rtl8723bs模块是tf卡模块,V3s是淘宝买的lichee zero核心版。
连上wifi后,ping一会大约30秒左右,就会掉线,然后自动重连,是什么原因呢
64 bytes from 61.151.166.139: seq=25 ttl=51 time=11.242 ms
64 bytes from 61.151.166.139: seq=26 ttl=51 time=18.844 ms
64 bytes from 61.151.166.139: seq=27 ttl=51 time=12.793 ms
64 bytes from 61.151.166.139: seq=28 ttl=51 time=14.494 ms
64 bytes from 61.151.166.139: seq=29 ttl=51 time=73.121 ms
64 bytes from 61.151.166.139: seq=30 ttl=51 time=11.535 ms
64 bytes from 61.151.166.139: seq=31 ttl=51 time=11.188 ms
64 bytes from 61.151.166.139: seq=32 ttl=51 time=16.665 ms
[ 120.367231] RTL8723BS: sta recv deauth reason code(8) sta:4c:ed:fb:a2:cc:08, ignore = 0
ping: sendto: Network is unreachable
# [ 122.023923] RTL8723BS: rtw_set_802_11_connect(wlan0) fw_state = 0x00000008
[ 122.242847] RTL8723BS: sta recv deauth reason code(6) sta:4c:ed:fb:a2:cc:08, ignore = 0
[ 124.423994] RTL8723BS: rtw_set_802_11_connect(wlan0) fw_state = 0x00000008
[ 124.657186] RTL8723BS: sta recv deauth reason code(6) sta:4c:ed:fb:a2:cc:08, ignore = 0
[ 127.225828] RTL8723BS: rtw_set_802_11_connect(wlan0) fw_state = 0x00000008
[ 127.442710] RTL8723BS: sta recv deauth reason code(6) sta:4c:ed:fb:a2:cc:08, ignore = 0
[ 127.451137] RTL8723BS: sta recv deauth reason code(6) sta:4c:ed:fb:a2:cc:08, ignore = 0
[ 127.460150] RTL8723BS: sta recv deauth reason code(6) sta:4c:ed:fb:a2:cc:08, ignore = 0
[ 131.367011] RTL8723BS: nolinked power save enter
[ 132.698843] RTL8723BS: nolinked power save leave
[ 134.907671] RTL8723BS: nolinked power save enter
[ 137.918834] RTL8723BS: nolinked power save leave
[ 138.135956] RTL8723BS: rtw_set_802_11_connect(wlan0) fw_state = 0x00000008
[ 138.246014] RTL8723BS: start auth
[ 138.251692] RTL8723BS: auth success, start assoc
[ 138.261523] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
[ 138.268722] RTL8723BS: assoc success
[ 138.279324] RTL8723BS: send eapol packet
[ 139.256642] RTL8723BS: send eapol packet
[ 139.276550] RTL8723BS: send eapol packet
[ 139.281350] RTL8723BS: set pairwise key camid:4, addr:4c:ed:fb:a2:cc:08, kid:0, type:AES
[ 139.305766] RTL8723BS: set group key camid:5, addr:4c:ed:fb:a2:cc:08, kid:1, type:AES
# ping www.qq.com
PING www.qq.com (61.151.166.146): 56 data bytes
64 bytes from 61.151.166.146: seq=0 ttl=51 time=14.269 ms
64 bytes from 61.151.166.146: seq=1 ttl=51 time=11.851 ms
64 bytes from 61.151.166.146: seq=2 ttl=51 time=11.424 ms离线
和我的差不多,我试了三种网卡,8723bs. 雷凌3070,5572, 2.4G的模式总是断断续续,用5572的5G频段就完全正常,感觉是licheepi的小板子对2.4G频段有干扰
