楼主 #1 2017-12-16 09:38:03
daydayup
已发帖子: 343
请问各路大神直接烧录荔枝派zero提供的预编译u-boot和固件,出现这个错误, 应该如何解决?
U-Boot 2017.01-rc2-00055-gc41fbfe7b5 (Jan 20 2017 - 00:39:08 +0800) Allwinner Technology
Model: Lichee Pi Zero
DRAM: 64 MiB
MMC: SUNXI SD/MMC: 0
dotclock: 33000kHz = 33000kHz: (1 3MHz 66) / 6
In: serial@01c28000
Out: serial@01c28000
Err: serial@01c28000
Net: No ethernet found.
No controllers found
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
reading /sun8i-v3s-licheepi-zero.dtb
8585 bytes read in 28 ms (298.8 KiB/s)
USB is stopped. Please issue 'usb start' first.
No ethernet found.
missing environment variable: bootfile
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-sunxi
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
No ethernet found.
最近编辑记录 daydayup (2017-12-16 09:38:22)
#2 2017-12-16 09:42:13
已发帖子: 9,519
Re: 请问各路大神直接烧录荔枝派zero提供的预编译u-boot和固件,出现这个错误, 应该如何解决?
执行这三条指令,药到病除:
setenv bootcmd "setenv bootm_boot_mode sec; load mmc 0:1 0x41000000 zImage; load mmc 0:1 0x41800000 sun8i-v3s-licheepi-zero-dock.dtb; bootz 0x41000000 - 0x41800000;"
setenv bootargs "console=ttyS0,115200 panic=5 mtdparts=spi32766.0:1M(uboot),64k(dtb),4M(kernel),-(rootfs) rootwait root=/dev/mmcblk0p2 earlyprintk rw vt.global_cursor_default=0"
boot
#3 2017-12-16 10:29:34
zhuacai
已发帖子: 234
[ 0.000000] Linux version 4.13.0-licheepi-zero+ (root@ubuntu) (gcc version 6.3.1 20170109 (Linaro GCC 6.3-2017.02)) #1 SMP Tue Dec 12 17:49:00 PST 2017
[ 0.000000] OF: fdt: Machine model: Lichee Pi Zero with Dock
[ 0.000000] percpu: Embedded 16 pages/cpu @c3de6000 s33868 r8192 d23476 u65536
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 15883
[ 0.000000] Kernel command line: console=ttyS0,115200 panic=5 mtdparts=spi32766.0:1M(uboot),64k(dtb),4M(kernel),-(rootfs) rootwait root=/dev/mmcblk0p2 earlyprintk rw vt.global_cursor_default=0
[ 0.000000] Memory: 53584K/64036K available (6144K kernel code, 217K rwdata, 1436K rodata, 1024K init, 262K bss, 10452K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] vmalloc : 0xc4000000 - 0xff800000 ( 952 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc3e89000 ( 62 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0700000 (7136 kB)
[ 0.000000] .init : 0xc0900000 - 0xc0a00000 (1024 kB)
[ 0.000000] .data : 0xc0a00000 - 0xc0a36680 ( 218 kB)
[ 0.000000] .bss : 0xc0a3d868 - 0xc0a7f06c ( 263 kB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU event tracing is enabled.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
[ 0.000008] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000021] Switching to timer-based delay loop, resolution 41ns
[ 0.000186] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000418] Console: colour dummy device 80x30
[ 0.000453] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000468] pid_max: default: 32768 minimum: 301
[ 0.000595] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000613] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001216] CPU: Testing write buffer coherency: ok
[ 0.001590] /cpus/cpu@0 missing clock-frequency property
[ 0.001616] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002064] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.002253] Hierarchical SRCU implementation.
[ 0.002765] smp: Bringing up secondary CPUs ...
[ 0.002781] smp: Brought up 1 node, 1 CPU
[ 0.002790] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.002797] CPU: All CPU(s) started in SVC mode.
[ 0.003556] devtmpfs: initialized
[ 0.006605] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.006884] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.006916] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.007084] pinctrl core: initialized pinctrl subsystem
[ 0.007967] random: get_random_u32 called from bucket_table_alloc+0xf4/0x244 with crng_init=0
[ 0.008104] NET: Registered protocol family 16
[ 0.008588] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.009719] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.009738] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.023039] SCSI subsystem initialized
[ 0.023332] usbcore: registered new interface driver usbfs
[ 0.023400] usbcore: registered new interface driver hub
[ 0.023493] usbcore: registered new device driver usb
[ 0.023749] pps_core: LinuxPPS API ver. 1 registered
[ 0.023759] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.023798] PTP clock support registered
[ 0.024024] Advanced Linux Sound Architecture Driver Initialized.
[ 0.025870] clocksource: Switched to clocksource arch_sys_counter
[ 0.036974] NET: Registered protocol family 2
[ 0.037568] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.037605] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.037628] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.037763] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.037814] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.038037] NET: Registered protocol family 1
[ 0.038646] RPC: Registered named UNIX socket transport module.
[ 0.038665] RPC: Registered udp transport module.
[ 0.038670] RPC: Registered tcp transport module.
[ 0.038677] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.040778] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.049754] NFS: Registering the id_resolver key type
[ 0.049810] Key type id_resolver registered
[ 0.049819] Key type id_legacy registered
[ 0.050840] random: fast init done
[ 0.053748] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.053772] io scheduler noop registered
[ 0.053780] io scheduler deadline registered
[ 0.054032] io scheduler cfq registered (default)
[ 0.054045] io scheduler mq-deadline registered
[ 0.054052] io scheduler kyber registered
[ 0.058514] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.128575] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.131923] console [ttyS0] disabled
[ 0.152194] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 36, base_baud = 1500000) is a U6_16550A
[ 0.736175] console [ttyS0] enabled
[ 0.743086] libphy: Fixed MDIO Bus: probed
[ 0.747743] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[ 0.753542] dwmac-sun8i 1c30000.ethernet: No regulator found
[ 0.759311] dwmac-sun8i 1c30000.ethernet: Will use internal PHY
[ 0.765464] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[ 0.771167] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[ 0.778397] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[ 0.784050] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[ 0.791274] dwmac-sun8i 1c30000.ethernet: COE Type 2
[ 0.796243] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[ 0.803196] libphy: stmmac: probed
[ 0.808508] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.815048] ehci-platform: EHCI generic platform driver
[ 0.820671] ehci-platform 1c1a000.usb: EHCI Host Controller
[ 0.826351] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[ 0.834273] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000
[ 0.865894] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[ 0.873069] hub 1-0:1.0: USB hub found
[ 0.877036] hub 1-0:1.0: 1 port detected
[ 0.881546] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.887845] ohci-platform: OHCI generic platform driver
[ 0.893419] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[ 0.900148] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[ 0.908107] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400
[ 0.980953] hub 2-0:1.0: USB hub found
[ 0.984778] hub 2-0:1.0: 1 port detected
[ 0.992382] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[ 1.001961] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input0
[ 1.010941] sun6i-rtc 1c20400.rtc: rtc core: registered rtc-sun6i as rtc0
[ 1.017846] sun6i-rtc 1c20400.rtc: RTC enabled
[ 1.022388] i2c /dev entries driver
[ 1.027393] input: ns2009_ts as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0048/input/input1
[ 1.036901] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.105921] sunxi-mmc 1c0f000.mmc: base:0xc41f8000 irq:23
[ 1.165902] sunxi-mmc 1c10000.mmc: base:0xc41fc000 irq:24
[ 1.172418] usbcore: registered new interface driver usbhid
[ 1.178088] usbhid: USB HID core driver
[ 1.183559] sun4i-codec 1c22c00.codec: ASoC: /soc/codec-analog@01c23000 not registered
[ 1.191614] sun4i-codec 1c22c00.codec: Failed to register our card
[ 1.200240] NET: Registered protocol family 17
[ 1.204802] Key type dns_resolver registered
[ 1.209334] Registering SWP/SWPB emulation handler
[ 1.220967] simple-framebuffer 43e89000.framebuffer: framebuffer at 0x43e89000, 0x177000 bytes, mapped to 0xc4380000
[ 1.231638] simple-framebuffer 43e89000.framebuffer: format=x8r8g8b8, mode=800x480x32, linelength=3200
[ 1.248028] Console: switching to colour frame buffer device 100x30
[ 1.260476] simple-framebuffer 43e89000.framebuffer: fb0: simplefb registered!
[ 1.269032] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 1.280414] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.286254] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[ 1.294186] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.303454] hub 3-0:1.0: USB hub found
[ 1.307633] mmc0: new high speed SDHC card at address e624
[ 1.313717] hub 3-0:1.0: 1 port detected
[ 1.317933] mmcblk0: mmc0:e624 SU04G 3.69 GiB
[ 1.324641] using random self ethernet address
[ 1.329238] using random host ethernet address
[ 1.334113] mmcblk0: p1 p2
[ 1.338898] usb0: HOST MAC 1e:69:ad:e2:7c:5f
[ 1.343219] usb0: MAC 86:6f:e8:bc:ef:b5
[ 1.347212] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[ 1.354691] g_cdc gadget: g_cdc ready
[ 1.360979] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
[ 1.369697] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01 00:16:21 UTC (981)
[ 1.378119] vcc5v0: disabling
[ 1.381096] ALSA device list:
[ 1.384060] #0: V3s Audio Codec
[ 1.389582] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[ 1.399069] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[ 1.408987] mmc1: new high speed SDIO card at address 0001
[ 1.427652] EXT4-fs (mmcblk0p2): recovery complete
[ 1.432475] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.440744] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 1.448074] devtmpfs: mounted
[ 1.452344] Freeing unused kernel memory: 1024K
[ 1.458351] Starting init: /sbin/init exists but couldn't execute it (error -13)
[ 1.510886] musb-hdrc musb-hdrc.1.auto: VBUS_ERROR in b_idle (80, <SessEnd), retry #0, port1 00000100
/bin/sh: can't open 'earlyprintk'
[ 1.586006] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000200
[ 1.586006]
[ 1.595148] CPU: 0 PID: 1 Comm: sh Not tainted 4.13.0-licheepi-zero+ #1
[ 1.601752] Hardware name: Allwinner sun8i Family
[ 1.606489] [<c010e58c>] (unwind_backtrace) from [<c010b2b0>] (show_stack+0x10/0x14)
[ 1.614239] [<c010b2b0>] (show_stack) from [<c06627fc>] (dump_stack+0x84/0x98)
[ 1.621463] [<c06627fc>] (dump_stack) from [<c011b728>] (panic+0xdc/0x248)
[ 1.628336] [<c011b728>] (panic) from [<c011e298>] (do_exit+0xa68/0xa98)
[ 1.635034] [<c011e298>] (do_exit) from [<c011f114>] (do_group_exit+0x3c/0xd0)
[ 1.642249] [<c011f114>] (do_group_exit) from [<c011f1b8>] (__wake_up_parent+0x0/0x18)
[ 1.650168] Rebooting in 5 seconds..
我遇到的问题和楼主一样,按晕哥的方法解决,但又出现以上问题不能启动根文件系统,还请晕哥帮忙解决,谢谢!
#4 2017-12-16 10:33:57
已发帖子: 9,519
这个问题一般出现在使用了错误的工具链生成了busybox, 导致你使用了错误的指令集。
#5 2017-12-16 10:36:03
已发帖子: 9,519
你检查一下生成busybox是不是用了x86/x64的gcc, 而不是arm linux平台的gcc.
这个帖子: 荔枝派Zero V3s开发板入坑教程 的一楼有我编译好的uboot,zImage, rootfs下载。
#6 2017-12-16 10:46:43
zhuacai
已发帖子: 234
晕哥,我是按照 荔枝派Zero V3s开发板入坑教程 制作的文件系统,直接用buildroot-v3s-20171122.config配置文件编译,就是不知那里设置交又编译工具链!是不否能请教下那里设置交又编译工具链.
#7 2017-12-16 10:57:59
已发帖子: 9,519
哎,又一个被我带入坑的
看15楼: 荔枝派Zero V3s开发板入坑教程
我大概明白原因了, 应该解压缩 buildroot-v3s-20171122.zip 改名 成 .config
#8 2017-12-16 10:58:32
已发帖子: 9,519
看来挖坑侠不是白叫的 big_smile big_smile big_smile
#9 2017-12-16 11:06:11
zhuacai
已发帖子: 234
哎,又一个被我带入坑的
我是改成了.config才编译了
#10 2017-12-16 11:09:47
Wang
太多小白入坑了,晕哥应该多做些基础教程了:D
#11 2017-12-16 11:12:27
已发帖子: 9,519
zhuacai wrote:
哎,又一个被我带入坑的
我是改成了.config才编译了
这就尴尬了.
  1. 打开 .config, 看工具链是否真有arm ? 对比一下文件, linux下可以用meld工具,挺好用。
  2. 编译的时候控制台会出现工具链信息,确认是否是gcc or arm-linux-gcc ?
#12 2017-12-16 11:13:41
已发帖子: 9,519
挖坑网感谢各路网友捧场!
#13 2019-11-07 17:50:05
单刀
DRAM: 64 MiB
In: serial@01c28000
Scanning mmc 0:1...
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
其实最主要的问题是应该配置下u-boot里的sun8i.h(完整路径u-boot/include/configs/sun8i.h)
添加内容如下:
#define CONFIG_BOOTCOMMAND "setenv bootm_boot_mode sec; load mmc 0:1 0x41000000 zImage; load mmc 0:1 0x41800000 sun8i-v3s-licheepi-zero-dock.dtb; bootz 0x41000000 - 0x41800000;"
#define CONFIG_BOOTARGS    "console=ttyS0,115200 panic=5 mtdparts=spi32766.0:1M(uboot),64k(dtb),4M(kernel),-(rootfs) rootwait root=/dev/mmcblk0p2 earlyprintk rw  vt.global_cursor_default=0"
sun8i.h
今天刚入手荔枝派zero,搞完了spi启动,现在又搞TF启动,因此我也碰见了这问题。之前楼上在讨论是busybox的编译问题,但是既然用2楼的三条命令可以启动,那说明整个文件系统编译没有问题,否则再怎么着也启动不了。
感觉晕歌给的命令很像SPI启动的配置方式,因此就狸猫换太子,把命令修改了一下,结果还真好了。
最近编辑记录 单刀 (2019-11-07 17:50:49)
#14 2022-11-29 14:47:25
weilanhai1
先复制到虚拟机里面,然后解压,得到文件 buildroot-v3s-20171122.config
然后这里注意了啊,使用mv命令把这个文件移动到buildroot-2017.08这个源码文件夹下,并把这个文件名字改成.config
具体命令如下(我目前的路径就在这个配置文件的地方):
mv buildroot-v3s-20171122.config buildroot-2017.08/.config
然后这个配置文件就挪到了buildroot里面,里面的配置就会按照这个文件进行编译。
然后make它:
期间会下载很多软件包,下载速度非常慢,有一个方法是在控制台上复制他们的下载链接,用迅雷等下载器下载,然后复制到buildroot文件夹下的dl文件夹中,要是dl文件夹没有,那就先make一下,在ctrl+C取消掉,就会生成了。
然后再重新make,就会在/output/images下生成roofs.tar这个文件。
这个文件就是我们的文件系统,要烧录到TF卡中。
至此,需要的镜像全部编译完,拿到需要的四个文件:
