楼主 #1 2019-07-31 15:56:32
cdft
已发帖子: 22
移植lvgl,更新版本到6.0.0后,字体结构发生变化,不知道怎么修改?请大神赐教
移植用老版本littlevGL,移植成功后显示汉子成功;通过在线取模(https://littlevgl.com/ttf-font-to-c-array-old)。之前版本字体样式
lv_font_t chinese1_m1_font =
    .unicode_first = 19968,    /*First Unicode letter in this font*/
    .unicode_last = 40959,    /*Last Unicode letter in this font*/
    .h_px = 25,                /*Font height in pixels*/
    .glyph_bitmap = chinese1_m1_font_glyph_bitmap,    /*Bitmap of glyphs*/
    .glyph_dsc = chinese1_m1_font_glyph_dsc,        /*Description of glyphs*/
    //.glyph_cnt = 18,            /*Number of glyphs in the font*/
    .unicode_list = chinese1_m1_font_unicode_list,    /*List of unicode characters*/
    .get_bitmap = lv_font_get_bitmap_sparse,    /*Function pointer to get glyph's bitmap*/
    .get_width = lv_font_get_width_sparse,    /*Function pointer to get glyph's width*/
#if USE_CHINESE1_M1_FONT == 1
    .bpp = 1,                /*Bit per pixel*/
#elif USE_CHINESE1_M1_FONT == 2
    .bpp = 2,                /*Bit per pixel*/
#elif USE_CHINESE1_M1_FONT == 4
    .bpp = 4,                /*Bit per pixel*/
#elif USE_CHINESE1_M1_FONT == 8
    .bpp = 8,                /*Bit per pixel*/
    //.monospace = 0,                /*Fix width (0: if not used)*/
    .next_page = NULL,        /*Pointer to a font extension*/
移植最先版本littlevGL 6.0.0后,发现字体结构改变了,请教需要怎么修改?
typedef struct _lv_font_struct
    /** Get a glyph's  descriptor from a font*/
    bool (*get_glyph_dsc)(const struct _lv_font_struct *, lv_font_glyph_dsc_t *, uint32_t letter, uint32_t letter_next);
    /** Get a glyph's bitmap from a font*/
    const uint8_t * (*get_glyph_bitmap)(const struct _lv_font_struct *, uint32_t);
    /*Pointer to the font in a font pack (must have the same line height)*/
    uint8_t line_height;      /**< The real line height where any text fits*/
    uint8_t base_line;        /**< Base line measured from the top of the line_height*/
    void * dsc;               /**< Store implementation specific data here*/
#if LV_USE_USER_DATA
    lv_font_user_data_t user_data; /**< Custom user data for font. */
} lv_font_t;
楼主 #2 2019-07-31 16:57:41
cdft
已发帖子: 22
Re: 移植lvgl,更新版本到6.0.0后,字体结构发生变化,不知道怎么修改?请大神赐教
https://littlevgl.com/ttf-font-to-c-array 上想生成字体移植失败。
#3 2019-08-28 16:45:50
hengyongchao
@cdft 这个问题后来解决了吗?
楼主 #4 2019-08-28 16:51:06
cdft
已发帖子: 22
@hengyongchao 没有解决
#5 2019-08-31 14:42:34
zwmasdf
已发帖子: 24
重新去光网生成字体即可使用
#6 2019-08-31 14:47:17
zwmasdf 说:
重新去光网生成字体即可使用
请问是哪个地址呢
#7 2019-08-31 17:18:34
zwmasdf
已发帖子: 24
超级萌新 说:
zwmasdf 说:
重新去光网生成字体即可使用
请问是哪个地址呢
就是2楼的地址
楼主 #8 2019-11-05 13:31:01
cdft
已发帖子: 22
zwmasdf 说:
超级萌新 说:
zwmasdf 说:
重新去光网生成字体即可使用
请问是哪个地址呢
就是2楼的地址
可以么?
#9 2019-11-05 14:28:33
我思故我在
已发帖子: 244
分享一个好用的 littlevgl 字体生成工具. https://whycan.cn/t_1350.html
#10 2019-11-07 13:20:27
silong1126
已发帖子: 32
学习下。。。
