楼主 #1 2019-06-11 21:11:29
全志 GPIO 驱动能力设置
https://github.com/torvalds/linux/blob/master/arch/arm/boot/dts/sun8i-v3s.dtsi
mmc0_pins: mmc0-pins {
pins = "PF0", "PF1", "PF2", "PF3",
"PF4", "PF5";
function = "mmc0";
drive-strength = <30>; /10, 20, 30, 40mA 四个档次/
bias-pull-up;
代码实现:
https://github.com/torvalds/linux/blob/master/drivers/pinctrl/sunxi/pinctrl-sunxi.c
static int sunxi_pctrl_parse_drive_prop(struct device_node *node)
	u32 val;
	/* Try the new style binding */
	if (!of_property_read_u32(node, "drive-strength", &val)) {
		/* We can't go below 10mA ... */
		if (val < 10)
			return -EINVAL;
		/* ... and only up to 40 mA ... */
		if (val > 40)
			val = 40;
		/* by steps of 10 mA */
		return rounddown(val, 10);
	/* And then fall back to the old binding */
	if (of_property_read_u32(node, "allwinner,drive", &val))
		return -EINVAL;
	return (val + 1) * 10;
#2 2019-06-11 21:28:37
zhenfanhei
已发帖子: 344
Re: 全志 GPIO 驱动能力设置
不是写0,1,2,3吗,哦,可能内核不一样有区别,我看的一个devicetree文档里面是写这个
最近编辑记录 zhenfanhei (2019-06-11 21:29:49)
楼主 #3 2019-06-11 21:29:25
Re: 全志 GPIO 驱动能力设置
zhenfanhei wrote:
不是写0,1,2,3吗,
不是 10, 20, 30, 40,
看实现代码和 dts 样例得出的结论.
