楼主 #1 2019-11-11 16:21:30
苦逼的大白
自己写了一个获取HTTP流,播放的程序,但播放出来全是噪音
音频管道初始化代码
void player_pipeline_init()
audio_pipeline_cfg_t pipeline_cfg = DEFAULT_AUDIO_PIPELINE_CONFIG();
pipeline = audio_pipeline_init(&pipeline_cfg);
mem_assert(pipeline);
raw_stream_cfg_t raw_cfg = RAW_STREAM_CFG_DEFAULT();
raw_cfg.type = AUDIO_STREAM_WRITER;
raw_writer = raw_stream_init(&raw_cfg);
i2s_stream_cfg_t i2s_cfg = I2S_STREAM_CFG_DEFAULT();
i2s_cfg.type = AUDIO_STREAM_WRITER;
i2s_stream_writer = i2s_stream_init(&i2s_cfg);
audio_pipeline_register(pipeline, raw_writer, "raw_writer");
audio_pipeline_register(pipeline, i2s_stream_writer, "i2s");
audio_pipeline_link(pipeline, (const char *[]) {"raw_writer","i2s"}, 2);
i2s_stream_set_clk(i2s_stream_writer, 16000, 16, 1);
audio_pipeline_run(pipeline);
获取HTTP流,播放的代码
esp_http_client_config_t config =
.url = request_data,
.event_handler = http_client_event_msg_t,
client = esp_http_client_init(&config);
esp_http_client_set_method(client,HTTP_METHOD_GET);
esp_err_t err = esp_http_client_perform(client);
if(err == ESP_OK)
int audio_length = esp_http_client_get_content_length(client);
char audio_data = (char )calloc(audio_length,sizeof(char));
esp_http_client_read(client,audio_data,audio_length);
if(audio_data != NULL)
int write_len1,write_len2,offset = 0;
while(offset<audio_length)
write_len1 = (audio_length-offset)>1024?1024:(audio_length-offset);
write_len2 = raw_stream_write(raw_writer,audio_data+offset,write_len1);
offset += write_len2;
ESP_LOGI(TAG,"offset = %d",offset);
free(audio_data);
audio_data = NULL;
esp_http_client_cleanup(client);
问题出在哪里
楼主 #2 2019-11-11 16:23:53
苦逼的大白
Re: 自己写了一个获取HTTP流,播放的程序,但播放出来全是噪音
音频数据采样率为16000 16bit 单通道。写入哪里,分批写或者一次写完都全是噪音。音频数据是没问题的
#3 2019-11-11 20:03:26
这是从http服务器下载数据吗?是什么格式?mp3?
楼主 #4 2019-11-12 09:23:56
苦逼的大白
pcm,采样率16000,16位单通道
#5 2019-11-12 09:42:20
建议问题先简化一下:
  1. 把收到的数据存TF卡, 在电脑播放, 用于判断收到的数据是否正常.
  2. 直接播放 TF 卡的 PCM 文件.
