楼主 #1 2017-11-14 20:05:45
basicdev
已发帖子: 159
为什么我的V3s 换 32M flash之后 shell执行 reboot 不重启呢?
#2 2017-11-15 10:06:34
daydayup
已发帖子: 343
Re: 为什么我的V3s 换 32M flash之后 shell执行 reboot 不重启呢?
/usr/bin #
/usr/bin # reboot
/usr/bin # umount: devtmpfs busy - remounted read-only
umount: can't remount /dev/root read-only
can't run '/sbin/swapoff': No such file or directory
The system is going down NOW!
Sent SIGTERM to all processes
Requesting system rebootesses
[  837.214434] reboot: Restarting system
是不是这样,然后就没有然后了。。。
#3 2017-11-15 13:53:04
沉鱼
已发帖子: 161
荔枝派Q群群主说16M 的spi flash reboot正常,32M reboot不起来,
我验证过了,确实如此,
哪位大侠知道如何改吗?
#4 2017-11-15 14:45:04
沉鱼
已发帖子: 161
修改:  drivers/mtd/devices/m25p80.c
粗体部分是添加的内容:
static int m25p_remove(struct spi_device *spi)
    struct m25p *flash = spi_get_drvdata(spi);
    // manfeel note: add spi flash reset code
flash->command[0] = 0x66;
    spi_write(flash->spi, flash->command, 1);
    flash->command[0] = 0x99;
    /* Clean up MTD stuff. */
    return mtd_device_unregister(&flash->mtd);
static struct spi_driver m25p80_driver = {
    .driver = {
        .name   = "m25p80",
        .owner  = THIS_MODULE,
    .id_table   = m25p_ids,
    .probe  = m25p_probe,
    .remove = m25p_remove,
    // manfeel, add shutdown method to reset spi flash
    .shutdown = m25p_remove,
    /* REVISIT: many of these chips have deep power-down modes, which
     * should clearly be entered on suspend() to minimize power use.
     * And also when they're otherwise idle...
修改原因:
kernel已经能够支持32M SPI Flash的读写以及擦除操作.然而,可能是系统考虑不周,亦或是Linux系统的BUG,在配置了W25Q256的V3s开发板系统上,无法soft reset!经过查阅相关资料,发现,V3s默认支持24bit(3byte)的spi地址模式,而要支持32M以上的spi flash,则必须切换到32bit(4byte)地址模式.在soft reset的时候,spi停留在了32bit模式,没有切换回默认的24bit模式,导致reset后,V3s在默认的24bit模式,无法和32bit模式的spi通讯,系统死机.
感谢:
荔枝派Q群群主,
感谢 csdn的Manfeel大神
#5 2017-12-15 14:31:44
lzx1044364960
已发帖子: 35
为什么我的源码根目录没有这个drivers啊 只有这些
bin          Config.in  feeds.conf.default  LICENSE   rules.mk     tmp
BSDmakefile  dl         include             Makefile  scripts      toolchain
build_dir    docs       key-build           package   staging_dir  tools
config       feeds      key-build.pub       README    target
#6 2017-12-15 14:36:47
已发帖子: 9,423
建议你找一本Linux基本操作的书先看看
find . |grep m25p80.c
用这个命令可以找到文件的, 你先试一试, 有问题可以继续留言。
#7 2017-12-15 14:59:44
lzx1044364960
已发帖子: 35
我用的是MT7620a 32M 也是这么改么?
#8 2017-12-15 15:01:42
已发帖子: 9,423
lzx1044364960 说:
对,照着改就行了!
原理就是把bank寄存器切换回去。
#9 2017-12-15 15:21:39
lzx1044364960
已发帖子: 35
我find到三个文件改哪一个?还是都改?
./build_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_uClibc-0.9.33.2/linux-3.18.75/drivers/mtd/devices/m25p80.c
./build_dir/target-mipsel_24kec+dsp_uClibc-0.9.33.2/linux-ramips_mt7620/linux-3.18.75/.pc/platform/0044-mtd-add-chunked-read-io-to-m25p80.patch/drivers/mtd/devices/m25p80.c
./build_dir/target-mipsel_24kec+dsp_uClibc-0.9.33.2/linux-ramips_mt7620/linux-3.18.75/drivers/mtd/devices/m25p80.c
#10 2017-12-15 15:40:56
已发帖子: 9,423
看起来应该是这个:
#11 2017-12-15 15:42:34
已发帖子: 9,423
看起来应该是这个:
有2个简单的方法判断:
1 这个目录下面有没有 m25p80.o 文件?
2. 随便在m25p80.c 乱打打几个字母,编译出错就说明是这个文件了。
#12 2017-12-15 16:06:46
lzx1044364960
已发帖子: 35
三个全改了,编译以后ok了!!感谢大神们指点迷津D
#13 2017-12-15 16:12:54
已发帖子: 9,423
lzx1044364960 说:
不用客气,有空常回来转转。
#14 2017-12-15 16:27:08
lzx1044364960
已发帖子: 35
必须的
#15 2018-01-04 16:34:50
已发帖子: 9,423
发现32M spi flash 只能解决软件重启(busybox reboot)的问题,
解决不了硬件 RESET 的问题,
按下复位按键之后, W25Q256/MX25L256 芯片内部的寄存器可能没有切换回第0个bank,
导致V3s的BROM找不到启动头(估计是V3s BROM没有考虑用32M的spi flash),
而且8Pin的 spi flash没有引出RESET#引脚,
但是16pin的 spi flash引出了RESET#引脚,或许用16pin的spi flash能完美解决硬件复位的问题。
#16 2018-01-04 16:52:33
已发帖子: 9,423
widora neo用硬件解决了这个复位问题. 参考原理图: widora-neo-32-128-sch.pdf
#17 2019-02-18 16:29:04
tkyl01
# reboot
# Saving random seed... done.
Stopping logging: OK
[ 1075.465115] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Sent SIGKILL to[ 1077.487857] reboot: Restarting system
[ 1078.489799] Reboot failed -- System halted
licheepi Nano,16M flash,出现这个问题。
#18 2019-02-18 16:39:14
这个问题貌似和flash无关,可能涉及其他问题,貌似Q群提过几次了
#19 2020-05-07 15:07:55
物联小白
已发帖子: 19
怪不得我输入 reboot 没卵用,输完系统就装死。
#20 2020-05-15 21:39:32
huangjian276310465
我也是同样的问题,后面加上硬件看门狗
#21 2020-05-15 22:37:10
有梦的地方
已发帖子: 284
物联小白 说:
我换16pin的spi flash,flash复位脚和A33复位脚短路,上电一起复位,彻底解决了这个问题,全志brom的bug.
