楼主 #1 2020-01-24 13:50:16
pythinker
已发帖子: 215
Windows thinkphp 开发. composer & wamp & phpstorm
1. composer 下载安装: https://getcomposer.org/download/
   Windows版本直接下载地址: https://getcomposer.org/Composer-Setup.exe
2. wamp 下载地址: wampserver3.2.0_x64.exe
3. phpstorm 下载地址: https://www.tpxhm.com/odetail/203.html
参考链接: https://www.jianshu.com/p/22c88181e78d
参考链接: https://article.itxueyuan.com/566k90
楼主 #2 2020-01-24 14:14:25
pythinker
已发帖子: 215
Re: Windows thinkphp 开发. composer & wamp & phpstorm
上面那个 phpstorm 破解的原理是模拟一个 license 服务器, phpstorm连上license服务器就可以了.
楼主 #3 2020-01-24 15:03:39
pythinker
已发帖子: 215
composer create-project topthink/think  ./ 6.0.2
composer update topthink/framework
#如果上面的命令卡住不动, 就切换阿里云源#
composer config -g repo.packagist composer https://mirrors.aliyun.com/composer/
楼主 #4 2020-01-24 15:09:04
pythinker
已发帖子: 215
#5 2020-02-06 23:27:55
phpweb
感谢楼主分享.
#0 [0]InvalidArgumentException in Manager.php line 103
Driver [Think] not supported.
        if ($this->namespace || false !== strpos($type, '\\')) {
            $class = false !== strpos($type, '\\') ? $type : $this->namespace . Str::studly($type);
            if (class_exists($class)) {
                return $class;
        throw new InvalidArgumentException("Driver [$type] not supported.");
     * 获取驱动参数
     * @param $name
     * @return array
    protected function resolveParams($name): array
运行命令:
composer require topthink/think-view
解决上面的驱动问题.
#6 2020-03-03 11:10:06
光头程序员
pythinker 说:
感谢分享, 这个很好用。
phpstorm 破解步奏 (穷人逃 ...
1. 下载 PhpStorm-2019.2.1.exe (其他版本可能破解不成功) 并安装
2. 解压 patch_for_phpstorm201902.7zD:\Program Files\JetBrains\PhpStorm 2019.2.1\bin
3. 修改 phpstorm64.exe.vmoptions, 添加 -javaagent:D:\Program Files\JetBrains\PhpStorm 2019.2.1\bin\jetbrains-agent.jar
4. C:\Windows\System32\drivers\etc\hosts文件中追加: 0.0.0.0 account.jetbrains.com
5. 破解:
希望可以帮到各位手头拮据的phper, 有钱的朋友还是上官网买正版吧。
