楼主 #1 2018-05-30 15:23:49
gary
已发帖子: 54
移植 littleVGL 到nuc976 + MCU 8位9341 QVGA 彩屏+ FT6236 CTP
硬件资源:
TFT  (9341)
LCD_D0----D7   :  PA0---PA7
LCD_RS : PG9
LCD_nOE:PG8
LCD_nWE:PG7
LCD_nCS: PG6
LCD_RESET:PG0
LCD_BL: PH1
CTP  (FT6336U)
CTP_SDA:PA14
CTP_SCL:PA13
CTP_INT: PA12
CTP_RST:PA11
LCD 初始化
int32_t main(void)
         uint8_t *u8FrameBufPtr,*u8OSDFrameBufPtr;
         int i;
            outpw(REG_CLK_HCLKEN, 0x0527);
            outpw(REG_CLK_PCLKEN0, 0);
            outpw(REG_CLK_PCLKEN1, 0);
// outpw(REG_SYS_PWRON, (inpw(REG_SYS_PWRON)& ~0x00000004) | 0xFFFFFFF7);
       outpw(REG_SYS_REGWPCTL,0x59);
       outpw(REG_SYS_REGWPCTL,0x16);
       outpw(REG_SYS_REGWPCTL,0x88);
       while(!(inpw(REG_SYS_REGWPCTL)&(1<<0)));
         sysClearWatchDogTimerCount();    // clear WDT
         sysClearWatchDogTimerInterruptStatus();
         sysDisableWatchDogTimer();                //close WDT
         sysDisableWatchDogTimerReset();
         sysDisableCache();
         sysFlushCache(I_D_CACHE);
         sysEnableCache(CACHE_WRITE_BACK);
         sysInitializeUART();
        // Configure multi-function pin for LCD interface
        //GPG6 (CLK), GPG7 (HSYNC)
        outpw(REG_SYS_GPG_MFPL, (inpw(REG_SYS_GPG_MFPL)& ~0xFF000000) | 0x22000000);
        //GPG8 (VSYNC), GPG9 (DEN)
        outpw(REG_SYS_GPG_MFPH, (inpw(REG_SYS_GPG_MFPH)& ~0xFF) | 0x22);
        //DATA pin (8bit)
        outpw(REG_SYS_GPA_MFPL, 0x22222222);    //GPA0 ~ GPA7 (DATA0~7)
        // outpw(REG_SYS_GPA_MFPH, 0x22222222); //GPA8 ~ GPA15 (DATA8~15)
        //GPD8~D15 (DATA16~17)
        // outpw(REG_SYS_GPD_MFPH, (inpw(REG_SYS_GPD_MFPH)& ~0xFF) | 0x22);
        // LCD clock is selected from UPLL and divide to 20MHz
        outpw(REG_CLK_DIVCTL1, (inpw(REG_CLK_DIVCTL1) & ~0xFF1F) | 0x1018);
        // Init LCD interface for ILI9341 LCD module
        vpostLCMInit(DIS_PANEL_ILI9341_MPU80);
        // Init MPU80_TFT_8bit
       MPU80_TFT_Init();
       /* Setup display address */
     MPU80_TFT_SetAddress(0, 239, 0, 319);
        // Set scale to 1:1
        vpostVAScalingCtrl(1, 0, 1, 0, VA_SCALE_INTERPOLATION);
        // Set display color depth
        vpostSetVASrc(VA_SRC_RGB565);
        // Get pointer of video frame buffer
        // Note: before get pointer of frame buffer, must set display color depth first
            u8FrameBufPtr = vpostGetFrameBuffer();
            if(u8FrameBufPtr == NULL)
            sysprintf("Get buffer error !!\n");
        vpostOSDSetWindow(33, 30, 70, 70);
            /* Memory write */
        vpostSetOSDSrc(OSD_SRC_RGB565);
        u8OSDFrameBufPtr = vpostGetOSDBuffer();
        if(u8OSDFrameBufPtr == NULL)
        sysprintf("Get OSD buffer error !!\n");
        // Set scale to 1:1
        vpostOSDScalingCtrl(1, 0, 0);
        // Configure overlay function of OSD to display OSD image
        vpostOSDSetOverlay(DISPLAY_OSD, DISPLAY_OSD, 0);
        // Enable color key function
        vpostOSDSetColKey(0, 0, 0);
        vpostMPUWriteAddr(0x2c);
最近编辑记录 gary (2018-05-30 15:38:59)
楼主 #2 2018-05-30 15:39:45
gary
已发帖子: 54
Re: 移植 littleVGL 到nuc976 + MCU 8位9341 QVGA 彩屏+ FT6236 CTP
上面是点屏的代码
#3 2018-05-30 15:47:26
已发帖子: 9,415
屏幕可以点亮吗?
楼主 #4 2018-05-30 16:19:50
gary
已发帖子: 54
可以的,加上littleVGL 后编译很多错
#5 2018-05-30 16:21:49
已发帖子: 9,415
#6 2018-05-30 16:31:14
sindy
已发帖子: 146
楼主你的ILI9341屏在哪里买的?为什么我买到的都是SPI接口的?
楼主 #7 2018-05-30 21:20:59
gary
已发帖子: 54
9341,7789的屏我以前做产品用过,市场上很多的
#8 2018-05-30 21:30:56
已发帖子: 9,415
带CTP什么价格?
楼主 #9 2018-05-31 09:48:09
gary
已发帖子: 54
CTP是分开的
楼主 #10 2019-07-03 16:09:25
gary
已发帖子: 54
nuc97x  littltVGL DEMO
楼主 #11 2019-07-15 15:47:49
gary
已发帖子: 54
附件上传了,看不到
#12 2019-07-15 15:59:51
已发帖子: 9,415
gary 说:
附件上传了,看不到
给你添麻烦了,这个bbs不太好用, 需要插入: https://whycan.cn/t_588.html#p16351
