楼主 #1 2019-02-15 10:13:25
shun
各位大神,lichee zero开发板alsa无法识别GeneralPlus usb声卡
lichee zero内核使用zero-4.13.y分支,相关驱动都勾选了,lsusb中有usb设备,但alsa无法识别
# [  658.145235] usb 2-1: new full-speed USB device number 9 using ohci-platform
[  658.414870] input: GeneralPlus USB Audio Device as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.3/0003:1B3F:2008.0008/input/input9
[  658.495594] hid-generic 0003:1B3F:2008.0008: input: USB HID v2.01 Device [GeneralPlus USB Audio Device] on usb-1c1a400.usb-1/input3
# lsusb
Bus 003 Device 001: ID 1d6b:0002
Bus 002 Device 009: ID 1b3f:2008
Bus 001 Device 001: ID 1d6b:0002
Bus 002 Device 001: ID 1d6b:0001
# aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: Codec [V3s Audio Codec], device 0: CDC PCM Codec-0 []
  Subdevices: 1/1
  Subdevice #0: subdevice #0
# [  673.416232] usb 2-1: USB disconnect, device number 9
[  674.645264] musb-hdrc musb-hdrc.1.auto: VBUS_ERROR in b_idle (98, VALID), retry #1, port1 00000104
求助各位大神,如何让alsa可以识别到GeneralPlus usb声卡?
#2 2019-02-15 10:27:50
jimmy
已发帖子: 316
Re: 各位大神,lichee zero开发板alsa无法识别GeneralPlus usb声卡
看起来前面识别了 USB 声卡 input: GeneralPlus USB Audio Device
但是后面断开了 usb 2-1: USB disconnect, ?
楼主 #3 2019-02-15 10:38:09
shun
最下面的两行是我主动断开usb了
#4 2019-02-15 10:57:31
jimmy
已发帖子: 316
最下面的两行是我主动断开usb了
这就有点尴尬了,插电脑试一试。
比较一下 log
最近编辑记录 jimmy (2019-02-15 10:57:45)
楼主 #5 2019-02-15 11:15:31
shun
在ubuntu中,插上usb声卡,dmesg是
[ 7830.756853] usb 1-3: new full-speed USB device number 8 using xhci_hcd
[ 7830.926647] usb 1-3: New USB device found, idVendor=1b3f, idProduct=2008
[ 7830.926650] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7830.926652] usb 1-3: Product: USB Audio Device
[ 7830.926654] usb 1-3: Manufacturer: GeneralPlus
断开usb声卡
[ 7831.213412] input: GeneralPlus USB Audio Device as /devices/pci0000:00/0000:00:08.1/0000:02:00.3/usb1/1-3/1-3:1.3/0003:1B3F:2008.0004/input/input18
[ 7831.273223] hid-generic 0003:1B3F:2008.0004: input,hidraw2: USB HID v2.01 Device [GeneralPlus USB Audio Device] on usb-0000:02:00.3-3/input3
[ 7839.632246] usb 1-3: USB disconnect, device number 8
#6 2019-02-15 11:17:32
jimmy
已发帖子: 316
貌似你这个声卡是个符合USB设备, 声卡 + 键盘 ?
在 V3s 只识别到了键盘?
楼主 #7 2019-02-15 11:29:04
shun
在 V3s 只识别到了键盘?
不是复合usb设备,只是个声卡
楼主 #8 2019-02-18 09:45:24
shun
顶一下,求大牛们解惑
#9 2019-02-18 13:57:03
ippen
已发帖子: 345
启动是编译到内核里面?
试一下将驱动编译为模块,插上声卡后手动加载
