楼主 #1 2019-07-20 11:16:06
pqfeng
已发帖子: 129
为什么它始终报找不到头文件,明明我有说明搜索路径,变量有定义。
Creating qmake. Please wait...
make: Nothing to be done for 'first'.
floatmath auto-detection... ()
/opt/arm-linux-gnueabihf/bin/arm-linux-gnueabihf-g++ -c -O2 -march=armv7-a -lts -I../../../mkspecs/arm-linux-gnueabihf -I. -o floatmath.o floatmath.cpp
/opt/arm-linux-gnueabihf/bin/arm-linux-gnueabihf-g++ -o floatmath floatmath.o
floatmath enabled.
tslib auto-detection... ()
/opt/arm-linux-gnueabihf/bin/arm-linux-gnueabihf-g++ -c -O2 -march=armv7-a -lts -I../../../mkspecs/arm-linux-gnueabihf -I. -o tslib.o tslib.cpp
tslib.cpp:1:19: fatal error: tslib.h: 没有那个文件或目录
#include <tslib.h>
compilation terminated.
Makefile:160: recipe for target 'tslib.o' failed
make: *** [tslib.o] Error 1
tslib disabled.
The tslib functionality test failed!
You might need to modify the include and library search paths by editing
QMAKE_INCDIR and QMAKE_LIBDIR in
qmake configuration for building with arm-linux-gnueabi-g++
以上是报错。但我明明有定义。搞不清楚原因。但肯定是有执行的。因为上面
MAKEFILE_GENERATOR = UNIX
TARGET_PLATFORM = unix
TEMPLATE = app
CONFIG += qt warn_on release incremental link_prl gdb_dwarf_index
QT += core gui
QMAKE_INCREMENTAL_STYLE = sublib
QMAKE_CFLAGS_RELEASE += -O2 -march=armv7-a -lts
QMAKE_CXXFLAGS_RELEASE += -O2 -march=armv7-a -lts
QMAKE_INCDIR=/opt/tslib/include
QMAKE_LIBDIR=/opt/tslib/lib
include(../common/linux.conf)
include(../common/gcc-base-unix.conf)
include(../common/g++-unix.conf)
modifications to g++.conf
QMAKE_CC = /opt/arm-linux-gnueabihf/bin/arm-linux-gnueabihf-gcc
QMAKE_CXX = /opt/arm-linux-gnueabihf/bin/arm-linux-gnueabihf-g++
QMAKE_LINK = /opt/arm-linux-gnueabihf/bin/arm-linux-gnueabihf-g++
QMAKE_LINK_SHLIB = /opt/arm-linux-gnueabihf/bin/arm-linux-gnueabihf-g++
modifications to linux.conf
QMAKE_AR = /opt/arm-linux-gnueabihf/bin/arm-linux-gnueabihf-ar cqs
QMAKE_OBJCOPY = /opt/arm-linux-gnueabihf/bin/arm-linux-gnueabihf-objcopy
QMAKE_STRIP = /opt/arm-linux-gnueabihf/bin/arm-linux-gnueabihf-strip
load(qt_config)
最近编辑记录 pqfeng (2019-07-20 11:18:24)
#2 2019-07-20 11:23:01
还能这么玩
已发帖子: 119
Re: 为什么它始终报找不到头文件,明明我有说明搜索路径,变量有定义。
很明显, 这一行并没有 -I/opt/tslib/include, 所以找不到头文件了。
还是配置问题.
楼主 #3 2019-07-20 11:45:11
pqfeng
已发帖子: 129
嗯这一行我手动加到编译环境中去了,却又报了其他的问题
You are licensed to use this software under the terms of
the GNU General Public License (GPL) versions 3.
You are also licensed to use this software under the terms of
the Lesser GNU General Public License (LGPL) versions 2.1.
You have already accepted the terms of the license.
/opt/arm-linux-gnueabihf/bin/arm-linux-gnueabihf-g++ -c -O2 -march=armv7-a -I/opt/tslib/include -L/opt/tslib/lib -lts -I../../../mkspecs/arm-linux-gnueabihf -I. -o floatmath.o floatmath.cpp
floatmath enabled.
/opt/arm-linux-gnueabihf/bin/arm-linux-gnueabihf-g++ -c -O2 -march=armv7-a -I/opt/tslib/include -L/opt/tslib/lib -lts -I../../../mkspecs/arm-linux-gnueabihf -I. -o tslib.o tslib.cpp
/opt/arm-linux-gnueabihf/bin/arm-linux-gnueabihf-g++ -o tslib tslib.o -lts
/opt/arm-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/4.9.2/../../../../arm-linux-gnueabihf/bin/ld: cannot find -lts
Makefile:91: recipe for target 'tslib' failed
make: *** [tslib] Error 1
tslib disabled.
/home/pqfeng/qt-embedded-linux-opensource-src-4.5.2/mkspecs/arm-linux-gnueabihf
#4 2019-07-20 14:35:58
/opt/arm-linux-gnueabihf/bin/arm-linux-gnueabihf-g++ -o tslib tslib.o -lts -L/opt/tslib/lib
这里要指定 libts.a 的目录
楼主 #5 2019-07-20 14:40:48
pqfeng
已发帖子: 129
这里报的错是因为我原来生成的tslib库居然是X86版的。
吐血。现在直接用以前的库替换了。懒得编译了。
