楼主 #1 2020-01-13 17:09:39
NaD
Allwinner H3 Projector with custom Android 4.4.2 called Levision. HELP
Hi Guys,
I have a Chinese Projector called a Magic-Image M1 with Android 4.4.2.I tried to install TWRP bootrecovery onto the device and it bricked it! It uses a H3 Allwinner hardware board running a flavor of Android they made them self's called Levision on 4.4.2. I managed to contact them and after a HUGH struggle to send me the
firmware, they eventually did! But here is the problem, they send it in OTA ZIP update format with these files listed,
2008/02/29 10:33 12 083 200 boot.img
2008/02/29 10:33 32 768 boot0_nand.fex
2008/02/29 10:33 32 768 boot0_sdcard.fex
2008/02/29 10:33 7 209 984 bootloader.fex
2008/02/29 10:33 131 072 env.fex
2008/02/29 10:33 9 075 file_contexts
2019/03/17 17:22 <DIR> META-INF
2019/03/17 14:01 <DIR> recovery
2019/03/15 18:57 13 012 992 recovery.img
system
2008/02/29 10:33 933 888 uboot_nand.fex
2008/02/29 10:33 933 888 uboot_sdcard.fex
Below is the error I extracted from the UART debug port via putty,
[sun8i_fixup]: From boot, get meminfo:
S?art: 0x40000000
ion_carveout reserve: 160m@0 300m@0 130m@1 200m@1
ion_reserve_select: ion chipid [0x2c00081!
ion_reserve_common: ion reserve: [0x4d400000, 0x60000000]!
[ 0.770060] ls_fetch_sysconfig_para: type err device_used = -1064009776.
[ 0.782056] [cpu_freq] ERR:get cpu extremity frequency from sysconfig failed, use max_freq
[ 0.802360] sunxi_oops: heming add OOPS_INFO_ADDR = -20
[ 0.957791] gpio-keys-polled gpio-keys-polled.0: unable to claim gpio 16, err=-16
[ 0.966275] ths_fetch_sysconfig_para: type err device_used = 1.
[ 0.981586] init: init proc start
[ 1.049087] init: open path: /dev/bus/usb/001/001
[ 1.240250] init: open path: /dev/bus/usb/002/002
[ 1.442023] init: open path: /dev/bus/usb/002/001
[ 1.710240] init: open path: /dev/bus/usb/003/002
[ 1.932304] init: start e2fsck listening...
[ 1.951050] init: open path: /dev/bus/usb/002/002
[ 1.956750] EXT4-fs (nandm): VFS: Can't find ext4 filesystem
[ 2.010218] fs_mgr: begin to format ext4 buffer : /dev/block/nandm
[ 2.055305] init: open path: /dev/bus/usb/003/001
[ 2.310516] init: open path: /dev/bus/usb/003/002
[ 2.564758] init: open path: /dev/bus/usb/004/001
[ 4.838517] fs_mgr: finish format to ext4 :/dev/block/nandm
[ 4.886940] EXT4-fs (nandn): VFS: Can't find ext4 filesystem
[ 4.937111] init: C_IN_START
[ 4.940154] init: path = /dev/block/by-name/cache
[ 4.960157] fs_mgr: begin to format ext4 buffer : /dev/block/nandn Z2 battery get level is 100.
[ 24.1132v2] fs_mor: finish format to ext4 :/dev/block/nandn
[ 24.145791] FAT-fs (nandi): bogus logical sector size 65535
[ 24.230097] fs_?gr: start ?rmat /de?/block/by-name/Reserve0
[ 24.236512] fs_mgr: wait for format /dev/block/by-name/Reserve0
[ 24.236773] fs_mgr: fork to format /dev/block/by-name/Reserve0 fileSystem: Fat16
[ ?4>251814] FA?-fs (nandi): bogus logical sector size 65535
[ 24.310114] fs_mgr: Cannot mont filesystem on /dev/block/by-name/Reserve0 at /mnt/Reserve0
[ 24.319425] init: fs_mgr_mount_all returned an error
[ 24.325607] init: defined DONT_SHOW_INITLOGO
[ 24?331069] ini?: /sys/cln?
[ 24.331108] init: dont need format /dev/block/by-name/private
[ 24.337216] init: skipping insecure file '/system/vendor/modules/mali.ko'
[ 24.337295] init: skipping?insecure file '/system/vendor/modules/sunxi-ir-rx.ko'
[ 24.337351] init: skipping insecure file '/system/vendor/modules/sunxi-keyboard.ko'
[ 24.337419] init: skipping insecure file '/system/vendor/modules/gpio-sunxi.ko'
[ 24.375922] init: The device is not low memory 1002
[ 24.381339] init: init_disp=0x20b0404, type=2, id=1
[ 24.386980] init: disp=1,type=2,mode=11
[ 24.419164] init: skipping insecure file '/system/build.prop'
[ 24.426149] init: get_disp_policy: for modify confi?s.
[ 24.431877] init: untracked pid 118 exited
[ 24.436882] init: skipping insecure file '/system/vendor/modules/bt_sleep.ko'
[ 24.444910] init: skipping insecure file '/system/vendor/modules/asix.ko'
[ 24.478503] healthd: No charger supplies found
[ 24.600448] init: cannot find '/system/bin/sh', disabling 'console'
[ 24.607585] android_usb: already disable?
[ 24.947444] init: C_IN_START
[ 24.9505r4] init: path = /dev/block/by-name/UDISK
[ 25.041200] init: cannot execve('/system/etc/install-recovery.sh'): No such folder
[ 26.232861] init: untracked pid 177 exited
I tried flashing it with PhoenixPro but it does not work. I am a NOOB with this. Can someone please help to get it working to be flashed via PhoenixPro or via SD port? The image is here https://drive.google.com/drive/u/0/folders/1wHtjVri9m-wxC8ibQBQ-2hZX02sqFpTm
I need someone to please help me convert the OTA ZIP to flashable IMG via PhoenixPro/Livesuit or point me in the correct direction how to fix it?
#2 2020-01-13 17:14:56
天马行空
已发帖子: 57
Re: Allwinner H3 Projector with custom Android 4.4.2 called Levision. HELP
请问你的Projector程序存放在 TF卡/eMMC/SPI NAND ?
楼主 #3 2020-01-13 18:22:45
NaD
Thanks for the reply! Originaly stored on NAND, but can be stored on TF card as well. So both TF card and NAND flash
#4 2020-01-13 18:43:26
所在地: 微信 whycan_cn
已发帖子: 9,252
你用 PhoenixSuit.exe 软件, 通过USB 口烧录到 NAND 可以启动吗?
楼主 #5 2020-01-13 18:47:09
NaD
I can flash through USB via PhoenixSuit or I can flash the NAND via TF (SD) Card if image was written via Phoenixcard.
楼主 #6 2020-01-13 22:25:48
NaD
Yes, I can flash NAND through USB via PhoenixSuit or I can flash the NAND via TF (SD) Card if image was written via Phoenixcard. I just need to full image ROM file to flash the H3 board
#7 2020-01-13 23:26:54
cityf
已发帖子: 195
感觉你的固件有问题,去香橙派或者友善之臂官网下载H3的固件,看能否跑起来吧。
楼主 #8 2020-01-14 13:26:01
NaD
cityf 说:
Thanks!! Obviously there is a problem with the Firmware as TWRP bricked the projector to boot up. In need help in converting the OTA update image into a full flash able image via PhoenixPro or Livesuit. The H3 Pie Firmware does work, but the projector does not display anything out the of the projection lamp. I need the Levision Android 4.4.2 firmware for this projector to work again
As per my original post, can someone please help me to convert the OTA ZIP update image into a full flash rom image? Or point me in the correct direction via the error log I supplied how to fix the current NAND flash firmware? for instance, needs a mounting script, or permissions etc. ? I will even pay someone a few BTC to help me, PLEASE!?!
I have uploaded the init.rc, build.prop.
Thanks guys!!
最近编辑记录 NaD (2020-01-14 14:49:27)
#9 2020-01-14 14:25:28
所在地: 微信 whycan_cn
已发帖子: 9,252
也就是说, 烧录其他 H3 固件是能启动的, 但是烧这个 OTA zip 不能启动, 你需要重新打包成烧录并能启动成功的 img 文件?
愿意支付多少 BTC 呢? 我愿意帮你去广播一下.
另外, 方便拍一下板子的照片吗?flash是什么型号呢?
楼主 #10 2020-01-14 14:59:14
NaD
Yes, precisely what i need!
I will pay around $100 USD in BTC?
I will take picture later when I am home
Thanks again for the help!
最近编辑记录 NaD (2020-01-14 16:37:30)
楼主 #11 2020-01-14 15:02:40
NaD
I tried to upload the OTA ZIP update but i does not upload. Can you guys access the Google drive link, https://drive.google.com/drive/u/0/folders/1wHtjVri9m-wxC8ibQBQ-2hZX02sqFpTm ?
#12 2020-01-14 16:38:13
所在地: 微信 whycan_cn
已发帖子: 9,252
一个朋友回复:
进入recovery 按照这个博客用官方升级方式升级
参考 http://m.blog.chinaunix.net/uid-29783732-id-4417641.html
package_extract_dir  这个是google官方的   可以升级system分区
#13 2020-01-14 16:40:52
assert
已发帖子: 54
根据 Android 9的经验 META-INF/目录内含update-binary 和 updater-script 可以参考下升级脚本,也可以根据晕哥说的博客地址内容使用系统recovery把OTA zip包升级试一下
楼主 #14 2020-01-14 18:13:13
NaD
I will try this method
Thank you very much guys!!!
最近编辑记录 NaD (2020-01-14 18:13:40)
楼主 #15 2020-01-14 23:25:39
NaD
一个朋友回复:
This fix did not work. :-(
I need the full image ROM to be flashed via PhoenixPro or Live suit.
楼主 #16 2020-01-14 23:32:30
NaD
I attached a picture of the board. I also cannot ADB to the device. It uses the vid_1f3a_pid_efe8 USB driver that only works via PhoenixPro or Livesuite
楼主 #17 2020-01-15 00:01:05
NaD
I can however get into the O/S via UART,
Reserve1    : 6e000000      2000000
Reserve2    : 70000000      1000000
cache       : 71000000      28000000
UDISK       : 99000000      0
base bootcmd=run setargs_nand boot_normal
bootcmd set setargs_nand
key 0
cant find rcvy value
cant find fstbt value
misc partition found
to be run cmd=run setargs_nand boot_normal
get secure storage map err
check user data form private
read flash error
WORK_MODE_BOOT
adver not need show
sunxi_bmp_logo_display
read all error: start=0, addr=0x769fda60 count=0x1
error: open bootlogo.bmp, maybe it is not exist
sunxi bmp info error : unable to open logo file bootlogo.bmp
[      2.303]Hit any key to stop autoboot:  0
sunxi#ls
Unknown command 'ls' - try 'help'
sunxi#help
楼主 #18 2020-01-15 00:02:01
NaD
Can the NAND be flashed via UART (Putty)?
楼主 #19 2020-01-16 13:06:04
NaD
Can anyone else please assist? PLEASE?
#20 2020-01-16 15:00:54
红白机
已发帖子: 133
你得想办法进入 android的recovery模式,这种模式下面才能升级 update.zip
#21 2020-01-16 15:01:27
assert
已发帖子: 54
先找方法进recovery模式吧,实在没办法用tf卡引导进一个系统,把分区内容给还原掉。在bootloader里面操作比较麻烦
