启动 log 是这样的:
[ 1.104468] i2c /dev entries driver
[ 1.228881] Goodix-TS 0-0014: ID 911, version: 1060
[ 1.234417] Goodix-TS 0-0014: Direct firmware load for goodix_911_cfg.bin failed with error -2
我的显示屏分辨率是 1024*600,
所以我想把触摸长宽也跳到这个分辨率.
据说是要在文件系统建立 /lib/firmware/goodix_911_cfg.bin, 驱动启动的时候加载这个触摸固件,
但是网上无论如何都没有搜索到这个固件,
这个是厂家提供的吗?我应该找谁要?
https://patchwork.kernel.org/patch/6915171/
On the host:
- modify some fields from goodix_911_cfg (e.g. change resolution of
x/y axes, maximum reported touch points, switch X,Y axes). For more
details check datasheet for format of Configuration Registers.
- run tools/touch-goodix-generate-fw.sh on the modified script to
obtain a valid config (it needs to recompute the checksum, set
Config_Fresh to 1 and generate the binary config firmware image):
$ ./tools/touch-goodix-generate-fw.sh goodix_911_cfg
- copy goodix_911_cfg.bin on the target in /lib/firmware
- when the goodix driver is initialized it will read the new config
firmware from /lib/firmware/goodix_911_cfg.bin and write it to the
device
- check that the new firmware was actually written to the device by
reading the config again on the target from
/sys/class/input/input4/device/dump_config. Also check that Config_Fresh
has been reset to 0. You can also check if the functionality changed
in the config has actually changed (reported resolution for x/y has
changed, x,y axis are switched, etc.)
diff --git a/tools/touch-goodix-generate-fw.sh b/tools/touch-goodix-generate-fw.sh
new file mode 100755
index 0000000..0efe2e1
--- /dev/null
+++ b/tools/touch-goodix-generate-fw.sh
@@ -0,0 +1,39 @@
+#!/bin/bash
+if [[ $# -lt 1 ]]; then
+ echo "$0 fw_filename"
+ exit 1
+fi
+file_in="$1"
+file_out_bin=${file_in}.bin
+print_val ()
+ val="$1"
+ printf "0x%.2x" "$val" | xxd -r -p >> ${file_out_bin}
+rm -f ${file_out_bin}
+size=`cat ${file_in} | wc -w`
+checksum=0
+i=1
+for val in `cat ${file_in}`; do
+ val="0x$val"
+ if [[ $i == $size ]]; then
+ # Config_Fresh
+ print_val 0x01
+ elif [[ $i == $((size-1)) ]]; then
+ # Config_Chksum
+ checksum=$(( (~ checksum + 1) & 0xFF))
+ print_val $checksum
+ else
+ checksum=$((checksum + val))
+ print_val $val
+ fi
+ i=$((i+1))
+done
+echo "Wrote ${file_out_bin}"
加载固件是通用的做法,还有种简单的方法是买汇顶的产测工具,直接固化参数,不用加载固件了
请问哪里下载固件,哪里下载量产工具呢?
要淘宝上的买啊,有了产测工具,你想用固件就用固件,想固化就固化
你的淘宝店有吗?
没得,直接上淘宝搜汇顶产测工具
没得,直接上淘宝搜汇顶产测工具
谢谢,我这就去淘宝搜搜
原来我是140买的,现在没得了,估计这种测试板不好卖,
https://item.taobao.com/item.htm?spm=a1z10.5-c.w4002-6855656898.10.4e757547xIumnH&id=44902119949
原来我是140买的,现在没得了,估计这种测试板不好卖,https://item.taobao.com/item.htm?spm=a1z10.5-c.w4002-6855656898.10.4e757547xIumnH&id=44902119949
好贵呀,我也想要这个不过太贵了
如果液晶屏种类多,搞它还是可以的,要不然各种固件好麻烦,如7寸高清 普清 10.1寸 5寸 。。。。
汇顶的配置文件和调试工具不知道哪里能下载
根据我血的教训,给你们诚心建议,不要想着修改这个配置文件,因为触摸屏种类太多了,每家的都不一样
可以读取触摸屏的分辨率,然后乘以一个系数,转成你液晶屏的分辨率即可
虽然这样可能会损失一点分辨率,但是对于电容屏来说无所谓,都是手指头点
下单买了一个 汇顶 GT911/GT9xx 电容触摸屏产测工具
https://whycan.com/t_2366.html
