楼主 #1 2018-02-04 23:19:21
zhuacai
已发帖子: 234
各位大神,全志Allwinner V3s用mplayer播放mp3没声音,要怎么做才能有声音?
# /usr/bin/mplayer 1.mp3
MPlayer 1.3.0-6.3.1 (C) 2000-2016 MPlayer Team
Playing 1.mp3.
libavformat version 57.25.100 (internal)
Audio only file format detected.
Load subtitles in ./
Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
libavcodec version 57.24.102 (internal)
AUDIO: 44100 Hz, 2 ch, floatle, 320.0 kbit/11.34% (ratio: 40000->352800)
Selected audio codec: [ffmp3float] afm: ffmpeg (FFmpeg MPEG layer-3 audio)
[AO OSS] audio_setup: Can't open audio device /dev/dsp: No such file or directory
DVB card number must be between 1 and 4
AO: [null] 44100Hz 2ch floatle (4 bytes per sample)
Video: no video
Starting playback...
A:  11.1 (11.0) of 225.0 (03:45.0)  3.1%
MPlayer interrupted by signal 2 in module: play_audio
A:  11.1 (11.1) of 225.0 (03:45.0)  3.1%
Exiting... (Quit)
楼主 #2 2018-02-05 13:48:36
zhuacai
已发帖子: 234
Re: 各位大神,全志Allwinner V3s用mplayer播放mp3没声音,要怎么做才能有声音?
使用mplayer播放音乐时警告“[AO OSS] audio_setup: Can't open audio device /dev/dsp: No such file or directory”
这个问题主要是缺少了OSS PCM (digital audio) API模块。
cd /home/vv3/Downloads/linux#
make ARCH=arm menuconfig 配置内核
Device Drivers  --->
   <*> Sound card support  --->
        <*>   Advanced Linux Sound Architecture  --->
                -- Advanced Linux Sound Architecture
                [*]   Enable OSS Emulation
                <*>     OSS Mixer API
                <*>     OSS PCM (digital audio) API
                [/*]       OSS PCM (digital audio) API - Include plugin system
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- -j4 编译内核
# ./tinymix set 1 63 设置声音大小
# ./tinymix set 2 1
# /usr/bin/mplayer -x 800 -y 480 -zoom aa.avi  播放频视
#3 2018-02-05 13:49:34
已发帖子: 9,358
buildroot里面把 alsa-lib, alsa-utils, madplay都编译进去,
先测试 aplay能否播放wave文件,
然后测试:
#madplay -o  wave:- xxxx.mp3 | aplay
madplay解码的音频流通过管道输出给 aplay进程。
楼主 #4 2018-02-05 13:52:37
zhuacai
已发帖子: 234
Device Drivers  --->
                <*>     OSS Mixer API
# ./tinymix set 2 1
可以播放频视,但声音不同步,声音快很多,是什么问题?
#5 2018-02-05 15:00:22
已发帖子: 9,358
感觉这个问题应该是mplayer的问题,
你换别的mp4文件呢?
当然也有可能是 alsa 转 oss 出了问题,
只能先判断是不是文件出问题了。
楼主 #6 2018-02-05 15:24:48
zhuacai
已发帖子: 234
你换别的mp4文件呢?
只能先判断是不是文件出问题了。
晕哥,换了几个mp4,avi都一样
#7 2018-02-05 15:33:00
已发帖子: 9,358
那就不能确定问题了。
楼主 #8 2018-02-06 09:44:26
zhuacai
已发帖子: 234
加了-framedrop 播放avi声音能同步,播放mp4声音还不能同步,待解决
/usr/bin/mplayer -x 800 -y 480 -zoom -framedrop aa.avi
#9 2018-07-18 18:04:30
yangbo
请教一个问题,我用qt5中multimedia做视频播放,ubuntu 和开发板运行程序,都会出现defaultServiceProvider::requestService(): no service found for - "org.qt-project.qt.mediaplayer",网上说安装sudo apt-get install qtmultimedia5-dev sudo apt-get install libqt5multimedia5-plugins工具包都不行,有没有什么办法解决?
#10 2018-07-18 18:11:01
已发帖子: 9,358
可能底层没有适配好, 我都是直接改改 tinyplay.c 输出声音的。
#11 2018-07-31 21:24:07
奇异果
已发帖子: 22
大佬们我这内核里面的配置好了,而且在/dev路径下也有dsp文件,运行程序的时候也没出现错误,但是为什么mplayer运行后再耳机里面还是没有声音啊?
#12 2018-08-01 00:15:43
已发帖子: 9,358
有两个解决方法:
1. MPlayer从alsa接口输出声音
2. 在内核开启oss模拟
#13 2019-01-04 11:48:36
千石级灯
已发帖子: 47
@晕哥
晕哥请问下,在v3s上移植mplayer1.3.0时,我在编译时遇到了如下的错误,不知道该怎么解决?
我是参考这个网址来进行配置的:http://www.cnblogs.com/guanglun/p/9141791.html
ffmpeg/libavcodec/libavcodec.a(pngdec.o): In function `decode_text_chunk.isra.4':
pngdec.c:(.text+0x20c): undefined reference to `inflateInit_'
pngdec.c:(.text+0x26c): undefined reference to `inflate'
pngdec.c:(.text+0x2a4): undefined reference to `inflateEnd'
pngdec.c:(.text+0x4d8): undefined reference to `inflateEnd'
ffmpeg/libavcodec/libavcodec.a(pngdec.o): In function `decode_frame_common.isra.6':
pngdec.c:(.text+0x1048): undefined reference to `inflate'
ffmpeg/libavcodec/libavcodec.a(pngdec.o): In function `decode_frame_apng':
pngdec.c:(.text+0x354c): undefined reference to `inflateInit_'
pngdec.c:(.text+0x35c4): undefined reference to `inflateEnd'
ffmpeg/libavcodec/libavcodec.a(rscc.o): In function `rscc_decode_frame':
rscc.c:(.text+0x2f8): undefined reference to `uncompress'
rscc.c:(.text+0x514): undefined reference to `uncompress'
ffmpeg/libavcodec/libavcodec.a(screenpresso.o): In function `screenpresso_decode_frame':
screenpresso.c:(.text+0x90): undefined reference to `uncompress'
ffmpeg/libavcodec/libavcodec.a(tdsc.o): In function `tdsc_decode_frame':
tdsc.c:(.text+0x74): undefined reference to `uncompress'
Makefile:747: recipe for target 'mplayer' failed
make: *** [mplayer] Error 1
下面是我的配置选项:
./configure --enable-cross-compile --host-cc=gcc --cc=arm-linux-gnueabihf-gcc --as=arm-linux-gnueabihf-as --ar=arm-linux-gnueabihf-ar --ranlib=arm-linux-gnueabihf-ranlib --target=arm-linux --disable-dvdread --disable-win32dll --enable-fbdev --disable-mencoder --disable-live --disable-mp3lame --disable-armv5te  --enable-alsa --extra-cflags="-I /usr/local/alsa/build/include" --extra-ldflags="-L /usr/local/alsa/build/lib "
之后make就出现上面的错误了。
#14 2019-01-04 14:22:34
已发帖子: 9,358
https://www.zlib.net/manual.html
inflateEnd 这些是 zlib 的函数, 你的先编译这个。
这些依赖关系很麻烦, 用 buildroot 省事。
#15 2019-01-04 14:44:45
千石级灯
已发帖子: 47
@晕哥
晕哥,请问下如果使用buildroot的话,因为我是个新手,对这个使用不是特别的熟悉,有没有一些参考的网址来学习下如何使用的呢?
#16 2019-01-04 14:55:17
已发帖子: 9,358
本站搜索一下, 有挺多关于 buildroot 的帖子, 不明白跟帖就可以了。
