楼主 #1 2017-11-15 09:16:08
daydayup
已发帖子: 343
全志V3s只有一个spi口,我用spi flash作为存储和启动设备,那么这组spi还可以接其他设备吗,比如MFRC522,nrf24L01
全志V3s只有一个spi口,
那么这组spi还可以接其他设备吗,
比如MFRC522,nrf24L01这些nfc和数传模块吗?
楼主 #2 2017-11-15 09:33:53
daydayup
已发帖子: 343
Re: 全志V3s只有一个spi口,我用spi flash作为存储和启动设备,那么这组spi还可以接其他设备吗,比如MFRC522,nrf24L01
spi flash dts是这样的:
&spi0 {
        status ="okay";
        mx25l25635e:mx25l25635e@0 {
                compatible = "jedec,spi-nor";
                reg = <0x0>;
                #address-cells = <1>;
                #size-cells = <1>;
#3 2017-11-15 10:44:47
dgtg
已发帖子: 264
用gpio做CS, 读写Flash之前先做操作gpio, 应该可以吧?
#4 2017-11-15 11:15:01
沉鱼
已发帖子: 161
理论上来说是没有问题的, 在dts里面添加设备, 把设备的cs引脚设置成对应的gpio, 不过没有实践过, 仅提供参考意见。
#5 2017-11-20 19:19:02
已发帖子: 9,389
参考一下这个:
https://github.com/jpbarraca/pynrf24/blob/master/spi/BB-nRF24-SPI0-00A0.dts
 * Virtual cape for SPI0 on connector pins P9.22 P9.21 P9.18 P9.17
 * This program is free software; you can redistribute it and/or modify
 * it under the terms of the GNU General Public License version 2 as
 * published by the Free Software Foundation.
/dts-v1/;
/plugin/;
	compatible = "ti,beaglebone", "ti,beaglebone-black";
	/* identification */
	part-number = "BB-nRF24-SPI0";
	version = "00A0";
	/* state the resources this cape uses */
	exclusive-use =
		/* the pin header uses */
		"P9.17",	/* spi0_cs0 */
		"P9.18",	/* spi0_d1 */
		"P9.21",	/* spi0_d0 */
		"P9.22",	/* spi0_sclk */
		/* the hardware ip uses */
		"spi0";
	fragment@0 {
		target = <&am33xx_pinmux>;
		__overlay__ {
			/* default state has all gpios released and mode set to uart1 */
			bb_spi0_pins: pinmux_bb_spi0_pins {
				pinctrl-single,pins = <
					0x150 0x30	/* spi0_sclk.spi0_sclk, INPUT_PULLUP | MODE0 */
					0x154 0x30	/* spi0_d0.spi0_d0, INPUT_PULLUP | MODE0 */
					0x158 0x10	/* spi0_d1.spi0_d1, OUTPUT_PULLUP | MODE0 */
					0x15c 0x10	/* spi0_cs0.spi0_cs0, OUTPUT_PULLUP | MODE0 */
	fragment@1 {
		target = <&spi0>;	/* spi0 is numbered correctly */
		__overlay__ {
			pinctrl-names = "default";
			pinctrl-0 = <&bb_spi0_pins>;
			#size-cells = <0>;
			spidev: spidev@0{
				#size-cells = <0>;
				compatible = "linux,spidev";
				reg = <0>;
				spi-max-frequency = <10000000>;
#6 2017-11-20 19:38:56
已发帖子: 9,389
#7 2020-07-15 15:38:18
我思故我在
已发帖子: 244
