楼主 #1 2019-09-26 19:09:07
luckymist
已发帖子: 50
nano板子加载esp8089后报错
log如下:
# insmod /lib/modules/4.14.0-licheepi-nano\+/esp8089.ko
[   40.843744] eagle_sdio mmc0:0001:1: Direct firmware load for eagle_fw_ate_config_v19.bin failed with error -2
[   40.853913] download firmware failed
[   40.857547] esp_init_all failed: -2
[   40.861057] first error exit
#2 2019-09-26 19:19:27
已发帖子: 9,285
楼主 #3 2019-09-26 19:32:06
luckymist
已发帖子: 50
Re: nano板子加载esp8089后报错
eagle_fw_ate_config_v19.bin等firmware 必须放入rootfs中哪个目录吗?
楼主 #4 2019-09-26 19:33:03
luckymist
已发帖子: 50
晕哥大爱啊,真神速
我去试下
#5 2019-09-26 19:47:41
已发帖子: 9,285
/lib/firmware/eagle_fw_ate_config_v19.bin
/lib/firmware/eagle_fw_first_init_v19.bin
/lib/firmware/eagle_fw_second_init_v19.bin
应该是这种结构
楼主 #6 2019-09-26 20:34:26
luckymist
已发帖子: 50
应该是这种结构
加进去了
要敲什么命令才能连接wifi?
敲什么命令才能作为AP?
#7 2019-09-26 20:37:02
已发帖子: 9,285
https://whycan.cn/t_2091.html
作为热点是用 hostapd 命令
楼主 #8 2019-09-26 20:57:29
luckymist
已发帖子: 50
作为热点是用 hostapd 命令
烧写帖子里的镜像
连不上wifi,提示 Could not read interface wlan0 flags: No such device
# wpa_supplicant -i wlan0 -D wext -c /etc/wpa_supplicant.conf -d
wpa_supplicant v2.6
random: Trying to read entropy from /dev/random
Initializing interface 'wlan0' conf '/etc/wpa_supplicant.conf' driver 'wext' ctrl_interface 'N/A' bridge 'N/A'
Configuration file '/etc/wpa_supplicant.conf' -> '/etc/wpa_supplicant.conf'
Reading configuration file '/etc/wpa_supplicant.conf'
ctrl_interface='/var/run/wpa_supplicant'
ap_scan=1
Priority group 0
   id=0 ssid='360HCFA'
   id=1 ssid='cts_v4'
rfkill: Cannot get wiphy information
WEXT: RFKILL status not available
WEXT: Could not set interface 'wlan0' UP
wlan0: Failed to initialize driver interface
Failed to add interface wlan0
wlan0: Cancelling scan request
wlan0: Cancelling authentication timeout
楼主 #9 2019-09-26 21:01:03
luckymist
已发帖子: 50
开机进去之后只有lo,怎样才能把wlan0启动出来?
# ifconfig
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          collisions:0 txqueuelen:1000
#10 2019-09-26 21:02:54
已发帖子: 9,285
有没有先执行 insmod esp8089.ko
楼主 #11 2019-09-26 21:17:15
luckymist
已发帖子: 50
有先执行了。
用帖子里的固件,执行insmod时提示已经加载过esp8089.ko了。
楼主 #12 2019-09-26 21:20:22
luckymist
已发帖子: 50
wlan0是执行了insmod esp8089.ko就会出来吗?
#13 2019-09-26 21:23:47
已发帖子: 9,285
luckymist 说:
是的
楼主 #14 2019-09-26 21:30:48
luckymist
已发帖子: 50
luckymist 说:
是的
flashimg_f1c100s_esp8089.bin这个固件是可以的对吧?
这样的话可能是我的esp8089模块坏了。
楼主 #15 2019-09-26 21:42:21
luckymist
已发帖子: 50
modprobe esp8089.ko config=crystal_26M_en=2
像这样指定晶振频率的话,就报错 modprobe: can't open 'modules.dep': No such file or directory
楼主 #16 2019-09-26 21:50:24
luckymist
已发帖子: 50
这个失败有关系吗?
[    1.144798] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    1.153583] cfg80211: failed to load regulatory.db
楼主 #17 2019-09-26 21:53:14
luckymist
已发帖子: 50
luckymist 说:
这个失败有关系吗?
这个可能是我刚才没插入esp8089模块
现在模块插入后,执行insmod报错:
# insmod /lib/modules/esp8089.ko
[  253.462913] Set sdio block size 512 failed: -110)
[  253.468052] first error exit
[  253.471056] eagle_sdio: probe of mmc0:0001:1 failed with error -110
楼主 #18 2019-09-26 21:54:55
luckymist
已发帖子: 50
luckymist 说:
luckymist 说:
这个失败有关系吗?
现在模块插入后,执行insmod报错:
额~   重启了一下,wlan0就出来了。。。。
楼主 #19 2019-09-26 22:02:57
luckymist
已发帖子: 50
luckymist 说:
luckymist 说:
luckymist 说:
这个失败有关系吗?
现在模块插入后,执行insmod报错:
极不稳定,一会wlan0就没了。重启也没再出来。。。
楼主 #20 2019-09-26 22:05:59
luckymist
已发帖子: 50
luckymist 说:
luckymist 说:
luckymist 说:
现在模块插入后,执行insmod报错:
跟Gadget有关吗?
#21 2019-09-26 22:17:57
已发帖子: 9,285
可能和接触不稳定有关系, 也有可能是电源问题吧
#22 2020-06-30 10:57:48
所在地: 你猜
已发帖子: 3,379
luckymist 说:
加进去了
要敲什么命令才能连接wifi?
敲什么命令才能作为AP?
这里有固件下载: https://whycan.cn/t_3400.html#p48599
既支持RTL8723BS, 也支持ESP8089
既支持AP模式,也支持STA模式
