楼主 #1 2019-06-25 11:18:10
用 gcc7 编译 bsp V3s 出错了, 有没有大神可以帮忙解决?
smartcar@ubuntu:/opt/v3s_linux3.4$ make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- uImage
  HOSTCC  scripts/kconfig/conf.o
  SHIPPED scripts/kconfig/zconf.tab.c
  SHIPPED scripts/kconfig/zconf.lex.c
  SHIPPED scripts/kconfig/zconf.hash.c
  HOSTCC  scripts/kconfig/zconf.tab.o
  HOSTLD  scripts/kconfig/conf
scripts/kconfig/conf --silentoldconfig Kconfig
  WRAP    arch/arm/include/generated/asm/auxvec.h
  WRAP    arch/arm/include/generated/asm/bitsperlong.h
  WRAP    arch/arm/include/generated/asm/cputime.h
  WRAP    arch/arm/include/generated/asm/emergency-restart.h
  WRAP    arch/arm/include/generated/asm/errno.h
  WRAP    arch/arm/include/generated/asm/ioctl.h
  WRAP    arch/arm/include/generated/asm/irq_regs.h
  WRAP    arch/arm/include/generated/asm/kdebug.h
  WRAP    arch/arm/include/generated/asm/local.h
  WRAP    arch/arm/include/generated/asm/local64.h
  WRAP    arch/arm/include/generated/asm/percpu.h
  WRAP    arch/arm/include/generated/asm/poll.h
  WRAP    arch/arm/include/generated/asm/resource.h
  WRAP    arch/arm/include/generated/asm/sections.h
  WRAP    arch/arm/include/generated/asm/siginfo.h
  WRAP    arch/arm/include/generated/asm/sizes.h
  CHK     include/linux/version.h
  UPD     include/linux/version.h
  CHK     include/generated/utsrelease.h
  UPD     include/generated/utsrelease.h
  Generating include/generated/mach-types.h
  CC      kernel/bounds.s
In file included from include/linux/compiler.h:48:0,
                 from include/linux/stddef.h:4,
                 from include/linux/posix_types.h:4,
                 from include/linux/types.h:17,
                 from include/linux/page-flags.h:8,
                 from kernel/bounds.c:9:
include/linux/compiler-gcc.h:100:1: fatal error: linux/compiler-gcc7.h: No such file or directory
#include gcc_header(__GNUC__)
compilation terminated.
/opt/v3s_linux3.4/./Kbuild:35: recipe for target 'kernel/bounds.s' failed
make[1]: *** [kernel/bounds.s] Error 1
Makefile:985: recipe for target 'prepare0' failed
make: *** [prepare0] Error 2
楼主 #2 2019-06-25 11:18:55
Re: 用 gcc7 编译 bsp V3s 出错了, 有没有大神可以帮忙解决?
我是参考 @qianhao 大神这个帖子: https://whycan.cn/t_682.html
6.编译内核
使用我提供的 lichee_BSP_config 说明一下  这里修改了内核支持网口 支持ext4文件系统 就直接给出我配置好的。
cd linux-3.4
cp lichee_BSP_config .config
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabi- uImage -j16
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabi- -j16 INSTALL_MOD_PATH=out modules
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabi- -j16 INSTALL_MOD_PATH=out modules_install
这时  我们要用的  uImage 在 arch/arm/boot/uImage
楼主 #3 2019-06-25 11:25:45
复制一份,骗一骗编译器搞定:
cp include/linux/compiler-gcc4.h include/linux/compiler-gcc7.h
'make CONFIG_DEBUG_SECTION_MISMATCH=y'
  GEN     .version
  CHK     include/generated/compile.h
  UPD     include/generated/compile.h
  CC      init/version.o
  LD      init/built-in.o
  LD      .tmp_vmlinux1
  KSYM    .tmp_kallsyms1.S
  AS      .tmp_kallsyms1.o
  LD      .tmp_vmlinux2
  KSYM    .tmp_kallsyms2.S
  AS      .tmp_kallsyms2.o
  LD      vmlinux
  SYSMAP  System.map
  SYSMAP  .tmp_System.map
  OBJCOPY arch/arm/boot/Image
  Kernel: arch/arm/boot/Image is ready
  AS      arch/arm/boot/compressed/head.o
  GZIP    arch/arm/boot/compressed/piggy.gzip
  AS      arch/arm/boot/compressed/piggy.gzip.o
  CC      arch/arm/boot/compressed/misc.o
  CC      arch/arm/boot/compressed/decompress.o
  CC      arch/arm/boot/compressed/string.o
  SHIPPED arch/arm/boot/compressed/lib1funcs.S
  AS      arch/arm/boot/compressed/lib1funcs.o
  SHIPPED arch/arm/boot/compressed/ashldi3.S
  AS      arch/arm/boot/compressed/ashldi3.o
  LD      arch/arm/boot/compressed/vmlinux
  OBJCOPY arch/arm/boot/zImage
  Kernel: arch/arm/boot/zImage is ready
  UIMAGE  arch/arm/boot/uImage
Image Name:   Linux-3.4.39+
Created:      Tue Jun 25 11:22:27 2019
Data Size:    2572736 Bytes = 2512.44 KiB = 2.45 MiB
Load Address: 40008000
Entry Point:  40008000
  Image arch/arm/boot/uImage is ready
