今天修改了dts,想测试nano板子上的串口。
测试发现发现PA2 PA3不好使,测量两个口对地电压为0v
后来又试了试PE7,PE8,测试PE7口对地有3v电压,PE8没有电压,用示波器也看到输出波形了,有人用过这两个口的串口吗?
用的命令:
echo “1234” > /dev/ttyS1
echo “1234” > /dev/ttyS2
两个指令执行都正常,但PA2没有波形。
有人测试过这个接口吗?
我的PA2,PA3做触摸了,没有用作串口,所以没办法帮你测试了
dts 配置没问题吧?
这两个串口我用过,没问题,是不是dts配置的问题
配置设备树应该没错,估计有可能是硬件问题吧,我明天再试试别的nano吧。
能写ttyS1,软件应该没问题。
这排除法满分
硬件问题很少吧,设备树贴出来,大家帮你看看
suniv.dtsi文件:
#include <dt-bindings/clock/suniv-ccu.h>
#include <dt-bindings/reset/suniv-ccu.h>
#address-cells = <1>;
#size-cells = <1>;
interrupt-parent = <&intc>;
clocks {
#size-cells = <1>;
ranges;
osc24M: clk-24M {
#clock-cells = <0>;
compatible = "fixed-clock";
clock-frequency = <24000000>;
osc32k: clk-32k {
#clock-cells = <0>;
clock-frequency = <32768>;
fake100M: clk-100M {
#clock-cells = <0>;
clock-frequency = <100000000>;
clock-output-names = "fake-100M";
cpus {
#address-cells = <0>;
#size-cells = <0>;
cpu {
device_type = "cpu";
de: display-engine {
compatible = "allwinner,suniv-display-engine";
allwinner,pipelines = <&fe0>;
status = "disabled";
soc {
compatible = "simple-bus";
#size-cells = <1>;
ranges;
sram-controller@1c00000 {
compatible = "allwinner,sun4i-a10-sram-controller";
reg = <0x01c00000 0x30>;
#size-cells = <1>;
ranges;
sram_d: sram@10000 {
compatible = "mmio-sram";
reg = <0x00010000 0x1000>;
#size-cells = <1>;
otg_sram: sram-section@0 {
reg = <0x0000 0x1000>;
spi0: spi@1c05000 {
"allwinner,sun8i-h3-spi";
reg = <0x01c05000 0x1000>;
interrupts = <10>;
clock-names = "ahb", "mod";
resets = <&ccu RST_BUS_SPI0>;
#size-cells = <0>;
spi1: spi@1c06000 {
reg = <0x01c06000 0x1000>;
interrupts = <11>;
clocks = <&ccu CLK_BUS_SPI1>, <&ccu CLK_BUS_SPI1>;
resets = <&ccu RST_BUS_SPI1>;
#size-cells = <0>;
tcon0: lcd-controller@1c0c000 {
compatible = "allwinner,suniv-tcon";
reg = <0x01c0c000 0x1000>;
interrupts = <29>;
clocks = <&ccu CLK_BUS_LCD>,
<&ccu CLK_TCON>,
<&osc24M>; /* Still unknown */
"tcon-ch0",
"tcon-ch1";
clock-output-names = "tcon-pixel-clock";
resets = <&ccu RST_BUS_LCD>;
reset-names = "lcd";
ports {
#size-cells = <0>;
tcon0_in: port@0 {
#size-cells = <0>;
reg = <0>;
tcon0_in_be0: endpoint@0 {
reg = <0>;
remote-endpoint = <&be0_out_tcon0>;
tcon0_out: port@1 {
#size-cells = <0>;
reg = <1>;
mmc0: mmc@1c0f000 {
compatible = "allwinner,suniv-mmc",
"allwinner,sun7i-a20-mmc";
reg = <0x01c0f000 0x1000>;
clocks = <&ccu CLK_BUS_MMC0>,
<&ccu CLK_MMC0>,
<&ccu CLK_MMC0_OUTPUT>,
<&ccu CLK_MMC0_SAMPLE>;
"mmc",
"output",
"sample";
resets = <&ccu RST_BUS_MMC0>;
reset-names = "ahb";
interrupts = <23>;
pinctrl-names = "default";
pinctrl-0 = <&mmc0_pins>;
#size-cells = <0>;
mmc1: mmc@1c10000 {
reg = <0x01c10000 0x1000>;
clocks = <&ccu CLK_BUS_MMC1>,
<&ccu CLK_MMC1>,
<&ccu CLK_MMC1_OUTPUT>,
<&ccu CLK_MMC1_SAMPLE>;
"mmc",
"output",
"sample";
resets = <&ccu RST_BUS_MMC1>;
interrupts = <24>;
#size-cells = <0>;
ccu: clock@1c20000 {
compatible = "allwinner,suniv-ccu";
reg = <0x01c20000 0x400>;
clock-names = "hosc", "losc";
#clock-cells = <1>;
#reset-cells = <1>;
compatible = "allwinner,suniv-ic";
reg = <0x01c20400 0x400>;
interrupt-controller;
#interrupt-cells = <1>;
pio: pinctrl@1c20800 {
compatible = "allwinner,suniv-pinctrl";
reg = <0x01c20800 0x400>;
gpio-controller;
#interrupt-cells = <3>;
#gpio-cells = <3>;
spi0_pins_a: spi0-pins-pc {
function = "spi0";
lcd_rgb666_pins: lcd-rgb666-pins {
pins = "PD0", "PD1", "PD2", "PD3", "PD4",
"PD5", "PD6", "PD7", "PD8", "PD9",
"PD10", "PD11", "PD12", "PD13", "PD14",
"PD15", "PD16", "PD17", "PD18", "PD19",
"PD20", "PD21";
function = "lcd";
uart0_pins_a: uart-pins-pe {
pins = "PE0", "PE1";
function = "uart0";
uart1_pins_a: uart-pins-pa {
pins = "PA2", "PA3";
function = "uart1";
uart2_pins_a: uart-pins-pe1 {
pins = "PE7", "PE8";
function = "uart2";
mmc0_pins: mmc0-pins {
pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5";
function = "mmc0";
timer@1c20c00 {
compatible = "allwinner,suniv-timer";
reg = <0x01c20c00 0x90>;
interrupts = <13>;
clocks = <&osc24M>;
wdt: watchdog@1c20ca0 {
reg = <0x01c20ca0 0x20>;
uart0: serial@1c25000 {
reg = <0x01c25000 0x400>;
interrupts = <1>;
reg-shift = <2>;
reg-io-width = <4>;
uart1: serial@1c25400 {
reg = <0x01c25400 0x400>;
interrupts = <2>;
reg-shift = <2>;
reg-io-width = <4>;
uart2: serial@1c25800 {
reg = <0x01c25800 0x400>;
interrupts = <3>;
reg-shift = <2>;
reg-io-width = <4>;
usb_otg: usb@1c13000 {
reg = <0x01c13000 0x0400>;
clocks = <&ccu CLK_BUS_OTG>;
resets = <&ccu RST_BUS_OTG>;
interrupts = <26>;
interrupt-names = "mc";
phys = <&usbphy 0>;
phy-names = "usb";
extcon = <&usbphy 0>;
usbphy: phy@1c13400 {
reg = <0x01c13400 0x10>;
reg-names = "phy_ctrl";
clocks = <&ccu CLK_USB_PHY0>;
clock-names = "usb0_phy";
resets = <&ccu RST_USB_PHY0>;
reset-names = "usb0_reset";
#phy-cells = <1>;
fe0: display-frontend@1e00000 {
compatible = "allwinner,suniv-display-frontend";
reg = <0x01e00000 0x20000>;
interrupts = <30>;
clocks = <&ccu CLK_BUS_DE_FE>, <&ccu CLK_DE_FE>,
<&ccu CLK_DRAM_DE_FE>;
clock-names = "ahb", "mod",
"ram";
resets = <&ccu RST_BUS_DE_FE>;
ports {
#size-cells = <0>;
fe0_out: port@1 {
#size-cells = <0>;
reg = <1>;
fe0_out_be0: endpoint@0 {
reg = <0>;
remote-endpoint = <&be0_in_fe0>;
be0: display-backend@1e60000 {
compatible = "allwinner,suniv-display-backend";
reg = <0x01e60000 0x10000>;
reg-names = "be";
interrupts = <31>;
clocks = <&ccu CLK_BUS_DE_BE>, <&ccu CLK_DE_BE>,
<&ccu CLK_DRAM_DE_BE>;
"ram";
resets = <&ccu RST_BUS_DE_BE>;
reset-names = "be";
assigned-clocks = <&ccu CLK_DE_BE>;
assigned-clock-rates = <300000000>;
ports {
#size-cells = <0>;
be0_in: port@0 {
#size-cells = <0>;
reg = <0>;
be0_in_fe0: endpoint@0 {
reg = <0>;
remote-endpoint = <&fe0_out_be0>;
be0_out: port@1 {
#size-cells = <0>;
reg = <1>;
be0_out_tcon0: endpoint@0 {
reg = <0>;
remote-endpoint = <&tcon0_in_be0>;
suniv-f1c100s-licheepi-nano.dts文件:
/dts-v1/;
#include "suniv-f1c100s.dtsi"
model = "Lichee Pi Nano";
compatible = "licheepi,licheepi-nano", "allwinner,suniv-f1c100s",
"allwinner,suniv";
aliases {
serial0 = &uart0;
serial1 = &uart1;
Serial2 = &uart2;
spi0 = &spi0;
chosen {
panel: panel {
compatible = "lg,lb070wv8", "simple-panel";
#size-cells = <0>;
enable-gpios = <&pio 4 6 GPIO_ACTIVE_HIGH>;
port@0 {
reg = <0>;
#size-cells = <0>;
panel_input: endpoint@0 {
reg = <0>;
reg_vcc3v3: vcc3v3 {
regulator-name = "vcc3v3";
&de {
&mmc0 {
vmmc-supply = <®_vcc3v3>;
bus-width = <4>;
broken-cd;
&otg_sram {
&spi0 {
pinctrl-0 = <&spi0_pins_a>;
flash:mx25l12805d@0 {
#size-cells = <1>;
compatible ="jedec,spi-nor";
reg = <0>;
partitions{
compatible ="fixed-partitions";
#size-cells = <1>;
partition@0{
label="uboot";
reg=<0x0 0x100000>;
read-only;
partition@100000{
label="dtb";
reg=<0x100000 0x10000>;
read-only;
partition@110000{
label="kernel";
reg=<0x110000 0x400000>;
read-only;
partition@510000{
label="rootfs";
reg=<0x510000 0xAF0000>;
&tcon0 {
pinctrl-0 = <&lcd_rgb666_pins>;
&tcon0_out {
tcon0_out_lcd: endpoint@0 {
reg = <0>;
&uart0 {
pinctrl-0 = <&uart0_pins_a>;
&uart1 {
pinctrl-0 = <&uart1_pins_a>;
&uart2 {
pinctrl-0 = <&uart2_pins_a>;
&usb_otg {
dr_mode = "otg";
&usbphy {
设备树上传了,各位大佬看看哪里有问题呢?
目测这里不对,而且Serial2的首字母是大写了
aliases {
serial0 = &uart0;
serial1 = &uart1;
Serial2 = &uart2;
spi0 = &spi0;
改为
aliases {
serial0 = &uart0;
spi0 = &spi0;
确定是硬件问题。
上午我把系统以及这个设备树用到 迪卡 的F1C200S的板子上就妥了。
测量方法是分别用万用表测量 A3(TX)引脚对GND的电压 以及E7(TX)对GND 的电压,电压都在3V左右。
设备树那个aliases是别名,dts后面其实并没有使用到这些别名,而是直接引用的&uart1,&uart2,&uart3,因此大小写也就无所谓了。。。。。。
啊,还有这种操作。
mark!!
