TSLIB_TSDEVICE=/dev/input/event1 ts_calibrate
TSLIB_TSDEVICE=/dev/input/event1 ts_test
# TSLIB_TSDEVICE=/dev/input/event1 /awtk/bin/demoui
app_root_is_valid:43 app_root != NULL
try /root
try /awtk/bin
app_root=/awtk
fb_info_t: /dev/fb0
fb_info_t: xres=800 yres=480 bits_per_pixel=32 mem_size=1536000
fb_info_t: red(16 8) green(8 8) blue(0 8)
line_length=3200 mem_size=1536000 smem_len=1536000
xres_virtual =800 yres_virtual=480 xpanstep=1 ywrapstep=0
ratio=1.000000 800 480
Build at: Oct 22 2019 16:41:20
window preload open
tslib: Selected device is not a touchscreen (must support ABS event type)
tslib_dispatch_one_event:61 tslib read failed(ret=0, errno=0, filename=/dev/input/event0)
Print tslib: : Success
keyboard pointer down:3198 982
input_dispatch_one_event:71 mouse read failed(ret=-1, errno=0, fd=-1, filename=/dev/input/mice)
Print mouse: : Success
window system_bar open
main
ignore_user_input
window main open
window preload close
main
main
input_dispatch_one_event:71 mouse read failed(ret=-1, errno=2, fd=-1, filename=/dev/input/mice)
Print mouse: : No such file or directory
keyboard pointer up:1148 641
keyboard pointer down:1439 531
keyboard pointer up:1441 530
keyboard pointer down:1488 468
keyboard pointer up:1488 477
keyboard pointer down:1452 523
keyboard pointer up:1458 525
keyboard pointer down:1435 424
keyboard pointer up:1428 422
keyboard pointer down:1904 750
keyboard pointer up:1908 734
Print tslib: : Success这里是按压触摸屏的输出:
keyboard pointer down:1452 523但是实际上触摸是没有反应的.
请问这是为什么呢?
找到问题了, awtk 默认使用 /dev/input/event0 作为电阻触摸输入设备, 但是我的 event0 是键盘输入设备,
所以我先删除 event0, 然后把 event1 链接到 event0:
rm /dev/input/event0
ln /dev/input/event1 /dev/input/event0 -s暂时性解决这个问题
现在问题来了, 能不能通过环境设置tslib 触摸的设备是 /dev/input/event1 ?
或者让程序自动去找合适的 abs 输入设备?
还有, 请问我应该如何隐藏界面的光标(cursor)呢?
电阻屏用 ts_test 测试一切正常, 但是 AWTK 运行的时候, 触摸笔按下不动, 整个界面都抖个不停.
1. 看到这位兄弟 https://whycan.cn/t_2386.html#p25634 修改 c 文件,才想起要改 awtk-port/main_loop_linux.c
#define FB_DEVICE_FILENAME "/dev/fb0"
#define TS_DEVICE_FILENAME "/dev/input/event1"
#define KB_DEVICE_FILENAME "/dev/input/event0"2. 改完后界面也不抖了.
3. 现在最后一个问题: 如何隐藏界面的光标(cursor)呢?
顶起,呼叫作者
谢谢大家支持,这个我还不知道,等我研究一下。
新版本隐藏了text cursor,麻烦更新一下awtk-linux-fb
请问前辈们,你们是用window下的awtk desinger生成的嘛,然后再到Ubuntu编译后移植到开发板上的吗?我在awtk desinger生成的文件有7M这么大,16M的spi flash根本不够用,主要是不知道怎么用desinger生成的代码移植到开发板上。
