楼主 #1 2019-10-15 10:44:31
歌以咏志
已发帖子: 219
编译了周立功 awtk 到 V3s 跑, 出现了一堆错误
代码: https://github.com/zlgopen/awtk-linux-fb
获取源码
也编辑了 awtk_config.py 设置工具链的路径
TSLIB_LIB_DIR='/opt/28x/tslib/lib'
TSLIB_INC_DIR='/opt/28x/tslib/include'
TOOLS_PREFIX='/opt/28x/gcc-4.4.4-glibc-2.11.1-multilib-1.0/arm-fsl-linux-gnueabi/bin/arm-linux-'
界面没有任何显示,控制台一堆错误:
# /usr/bin/demo_animator
app_root_is_valid:43 app_root != NULL
try /root
try /usr/bin
app_root=
Not found valid assets folder!
!!!Asset [name=en_US type=strings] not exist!!!
!!!Asset [name=en type=strings] not exist!!!
fb_info_t: /dev/fb0
fb_info_t: xres=800 yres=480 bits_per_pixel=32 mem_size=1536000
fb_info_t: red(16 8) green(8 8) blue(0 8)
line_length=3200 mem_size=1536000 smem_len=1536000
xres_virtual =800 yres_virtual=480 xpanstep=0 ywrapstep=0
ratio=1.000000 800 480
Build at: Oct 15 2019 09:58:05
assets_manager_preload:585 info != NULL
theme_find_style:89 t != NULL && t->data != NULL
!!!Asset [name=cursor type=image] not exist!!!
window_manager_default_set_cursor:993 image_manager_get_bitmap(image_manager(), cursor, &bitmap) == RET_OK
!!!Asset [name=earth type=image] not exist!!!
image_on_paint_self:41 widget_load_image(widget, image_base->image, &bitmap) == RET_OK
!!!Asset [name=bricks type=image] not exist!!!
window_manager_paint_cursor:529 image_manager_get_bitmap(image_manager(), wm->cursor, &bitmap) == RET_OK
input_dispatch_one_event:71 mouse read failed(ret=-1, errno=0, fd=-1, filename=/dev/input/mice)
Print mouse: : Success
input_dispatch_one_event:150 keyboard read failed(ret=-1, errno=0)
input_dispatch_one_event:154 keyboard read failed(ret=-1, errno=0, fd=-1, filename=/dev/input/event1)
Print keyboard: : Success
tslib_dispatch_one_event:61 tslib read failed(ret=-1, errno=0, filename=/dev/input/event0)
Print tslib: : Success
楼主 #2 2019-10-15 11:02:21
歌以咏志
已发帖子: 219
Re: 编译了周立功 awtk 到 V3s 跑, 出现了一堆错误
对于内置的 demoui 例子
先执行: ./release.sh
然后生成: release.tar.gz
最后解压到V3s 开发板, 现在貌似正常了。
#3 2019-10-16 17:29:52
lixianjing
已发帖子: 103
谢谢支持,有问题@我:)
#4 2019-10-21 12:02:21
a32425262
已发帖子: 104
我也是差不多一样的错误,解压release也不行的
# ./release/bin/demo
try /mnt/awtk
try /mnt/awtk/release/bin
app_root=/mnt/awtk/release
fb_info_t: /dev/fb0
fb_info_t: xres=480 yres=272 bits_per_pixel=32 mem_size=522240
line_length=1920 mem_size=522240 smem_len=522240
xres_virtual =480 yres_virtual=272 xpanstep=0 ywrapstep=0
ratio=1.000000 480 272
tslib: Selected device is not a touchscreen (must support ABS and KEY event types)
tslib_dispatch_one_event:61 tslib read failed(ret=0, errno=0, filename=/dev/input/event0)
assets_manager_preload:626 info != NULL
!!!Asset [name=default type=font] not exist!!!
canvas_measure_text_default:259 c != NULL && str != NULL && c->font != NULL
font_get_glyph:26 f != NULL && f->get_glyph != NULL && g != NULL
input_dispatch_one_event:71 mouse read failed(ret=-1, errno=2, fd=-1, filename=/dev/input/mice)
Print mouse: : No such file or directory
#5 2019-10-24 11:28:07
lixianjing
已发帖子: 103
不好意思,麻烦更新一下AWTK和awtk-linux-fb。
前几天加了多主题实时切换功能,资源加了一级目录,release.sh忘记更新了。
