楼主 #1 2019-06-24 19:21:36
VMware® Workstation 14 Pro 安装 Ubuntu18.04, 安装程序会自动装上 vmtools, 不需要手动安装了
感觉挺方便的
楼主 #2 2019-06-24 23:41:19
Re: VMware® Workstation 14 Pro 安装 Ubuntu18.04, 安装程序会自动装上 vmtools, 不需要手动安装了
smartcar:/$ gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/7/lto-wrapper
OFFLOAD_TARGET_NAMES=nvptx-none
OFFLOAD_TARGET_DEFAULT=1
Target: x86_64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Ubuntu 7.4.0-1ubuntu1~18.04.1' --with-bugurl=file:///usr/share/doc/gcc-7/README.Bugs --enable-languages=c,ada,c++,go,brig,d,fortran,objc,obj-c++ --prefix=/usr --with-gcc-major-version-only --program-suffix=-7 --program-prefix=x86_64-linux-gnu- --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-vtable-verify --enable-libmpx --enable-plugin --enable-default-pie --with-system-zlib --with-target-system-zlib --enable-objc-gc=auto --enable-multiarch --disable-werror --with-arch-32=i686 --with-abi=m64 --with-multilib-list=m32,m64,mx32 --enable-multilib --with-tune=generic --enable-offload-targets=nvptx-none --without-cuda-driver --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu
Thread model: posix
gcc version 7.4.0 (Ubuntu 7.4.0-1ubuntu1~18.04.1)
smartcar:/$ arm-linux-gnueabihf-gcc -v
COLLECT_GCC=arm-linux-gnueabihf-gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc-cross/arm-linux-gnueabihf/7/lto-wrapper
Target: arm-linux-gnueabihf
Configured with: ../src/configure -v --with-pkgversion='Ubuntu/Linaro 7.4.0-1ubuntu1~18.04.1' --with-bugurl=file:///usr/share/doc/gcc-7/README.Bugs --enable-languages=c,ada,c++,go,d,fortran,objc,obj-c++ --prefix=/usr --with-gcc-major-version-only --program-suffix=-7 --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-libitm --disable-libquadmath --disable-libquadmath-support --enable-plugin --enable-default-pie --with-system-zlib --with-target-system-zlib --enable-multiarch --enable-multilib --disable-sjlj-exceptions --with-arch=armv7-a --with-fpu=vfpv3-d16 --with-float=hard --with-mode=thumb --disable-werror --enable-multilib --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=arm-linux-gnueabihf --program-prefix=arm-linux-gnueabihf- --includedir=/usr/arm-linux-gnueabihf/include
Thread model: posix
gcc version 7.4.0 (Ubuntu/Linaro 7.4.0-1ubuntu1~18.04.1)
gcc 默认都是 7.4 了, 这很好,不需要再手动安装其他工具链
楼主 #3 2019-06-25 07:00:26
选择 aliyun 阿里云软件源
楼主 #4 2019-06-25 08:55:08
sudo apt install gnome-tweak-tool
gnome-tweaks
虚拟机里面还是关闭动画显示比较好,没必要那么炫酷。
最近编辑记录 smartcar (2019-06-25 08:55:37)
#5 2019-06-25 09:23:38
Jmhh247
已发帖子: 262
不错,不错
楼主 #6 2019-06-25 14:03:44
解决右上角网络图标消失, 网络连接失败等问题:
sudo service network-manager stop
sudo rm /var/lib/NetworkManager/NetworkManager.state
sudo service network-manager start
楼主 #7 2019-06-26 14:48:31
关闭恼人的屏保: https://askubuntu.com/questions/1048774/disabling-lock-screen-18-04
关闭屏保:
gsettings set org.gnome.desktop.lockdown disable-lock-screen 'true'
读取 是否关闭屏保:
gsettings get org.gnome.desktop.lockdown disable-lock-screen
楼主 #8 2019-06-29 11:53:50
上面的屏保还是没有关掉, 久久不用还是进入了屏保, 还要手势上拉才能进入窗口, 虽然不用输入密码。
还有 通用的电脑配置, Ubuntu18.04 比 14.04 慢了挺多。
