楼主 #1 2019-05-24 21:36:49
xxdebug
nano下mt7601跑不起来用过同学帮忙指点一下
140962] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    1.147000] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[    1.157507] hub 1-0:1.0: USB hub found
[    1.161620] hub 1-0:1.0: 1 port detected
[    1.167976] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    1.186619] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    1.194610] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    1.203388] cfg80211: failed to load regulatory.db
[    1.209067] Waiting for root device /dev/mmcblk0p2...
[    1.252448] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.264504] mmc0: new high speed SD card at address e624
[    1.272667] mmcblk0: mmc0:e624 SU02G 1.84 GiB
[    1.284548]  mmcblk0: p1 p2
[    1.361742] random: fast init done
[    1.369443] EXT4-fs (mmcblk0p2): mounted filesystem without journal. Opts: (null)
[    1.377257] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    1.388088] devtmpfs: mounted
[    1.395746] Freeing unused kernel memory: 1024K
[    1.400465] Run /sbin/init as init process
[    1.604566] usb 1-1: new high-speed USB device number 2 using musb-hdrc
[    1.639751] EXT4-fs (mmcblk0p2): re-mounted. Opts: block_validity,delalloc,barrier,user_xattr,acl
[    1.828567] hub 1-1:1.0: USB hub found
[    1.843231] hub 1-1:1.0: 4 ports detected
[    2.032433] random: dd: uninitialized urandom read (512 bytes read)
[    2.164626] usb 1-1.2: new high-speed USB device number 3 using musb-hdrc
[    2.299859] hub 1-1.2:1.0: USB hub found
[    2.311781] hub 1-1.2:1.0: 4 ports detected
[    2.424633] usb 1-1.3: new full-speed USB device number 4 using musb-hdrc
[    2.634577] usb 1-1.3: new high-speed USB device number 5 using musb-hdrc
[    2.984535] usb 1-1.3: reset high-speed USB device number 5 using musb-hdrc
[    3.117259] mt7601u 1-1.3:1.0: ASIC revision: 76010001 MAC revision: 76010500
[    3.177491] mt7601u 1-1.3:1.0: EEPROM ver:0c fae:00
[    3.423941] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[    3.699238] random: dhcpcd: uninitialized urandom read (120 bytes read)
[    7.144021] random: crng init done
[   80.044534] mt7601u 1-1.3:1.0: Warning: mt7601u_mcu_wait_resp retrying
[   80.354581] mt7601u 1-1.3:1.0: Warning: mt7601u_mcu_wait_resp retrying
[   80.664513] mt7601u 1-1.3:1.0: Warning: mt7601u_mcu_wait_resp retrying
[   80.974581] mt7601u 1-1.3:1.0: Warning: mt7601u_mcu_wait_resp retrying
[   81.284529] mt7601u 1-1.3:1.0: Warning: mt7601u_mcu_wait_resp retrying
[   81.291163] mt7601u 1-1.3:1.0: Error: mt7601u_mcu_wait_resp timed out
7601模块绝对是好的,firmware也有,但不知道是否下载成功,nano,内核4。19参考晕哥帖子编译的,BUILDROOT 2019。5 8188也没跑起来,U盘读写OK
最近编辑记录 xxdebug (2019-05-24 21:57:57)
楼主 #2 2019-05-24 21:45:01
xxdebug
Re: nano下mt7601跑不起来用过同学帮忙指点一下
在线等 yikes
楼主 #3 2019-05-24 22:21:24
xxdebug
8192可以了,8188 7601还不行,坐等支援
# wpa_supplicant -Dwext -iwlan0 -c/test.conf -B
rfkill: Cannot open RFKILL contr[ 4354.637193] rtl8192cu: MAC auto ON okay!
ol device
[ 4354.679894] rtl8192cu: Tx queue select: 0x05
ioctl[SIOCSIWENCODEEXT]: Invalid argument
# [ 4357.076260] wlan0: authenticate with 10:da:43:80:c0:ea
[ 4357.097829] wlan0: send auth to 10:da:43:80:c0:ea (try 1/3)
[ 4357.111263] wlan0: authenticated
[ 4357.125505] wlan0: associate with 10:da:43:80:c0:ea (try 1/3)
[ 4357.139596] wlan0: RX AssocResp from 10:da:43:80:c0:ea (capab=0x1411 status=0 aid=9)
[ 4357.265971] wlan0: associated
# udhcpc -i wlan0
udhcpc: started, v1.30.1
udhcpc: sending discover
udhcpc: sending select for 10.0.0.19
udhcpc: lease of 10.0.0.19 obtained, lease time 86400
deleting routers
adding dns 10.0.0.1
# ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
2: bond0: <NO-CARRIER,BROADCAST,MULTICAST,MASTER,UP> mtu 1500 qdisc noqueue state DOWN group default qlen 1000
    link/ether 6a:c7:11:4d:3b:4d brd ff:ff:ff:ff:ff:ff
5: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
    link/ether 00:0f:00:ce:cb:3c brd ff:ff:ff:ff:ff:ff
    inet 10.0.0.19/24 brd 10.0.0.255 scope global wlan0
# ping [url=http://www.sina.com]www.sina.com[/url]
PING 202.102.94.124 (202.102.94.124) 56(84) bytes of data.
64 bytes from 202.102.94.124 (202.102.94.124): icmp_seq=1 ttl=57 time=152 ms
64 bytes from 202.102.94.124 (202.102.94.124): icmp_seq=2 ttl=57 time=12.7 ms
64 bytes from 202.102.94.124 (202.102.94.124): icmp_seq=3 ttl=57 time=13.6 ms
64 bytes from 202.102.94.124 (202.102.94.124): icmp_seq=4 ttl=57 time=12.3 ms
64 bytes from 202.102.94.124 (202.102.94.124): icmp_seq=5 ttl=57 time=17.3 ms
^C
--- 202.102.94.124 ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 10ms
rtt min/avg/max/mdev = 12.287/41.649/152.344/55.376 ms
楼主 #4 2019-05-25 08:47:40
xxdebug
8188f厂家驱动编译成KO也可以了,7601是不是也要厂家驱动,没搞成功
最近编辑记录 xxdebug (2019-05-25 08:48:25)
#5 2019-05-25 20:35:27
已发帖子: 9,437
不会,帮你顶一下吧
#6 2020-05-24 01:54:44
zhaolei_cpp
已发帖子: 23
xxdebug 说:
问题解决了吗?
我买的荔枝nano没有问题,自己焊接的板子,就和你的错误的一样的?
