log 日志如下:
为什么打印中没有显示jffs2的那个表??加载不成功啊。
sunxi_display.monitor = 3
sunxi_display.depth = 18
sunxi_display.fb_size = 2457600,1024, 600
Setting up a 1024x600 lcd console (overscan 0x0)
gd->bd->bi_dram[0].start = 1073741824, 67108864, 2457600
dotclock: 48000kHz = 48000kHz: (1 * 3MHz * 96) / 6
In: serial@01c28800
Out: serial@01c28800
Err: serial@01c28800
Net: phy interface0
eth0: ethernet@1c30000
No controllers found
Loading Device Tree to 42dfa000, end 42dffc6a ... OK
[ 0.000000] Linux version 4.13.16-licheepi-zero+ (pqfeng@ubuntu) (gcc version 4.9.2 20140904 (prerelease) (crosstool-NG linaro-1.13.1-4.9-2014.09 - Linaro GCC 4.9-2014.09)) #66 SMP Wed Nov 28 16:42:23 CST 2018
[ 0.000000] OF: fdt: Machine model: Lichee Pi Zero
[ 0.000000] percpu: Embedded 16 pages/cpu @c3d07000 s33920 r8192 d23424 u65536
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 15660
[ 0.000000] Kernel command line: console=ttyS2,115200 earlyprintk panic=5 rootwait mtdparts=spi32766.0:1M(uboot)ro,64k(dtb)ro,4M(kernel)ro,-(rootfs) root=31:03 rw rootfstype=jffs2
[ 0.000000] Memory: 52684K/63136K available (6144K kernel code, 218K rwdata, 1500K rodata, 1024K init, 266K bss, 10452K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] vmalloc : 0xc4000000 - 0xff800000 ( 952 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc3da8000 ( 61 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0700000 (7136 kB)
[ 0.000000] .init : 0xc0900000 - 0xc0a00000 (1024 kB)
[ 0.000000] .data : 0xc0a00000 - 0xc0a36b40 ( 219 kB)
[ 0.000000] .bss : 0xc0a3db44 - 0xc0a8037c ( 267 kB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU event tracing is enabled.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
[ 0.000008] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000019] Switching to timer-based delay loop, resolution 41ns
[ 0.000179] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000309] 44444444444444444444444444444444444444444444444
[ 0.000408] Console: colour dummy device 80x30
[ 0.000440] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000455] pid_max: default: 32768 minimum: 301
[ 0.000501] 5555555555555555555555555555555555555555
[ 0.000595] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000609] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001211] 6666666666666666666666666666666666666666666666
[ 0.001232] CPU: Testing write buffer coherency: ok
[ 0.001269] 7777777777777777777777777777777777777777777777
[ 0.001590] /cpus/cpu@0 missing clock-frequency property
[ 0.001615] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002061] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.002238] Hierarchical SRCU implementation.
[ 0.002750] smp: Bringing up secondary CPUs ...
[ 0.002764] smp: Brought up 1 node, 1 CPU
[ 0.002773] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.002781] CPU: All CPU(s) started in SVC mode.
[ 0.003554] devtmpfs: initialized
[ 0.006649] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.006920] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.006951] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.007123] pinctrl core: initialized pinctrl subsystem
[ 0.008023] random: get_random_u32 called from bucket_table_alloc+0xf0/0x240 with crng_init=0
[ 0.008165] NET: Registered protocol family 16
[ 0.008659] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.009824] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.009846] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.022272] SCSI subsystem initialized
[ 0.022561] usbcore: registered new interface driver usbfs
[ 0.022629] usbcore: registered new interface driver hub
[ 0.022726] usbcore: registered new device driver usb
[ 0.022948] Linux video capture interface: v2.00
[ 0.023010] pps_core: LinuxPPS API ver. 1 registered
[ 0.023017] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.023040] PTP clock support registered
[ 0.023256] Advanced Linux Sound Architecture Driver Initialized.
[ 0.025114] clocksource: Switched to clocksource arch_sys_counter
[ 0.025630] ggggggggggggggggggggggggggggggggggggg
[ 0.026084] fffffffffffffffffffffffffffffffffffff
[ 0.036261] NET: Registered protocol family 2
[ 0.036875] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.036907] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.036930] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.037062] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.037110] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.037320] NET: Registered protocol family 1
[ 0.037912] RPC: Registered named UNIX socket transport module.
[ 0.037931] RPC: Registered udp transport module.
[ 0.037937] RPC: Registered tcp transport module.
[ 0.037943] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.039849] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.049119] NFS: Registering the id_resolver key type
[ 0.049173] Key type id_resolver registered
[ 0.049180] Key type id_legacy registered
[ 0.049199] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.049235] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.050696] random: fast init done
[ 0.053518] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.053541] io scheduler noop registered
[ 0.053548] io scheduler deadline registered
[ 0.053836] io scheduler cfq registered (default)
[ 0.053847] io scheduler mq-deadline registered
[ 0.053854] io scheduler kyber registered
[ 0.058356] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.126995] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.150661] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 31, base_baud = 1500000) is a U6_16550A
[ 0.172256] 1c28800.serial: ttyS2 at MMIO 0x1c28800 (irq = 32, base_baud = 1500000) is a U6_16550A
[ 0.812766] console [ttyS2] enabled
[ 0.819690] m25p80 spi0.0: mx25l12805d (16384 Kbytes)
[ 0.824773] spi0.0: parser cmdlinepart: 0
[ 0.828863] spi0.0: parser ofpart: 0
[ 0.833451] libphy: Fixed MDIO Bus: probed
[ 0.838117] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[ 0.843910] dwmac-sun8i 1c30000.ethernet: No regulator found
[ 0.849714] dwmac-sun8i 1c30000.ethernet: Will use internal PHY
[ 0.855746] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 148000 (expect 38000)
[ 0.865200] aaaaaaaaaaaaaaaaaaaaa
[ 0.868539] bbbbbbbbbbbbbbbbbbbbb
[ 0.871873] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[ 0.877548] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[ 0.884762] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[ 0.890428] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[ 0.897653] dwmac-sun8i 1c30000.ethernet: COE Type 2
[ 0.902612] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[ 0.909602] libphy: stmmac: probed
[ 0.914832] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.921495] ehci-platform: EHCI generic platform driver
[ 0.926910] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.933122] ohci-platform: OHCI generic platform driver
[ 0.939625] sun6i-rtc 1c20400.rtc: rtc core: registered rtc-sun6i as rtc0
[ 0.946517] sun6i-rtc 1c20400.rtc: RTC enabled
[ 0.951074] i2c /dev entries driver
[ 0.955563] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.015162] sunxi-mmc 1c0f000.mmc: base:0xc406d000 irq:23
[ 1.021604] usbcore: registered new interface driver usbhid
[ 1.027263] usbhid: USB HID core driver
[ 1.032946] NET: Registered protocol family 17
[ 1.037657] Key type dns_resolver registered
[ 1.042085] Registering SWP/SWPB emulation handler
[ 1.052757] simple-framebuffer 43da8000.framebuffer: framebuffer at 0x43da8000, 0x258000 bytes, mapped to 0xc4500000
[ 1.063406] simple-framebuffer 43da8000.framebuffer: format=x8r8g8b8, mode=1024x600x32, linelength=4096
[ 1.085479] Console: switching to colour frame buffer device 128x37
[ 1.101379] simple-framebuffer 43da8000.framebuffer: fb0: simplefb registered!
[ 1.109988] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 1.121410] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.127268] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 1.136497] hub 1-0:1.0: USB hub found
[ 1.140369] hub 1-0:1.0: 1 port detected
[ 1.148933] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01 00:28:41 UTC (1721)
[ 1.157428] vcc3v0: disabling
[ 1.160402] vcc5v0: disabling
[ 1.163366] ALSA device list:
[ 1.166389] No soundcards found.
[ 1.170731] VFS: Cannot open root device "31:03" or unknown-block(31,3): error -19
[ 1.178400] Please append a correct "root=" boot option; here are the available partitions:
[ 1.186776] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,3)
[ 1.195122] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.13.16-licheepi-zero+ #66
[ 1.202504] Hardware name: Allwinner sun8i Family
[ 1.207244] [<c010e5d0>] (unwind_backtrace) from [<c010b358>] (show_stack+0x10/0x14)
[ 1.214989] [<c010b358>] (show_stack) from [<c068c234>] (dump_stack+0x94/0xa8)
[ 1.222211] [<c068c234>] (dump_stack) from [<c011b594>] (panic+0xdc/0x254)
[ 1.229089] [<c011b594>] (panic) from [<c0901120>] (mount_block_root+0x204/0x2c8)
[ 1.236567] [<c0901120>] (mount_block_root) from [<c09013ac>] (prepare_namespace+0x14c/0x190)
[ 1.245085] [<c09013ac>] (prepare_namespace) from [<c0900e00>] (kernel_init_freeable+0x1d0/0x1e0)
[ 1.253950] [<c0900e00>] (kernel_init_freeable) from [<c069ef88>] (kernel_init+0x8/0x110)
[ 1.262122] [<c069ef88>] (kernel_init) from [<c01076b8>] (ret_from_fork+0x14/0x3c)
[ 1.269695] Rebooting in 5 seconds..离线
我看了一下,但问题还是没有解决。它把主频从50M改成16M,我改了,但没有任何变化
[ 0.053682] io scheduler noop registered
[ 0.053689] io scheduler deadline registered
[ 0.053974] io scheduler cfq registered (default)
[ 0.053985] io scheduler mq-deadline registered
[ 0.053991] io scheduler kyber registered
[ 0.058525] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.127321] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.150999] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 31, base_baud = 1500000) is a U6_16550A
[ 0.172606] 1c28800.serial: ttyS2 at MMIO 0x1c28800 (irq = 32, base_baud = 1500000) is a U6_16550A
[ 0.813121] console [ttyS2] enabled
[ 0.820066] m25p80 spi0.0: mx25l12805d (16384 Kbytes)
[ 0.825236] spi0.0: parser cmdlinepart: 0
[ 0.829247] spi0.0: parser ofpart: 0
[ 0.833819] libphy: Fixed MDIO Bus: probed
[ 0.838487] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[ 0.844283] dwmac-sun8i 1c30000.ethernet: No regulator found
[ 0.850082] dwmac-sun8i 1c30000.ethernet: Will use internal PHY
[ 0.856122] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 148000 (expect 38000)
检测到了 SPI FLASH, 但是你的 cmdline 里面 parts 参数 和 dts 里面均没有找到分区信息, 所以就挂不起文件系统。
cmdline应该没有问题啊。 Kernel command line: console=ttyS2,115200 earlyprintk panic=5 rootwait mtdparts=spi32766.0:1M(uboot)ro,64k(dtb)ro,4M(kernel)ro,-(rootfs) root=31:03 rw rootfstype=jffs2 你说dts没有分区信息。dts本来就没有吧??
没理解啊
没理解啊
我的意思是,根据log信息 既没有在mtdparts分析出mtd分区信息,也没有在dts分析出mtd分区信息。
看下cmdline这行是不是错了字符?
我看了一下,仔细对了一下,没有问题,原来提是ttys0,我们现在的是s2,能正常打印,说明这个是没有问题的
我看起来,它是解析分区表时出错了。解析不出来。不知道这是为什么。
楼主,问题解决了吗,我目前的问题跟你的一样
什么问题,把 log 贴出来吧.
1. 添加 m25p80 驱动
2. 设备树添加 spi flash
3. 内核配置 config commandline parts (也可以配置设备树 dts parts)
4. bootargs 添加 mtdparts 命令行 (也可以在设备树配置mtdparts)
5. 用 mkfs.jffs2 制作根文件系统, 并且烧录到 前面mtdparts指定的位置.
我使用w25q256,
1. 添加 m25p80 驱动
已添加
2. 设备树添加 spi flash
已添加
已添加
已添加
完全参考看云上的方法做的,https://www.kancloud.cn/lichee/lpi0/331844。
我的log如下,
U-Boot 2017.01-rc2 (Dec 14 2018 - 11:34:03 +0800) Allwinner Technology
Model: Lichee Pi Zero
I2C: ready
DRAM: 64 MiB
MMC: SUNXI SD/MMC: 0
SF: Detected w25q256 with page size 256 Bytes, erase size 4 KiB, total 32 MiB
SF: Warning - Only lower 16MiB accessible, Full access #define CONFIG_SPI_FLASH_BAR
In: serial@01c28000
Out: serial@01c28000
Err: serial@01c28000
Net: No ethernet found.
Loading Device Tree to 42dfa000, end 42dff2b2 ... OK
[ 0.000000] Linux version 4.14.0-licheepi-zero (wlyu@wlyu-virtual-machine) (gcc version 4.7.4 (Ubuntu/Linaro 4.7.4-3ubuntu12)) #19 SMP Fri Dec 14 14:02:26 CST 2018
[ 0.000000] random: fast init done
[ 0.000000] percpu: Embedded 16 pages/cpu @c3f61000 s33740 r8192 d23604 u65536
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 16256
[ 0.000000] Kernel command line: console=ttyS0,115200 earlyprintk panic=5 rootwait mtdparts=spi32766.0:1M(uboot)ro,64k(dtb)ro,4M(kernel)ro,-(rootfs) root=31:03 rw rootfstype=jffs2
[ 0.000000] Memory: 55028K/65536K available (6144K kernel code, 286K rwdata, 1504K rodata, 1024K init, 263K bss, 10508K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] vmalloc : 0xc4800000 - 0xff800000 ( 944 MB)
[ 0.000000] .data : 0xc0a00000 - 0xc0a478a0 ( 287 kB)
[ 0.000000] .bss : 0xc0a4eaf0 - 0xc0a909f4 ( 264 kB)
[ 0.000018] Switching to timer-based delay loop, resolution 41ns
[ 0.000166] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000399] Console: colour dummy device 80x30
[ 0.000456] pid_max: default: 32768 minimum: 301
[ 0.000581] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000597] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001264] CPU: Testing write buffer coherency: ok
[ 0.001649] /cpus/cpu@0 missing clock-frequency property
[ 0.001672] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002109] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.002276] Hierarchical SRCU implementation.
[ 0.002766] smp: Bringing up secondary CPUs ...
[ 0.002782] smp: Brought up 1 node, 1 CPU
[ 0.002790] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.002796] CPU: All CPU(s) started in SVC mode.
[ 0.003561] devtmpfs: initialized
[ 0.006418] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.006702] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.006730] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.006901] pinctrl core: initialized pinctrl subsystem
[ 0.007887] NET: Registered protocol family 16
[ 0.008386] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.009502] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.009519] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.020283] SCSI subsystem initialized
[ 0.020536] usbcore: registered new interface driver usbfs
[ 0.020588] usbcore: registered new interface driver hub
[ 0.020670] usbcore: registered new device driver usb
[ 0.020887] pps_core: LinuxPPS API ver. 1 registered
[ 0.020896] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.020916] PTP clock support registered
[ 0.021111] Advanced Linux Sound Architecture Driver Initialized.
[ 0.022826] clocksource: Switched to clocksource arch_sys_counter
[ 0.031888] NET: Registered protocol family 2
[ 0.032528] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.032556] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.032579] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.032710] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.032758] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.033053] NET: Registered protocol family 1
[ 0.033702] RPC: Registered named UNIX socket transport module.
[ 0.033723] RPC: Registered udp transport module.
[ 0.033728] RPC: Registered tcp transport module.
[ 0.033734] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.035543] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.041299] NFS: Registering the id_resolver key type
[ 0.041351] Key type id_resolver registered
[ 0.041358] Key type id_legacy registered
[ 0.041639] JFS: nTxBlock = 429, nTxLock = 3439
[ 0.046646] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.046668] io scheduler noop registered
[ 0.046675] io scheduler deadline registered
[ 0.046875] io scheduler cfq registered (default)
[ 0.046886] io scheduler mq-deadline registered
[ 0.046893] io scheduler kyber registered
[ 0.047428] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO
[ 0.050515] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.109349] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.112245] console [ttyS0] disabled
[ 0.132512] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 30, base_baud = 1500000) is a U6_16550A
[ 0.716132] console [ttyS0] enabled
[ 0.723702] m25p80 spi0.0: w25q256 (32768 Kbytes)
[ 0.729405] libphy: Fixed MDIO Bus: probed
[ 0.733907] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.740432] ehci-platform: EHCI generic platform driver
[ 0.745782] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.752001] ohci-platform: OHCI generic platform driver
[ 0.757760] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[ 0.767297] sun6i-rtc 1c20400.rtc: rtc core: registered rtc-sun6i as rtc0
[ 0.774168] sun6i-rtc 1c20400.rtc: RTC enabled
[ 0.778728] i2c /dev entries driver
[ 0.782418] IR NEC protocol handler initialized
[ 0.786995] IR RC5(x/sz) protocol handler initialized
[ 0.792040] IR RC6 protocol handler initialized
[ 0.796581] IR JVC protocol handler initialized
[ 0.801104] IR Sony protocol handler initialized
[ 0.805726] IR SANYO protocol handler initialized
[ 0.810422] IR Sharp protocol handler initialized
[ 0.815130] IR MCE Keyboard/mouse protocol handler initialized
[ 0.820952] IR XMP protocol handler initialized
[ 0.826110] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 0.892868] sunxi-mmc 1c0f000.mmc: base:0xc489d000 irq:22
[ 0.899658] usbcore: registered new interface driver usbhid
[ 0.905329] usbhid: USB HID core driver
[ 0.910691] NET: Registered protocol family 17
[ 0.915359] Key type dns_resolver registered
[ 0.919810] Registering SWP/SWPB emulation handler
[ 0.931436] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 0.942987] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 0.948756] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 0.959837] hub 1-0:1.0: USB hub found
[ 0.963835] hub 1-0:1.0: 1 port detected
[ 0.968867] using random self ethernet address
[ 0.973435] using random host ethernet address
[ 0.978748] usb0: HOST MAC f2:e1:be:48:4a:01
[ 0.983217] usb0: MAC b6:4c:e4:72:da:1a
[ 0.987114] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[ 0.994642] g_cdc gadget: g_cdc ready
[ 0.998675] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01 00:00:07 UTC (7)
[ 1.006891] vcc3v0: disabling
[ 1.009868] vcc5v0: disabling
[ 1.012886] ALSA device list:
[ 1.015852] No soundcards found.
[ 1.020642] VFS: Cannot open root device "31:03" or unknown-block(31,3): error -19
[ 1.028324] Please append a correct "root=" boot option; here are the available partitions:
[ 1.036699] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,3)
[ 1.045044] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.14.0-licheepi-zero #19
[ 1.052254] Hardware name: sun8i
[ 1.055518] [<c010e794>] (unwind_backtrace) from [<c010b540>] (show_stack+0x10/0x14)
[ 1.063260] [<c010b540>] (show_stack) from [<c0679630>] (dump_stack+0x80/0xa0)
[ 1.070483] [<c0679630>] (dump_stack) from [<c011b39c>] (panic+0xd0/0x25c)
[ 1.077358] [<c011b39c>] (panic) from [<c0901150>] (mount_block_root+0x174/0x260)
[ 1.084835] [<c0901150>] (mount_block_root) from [<c0901344>] (mount_root+0x108/0x12c)
[ 1.092744] [<c0901344>] (mount_root) from [<c0901494>] (prepare_namespace+0x12c/0x190)
[ 1.100740] [<c0901494>] (prepare_namespace) from [<c0900e04>] (kernel_init_freeable+0x18c/0x1d0)
[ 1.109606] [<c0900e04>] (kernel_init_freeable) from [<c068be54>] (kernel_init+0x8/0x114)
[ 1.117777] [<c068be54>] (kernel_init) from [<c0107970>] (ret_from_fork+0x14/0x24)
[ 1.125348] Rebooting in 5 seconds..然后我替换了kernel以后出现如下log
I2C: ready
DRAM: 64 MiB
In: serial@01c28000
[ 0.000000] Linux version 4.13.0-licheepi-zero+ (root@ubuntu) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.9)) #1 SMP Sun Jul 15 23:54:34 CST 2018
[ 0.000000] percpu: Embedded 16 pages/cpu @c3f61000 s33868 r8192 d23476 u65536
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
[ 0.000000] Memory: 55104K/65536K available (6144K kernel code, 224K rwdata, 1356K rodata, 1024K init, 251K bss, 10432K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] .data : 0xc0a00000 - 0xc0a383e0 ( 225 kB)
[ 0.000000] .bss : 0xc0a3f61c - 0xc0a7e48c ( 252 kB)
[ 0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000167] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000380] Console: colour dummy device 80x30
[ 0.000414] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000430] pid_max: default: 32768 minimum: 301
[ 0.000551] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000568] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001150] CPU: Testing write buffer coherency: ok
[ 0.001511] /cpus/cpu@0 missing clock-frequency property
[ 0.001535] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.001960] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.002140] Hierarchical SRCU implementation.
[ 0.002620] smp: Bringing up secondary CPUs ...
[ 0.002637] smp: Brought up 1 node, 1 CPU
[ 0.002646] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.002653] CPU: All CPU(s) started in SVC mode.
[ 0.003396] devtmpfs: initialized
[ 0.005882] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.006150] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.006179] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.006345] pinctrl core: initialized pinctrl subsystem
[ 0.007197] random: get_random_u32 called from bucket_table_alloc+0xf0/0x23c with crng_init=0
[ 0.007334] NET: Registered protocol family 16
[ 0.007772] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.008806] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.008825] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.018996] SCSI subsystem initialized
[ 0.019290] usbcore: registered new interface driver usbfs
[ 0.019356] usbcore: registered new interface driver hub
[ 0.019446] usbcore: registered new device driver usb
[ 0.019638] pps_core: LinuxPPS API ver. 1 registered
[ 0.019648] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.019670] PTP clock support registered
[ 0.019903] Advanced Linux Sound Architecture Driver Initialized.
[ 0.021733] clocksource: Switched to clocksource arch_sys_counter
[ 0.031789] NET: Registered protocol family 2
[ 0.032377] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.032409] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.032432] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.032559] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.032606] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.032833] NET: Registered protocol family 1
[ 0.034627] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.042654] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 0.044122] random: fast init done
[ 0.046910] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.046934] io scheduler noop registered
[ 0.046941] io scheduler deadline registered
[ 0.047173] io scheduler cfq registered (default)
[ 0.047184] io scheduler mq-deadline registered
[ 0.047192] io scheduler kyber registered
[ 0.051469] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.115187] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.118283] console [ttyS0] disabled
[ 0.138549] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 30, base_baud = 1500000) is a U6_16550A
[ 0.693714] console [ttyS0] enabled
[ 0.700760] m25p80 spi32766.0: w25q256 (32768 Kbytes)
[ 0.705928] 4 cmdlinepart partitions found on MTD device spi32766.0
[ 0.712220] Creating 4 MTD partitions on "spi32766.0":
[ 0.717363] 0x000000000000-0x000000100000 : "uboot"
[ 0.723692] 0x000000100000-0x000000110000 : "dtb"
[ 0.729597] 0x000000110000-0x000000510000 : "kernel"
[ 0.735906] 0x000000510000-0x000002000000 : "rootfs"
[ 0.742349] libphy: Fixed MDIO Bus: probed
[ 0.746758] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.753361] ehci-platform: EHCI generic platform driver
[ 0.758676] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.764902] ohci-platform: OHCI generic platform driver
[ 0.770287] usbcore: registered new interface driver usb-storage
[ 0.776756] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[ 0.786327] sun6i-rtc 1c20400.rtc: rtc core: registered rtc-sun6i as rtc0
[ 0.793196] sun6i-rtc 1c20400.rtc: RTC enabled
[ 0.797743] i2c /dev entries driver
[ 0.802018] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 0.861785] sunxi-mmc 1c0f000.mmc: base:0xc48b2000 irq:22
[ 0.868631] usbcore: registered new interface driver usbhid
[ 0.874302] usbhid: USB HID core driver
[ 0.879628] NET: Registered protocol family 17
[ 0.884353] Registering SWP/SWPB emulation handler
[ 0.895955] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 0.907406] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 0.913255] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 0.924437] hub 1-0:1.0: USB hub found
[ 0.928295] hub 1-0:1.0: 1 port detected
[ 0.933513] using random self ethernet address
[ 0.938002] using random host ethernet address
[ 0.943614] usb0: HOST MAC 42:5b:e6:44:64:90
[ 0.947931] usb0: MAC d2:86:b5:e1:10:8f
[ 0.951923] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[ 0.959401] g_cdc gadget: g_cdc ready
[ 0.963432] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01 00:00:06 UTC (6)
[ 0.971600] vcc3v0: disabling
[ 0.974646] vcc5v0: disabling
[ 0.977615] ALSA device list:
[ 0.980578] No soundcards found.
[ 0.990610] jffs2: Node at 0x00000fe0 with length 0x000000cd would run over the end of the erase block
[ 1.000028] jffs2: Perhaps the file system was created with the wrong erase size?
[ 1.007571] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000fe4: 0x00cd instead
[ 1.017087] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000fe8: 0x02ac instead
[ 1.026600] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000fec: 0x0014 instead
[ 1.036085] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000ff0: 0x000b instead
[ 1.045753] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000ff4: 0x81ed instead
[ 1.055749] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00001000: 0x22bf instead
[ 1.065266] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00001004: 0x22bf instead
[ 1.074753] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00001008: 0x22bf instead
[ 1.084231] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000100c: 0x0a00 instead
[ 1.093707] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00001010: 0x0089 instead
[ 1.103180] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00001014: 0x0100 instead
[ 1.112655] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00001018: 0x0006 instead
[ 1.122166] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000101c: 0xbef7 instead
[ 1.131633] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00001020: 0x8a40 instead
[ 1.141114] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00001024: 0x5e78 instead
[ 1.150588] jffs2: Further such events for this erase block will not be printed
[ 1.160108] jffs2: Node at 0x00001f50 with length 0x000000f2 would run over the end of the erase block
[ 1.169440] jffs2: Perhaps the file system was created with the wrong erase size?
[ 1.177338] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00002000: 0x9f9c instead
[ 1.186843] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00002004: 0x4605 instead
[ 1.196326] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00002008: 0x2f92 instead
[ 1.205804] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000200c: 0x5bc6 instead
[ 1.215281] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00002010: 0x5d23 instead
[ 1.224755] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00002014: 0x7945 instead
[ 1.234230] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00002018: 0x0d2f instead
[ 1.243705] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000201c: 0xb254 instead
[ 1.253178] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00002020: 0xd5f7 instead
[ 1.262653] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00002024: 0xc142 instead
[ 1.272126] jffs2: Further such events for this erase block will not be printed
[ 1.281615] jffs2: Node at 0x00002f88 with length 0x000000e0 would run over the end of the erase block
[ 1.290939] jffs2: Perhaps the file system was created with the wrong erase size?
[ 1.298826] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00003000: 0x208e instead
[ 1.308329] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00003004: 0xfa88 instead
[ 1.317809] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00003008: 0x853e instead
[ 1.327285] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000300c: 0xe120 instead
[ 1.336760] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00003010: 0x02fa instead
[ 1.346236] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00003014: 0xb484 instead
[ 1.355710] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00003018: 0x6be3 instead
[ 1.365185] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000301c: 0x7206 instead
[ 1.374660] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00003020: 0xefbc instead
[ 1.384135] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00003024: 0x287b instead
[ 1.393607] jffs2: Further such events for this erase block will not be printed
[ 1.403098] jffs2: Node at 0x00003fd0 with length 0x0000013e would run over the end of the erase block
[ 1.412418] jffs2: Perhaps the file system was created with the wrong erase size?
[ 1.420288] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00004000: 0x00fa instead
[ 1.429788] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00004004: 0x00ff instead
[ 1.439268] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00004008: 0x0006 instead
[ 1.448745] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000400c: 0xdb4e instead
[ 1.458221] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00004010: 0xe2a3 instead
[ 1.467700] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00004014: 0x5e78 instead
[ 1.477176] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00004018: 0xd0c0 instead
[ 1.486652] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000401c: 0xf110 instead
[ 1.496126] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00004020: 0x8181 instead
[ 1.505602] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00004024: 0xe181 instead
[ 1.515074] jffs2: Further such events for this erase block will not be printed晕哥帮忙看一下~
我只替换了zImage,用的是您发的 V3s_W25Q256_MX25L256_Qt5.9.1.bin 里dd出来的kernel,
内核里这个也选中了<*> Command line partition table parsing
看不出问题了,
有这个log
而没有解析出分区,可能是设备树没有配 spi flash
你把你的 dts 贴出来看下
这是我前几天做的flash镜像,你试一试: v3s_32M_flash.tgz
感觉我的问题可能出在这
我uboot log,说
SF: Warning - Only lower 16MiB accessible, Full access #define CONFIG_SPI_FLASH_BAR另外我的dts是
&spi0 {
w25q128:w25q128@0 {
compatible = "jedec,spi-nor";
reg = <0x0>;
spi-max-frequency = <16000000>;
#address-cells = <1>;
#size-cells = <1>;
};小猪佩奇 说:我只替换了zImage,用的是您发的 V3s_W25Q256_MX25L256_Qt5.9.1.bin 里dd出来的kernel,
看不出问题了,
有这个log
你把你的 dts 贴出来看下
那会不会是我镜像文件生成的有问题,我是这样操作的,(w25q256)
jffs2分区总空间是 32M-1M-64K-4M= 0x1AF0000
mkfs.jffs2 -s 0x100 -e 0x10000 -p 0x1AF0000 -d rootfs/ -o jffs2.img dd if=/dev/zero of=flashimg.bin bs=32M count=1
dd if=../ubootmainline/u-boot/u-boot-sunxi-with-spl.bin of=flashimg.bin bs=1K conv=notrunc
dd if=../zero41y/linux-zero-4.10.y/arch/arm/boot/dts/sun8i-v3s-licheepi-zero-dock.dtb of=flashimg.bin bs=1K seek=1024 conv=notrunc
dd if=../zero41y/linux-zero-4.10.y/arch/arm/boot/zImage of=flashimg.bin bs=1K seek=1088 conv=notrunc
dd if=../zero_imager/jffs2/jffs2.img of=flashimg.bin bs=1K seek=5184 conv=notrunc离线
把这两个参数去掉,并换成4.13y的内核
现在可以启动了,感谢晕哥~
把这两个参数先去掉: -s 0x100 -e 0x10000
现在可以启动了,感谢晕哥~晕哥 说:把这两个参数先去掉: -s 0x100 -e 0x10000
客气客气, 看到有朋友解决问题了很开森.
去掉这两个参数就是使用命令行的默认参数了 -s 0x1000 -e 0x10000,
s 是指 page size, 可能是驱动设置的page size 就是 0x1000
具体你可以用 beyond compare 比较二者生成的二进制文件和驱动代码。
另外我想除了USB烧写方式以外可不可以TF卡烧写,
把生成的bin文件放到TF卡里面,然后用mtd_write,或者dd是否可行,我试了一下目前是没写进去
