U-Boot SPL 2019.10-ge71ae959-dirty (Dec 10 2019 - 19:15:16 +0000)
DRAM: 64 MiB
Trying to boot from MMC1
U-Boot 2019.10-ge71ae959-dirty (Dec 10 2019 - 19:15:16 +0000) Allwinner Technology
Model: Lichee Pi Zero
DRAM: 64 MiB
MMC: mmc@01c0f000: 0
Loading Environment from FAT... *** Warning - bad CRC, using default environment
In: serial@01c28000
Out: serial@01c28000
Err: serial@01c28000
Net: No ethernet found.
No working controllers found
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
207 bytes read in 3 ms (67.4 KiB/s)
1: Linux vanilla
Retrieving file: /boot/initramfs-vanilla
6588262 bytes read in 300 ms (20.9 MiB/s)
Retrieving file: /boot/zImage
3608368 bytes read in 177 ms (19.4 MiB/s)
append: modules=loop,squashfs,sd-mod,usb-storage quiet
Retrieving file: /boot/dtbs/sun8i-v3s-licheepi-zero.dtb
8455 bytes read in 16 ms (515.6 KiB/s)
Loading Ramdisk to 427b7000, end 42dff766 ... OK
Loading Device Tree to 427b1000, end 427b6106 ... OK
[ 0.001675] /cpus/cpu@0 missing clock-frequency property
OpenRC 0.41.2.6fc2696f3e is starting up Linux 4.10.0-rc1-gdd75eb5de (armv7l)
* /proc is already mounted
* Mounting /run ... * /run/openrc: creating directory
* /run/lock: creating directory
* /run/lock: correcting owner
* Caching service dependencies ... [ ok ]
* Clock skew detected with `(null)'
* Adjusting mtime of `/run/openrc/deptree' to Mon Jun 10 08:36:51 2019
* WARNING: clock skew detected!
* Remounting devtmpfs on /dev ... [ ok ]
* Mounting modloop ... * Verifying modloop
mount: can't setup loop device: No such device or address
* ERROR: modloop failed to start
* Mounting debug filesystem ... [ ok ]
* Starting busybox mdev ... [ ok ]
* Loading hardware drivers ... [ ok ]
* Loading modules ...modprobe: can't change directory to '/lib/modules': No such file or directory
[ ok ]
* Setting system clock using the hardware clock [UTC] ... [ ok ]
* Checking local filesystems ... [ ok ]
* Remounting filesystems ... [ ok ]
* Mounting local filesystems ... [ ok ]
* Configuring kernel parameters ...sysctl: error: 'net.ipv4.tcp_syncookies' is an unknown key
sysctl: error: 'net.ipv6.conf.all.accept_redirects' is an unknown key
sysctl: error: 'net.ipv6.conf.all.accept_source_route' is an unknown key
sysctl: error: 'net.ipv6.conf.default.use_tempaddr' is an unknown key
sysctl: error: 'net.ipv6.conf.all.use_tempaddr' is an unknown key
[ ok ]
* Migrating /var/lock to /run/lock ... [ ok ]
* Creating user login records ... [ ok ]
* Wiping /tmp directory ... [ ok ]
* Setting hostname ... [ ok ]
* Starting busybox syslog ... [ ok ]
Welcome to Alpine Linux 3.10
Kernel 4.10.0-rc1-gdd75eb5de on an armv7l (/dev/ttyS0)
alpine login:
终于跑起来,主要问题更新 sd 卡 u-boot-sunxi-with-spl.bin 和 zimage
- sudo dd if=<board>/u-boot-sunxi-with-spl.bin of=/dev/<sdX> bs=1024 seek=8
- zimage 开启 initramfs 支持,并修改 size 为 32768,数量为 1
- /extlinux/extlinux.conf
- KERNEL /boot/vmlinuz-vanilla
>> KERNEL /boot/zimage
- /boot/grub/grub.cfg
- linux /boot/vmlinuz-vanilla modules=loop,squashfs,sd-mod,usb-storage quiet
>> linux /boot/zimage modules=loop,squashfs,sd-mod,usb-storage quiet
login: root
>> setup-alpine 执行 Alpine linux 安装
TODO...
最近编辑记录 Iron (2019-12-11 04:54:07)
alpine linux 怎么玩的,有没有教程?
https://wiki.alpinelinux.org/wiki/Main_Page
只能看官方文档咯0..0,我也不熟,学习摸索中。
