楼主 #1 2019-01-02 15:39:03
aoaoao123mm
有大哥知道lradc的中断驱动怎么写吗
 #include <linux/init.h>
#include <linux/kernel.h>
#include <linux/module.h>
#include <linux/fs.h>
#include <linux/cdev.h>
#include <linux/uaccess.h>
#include <linux/device.h>
#include <linux/io.h>
#include <linux/interrupt.h>
static void __iomem *LRADC_BASE_Data0;
static void __iomem *LRADC_BASE_Inter_S;
static void __iomem *LRADC_BASE_Inter_C;
static void __iomem *LRADC_BASE_Control;
static void __iomem *LRADC_BASE;
static struct cdev LRADC_cdev;		//字符设备结构体
static dev_t	LRADC_num = 0;		//设备号
static struct class 	*LRADC_class;
static struct device 	*LRADC_device;
short int irq_key = 30;
char name[]={"key"};
static int  LRADC_open(struct inode * inode, struct file *file)
	printk("LRADC_open \n");
static int  LRADC_release(struct inode * inode, struct file *file)
	printk("LRADC_release \n");
static ssize_t LRADC_write(struct file * file, const char __user * buf, size_t len,loff_t * off)
	printk("LRADC_BASE_Data0=0x%x\r\n",ioread32(LRADC_BASE_Data0));
        printk("LRADC_BASE_Inter_C=0x%x",ioread32(LRADC_BASE_Inter_C));
        printk("LRADC_BASE_Inter_S=0x%x\r\n",ioread32(LRADC_BASE_Inter_S));
	return ioread32(LRADC_BASE_Data0);
static const struct file_operations LRADC_fops = {
	.owner = THIS_MODULE,
	.write = LRADC_write,
	.open =  LRADC_open,
	.release = LRADC_release
static irqreturn_t r_irq_handler(int irq, void *dev_id)
        printk("being interrupt\r\n");
        if(ioread32(LRADC_BASE_Inter_S) != 0)
        	printk("KEY RISING\r\n");
        return IRQ_HANDLED;
//入口函数
static int __init init_LRADC(void)
	int rt = 0;
	struct resource * LRADC_res = NULL;
	//动态申请设备号
	rt = alloc_chrdev_region(&LRADC_num, 0, 1, "LRADC");
	if (rt < 0)
		printk("alloc_chrdev_region fail\n");
		return rt;
	//字符设备初始化
	cdev_init(&LRADC_cdev, &LRADC_fops);
	//字符设备添加到内核
	rt = cdev_add(&LRADC_cdev, LRADC_num, 1);
	if (rt < 0)
		printk("cdev_add fail\n");
		goto fail_cdev_add;
	//创建类
	LRADC_class = class_create(THIS_MODULE, "LRADC");
	if (IS_ERR(LRADC_class))
		rt = PTR_ERR(LRADC_class);
		printk("class_create LRADC fail\n");
		goto fail_class_create;
	//创建设备
	LRADC_device = device_create(LRADC_class, NULL, LRADC_num, NULL, "LRADC");
	if (IS_ERR(LRADC_device))
		rt = PTR_ERR(LRADC_device);
		printk("device_create LRADC fail\n");
		goto fail_device_create;
	//申请物理内存区
        //起始地址GPIOg寄存器基址0x01C20000
        //申请大小0xffff字节
        //申请到的名字为GPIOH_MEM
        LRADC_res = request_mem_region(0x01C20000,0xFFFF,"GPIOG_MEM");
	if(LRADC_res == NULL)
	   printk("request_mem_region fail\n");
	  // goto fail_request_mem_region;
	//IO内存动态映射,得到物理地址相应的虚拟地址
	LRADC_BASE = ioremap(0x01C22000,0XFFFF);
        printk("LRADC_BASE=0x%x",((unsigned int)LRADC_BASE));
	if(LRADC_BASE == NULL)
	    printk("ioremap  fail\n");
	    goto fail_ioremap;
	//得到每个寄存器的虚拟地址
	LRADC_BASE_Control = LRADC_BASE + 0x800;
        printk("addr:LRADC_BASE_Control=0x%x",((unsigned int)LRADC_BASE_Control));
	LRADC_BASE_Data0 = LRADC_BASE + 0x80C;
	printk("addr:LRADC_BASE_Data0=0x%x",((unsigned int)LRADC_BASE_Data0));
	LRADC_BASE_Inter_S  = LRADC_BASE + 0x808;
        printk("addr:LRADC_BASE_Inter_S=0x%x",((unsigned int)LRADC_BASE_Inter_S));
        LRADC_BASE_Inter_C  = LRADC_BASE + 0x804;
        printk("addr:LRADC_BASE_Inter_C=0x%x",((unsigned int)LRADC_BASE_Inter_C));
	iowrite32(0x1000141 , LRADC_BASE_Control);
        iowrite32(0x2 , LRADC_BASE_Inter_C);        //down
	printk("LRADC_BASE_Data0=0x%x",ioread32(LRADC_BASE_Data0));
        printk("LRADC_BASE_Inter_S=0x%x",ioread32(LRADC_BASE_Inter_S));
        printk("key init\r\n");
        if (request_irq(irq_key,(irq_handler_t ) r_irq_handler, IRQF_TRIGGER_FALLING , name , NULL))
     		printk("Irq Request failure\n");
fail_ioremap:
	release_mem_region(0x01C22000, 0xffff);
fail_request_mem_region:
	device_destroy(LRADC_class, LRADC_num);
fail_device_create:
	class_destroy(LRADC_class);
fail_class_create:
	cdev_del(&LRADC_cdev);
fail_cdev_add:
	unregister_chrdev_region(LRADC_num, 1);
	return rt;
//出口函数
static void __exit exit_LRADC(void)
	iounmap(LRADC_BASE);
        release_mem_region(0x01C22000,0xffff);
	free_irq(irq_key, NULL);
        printk("key remove\r\n");
        return ;
module_init(init_LRADC);
module_exit(exit_LRADC);
MODULE_LICENSE("GPL");//驱动程序符合的协议
楼主 #2 2019-01-02 15:40:20
aoaoao123mm
Re: 有大哥知道lradc的中断驱动怎么写吗
我这样写是申请失败的
楼主 #3 2019-01-02 15:43:46
aoaoao123mm
板子是荔枝派zero,那个if (request_irq(irq_key,(irq_handler_t ) r_irq_handler, IRQF_TRIGGER_FALLING , name , NULL))中的第三个参数我到底填什么,这个中断事件怎么找???
#4 2019-01-02 16:04:18
trigger
已发帖子: 41
devname设置中断名称,通常是设备驱动程序的名称  在cat /proc/interrupts中可以看到此名称。
楼主 #5 2019-01-02 17:03:34
aoaoao123mm
trigger 说:
是第三个那个(IRQF_TRIGGER_FALLING),是中断标志,我不知道在哪里找?你说的中断名称是第四个。
#6 2019-01-02 21:28:40
basicdev
已发帖子: 159
参考这个帖子:  https://whycan.cn/t_1916.html
楼主 #7 2019-01-03 08:52:07
aoaoao123mm
basicdev 说:
这个帖子我看过了,但最后也没有给出解决方法。。。。
楼主 #8 2019-01-03 14:27:10
aoaoao123mm
参考晕哥的GPIO中断就可以,但这个lradc中断却不行。。。。。有大神救救吗
