楼主 #1 2019-09-04 23:35:46
chendong
已发帖子: 85
全志V3S 编译neon
现在想一只webrtc 上v3s上,但是这个算法好像要用到neon,如何在编译的时候用neon选项(else ifneq ($(findstring neon,@ac_webrtc_instset@)谢谢。
WEBRTC_OTHER_CFLAGS = -fexceptions -DWEBRTC_POSIX=1 @ac_webrtc_cflags@
ifneq ($(findstring sse2,@ac_webrtc_instset@),)
    WEBRTC_SRC = \
              modules/audio_processing/aec/aec_core_sse2.o         \
          modules/audio_processing/aec/aec_rdft_sse2.o             \
          modules/audio_processing/aecm/aecm_core_c.o             \
          modules/audio_processing/ns/nsx_core_c.o                     \
          system_wrappers/source/cpu_features.o
else ifneq ($(findstring neon,@ac_webrtc_instset@),)
    WEBRTC_SRC = \
                 modules/audio_processing/aec/aec_core_neon.o               \
          modules/audio_processing/aec/aec_rdft_neon.o               \
          modules/audio_processing/aecm/aecm_core_neon.o             \
          modules/audio_processing/ns/nsx_core_neon.o                \
          common_audio/signal_processing/cross_correlation_neon.o    \
          common_audio/signal_processing/downsample_fast_neon.o      \
          common_audio/signal_processing/min_max_operations_neon.o
    WEBRTC_OTHER_CFLAGS += -DWEBRTC_HAS_NEON
