楼主 #1 2017-12-25 15:20:10
qianhao
已发帖子: 138
有没有使用过BSP内核(lichee里面编译的),它后面接的根文件系统可以使用最新的buildroot出来的吗
我使用lichee编译出来的内核,配上最新的buildroot出来的根文件系统 启动到内核以后 就卡着不动了。截取到卡死的那一段
[    4.594237] [mmc]: sdc2 set ios: clk 25000000Hz bm PP pm ON vdd 3.3V width 1 timing MMC-HS(SDR20) dt B
[    4.594307] [mmc]: mclk 0xf1c20090 0xc100000b
[    4.615689] otg_wakelock_init: No USB transceiver found
[    4.621530] sunxi-rtc sunxi-rtc: setting system clock to 1970-01-01 00:00:06 UTC (6)
[    4.630165] ths_fetch_sysconfig_para: type err  device_used = 1.
[    4.636925] ths_fetch_sysconfig_para: type err ths_trip1_3 = 110.
[    4.643790] ths_fetch_sysconfig_para: type err ths_trip1_4 = 110.
[    4.649340] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing MMC-HS(SDR20) dt B
[    4.649411] [mmc]: mclk 0xf1c20090 0xc1000005
[    4.665789] ths_fetch_sysconfig_para: type err ths_trip1_5 = 110.
[    4.672655] ths_fetch_sysconfig_para: type err ths_trip1_6 = 110.
[    4.679508] ths_fetch_sysconfig_para: type err ths_trip1_7 = 110.
[    4.686379] ths_fetch_sysconfig_para: type err ths_trip1_3_min = 0.
[    4.693437] ths_fetch_sysconfig_para: type err ths_trip1_3_max = 0.
[    4.700493] ths_fetch_sysconfig_para: type err ths_trip1_4_min = 0.
[    4.704540] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing MMC-HS(SDR20) dt B
[    4.704604] [mmc]: mclk 0xf1c20090 0xc1000005
[    4.722683] ths_fetch_sysconfig_para: type err ths_trip1_4_max = 0.
[    4.729728] ths_fetch_sysconfig_para: type err ths_trip1_5_min = 0.
[    4.736786] ths_fetch_sysconfig_para: type err ths_trip1_5_max = 0.
[    4.743844] ths_fetch_sysconfig_para: type err ths_trip1_6_min = 0.
[    4.750901] ths_fetch_sysconfig_para: type err ths_trip1_6_max = 0.
[    4.757946] ths_fetch_sysconfig_para: type err ths_trip2_count = 0.
[    4.759807] mmc0: new high speed MMC card at address 0001
[    4.760246] mmcblk0: mmc0:0001 8WPD3R 7.28 GiB
[    4.760443] mmcblk0boot0: mmc0:0001 8WPD3R partition 1 4.00 MiB
[    4.760635] mmcblk0boot1: mmc0:0001 8WPD3R partition 2 4.00 MiB
[    4.761666]  mmcblk0: p1 p2 p3 < p5 p6 p7 p8 >
[    4.761717] mmcblk0: p1 size 10969088 extends beyond EOD, truncated
[    4.764075]  mmcblk0boot1: unknown partition table
[    4.765035]  mmcblk0boot0: unknown partition table
[    4.765269] *******************mmc init ok *******************
[    4.818024] ths_fetch_sysconfig_para: type err ths_trip2_0 = 0.
[    4.820031] ====codec_init_events===
[    4.828873] input: sunxi-ths as /devices/virtual/input/input2
[    4.835721] suxi_ths: Kernel Thermal management registered
[    4.841831] fetch C0_LV_count from sysconfig failed
[    4.847712] CPU Budget:Register notifier
[    4.852089] CPU Budget:register Success
[    4.856343] sunxi-budget-cooling sunxi-budget-cooling: Cooling device registered: thermal-budget-0
[    4.870177] ALSA device list:
[    4.873471]   #0: audiocodec
[    4.877013] Freeing init memory: 328K
[    4.929825] EXT4-fs (mmcblk0p7): barriers disabled
[    4.936737] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,barrier=0,data=ordered
#2 2017-12-25 15:39:41
已发帖子: 9,435
Re: 有没有使用过BSP内核(lichee里面编译的),它后面接的根文件系统可以使用最新的buildroot出来的吗
根文件系统可以用buildroot编译出来的rootfs.
我现在项目还和新唐NUC972共用rootfs呢,一样的用。
#3 2017-12-25 15:49:36
daydayup
已发帖子: 343
建议看下是不是缺了 /dev/console 的设备?如果没有就用 mknod /dev/console c 5 1 建一个。
参考: jsanders/code/init
楼主 #4 2017-12-26 10:17:51
qianhao
已发帖子: 138
有 /dev/console的  不知道为什么不行 很蛋疼
#5 2017-12-26 10:24:40
已发帖子: 9,435
qianhao 说:
那用buildroot的rootfs试一试
楼主 #6 2017-12-26 14:06:24
qianhao
已发帖子: 138
我是使用了一个lichee的sdk 他里面有个pack 工具  我就使用这个 把最新的buildroot生成出来的rootfs.ext4 打包进去  我看烧录到sd卡里面对的  文件系统就是buildroot生成出来的。我也修改了 /etc/inittab 里面的串口 修改到使用的ttyS2  看了dev/console  也纯正的  不知道为何 跑不下去
[    4.991069] Freeing init memory: 328K
[    5.002533] [mmc]: sdc2 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    5.013052] [mmc]: mclk 0xf1c20090 0xc001000e
[    5.084142] EXT4-fs (mmcblk0p7): barriers disabled
[    5.094197] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,barrier=0,data=ordered
[    5.111366] [mmc]: sdc2 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    5.121671] [mmc]: mclk 0xf1c20090 0xc001000e
[    5.192260] [mmc]: sdc2 set ios: clk 25000000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    5.202712] [mmc]: mclk 0xf1c20090 0xc100000b
[    5.260122] [mmc]: sdc2 set ios: clk 25000000Hz bm PP pm ON vdd 3.3V width 1 timing MMC-HS(SDR20) dt B
[    5.270517] [mmc]: mclk 0xf1c20090 0xc100000b
[    5.330377] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing MMC-HS(SDR20) dt B
[    5.340798] [mmc]: mclk 0xf1c20090 0xc1000005
[    5.400753] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing MMC-HS(SDR20) dt B
[    5.411145] [mmc]: mclk 0xf1c20090 0xc1000005
[    5.471168] mmc1: new high speed MMC card at address 0001
[    5.477691] mmcblk1: mmc1:0001 8WPD3R 7.28 GiB
[    5.482961] mmcblk1boot0: mmc1:0001 8WPD3R partition 1 4.00 MiB
[    5.489714] mmcblk1boot1: mmc1:0001 8WPD3R partition 2 4.00 MiB
[    5.497377]  mmcblk1: p1 p2 p3 < p5 p6 p7 p8 >
[    5.502378] mmcblk1: p1 size 10969088 extends beyond EOD, truncated
[    5.512740]  mmcblk1boot1: unknown partition table
[    5.519045]  mmcblk1boot0: unknown partition table
[    5.524607] *******************mmc init ok *******************
又卡在这里
#7 2017-12-26 14:19:26
goodgoodstudy
已发帖子: 61
没跑过全志sdk,  楼主早日搞定分享经验。
