[ 1.729441] ALSA device list:
[ 1.732429] #0: Loopback 1
[ 1.740730] Freeing unused kernel memory: 1024K
[ 1.805151] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.826963] mmc0: new high speed SD card at address 0001
[ 1.842553] mmcblk0: mmc0:0001 MS 1.83 GiB
[ 1.856988] mmcblk0: p1
can't open /dev/null: No such file or directory
Starting syslogd: OK
Starting klogd: OK
Starting mdev...
[ 5.436642] musb-sunxi 1c13000.usb: Invalid or missing 'dr_mode' property
[ 5.443491] musb-sunxi: probe of 1c13000.usb failed with error -22
Starting network: OKWelcome to Buildroot
buildroot login:
buildroot login: root
#modprobe g_serial
[ 59.417855] udc-core: couldn't find an available UDC - added [g_serial] to list of pending drivers
f1c100s 主线 Linux 的 usb 出现这个 missing 'dr_mode' property 问题, 请问应该怎么解决?
