楼主 #1 2020-02-21 09:18:47
chainsx
已发帖子: 37
编译v3s bsp添加rtl8723bs时出现以下错误
MODPOST vmlinux.o
WARNING: modpost: Found 5 section mismatch(es).
To see full details build your kernel with:
'make CONFIG_DEBUG_SECTION_MISMATCH=y'
  GEN     .version
  CHK     include/generated/compile.h
  UPD     include/generated/compile.h
  CC      init/version.o
  LD      init/built-in.o
  LD      .tmp_vmlinux1
  KSYM    .tmp_kallsyms1.S
  AS      .tmp_kallsyms1.o
  LD      .tmp_vmlinux2
  KSYM    .tmp_kallsyms2.S
  AS      .tmp_kallsyms2.o
  LD      vmlinux
  SYSMAP  System.map
  SYSMAP  .tmp_System.map
  OBJCOPY arch/arm/boot/Image
  Building modules, stage 2.
  MODPOST 16 modules
  Kernel: arch/arm/boot/Image is ready
  GZIP    arch/arm/boot/compressed/piggy.gzip
WARNING: could not find drivers/media/video/sunxi-vfe/lib/.libisp.cmd for drivers/media/video/sunxi-vfe/lib/libisp
ERROR: "wifi_pm_get_mod_type" [drivers/net/wireless/rtl8723bs/8723bs.ko] undefined!ERROR: "wifi_pm_power" [drivers/net/wireless/rtl8723bs/8723bs.ko] undefined!
/root/v3s-linux-sdk/linux-3.4/scripts/Makefile.modpost:91: recipe for target '__modpost' failed
make[1]: *** [__modpost] Error 1
Makefile:1096: recipe for target 'modules' failed
make: *** [modules] Error 2
make: *** Waiting for unfinished jobs....
  AS      arch/arm/boot/compressed/piggy.gzip.o
  LD      arch/arm/boot/compressed/vmlinux
  OBJCOPY arch/arm/boot/zImage
  Kernel: arch/arm/boot/zImage is ready
#2 2020-02-21 09:25:27
我心飞翔
已发帖子: 82
Re: 编译v3s bsp添加rtl8723bs时出现以下错误
grep 搜索 wifi_pm_get_mod_type 对应的代码模块, 然后去 menuconfig 开启对应的开关就可以了, 我记得是 RFKILL ???
