ff@ff:~/Documents/V3s_/u-boot$ arm-linux-gnueabihf-gcc -v
Using built-in specs.
COLLECT_GCC=arm-linux-gnueabihf-gcc
COLLECT_LTO_WRAPPER=/opt/gcc-linaro-7.4.1-2019.02-x86_64_arm-linux-gnueabihf/bin/../libexec/gcc/arm-linux-gnueabihf/7.4.1/lto-wrapper
Target: arm-linux-gnueabihf
Configured with: '/home/tcwg-buildslave/workspace/tcwg-make-release_0/snapshots/gcc.git~linaro-7.4-2019.02/configure' SHELL=/bin/bash --with-mpc=/home/tcwg-buildslave/workspace/tcwg-make-release_0/_build/builds/destdir/x86_64-unknown-linux-gnu --with-mpfr=/home/tcwg-buildslave/workspace/tcwg-make-release_0/_build/builds/destdir/x86_64-unknown-linux-gnu --with-gmp=/home/tcwg-buildslave/workspace/tcwg-make-release_0/_build/builds/destdir/x86_64-unknown-linux-gnu --with-gnu-as --with-gnu-ld --disable-libmudflap --enable-lto --enable-shared --without-included-gettext --enable-nls --with-system-zlib --disable-sjlj-exceptions --enable-gnu-unique-object --enable-linker-build-id --disable-libstdcxx-pch --enable-c99 --enable-clocale=gnu --enable-libstdcxx-debug --enable-long-long --with-cloog=no --with-ppl=no --with-isl=no --disable-multilib --with-float=hard --with-fpu=vfpv3-d16 --with-mode=thumb --with-tune=cortex-a9 --with-arch=armv7-a --enable-threads=posix --enable-multiarch --enable-libstdcxx-time=yes --enable-gnu-indirect-function --with-build-sysroot=/home/tcwg-buildslave/workspace/tcwg-make-release_0/_build/sysroots/arm-linux-gnueabihf --with-sysroot=/home/tcwg-buildslave/workspace/tcwg-make-release_0/_build/builds/destdir/x86_64-unknown-linux-gnu/arm-linux-gnueabihf/libc --enable-checking=release --disable-bootstrap --enable-languages=c,c++,fortran,lto --build=x86_64-unknown-linux-gnu --host=x86_64-unknown-linux-gnu --target=arm-linux-gnueabihf --prefix=/home/tcwg-buildslave/workspace/tcwg-make-release_0/_build/builds/destdir/x86_64-unknown-linux-gnu
Thread model: posix
gcc version 7.4.1 20181213 [linaro-7.4-2019.02 revision 56ec6f6b99cc167ff0c2f8e1a2eed33b1edc85d4] (Linaro GCC 7.4-2019.02)
ff@ff:~/Documents/V3s_/u-boot$ time make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- 2>&1 | tee build.log
scripts/kconfig/conf --silentoldconfig Kconfig
CHK include/config.h
CFG u-boot.cfg
GEN include/autoconf.mk
GEN include/autoconf.mk.dep
CFG spl/u-boot.cfg
GEN spl/include/autoconf.mk
CHK include/config/uboot.release
CHK include/generated/version_autogenerated.h
CHK include/generated/timestamp_autogenerated.h
UPD include/generated/timestamp_autogenerated.h
CHK include/generated/generic-asm-offsets.h
CHK include/generated/asm-offsets.h
HOSTCC tools/mkenvimage.o
HOSTLD tools/mkenvimage
HOSTCC tools/fit_image.o
HOSTCC tools/image-host.o
HOSTCC tools/dumpimage.o
HOSTLD tools/dumpimage
HOSTCC tools/mkimage.o
HOSTLD tools/mkimage
CC cmd/bootm.o
cmd/bootm.c: In function 'do_imls_nor':
cmd/bootm.c:327:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
cmd/bootm.c:327:7: note: each undeclared identifier is reported only once for each function it appears in
scripts/Makefile.build:280: recipe for target 'cmd/bootm.o' failed
make[1]: *** [cmd/bootm.o] Error 1
Makefile:1206: recipe for target 'cmd' failed
make: *** [cmd] Error 2
real 0m1.858s
user 0m1.455s
sys 0m0.408s
出现这么个问题,最后cmd错误编译失败
配置时开启了flash bank选项
是个W256的flash
新手一脸茫然 被水淹没 不知所措
请求帮助
不改配置正常吗?
还是报错
不改配置正常吗?
直接time make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- 2>&1 | tee build.log就是这样
ff@ff:~/Documents/u-boot$ time make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- 2>&1 | tee build.log
*** Error during update of the configuration.
scripts/kconfig/Makefile:46: recipe for target 'silentoldconfig' failed
make[2]: *** [silentoldconfig] Error 1
Makefile:478: recipe for target 'silentoldconfig' failed
make[1]: *** [silentoldconfig] Error 2
make: *** No rule to make target 'include/config/auto.conf', needed by 'include/config/uboot.release'. Stop.
real 0m0.246s
user 0m0.192s
sys 0m0.059s
不改配置正常吗?
root用户
root@ff:/home/ff/Documents/u-boot# time make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- 2>&1 | tee build.log
make: arm-linux-gnueabihf-gcc: Command not found
/bin/sh: 1: arm-linux-gnueabihf-gcc: not found
dirname: missing operand
Try 'dirname --help' for more information.
warning: (ARCH_SUNXI && TDX_CFG_BLOCK && TDX_CFG_BLOCK && TDX_CFG_BLOCK && TDX_CFG_BLOCK && TDX_CFG_BLOCK && TDX_CFG_BLOCK && ARCH_UNIPHIER_LD20 && TDX_CFG_BLOCK && TDX_CFG_BLOCK) selects OF_BOARD_SETUP which has unmet direct dependencies (OF_LIBFDT)
warning: (ARCH_SUNXI) selects SPL_STACK_R which has unmet direct dependencies (SPL)
warning: (ARCH_SUNXI) selects SPL_SYS_MALLOC_SIMPLE which has unmet direct dependencies (SPL)
CFG u-boot.cfg
scripts/Makefile.autoconf:79: recipe for target 'u-boot.cfg' failed
make[1]: *** [u-boot.cfg] Error 1
real 0m0.227s
user 0m0.192s
sys 0m0.030s
make[1]: *** Waiting for unfinished jobs....
还是同样的错误
按这个流程不会出问题,你的电脑系统是什么什么?
Ubuntu18.04_server_amd64
drivers/mtd/spi/spi_flash.c:1114:12: error: redefinition of 'write_bar'
static int write_bar(struct spi_flash *flash, u32 offset)
drivers/mtd/spi/spi_flash.c:116:12: note: previous definition of 'write_bar' was here
drivers/mtd/spi/spi_flash.c:1114:12: warning: 'write_bar' defined but not used [-Wunused-function]
scripts/Makefile.build:280: recipe for target 'drivers/mtd/spi/spi_flash.o' failed
make[1]: *** [drivers/mtd/spi/spi_flash.o] Error 1
Hu187 说:晕哥 说:按这个流程不会出问题,你的电脑系统是什么什么?
可以把你的大概流程说一下吗?
以下为详细操作日志
ff@ff:~$ cd ./Documents/u-boot/
ff@ff:~/Documents/u-boot$ ls
Kbuild MAINTAINERS api build.log config.mk doc examples lib scripts tools
Kconfig Makefile arch cmd configs drivers fs net snapshot.commit
Licenses README board common disk dts include post test
ff@ff:~/Documents/u-boot$ ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- make LicheePi_Zero_defconfig
# configuration written to .config
ff@ff:~/Documents/u-boot$ ARCH=arm make menuconfig //激活大容量flalsh支持 设置cpu主频到1.2GHz
scripts/kconfig/mconf Kconfig
*** End of the configuration.
*** Execute 'make' to start the build or try 'make help'.
ff@ff:~/Documents/u-boot$ ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- make -j8
superuser编译打印输出片段:
drivers/spi/sunxi_spi.c: In function ‘sunxi_spi_claim_bus’:
drivers/spi/sunxi_spi.c:179:15: warning: unused variable ‘pin_func’ [-Wunused-variable]
unsigned int pin_func = SUNXI_GPC_SPI0;
LD drivers/video/built-in.o
CC common/edid.o
LD drivers/built-in.o
CC drivers/usb/common/common.o
LD drivers/usb/dwc3/built-in.o
common/edid.c: In function ‘edid_print_dtd’:
common/edid.c:242:15: warning: ‘*’ in boolean context, suggest ‘&&’ instead [-Wint-in-bool-context]
if (v_total * h_total)
此时成功生成。bin文件
执行初始化配置文件之后:
立即编译:
能成功吗?
成功
执行初始化配置文件之后:
立即编译:
能成功吗?
但此时只能用到16MB
晕哥 说:执行初始化配置文件之后:
立即编译:
能成功吗?
成功
又调整了几下 编译中有警告 但最终生成了。bin
非常感谢 。改天烧进去试试
