust_spinlocks.o
  CC      fs/namei.o
#2 2018-11-28 11:15:39
lilo
已发帖子: 215
Re: 请教一下,为什么我没有用到dock,却会报dock错误。
你是说 docker ? 这个是说 arch/arm/boot/dts/sun8i-v3s-licheepi-zero-dock.dts 62 行出现语法错误吧,
你是不是改过这个文件?
