楼主 #1 2019-11-07 08:23:05
xgui
已发帖子: 224
试一试编译 @bamkrsde 的 V3s Openwrt
楼主 #2 2019-11-07 08:37:58
xgui
已发帖子: 224
Re: 试一试编译 @bamkrsde 的 V3s Openwrt
克隆源码:
git clone https://github.com/bhorn/openwrt
cd openwrt
git checkout dolphinpi-spinand
然后 make menuconfig 选中:
> Base System > mtd
> Kernel modules > SPI Support > kmod-spi-dev
如果你用root登录的, 请用这个命令编译:
FORCE_UNSAFE_CONFIGURE=1 make V=s
楼主 #3 2019-11-07 08:38:51
xgui
已发帖子: 224
楼主 #4 2019-11-07 08:44:28
xgui
已发帖子: 224
https://blog.csdn.net/tx422/article/details/78593860
编译错误 you should not run configure as root (set FORCE_UNSAFE_CONFIGURE=1 in environment to bypass this
export FORCE_UNSAFE_CONFIGURE=1
楼主 #5 2019-11-07 08:45:04
xgui
已发帖子: 224
-- Looking for getgrnam_r
-- Looking for getgrnam_r - found
-- Looking for getpwnam_r
-- Looking for getpwnam_r - found
-- Looking for getpid
-- Looking for getpid - found
-- Looking for getvfsbyname
-- Looking for getvfsbyname - not found
-- Looking for lchflags
-- Looking for lchflags - not found
-- Looking for lchown
-- Looking for lchown - found
-- Looking for link
-- Looking for link - found
-- Looking for lstat
-- Looking for lstat - found
-- Looking for lutimes
-- Looking for lutimes - found
-- Looking for mbrtowc
-- Looking for mbrtowc - found
-- Looking for memmove
-- Looking for memmove - found
-- Looking for mkdir
-- Looking for mkdir - found
-- Looking for mkfifo
-- Looking for mkfifo - found
-- Looking for mknod
-- Looking for mknod - found
-- Looking for mkstemp
-- Looking for mkstemp - found
-- Looking for nl_langinfo
-- Looking for nl_langinfo - found
-- Looking for openat
-- Looking for openat - found
-- Looking for posix_spawnp
-- Looking for posix_spawnp - found
-- Looking for readlink
-- Looking for readlink - found
-- Looking for readpassphrase
-- Looking for readpassphrase - not found
-- Looking for setenv
-- Looking for setenv - found
-- Looking for statfs
-- Looking for statfs - found
-- Looking for statvfs
-- Looking for statvfs - found
-- Looking for strchr
-- Looking for strchr - found
-- Looking for strerror
-- Looking for strerror - found
-- Looking for strncpy_s
-- Looking for strncpy_s - not found
-- Looking for strrchr
-- Looking for strrchr - found
-- Looking for symlink
-- Looking for symlink - found
-- Looking for timegm
-- Looking for timegm - found
-- Looking for tzset
-- Looking for tzset - found
-- Looking for utimes
-- Looking for utimes - found
-- Looking for utimensat
-- Looking for utimensat - found
-- Looking for vfork
-- Looking for vfork - found
-- Looking for wcrtomb
-- Looking for wcrtomb - found
-- Looking for wcscmp
-- Looking for wcscmp - found
-- Looking for wcscpy
-- Looking for wcscpy - found
-- Looking for wcslen
-- Looking for wcslen - found
-- Looking for wctomb
-- Looking for wctomb - found
-- Looking for _ctime64_s
-- Looking for _ctime64_s - not found
-- Looking for _fseeki64
-- Looking for _fseeki64 - not found
-- Looking for _get_timezone
-- Looking for _get_timezone - not found
-- Looking for _localtime64_s
-- Looking for _localtime64_s - not found
-- Looking for _mkgmtime64
-- Looking for _mkgmtime64 - not found
-- Looking for cygwin_conv_path
-- Looking for cygwin_conv_path - not found
-- Looking for fseeko
-- Looking for fseeko - found
-- Looking for vprintf
-- Looking for vprintf - found
-- Looking for wmemcmp
-- Looking for wmemcmp - found
-- Looking for wmemcpy
-- Looking for wmemcpy - found
-- Looking for wmemmove
-- Looking for wmemmove - found
-- Performing Test HAVE_STRUCT_VFSCONF
-- Performing Test HAVE_STRUCT_VFSCONF - Failed
-- Performing Test HAVE_STRUCT_XVFSCONF
-- Performing Test HAVE_STRUCT_XVFSCONF - Failed
-- Performing Test HAVE_READDIR_R
-- Performing Test HAVE_READDIR_R - Success
-- Performing Test HAVE_DIRFD
-- Performing Test HAVE_DIRFD - Success
-- Performing Test HAVE_READLINKAT
-- Performing Test HAVE_READLINKAT - Success
-- Performing Test MAJOR_IN_MKDEV
-- Performing Test MAJOR_IN_MKDEV - Failed
-- Performing Test MAJOR_IN_SYSMACROS
-- Performing Test MAJOR_IN_SYSMACROS - Success
-- Performing Test HAVE_LZMA_STREAM_ENCODER_MT
-- Performing Test HAVE_LZMA_STREAM_ENCODER_MT - Failed
-- Looking for EFTYPE
-- Looking for EFTYPE - not found
-- Looking for EILSEQ
-- Looking for EILSEQ - found
-- Looking for D_MD_ORDER
-- Looking for D_MD_ORDER - not found
-- Looking for INT32_MAX
-- Looking for INT32_MAX - found
-- Looking for INT32_MIN
-- Looking for INT32_MIN - found
-- Looking for INT64_MAX
-- Looking for INT64_MAX - found
-- Looking for INT64_MIN
-- Looking for INT64_MIN - found
-- Looking for INTMAX_MAX
-- Looking for INTMAX_MAX - found
-- Looking for INTMAX_MIN
-- Looking for INTMAX_MIN - found
-- Looking for UINT32_MAX
-- Looking for UINT32_MAX - found
-- Looking for UINT64_MAX
-- Looking for UINT64_MAX - found
-- Looking for UINTMAX_MAX
-- Looking for UINTMAX_MAX - found
-- Looking for SIZE_MAX
-- Looking for SIZE_MAX - found
-- Looking for SSIZE_MAX
-- Looking for SSIZE_MAX - found
-- Performing Test HAVE_STRUCT_TM_TM_GMTOFF
-- Performing Test HAVE_STRUCT_TM_TM_GMTOFF - Success
-- Performing Test HAVE_STRUCT_TM___TM_GMTOFF
-- Performing Test HAVE_STRUCT_TM___TM_GMTOFF - Failed
-- Performing Test HAVE_STRUCT_STATFS_F_NAMEMAX
-- Performing Test HAVE_STRUCT_STATFS_F_NAMEMAX - Failed
-- Performing Test HAVE_STRUCT_STAT_ST_BIRTHTIME
-- Performing Test HAVE_STRUCT_STAT_ST_BIRTHTIME - Failed
-- Performing Test HAVE_STRUCT_STAT_ST_BIRTHTIMESPEC_TV_NSEC
-- Performing Test HAVE_STRUCT_STAT_ST_BIRTHTIMESPEC_TV_NSEC - Failed
-- Performing Test HAVE_STRUCT_STAT_ST_MTIMESPEC_TV_NSEC
-- Performing Test HAVE_STRUCT_STAT_ST_MTIMESPEC_TV_NSEC - Failed
-- Performing Test HAVE_STRUCT_STAT_ST_MTIM_TV_NSEC
-- Performing Test HAVE_STRUCT_STAT_ST_MTIM_TV_NSEC - Success
-- Performing Test HAVE_STRUCT_STAT_ST_MTIME_N
-- Performing Test HAVE_STRUCT_STAT_ST_MTIME_N - Failed
-- Performing Test HAVE_STRUCT_STAT_ST_UMTIME
-- Performing Test HAVE_STRUCT_STAT_ST_UMTIME - Failed
-- Performing Test HAVE_STRUCT_STAT_ST_MTIME_USEC
-- Performing Test HAVE_STRUCT_STAT_ST_MTIME_USEC - Failed
-- Performing Test HAVE_STRUCT_STAT_ST_BLKSIZE
-- Performing Test HAVE_STRUCT_STAT_ST_BLKSIZE - Success
-- Performing Test HAVE_STRUCT_STAT_ST_FLAGS
-- Performing Test HAVE_STRUCT_STAT_ST_FLAGS - Failed
-- Performing Test HAVE_STRUCT_STATVFS_F_IOSIZE
-- Performing Test HAVE_STRUCT_STATVFS_F_IOSIZE - Failed
-- Check size of dev_t
-- Check size of dev_t - done
-- Check size of gid_t
-- Check size of gid_t - done
-- Check size of id_t
-- Check size of id_t - done
-- Check size of mode_t
-- Check size of mode_t - done
-- Check size of off_t
-- Check size of off_t - done
-- Check size of size_t
-- Check size of size_t - done
-- Check size of ssize_t
-- Check size of ssize_t - done
-- Check size of uid_t
-- Check size of uid_t - done
-- Check size of pid_t
-- Check size of pid_t - done
-- Check size of intptr_t
-- Check size of intptr_t - done
-- Check size of wchar_t
-- Check size of wchar_t - done
-- Checking _FILE_OFFSET_BITS for large files
-- Checking _FILE_OFFSET_BITS for large files - not needed
-- Checking support for ARCHIVE_CRYPTO_MD5_LIBC
-- Checking support for ARCHIVE_CRYPTO_MD5_LIBC -- not found
-- Checking support for ARCHIVE_CRYPTO_RMD160_LIBC
-- Checking support for ARCHIVE_CRYPTO_RMD160_LIBC -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA1_LIBC
-- Checking support for ARCHIVE_CRYPTO_SHA1_LIBC -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA256_LIBC
-- Checking support for ARCHIVE_CRYPTO_SHA256_LIBC -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA384_LIBC
-- Checking support for ARCHIVE_CRYPTO_SHA384_LIBC -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA512_LIBC
-- Checking support for ARCHIVE_CRYPTO_SHA512_LIBC -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA256_LIBC2
-- Checking support for ARCHIVE_CRYPTO_SHA256_LIBC2 -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA384_LIBC2
-- Checking support for ARCHIVE_CRYPTO_SHA384_LIBC2 -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA512_LIBC2
-- Checking support for ARCHIVE_CRYPTO_SHA512_LIBC2 -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA256_LIBC3
-- Checking support for ARCHIVE_CRYPTO_SHA256_LIBC3 -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA384_LIBC3
-- Checking support for ARCHIVE_CRYPTO_SHA384_LIBC3 -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA512_LIBC3
-- Checking support for ARCHIVE_CRYPTO_SHA512_LIBC3 -- not found
-- Checking support for ARCHIVE_CRYPTO_MD5_LIBSYSTEM
-- Checking support for ARCHIVE_CRYPTO_MD5_LIBSYSTEM -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA1_LIBSYSTEM
-- Checking support for ARCHIVE_CRYPTO_SHA1_LIBSYSTEM -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA256_LIBSYSTEM
-- Checking support for ARCHIVE_CRYPTO_SHA256_LIBSYSTEM -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA384_LIBSYSTEM
-- Checking support for ARCHIVE_CRYPTO_SHA384_LIBSYSTEM -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA512_LIBSYSTEM
-- Checking support for ARCHIVE_CRYPTO_SHA512_LIBSYSTEM -- not found
-- Checking support for ARCHIVE_CRYPTO_MD5_OPENSSL
-- Checking support for ARCHIVE_CRYPTO_MD5_OPENSSL -- not found
-- Checking support for ARCHIVE_CRYPTO_RMD160_OPENSSL
-- Checking support for ARCHIVE_CRYPTO_RMD160_OPENSSL -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA1_OPENSSL
-- Checking support for ARCHIVE_CRYPTO_SHA1_OPENSSL -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA256_OPENSSL
-- Checking support for ARCHIVE_CRYPTO_SHA256_OPENSSL -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA384_OPENSSL
-- Checking support for ARCHIVE_CRYPTO_SHA384_OPENSSL -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA512_OPENSSL
-- Checking support for ARCHIVE_CRYPTO_SHA512_OPENSSL -- not found
-- Checking support for ARCHIVE_CRYPTO_MD5_LIBMD
-- Checking support for ARCHIVE_CRYPTO_MD5_LIBMD -- not found
-- Checking support for ARCHIVE_CRYPTO_RMD160_LIBMD
-- Checking support for ARCHIVE_CRYPTO_RMD160_LIBMD -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA1_LIBMD
-- Checking support for ARCHIVE_CRYPTO_SHA1_LIBMD -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA256_LIBMD
-- Checking support for ARCHIVE_CRYPTO_SHA256_LIBMD -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA512_LIBMD
-- Checking support for ARCHIVE_CRYPTO_SHA512_LIBMD -- not found
-- Checking for curses support
-- Checking for curses support - Success
-- Looking for wsyncup in /usr/lib/x86_64-linux-gnu/libcurses.so
-- Looking for wsyncup in /usr/lib/x86_64-linux-gnu/libcurses.so - found
-- Looking for cbreak in /usr/lib/x86_64-linux-gnu/libncurses.so
-- Looking for cbreak in /usr/lib/x86_64-linux-gnu/libncurses.so - found
-- Found Curses: /usr/lib/x86_64-linux-gnu/libncurses.so
-- Looking for elf.h
-- Looking for elf.h - found
-- Looking for a Fortran compiler
-- Looking for a Fortran compiler - NOTFOUND
-- Performing Test run_pic_test
-- Performing Test run_pic_test - Success
-- Performing Test run_inlines_hidden_test
-- Performing Test run_inlines_hidden_test - Success
CMake Error at /usr/lib/x86_64-linux-gnu/cmake/Qt5Gui/Qt5GuiConfig.cmake:27 (mes        sage):
  The imported target "Qt5::Gui" references the file
     "/usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqwayland-egl.so"
  but this file does not exist.  Possible reasons include:
  * The file was deleted, renamed, or moved to another location.
  * An install or uninstall procedure did not complete successfully.
  * The installation package was faulty and contained
     "/usr/lib/x86_64-linux-gnu/cmake/Qt5Gui/Qt5Gui_QWaylandEglPlatformIntegrati        onPlugin.cmake"
  but not all the files it references.
Call Stack (most recent call first):
  /usr/lib/x86_64-linux-gnu/cmake/Qt5Gui/Qt5GuiConfig.cmake:171 (_qt5_Gui_check_        file_exists)
  /usr/lib/x86_64-linux-gnu/cmake/Qt5Gui/Qt5Gui_QWaylandEglPlatformIntegrationPl        ugin.cmake:4 (_populate_Gui_plugin_properties)
  /usr/lib/x86_64-linux-gnu/cmake/Qt5Gui/Qt5GuiConfig.cmake:179 (include)
  /usr/lib/x86_64-linux-gnu/cmake/Qt5Widgets/Qt5WidgetsConfig.cmake:101 (find_pa        ckage)
  Tests/CMakeLists.txt:1344 (find_package)
-- Configuring incomplete, errors occurred!
See also "/opt/openwrt/build_dir/host/cmake-3.15.1/CMakeFiles/CMakeOutput.log".
See also "/opt/openwrt/build_dir/host/cmake-3.15.1/CMakeFiles/CMakeError.log".
Error when bootstrapping CMake:
Problem while running initial CMake
Makefile:49: recipe for target '/opt/openwrt/build_dir/host/cmake-3.15.1/.config        ured' failed
make[3]: *** [/opt/openwrt/build_dir/host/cmake-3.15.1/.configured] Error 11
make[3]: Leaving directory '/opt/openwrt/tools/cmake'
time: tools/cmake/compile#558.68#85.65#647.80
tools/Makefile:157: recipe for target 'tools/cmake/compile' failed
make[2]: *** [tools/cmake/compile] Error 2
make[2]: Leaving directory '/opt/openwrt'
tools/Makefile:155: recipe for target '/opt/openwrt/staging_dir/host/stamp/.tool        s_compile_yynyynnyyynyyyyynyynnyyyynyyyyyyyyyyyyyyynynynnyyynnyyy' failed
make[1]: *** [/opt/openwrt/staging_dir/host/stamp/.tools_compile_yynyynnyyynyyyy        ynyynnyyyynyyyyyyyyyyyyyyynynynnyyynnyyy] Error 2
make[1]: Leaving directory '/opt/openwrt'
/opt/openwrt/include/toplevel.mk:225: recipe for target 'world' failed
make: *** [world] Error 2
又出现了一个编译错误。
楼主 #6 2019-11-07 09:04:18
xgui
已发帖子: 224
root@xgui:/opt/openwrt# sudo apt-get install qtwayland5 -y
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following NEW packages will be installed:
  qtwayland5
0 upgraded, 1 newly installed, 0 to remove and 115 not upgraded.
Need to get 117 kB of archives.
After this operation, 846 kB of additional disk space will be used.
Get:1 http://us.archive.ubuntu.com/ubuntu bionic/universe amd64 qtwayland5 amd64 5.9.5-0ubuntu1 [117 kB]
Fetched 117 kB in 1s (189 kB/s)
Selecting previously unselected package qtwayland5:amd64.
(Reading database ... 163653 files and directories currently installed.)
Preparing to unpack .../qtwayland5_5.9.5-0ubuntu1_amd64.deb ...
Unpacking qtwayland5:amd64 (5.9.5-0ubuntu1) ...
Setting up qtwayland5:amd64 (5.9.5-0ubuntu1) ...
root@xgui:/opt/openwrt# ls "/usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqwayland-egl.so"
执行下面的命令安装, 就有了 /usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqwayland-egl.so
楼主 #7 2019-11-07 15:03:23
xgui
已发帖子: 224
编译完成, 生成了几个镜像文件:
root@xgui:/opt/openwrt/bin/targets/sunxi/cortexa7# find /opt/openwrt/ |grep img.gz$ |xargs ls -l
-rw-r--r-- 1 root root 5528281 Nov  7 01:23 /opt/openwrt/bin/targets/sunxi/cortexa7/openwrt-sunxi-cortexa7-sun8i-v3s-dolphinpi-ext4-sdcard.img.gz
-rw-r--r-- 1 root root 5511748 Nov  7 01:23 /opt/openwrt/bin/targets/sunxi/cortexa7/openwrt-sunxi-cortexa7-sun8i-v3s-dolphinpi-ext4-spinand.img.gz
-rw-r--r-- 1 root root 4896001 Nov  7 01:23 /opt/openwrt/bin/targets/sunxi/cortexa7/openwrt-sunxi-cortexa7-sun8i-v3s-dolphinpi-squashfs-sdcard.img.gz
-rw-r--r-- 1 root root 4878068 Nov  7 01:23 /opt/openwrt/bin/targets/sunxi/cortexa7/openwrt-sunxi-cortexa7-sun8i-v3s-dolphinpi-squashfs-spinand.img.gz
楼主 #8 2019-11-07 15:26:54
xgui
已发帖子: 224
把这个文件 openwrt-sunxi-cortexa7-sun8i-v3s-dolphinpi-ext4-sdcard.img 写到TF卡插到海豚派启动,
会提示没有找到SPI NAND
U-Boot SPL 2019.10 (Nov 06 2019 - 15:22:33 +0000)
DRAM: 64 MiB
Trying to boot from MMC1
U-Boot 2019.10 (Nov 06 2019 - 15:22:33 +0000) Allwinner Technology
Model: Dolphin Pi
DRAM:  64 MiB
MMC:   mmc@01c0f000: 0
In:    serial@01c28800
Out:   serial@01c28800
Err:   serial@01c28800
Net:   No ethernet found.
unknown raw ID 43d60dc8
MTD device spi-nand0 not found, ret -19
unknown raw ID 43d60d90
Wrong Image Format for bootm command
ERROR: can't get kernel image!
因为我这片买的是 SPI NOR 的板子, 晚点换个 SPI NAND 试一试。
楼主 #9 2019-11-07 15:42:20
xgui
已发帖子: 224
楼主 #10 2019-11-07 20:26:34
xgui
已发帖子: 224
焊了一片 gd 的 5F1G04 还是出现一样的错误:
DRAM: 64 MiB
Model: Dolphin Pi
DRAM:  64 MiB
In:    serial@01c28800
然后我手动执行命令:
fatload mmc 0 $fdt_addr_r dtb
fatload mmc 0 $kernel_addr_r uImage
setenv bootargs console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rootwait
bootm $kernel_addr_r - $fdt_addr_r
然后才启动:
=> fatload mmc 0 $fdt_addr_r dtb
9573 bytes read in 4 ms (2.3 MiB/s)
=> loadkernel fatload mmc 0 $kernel_addr_r uImage
Unknown command 'loadkernel' - try 'help'
=>  fatload mmc 0 $kernel_addr_r uImage
2926552 bytes read in 157 ms (17.8 MiB/s)
=> setenv bootargs console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rootwait
=> bootm $kernel_addr_r - $fdt_addr_r
## Booting kernel from Legacy Image at 41000000 ...
   Image Name:   ARM OpenWrt Linux-4.19.81
   Data Size:    2926488 Bytes = 2.8 MiB
   Load Address: 40008000
   Entry Point:  40008000
   Verifying Checksum ... OK
   Loading Kernel Image
   Using Device Tree in place at 41800000, end 41805564
[    0.000000] Linux version 4.19.81 (root@test5) (gcc version 8.3.0 (OpenWrt GCC 8.3.0 r11430-68d12ac1fe)) #0 SMP PREEMPT Wed Nov 6 15:22:33 2019
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=30c5387d
[    0.000000] OF: fdt: Machine model: Dolphin PI
[    0.000000] random: get_random_bytes called from start_kernel+0x7c/0x42c with crng_init=0
[    0.000000] percpu: Embedded 15 pages/cpu s31244 r8192 d22004 u61440
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 16240
[    0.000000] Kernel command line: console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rootwait
[    0.000000] Memory: 53872K/65536K available (5928K kernel code, 396K rwdata, 1644K rodata, 2048K init, 242K bss, 11664K reserved, 0K cma-reserved, 0K highmem)
[    0.000000]       .text : 0x(ptrval) - 0x(ptrval)   (7945 kB)
[    0.000000]       .init : 0x(ptrval) - 0x(ptrval)   (2048 kB)
[    0.000000]       .data : 0x(ptrval) - 0x(ptrval)   ( 397 kB)
[    0.000000]        .bss : 0x(ptrval) - 0x(ptrval)   ( 243 kB)
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000]  Tasks RCU enabled.
[    0.000000] GIC: GICv2 detected, but range too small and irqchip.gicv2_force_probe not set
[    0.000246] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000448] Console: colour dummy device 80x30
[    0.000504] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000520] pid_max: default: 32768 minimum: 301
[    0.000691] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000707] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.001622] CPU: Testing write buffer coherency: ok
[    0.002183] /cpus/cpu@0 missing clock-frequency property
[    0.002212] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.060207] Setting up static identity map for 0x40200000 - 0x40200060
[    0.080209] rcu: Hierarchical SRCU implementation.
[    0.120334] smp: Bringing up secondary CPUs ...
[    0.120362] smp: Brought up 1 node, 1 CPU
[    0.120372] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[    0.120380] CPU: All CPU(s) started in HYP mode.
[    0.120385] CPU: Virtualization extensions available.
[    0.130551] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.131308] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.131343] futex hash table entries: 256 (order: 2, 16384 bytes)
[    0.131700] pinctrl core: initialized pinctrl subsystem
[    0.132893] NET: Registered protocol family 16
[    0.133367] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.134565] No ATAGs?
[    0.194178] SCSI subsystem initialized
[    0.194601] usbcore: registered new interface driver usbfs
[    0.194675] usbcore: registered new interface driver hub
[    0.196554] usbcore: registered new device driver usb
[    0.197429] pps_core: LinuxPPS API ver. 1 registered
[    0.197447] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.197606] PTP clock support registered
[    0.199223] Advanced Linux Sound Architecture Driver Initialized.
[    0.204945] clocksource: Switched to clocksource arch_sys_counter
[    0.236731] NET: Registered protocol family 2
[    0.237572] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[    0.237617] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    0.237641] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[    0.237664] TCP: Hash tables configured (established 1024 bind 1024)
[    0.237815] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.237866] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.238141] NET: Registered protocol family 1
[    0.238675] kvm [1]: 8-bit VMID
[    0.239435] kvm [1]: Hyp mode initialized successfully
[    0.242242] No memory allocated for crashlog
[    0.243301] workingset: timestamp_bits=14 max_order=14 bucket_order=0
[    0.270420] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.271385] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    0.301294] io scheduler noop registered
[    0.301317] io scheduler deadline registered
[    0.301580] io scheduler cfq registered (default)
[    0.302426] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO
[    0.307911] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.510540] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.518801] console [ttyS0] disabled
[    0.540248] 1c28800.serial: ttyS0 at MMIO 0x1c28800 (irq = 30, base_baud = 1500000) is a U6_16550A
[    1.103214] console [ttyS0] enabled
[    1.121140] loop: module loaded
[    1.131309] spi-nand spi0.0: unknown raw ID e458a464
[    1.137088] spi-nand: probe of spi0.0 failed with error -524
[    1.144842] libphy: Fixed MDIO Bus: probed
[    1.150935] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[    1.157253] dwmac-sun8i 1c30000.ethernet: No regulator found
[    1.173557] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[    1.180995] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[    1.188288] dwmac-sun8i 1c30000.ethernet: COE Type 2
[    1.193249] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[    1.200076] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[    1.205749] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[    1.211421] dwmac-sun8i 1c30000.ethernet (unnamed net_device) (uninitialized): device MAC address 32:5c:bd:76:99:1b
[    1.222308] libphy: stmmac: probed
[    1.227287] dwmac-sun8i 1c30000.ethernet: Found internal PHY node
[    1.234233] libphy: mdio_mux: probed
[    1.238027] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY
[    1.244386] dwmac-sun8i 1c30000.ethernet: Powering internal PHY
[    1.252188] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.259846] ehci-platform: EHCI generic platform driver
[    1.265716] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.271953] ohci-platform: OHCI generic platform driver
[    1.278131] usbcore: registered new interface driver usb-storage
[    1.285694] mousedev: PS/2 mouse device common for all mice
[    1.292903] i2c /dev entries driver
[    1.298995] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    1.310046] sunxi-mmc 1c0f000.mmc: Linked as a consumer to regulator.2
[    1.344096] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[    1.358630] NET: Registered protocol family 10
[    1.375988] Segment Routing with IPv6
[    1.379769] NET: Registered protocol family 17
[    1.384750] can: controller area network core (rev 20170425 abi 9)
[    1.391859] NET: Registered protocol family 29
[    1.396812] 8021q: 802.1Q VLAN Support v1.8
[    1.401146] Registering SWP/SWPB emulation handler
[    1.415155] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.423934] hctosys: unable to open rtc device (rtc0)
[    1.430217] ALSA device list:
[    1.433201]   No soundcards found.
[    1.436883] mmc0: new high speed SD card at address 0001
[    1.443621] Waiting for root device /dev/mmcblk0p2...
[    1.460188] mmcblk0: mmc0:0001 MS 1.83 GiB
[    1.476884]  mmcblk0: p1 p2
[    1.558165] EXT4-fs (mmcblk0p2): mounted filesystem without journal. Opts: (null)
[    1.566112] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    1.575818] Freeing unused kernel memory: 2048K
[    1.580512] Run /sbin/init as init process
[    1.687264] init: Console is alive
[    1.690997] init: - watchdog -
[    1.803800] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[    1.811179] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[    1.821368] init: - preinit -
[    2.079822] random: jshn: uninitialized urandom read (4 bytes read)
[    2.113169] random: jshn: uninitialized urandom read (4 bytes read)
[    2.139990] random: jshn: uninitialized urandom read (4 bytes read)
[    2.166368] Generic PHY 0.1:01: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0.1:01, irq=POLL)
[    2.177796] dwmac-sun8i 1c30000.ethernet eth0: No Safety Features support found
[    2.185409] dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available
[    2.193072] dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW
[    2.201794] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Press the [f] key and hit [enter] to enter failsafe mode
Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
[    5.344628] mount_root: mounting /dev/root
[    5.379114] random: fast init done
[    5.382883] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    5.482515] urandom-seed: Seed file not found (/etc/urandom.seed)
[    5.530067] procd: - early -
[    5.533099] procd: - watchdog -
[    6.929323] procd: - watchdog -
[    6.932886] procd: - ubus -
[    6.949210] urandom_read: 1 callbacks suppressed
[    6.949222] random: ubusd: uninitialized urandom read (4 bytes read)
[    6.987345] random: ubusd: uninitialized urandom read (4 bytes read)
[    6.994250] random: ubusd: uninitialized urandom read (4 bytes read)
[    7.001779] procd: - init -
Please press Enter to activate this console.
[    7.354365] kmodloader: loading kernel modules from /etc/modules.d/*
[    7.470453] urngd: v1.0.1 started.
[    7.493438] xt_time: kernel timezone is -0000
[    7.546241] PPP generic driver version 2.4.2
[    7.553852] NET: Registered protocol family 24
[    7.589369] kmodloader: done loading kernel modules from /etc/modules.d/*
[    7.596678] random: crng init done
[    7.600091] random: 3 urandom warning(s) missed due to ratelimiting
[   18.119323] Generic PHY 0.1:01: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0.1:01, irq=POLL)
[   18.157530] dwmac-sun8i 1c30000.ethernet eth0: No Safety Features support found
[   18.164866] dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available
[   18.255391] dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW
[   18.283313] br-lan: port 1(eth0) entered blocking state
[   18.305348] br-lan: port 1(eth0) entered disabled state
[   18.311258] device eth0 entered promiscuous mode
[   18.326425] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
[   31.844972] vcc3v0: disabling
[   31.847967] vcc5v0: disabling
BusyBox v1.31.0 () built-in shell (ash)
  _______                     ________        __
 |       |.-----.-----.-----.|  |  |  |.----.|  |_
 |   -   ||  _  |  -__|     ||  |  |  ||   _||   _|
 |_______||   __|_____|__|__||________||__|  |____|
          |__| W I R E L E S S   F R E E D O M
 OpenWrt SNAPSHOT, r11430-68d12ac1fe
=== WARNING! =====================================
There is no root password defined on this device!
Use the "passwd" command to set up a new password
in order to prevent unauthorized SSH logins.
root@OpenWrt:/#
root@OpenWrt:/# cat /proc/mtd
dev:    size   erasesize  name
root@OpenWrt:/#
root@OpenWrt:/# df
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/root               104816      6736     95952   7% /
tmpfs                    27960        48     27912   0% /tmp
tmpfs                      512         0       512   0% /dev
root@OpenWrt:/# ifconfig
br-lan    Link encap:Ethernet  HWaddr 32:5C:BD:76:99:1B
          inet addr:192.168.1.1  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fdeb:9556:12eb::1/60 Scope:Global
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          collisions:0 txqueuelen:1000
eth0      Link encap:Ethernet  HWaddr 32:5C:BD:76:99:1B
          Interrupt:32 Base address:0xe000
          inet6 addr: ::1/128 Scope:Host
          RX packets:140 errors:0 dropped:0 overruns:0 frame:0
          TX packets:140 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:9520 (9.2 KiB)  TX bytes:9520 (9.2 KiB)
root@OpenWrt:/#
#11 2019-11-07 20:43:21
bamkrsde
已发帖子: 29
Hey I've seen you run into some trouble.
First of all: The u-boot spl currently only supports the MXIC35LFxG: https://github.com/bhorn/openwrt/blob/dolphinpi-spinand/package/boot/uboot-sunxi/src/arch/arm/mach-sunxi/spl_spinand_sunxi.c#L484
This is due to the address calculation and page addressing. You may need to check if the addressing and the commands are the same as in the MXIC35. If they are the same, add you chipid to the switch.
I need to refactor the SPL to ease the process of adding support for other chips.
Next I suggest you use the steps from https://whycan.cn/t_3123.html#p26937 to build an sd-card boot image from which you can flash the spi-nand.
Because I hard coded the Boot-Script for the spi-nand in the DolphinPi_defconfig of u-boot the dolphinpi-sdimage won't boot.
And please add questions or seek help in my thread. I can't monitor the whole forum. I cant read chinese and I have a hard time navigating or observing the forum.
最近编辑记录 bamkrsde (2019-11-07 20:44:23)
楼主 #12 2019-11-07 20:54:09
xgui
已发帖子: 224
@bamkrsde 感谢回复, 我一会更新到你的主题
thanks for reply, upload to your thread wait for moment.
#13 2020-07-22 16:06:57
yqqq
感谢分享,拿去耍耍看
