楼主 #1 2018-12-05 14:18:12
pqfeng
已发帖子: 129
请教一下:PF1 未保留是啥意思???
PF: set_value: error: gpio PF1 not reserved
#2 2018-12-05 14:19:40
已发帖子: 9,417
Re: 请教一下:PF1 未保留是啥意思???
没遇到过,怎么出来的
楼主 #3 2018-12-05 14:30:25
pqfeng
已发帖子: 129
gpio_direction_output(SUNXI_GPF(LCD_SCLK),1);
    gpio_direction_output(SUNXI_GPF(LCD_CS),1);
    sunxi_gpio_set_pull(SUNXI_GPF(LCD_SCLK),SUNXI_GPIO_PULL_UP);
    sunxi_gpio_set_pull(SUNXI_GPF(LCD_CS), SUNXI_GPIO_PULL_UP);
    gpio_set_value(SUNXI_GPF(LCD_CS), 1);
    gpio_set_value(SUNXI_GPF(LCD_SCLK), 1);
我没把这些GPIO添加到DTS里去。现在加一下试试
#4 2018-12-05 14:37:40
已发帖子: 9,417
gpio_set_value 出错吧, 跟进去试一试,或许是没有复用为 GPIO 引起.
楼主 #5 2018-12-05 14:39:37
pqfeng
已发帖子: 129
   Loading Device Tree to 42df9000, end 42dff121 ... OK
PF: dir_output: error: gpio PF1 not reserved
PF: dir_output: error: gpio PF5 not reserved
PF: set_value: error: gpio PF5 not reserved
PF: dir_output: error: gpio PF0 not reserved
PF: set_value: error: gpio PF0 not reserved
不单是这个原因呢
#6 2018-12-05 14:52:25
已发帖子: 9,417
不会,路过打酱油.
