rtl8723bs通过SDIO0的引脚直接插在板子上的,
试过了4.10和4.13的内核,加了r8723bs的驱动,
开机后modprobe r8723bs不报错也无回显,
ifconfig wlan0 up提示没有设备,
确认网卡没坏,插在f1c100s上能用,
这是因为什么原因?
设备树配好了吗?
cityf wrote:
设备树配好了吗?
你这里是指make menuconfig选择r8723bs之后还要对dts进行更改吗?
OK,解决了,原因是要使用sun8i-v3s-licheepi-zero-dock.dtb而不能使用sun8i-v3s-licheepi-zero.dtb
sunxi-mmc 1c10000.mmc: data error, sending stop command不知为何,然而还是挂了。
噢,对,就是这个问题。
据说RTL8723长时间工作不是很稳定,你可以试一试。
U-Boot SPL 2017.01-rc2-00055-gc41fbfe7b5 (Jan 20 2017 - 00:39:08)
DRAM: 64 MiB
Trying to boot from MMC1
U-Boot 2017.01-rc2-00055-gc41fbfe7b5 (Jan 20 2017 - 00:39:08 +0800) Allwinner Technology
Model: Lichee Pi Zero
DRAM: 64 MiB
MMC: SUNXI SD/MMC: 0
In: serial@01c28000
Out: serial@01c28000
Err: serial@01c28000
DRAM: 64 MiB
In: serial@01c28000
Net: No ethernet found.
No controllers found
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr
reading /boot.scr
287 bytes read in 17 ms (15.6 KiB/s)
reading zImage
3971856 bytes read in 661 ms (5.7 MiB/s)
reading sun8i-v3s-licheepi-zero.dtb
11856 bytes read in 29 ms (398.4 KiB/s)
Loading Device Tree to 42dfa000, end 42dffe4f ... OK
[ 0.000000] Linux version 4.13.16-licheepi-zero+ (root@chainsx.cn) (gcc version 7.4.0 (Ubuntu/Linaro 7.4.0-1ubuntu1~18.04.1)) #1 SMP Mon Jan 13 10:37:52 CST 2020
[ 0.000000] OF: fdt: Machine model: Lichee Pi Zero with Dock
[ 0.000000] percpu: Embedded 16 pages/cpu @c3de6000 s33868 r8192 d23476 u65536
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 15883
[ 0.000000] Kernel command line: console=ttyS0,115200 panic=5 console=tty0 rootwait root=/dev/mmcblk0p2 earlyprintk rw
[ 0.000000] Memory: 53560K/64036K available (6144K kernel code, 237K rwdata, 1448K rodata, 1024K init, 262K bss, 10476K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] vmalloc : 0xc4000000 - 0xff800000 ( 952 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc3e89000 ( 62 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0700000 (7136 kB)
[ 0.000000] .init : 0xc0900000 - 0xc0a00000 (1024 kB)
[ 0.000000] .data : 0xc0a00000 - 0xc0a3b580 ( 238 kB)
[ 0.000000] .bss : 0xc0a427f0 - 0xc0a8402c ( 263 kB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU event tracing is enabled.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
[ 0.000009] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000021] Switching to timer-based delay loop, resolution 41ns
[ 0.000181] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000420] Console: colour dummy device 80x30
[ 0.000852] console [tty0] enabled
[ 0.000890] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000928] pid_max: default: 32768 minimum: 301
[ 0.001070] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001101] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001719] CPU: Testing write buffer coherency: ok
[ 0.002130] /cpus/cpu@0 missing clock-frequency property
[ 0.002175] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002665] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.002878] Hierarchical SRCU implementation.
[ 0.003414] smp: Bringing up secondary CPUs ...
[ 0.003447] smp: Brought up 1 node, 1 CPU
[ 0.003467] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.003487] CPU: All CPU(s) started in SVC mode.
[ 0.004284] devtmpfs: initialized
[ 0.007472] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.007810] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.007868] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.008042] pinctrl core: initialized pinctrl subsystem
[ 0.008948] random: get_random_u32 called from bucket_table_alloc+0x110/0x238 with crng_init=0
[ 0.009124] NET: Registered protocol family 16
[ 0.009609] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.010844] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.010897] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.024144] SCSI subsystem initialized
[ 0.024462] usbcore: registered new interface driver usbfs
[ 0.024572] usbcore: registered new interface driver hub
[ 0.024690] usbcore: registered new device driver usb
[ 0.024965] pps_core: LinuxPPS API ver. 1 registered
[ 0.024991] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.025038] PTP clock support registered
[ 0.025268] Advanced Linux Sound Architecture Driver Initialized.
[ 0.027134] clocksource: Switched to clocksource arch_sys_counter
[ 0.038200] NET: Registered protocol family 2
[ 0.038837] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.038893] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.038931] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.039079] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.039144] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.039375] NET: Registered protocol family 1
[ 0.040000] RPC: Registered named UNIX socket transport module.
[ 0.040048] RPC: Registered udp transport module.
[ 0.040066] RPC: Registered tcp transport module.
[ 0.040083] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.042201] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.051250] NFS: Registering the id_resolver key type
[ 0.051327] Key type id_resolver registered
[ 0.051346] Key type id_legacy registered
[ 0.052351] random: fast init done
[ 0.055294] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.055348] io scheduler noop registered
[ 0.055367] io scheduler deadline registered
[ 0.055669] io scheduler cfq registered (default)
[ 0.055697] io scheduler mq-deadline registered
[ 0.055717] io scheduler kyber registered
[ 0.060171] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.131781] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.135213] console [ttyS0] disabled
[ 0.155519] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 36, base_baud = 1500000) is a U6_16550A
[ 0.737400] console [ttyS0] enabled
[ 0.744505] libphy: Fixed MDIO Bus: probed
[ 0.749208] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[ 0.755026] dwmac-sun8i 1c30000.ethernet: No regulator found
[ 0.760815] dwmac-sun8i 1c30000.ethernet: Will use internal PHY
[ 0.766993] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[ 0.772715] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[ 0.779973] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[ 0.785639] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[ 0.792886] dwmac-sun8i 1c30000.ethernet: COE Type 2
[ 0.797870] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[ 0.804868] libphy: stmmac: probed
[ 0.810261] usbcore: registered new interface driver rtl8xxxu
[ 0.816046] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.822704] ehci-platform: EHCI generic platform driver
[ 0.828274] ehci-platform 1c1a000.usb: EHCI Host Controller
[ 0.833913] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[ 0.841947] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000
[ 0.877149] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[ 0.884370] hub 1-0:1.0: USB hub found
[ 0.888359] hub 1-0:1.0: 1 port detected
[ 0.892893] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.899212] ohci-platform: OHCI generic platform driver
[ 0.904777] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[ 0.911532] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[ 0.919527] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400
[ 0.992294] hub 2-0:1.0: USB hub found
[ 0.996151] hub 2-0:1.0: 1 port detected
[ 1.003779] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[ 1.013408] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input0
[ 1.022456] sun6i-rtc 1c20400.rtc: rtc core: registered rtc-sun6i as rtc0
[ 1.029392] sun6i-rtc 1c20400.rtc: RTC enabled
[ 1.033953] i2c /dev entries driver
[ 1.038987] input: ns2009_ts as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0048/input/input1
[ 1.048579] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.117182] sunxi-mmc 1c0f000.mmc: base:0xc41f8000 irq:23
[ 1.164522] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.174733] mmc0: new high speed SDHC card at address 1234
[ 1.180831] sunxi-mmc 1c10000.mmc: base:0xc41fc000 irq:24
[ 1.187421] usbcore: registered new interface driver usbhid
[ 1.193023] usbhid: USB HID core driver
[ 1.197632] mmcblk0: mmc0:1234 SA04G 3.64 GiB
[ 1.205247] sun4i-codec 1c22c00.codec: ASoC: /soc/codec-analog@01c23000 not registered
[ 1.213320] sun4i-codec 1c22c00.codec: Failed to register our card
[ 1.221886] mmcblk0: p1 p2
[ 1.226822] NET: Registered protocol family 17
[ 1.231547] Key type dns_resolver registered
[ 1.235972] Registering SWP/SWPB emulation handler
[ 1.245421] simple-framebuffer 43e89000.framebuffer: framebuffer at 0x43e89000, 0x177000 bytes, mapped to 0xc4380000
[ 1.256119] simple-framebuffer 43e89000.framebuffer: format=x8r8g8b8, mode=800x480x32, linelength=3200
[ 1.272516] Console: switching to colour frame buffer device 100x30
[ 1.288908] simple-framebuffer 43e89000.framebuffer: fb0: simplefb registered!
[ 1.301357] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 1.320570] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.330413] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[ 1.343651] hub 3-0:1.0: USB hub found
[ 1.351652] hub 3-0:1.0: 1 port detected
[ 1.360820] using random self ethernet address
[ 1.369189] using random host ethernet address
[ 1.378423] usb0: HOST MAC 72:95:b9:b4:ad:46
[ 1.386373] usb0: MAC ca:34:cc:df:91:03
[ 1.393828] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[ 1.404910] g_cdc gadget: g_cdc ready
[ 1.414726] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
[ 1.427179] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01 00:28:40 UTC (1720)
[ 1.439389] vcc5v0: disabling
[ 1.445984] ALSA device list:
[ 1.452567] #0: V3s Audio Codec
[ 1.461751] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[ 1.475940] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[ 1.488948] mmc1: new high speed SDIO card at address 0001
[ 1.513090] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.525081] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 1.536626] devtmpfs: mounted
[ 1.544647] Freeing unused kernel memory: 1024K
[ 1.859659] systemd[1]: System time before build time, advancing clock.
[ 1.902638] systemd[1]: Failed to insert module 'autofs4': No such file or directory
[ 1.947626] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 1.977549] systemd[1]: Detected architecture arm.
[ 2.000937] systemd[1]: Set hostname to <acqua>.
[ 2.561583] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 2.577358] systemd[1]: Listening on udev Kernel Socket.
[ 2.590744] systemd[1]: Reached target Swap.
[ 2.602996] systemd[1]: Reached target Encrypted Volumes.
[ 2.616327] systemd[1]: Reached target Remote File Systems (Pre).
[ 2.630433] systemd[1]: Reached target Remote File Systems.
[ 2.644485] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 2.743762] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Ubuntu 16.04.6 LTS acqua ttyS0
acqua login: ro[ 14.488944] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 14.495655] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 14.505507] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 14.512451] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 14.519097] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 14.525605] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 14.532159] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 14.538687] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 14.545200] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 14.551746] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 14.558246] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 14.564722] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 14.571247] sunxi-mmc 1c10000.mmc: data error, sending stop command
o[ 14.577952] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 14.584759] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 14.591399] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 14.597977] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 14.604489] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 14.611355] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 14.617913] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 14.624409] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 14.630932] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 14.637476] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 14.645519] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 14.653172] sunxi-mmc 1c10000.mmc: data error, sending stop command
t
Password: [ 18.447256] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 18.453869] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 18.464811] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 18.474216] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 18.482577] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 18.493056] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 18.501027] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 18.508885] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 18.515949] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 18.523813] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 18.531630] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 18.538928] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 18.545948] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 18.553135] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 18.560298] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 18.568033] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 18.575210] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 18.582505] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 18.589693] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 18.596693] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 18.603857] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 18.611015] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 18.618138] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 18.625820] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 18.633156] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 18.640361] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 18.647727] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 18.654752] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 18.661924] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 18.669075] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 18.676096] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 18.683221] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 18.690438] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 18.698410] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 18.705765] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 19.667255] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 19.674341] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 19.684535] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 19.693735] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 19.701742] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 19.709589] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 19.716770] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 19.724547] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 19.732335] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 19.740151] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 19.754588] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 19.761832] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 19.769167] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 19.776185] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 19.783475] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 19.790657] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 19.797803] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 19.804798] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 19.811963] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 19.819107] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 19.826097] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 19.833246] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 19.840390] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 19.847522] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 19.854511] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 19.862389] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 19.869706] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 19.876866] sunxi-mmc 1c10000.mmc: data error, sending stop command
Last login: Thu Feb 11 16:33:07 UTC 2016 on ttyS0
Welcome to Ubuntu 16.04.6 LTS (GNU/Linux 4.13.16-licheepi-zero+ armv7l)
* Documentation: https://help.ubuntu.com
* Management: https://landscape.canonical.com
* Support: https://ubuntu.com/advantage
root@acqua:~# ifconfig
eth0 Link encap:Ethernet HWaddr 02:02:de:02:81:79
UP BROADCAST MULTICAST MTU:1500 Metric:1
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:38
lo Link encap:Local Loopback
UP LOOPBACK RUNNING MTU:65536 Metric:1
wlan0 Link encap:Ethernet HWaddr cc:d2:9b:4d:ae:7c
root@acqua:~# [ 43.018408] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 43.237917] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 43.245326] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 43.255358] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 43.265620] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 43.273533] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 43.281456] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 43.289276] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 43.296466] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 43.304191] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 43.312072] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 43.319823] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 43.326868] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 43.334732] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 43.342059] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 43.349989] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 43.357064] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 43.364341] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 43.371537] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 43.378683] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 43.385674] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 43.392843] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 43.399989] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 43.406980] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 43.414139] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 43.421293] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 43.428435] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 43.435419] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 43.442570] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 43.449706] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 43.456687] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 43.468743] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 43.687964] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 43.695387] sunxi-mmc 1c10000.mmc: data error, sending stop command
[ 43.702509] sunxi-mmc 1c10000.mmc: data error, sending stop command离线
PG0-5在dts可能被led占用了,检查一下。
cityf wrote:
噢,对,就是这个问题。
这不是不稳定的事了,用nmcli连接WiFi直接挂
连上网络通讯挂了?还是没连上就挂了?
leds {
/* The LEDs use PG0~2 pins, which conflict with MMC1 */
status = "disbaled";
};的确是,请问具体该怎么改呢?
删了就应该可以了。
嗯,我把led相关的都删了,看样子应该没问题了,谢谢各位了
v3s sdio1可以做wifi吗?
你好 您彻底解决了吗? 麻烦您可以加下我QQ 982034166吗 我遇到了和您一样的问题,重谢!!!
