楼主 #1 2019-09-19 11:40:26
shiqx429
已发帖子: 48
littlevgl触摸点是怎么映射的?
我现在将littlevgl移植到nano板子上
Linux上运行ts_calibrate正常
Linux运行ts_test也正常
1608.891816:    529    287    255
1608.931818:    505    266    255
1608.971854:    474    243    255
1609.011849:    448    220    255
1609.051823:    423    199    255
1609.091839:    395    176    255
1609.131810:    358    158    255
1609.171840:    358    144    255
1609.211843:    343    132    255
1609.251849:    329    120    255
1609.291859:    326    116    255
1609.331852:    305    102    255
1609.371806:    290     88    255
1609.411850:    288     81    255
点击屏幕后,上面的数据至少都在800*480之间
之后运行littlevgl的demo程序,发现demo自动运行(就是3个tab循环播放那种),点击屏幕没有任何效果,我在littlevgl中的evdev.c打印了log,获得的点坐标非常不对
code如下:
bool evdev_read(lv_indev_drv_t * drv, lv_indev_data_t * data)
    struct input_event in;
    while(read(evdev_fd, &in, sizeof(struct input_event)) > 0) {
 printf("in.type = %d\n", in.type);
printf("in.code = %d\n", in.code);
        if(in.type == EV_REL) {
            if(in.code == REL_X)
				#if EVDEV_SWAP_AXES
					evdev_root_y += in.value;
				#else
					evdev_root_x += in.value;
            else if(in.code == REL_Y)
				#if EVDEV_SWAP_AXES
				#else
        } else if(in.type == EV_ABS) {
            if(in.code == ABS_X)
				#if EVDEV_SWAP_AXES
					evdev_root_y = in.value;
				#else
					evdev_root_x = in.value;
            else if(in.code == ABS_Y)
				#if EVDEV_SWAP_AXES
				#else
            else if(in.code == ABS_MT_POSITION_X)
                                #if EVDEV_SWAP_AXES
                                #else
            else if(in.code == ABS_MT_POSITION_Y)
                                #if EVDEV_SWAP_AXES
                                #else
        } else if(in.type == EV_KEY) {
            if(in.code == BTN_MOUSE || in.code == BTN_TOUCH) {
                if(in.value == 0)
                    evdev_button = LV_INDEV_STATE_REL;
                else if(in.value == 1)
                    evdev_button = LV_INDEV_STATE_PR;
            } else if(drv->type == LV_INDEV_TYPE_KEYPAD) {
		data->state = (in.value) ? LV_INDEV_STATE_PR : LV_INDEV_STATE_REL;
		switch(in.code) {
			case KEY_BACKSPACE:
				data->key = LV_KEY_BACKSPACE;
				break;
			case KEY_ENTER:
				data->key = LV_KEY_ENTER;
				break;
			case KEY_UP:
				data->key = LV_KEY_UP;
				break;
			case KEY_LEFT:
				data->key = LV_KEY_PREV;
				break;
			case KEY_RIGHT:
				data->key = LV_KEY_NEXT;
				break;
			case KEY_DOWN:
				data->key = LV_KEY_DOWN;
				break;
			default:
				data->key = 0;
				break;
		evdev_key_val = data->key;
		evdev_button = data->state;
		return false;
        /* No data retrieved */
        data->key = evdev_key_val;
	data->state = evdev_button;
	return false;
    if(drv->type != LV_INDEV_TYPE_POINTER)
        return false;
    /*Store the collected data*/
#if EVDEV_SCALE
    data->point.x = map(evdev_root_x, 0, EVDEV_SCALE_HOR_RES, 0, lv_disp_get_hor_res(drv->disp));
    data->point.y = map(evdev_root_y, 0, EVDEV_SCALE_VER_RES, 0, lv_disp_get_ver_res(drv->disp));
#else
#if EVDEV_CALIBRATE
	data->point.x = map(evdev_root_x, EVDEV_HOR_MIN, EVDEV_HOR_MAX, 0, lv_disp_get_hor_res(drv->disp));
	data->point.y = map(evdev_root_y, EVDEV_VER_MIN, EVDEV_VER_MAX, 0, lv_disp_get_ver_res(drv->disp));
#else
    data->point.x = evdev_root_x;
    data->point.y = evdev_root_y;
printf("before data->point.x = %d\n", data->point.x);
printf("before data->point.y = %d\n", data->point.y);
    if(data->point.x < 0)
      data->point.x = 0;
    if(data->point.y < 0)
      data->point.y = 0;
    if(data->point.x >= lv_disp_get_hor_res(drv->disp))
      data->point.x = lv_disp_get_hor_res(drv->disp) - 1;
    if(data->point.y >= lv_disp_get_ver_res(drv->disp))
      data->point.y = lv_disp_get_ver_res(drv->disp) - 1;
printf("after data->point.x = %d\n", data->point.x);
printf("after data->point.y = %d\n", data->point.y);
    return false;
log如下
before data->point.x = 3921
before data->point.y = 3773
after data->point.x = 799
after data->point.y = 479
从(read(evdev_fd, &in, sizeof(struct input_event))获得的点基本都是3000多以上的,之后由于都超过800*480了,在下边的代码中都处理为799*499了
      data->point.x = 0;
      data->point.y = 0;
lv_drv_conf.h如下
#ifndef USE_EVDEV
#  define USE_EVDEV           1
#if USE_EVDEV
#  define EVDEV_NAME   "/dev/input/event1"        /*You can use the "evtest" Linux tool to get the list of devices and test them*/
main.c如下
lv_indev_drv_t indev_drv;
    lv_indev_drv_init(&indev_drv);          /*Basic initialization*/
    evdev_init();
    indev_drv.type = LV_INDEV_TYPE_POINTER; /*See below.*/
    indev_drv.read_cb = evdev_read;            /*See below.*/
    lv_indev_drv_register(&indev_drv);      /*Register the driver in LittlevGL*/
我现在搞不清我哪里配置错了,请帮忙看看?
另外运行官方的littlevgl的demo后,3个tab是循环播放吗?我感觉这个现象也怪怪的,我在pc_imulator上也运行过,他那个就没循环播放
#2 2019-09-19 11:48:14
firstman
已发帖子: 279
Re: littlevgl触摸点是怎么映射的?
这种一看就是 ADC 值,
要获取 LCD X/Y 要通过 tslib
tslib 有做滤波、去抖、校准等功能了。
楼主 #3 2019-09-19 11:59:34
shiqx429
已发帖子: 48
你的意思是要将tslib整合至littlevgl中吗?就像 https://whycan.cn/t_2303.html 说的, 下午我试试看看
firstman 说:
这种一看就是 ADC 值,
#4 2019-09-19 12:44:02
已发帖子: 9,422
对的,就是上面那个链接
#5 2019-09-19 13:18:39
Jmhh247
已发帖子: 262
点进去看了下,是我发的帖子。。。
shiqx429 说:
firstman 说:
这种一看就是 ADC 值,
楼主 #6 2019-09-19 13:33:42
shiqx429
已发帖子: 48
可以了,感谢二位!
楼主 #7 2019-09-19 13:34:46
shiqx429
已发帖子: 48
是啊,谢谢!!!
Jmhh247 说:
点进去看了下,是我发的帖子。。。
shiqx429 说:
firstman 说:
这种一看就是 ADC 值,
#8 2020-08-18 14:50:51
Sandaruwan
Can you share your pin out. I'm newbie to Lichee Pi Nano.
