#include <assert.h>
#include <stdio.h>
#include <sys/types.h>
#include <regex.h>
int main(void) {
int r;
regex_t reg;
regmatch_t match[2];
char *line = "----------------------- Page 1-----------------------";
regcomp(®, "[-]{23}[ ]*Page[ ]*([0-9]*)[-]{23}", REG_ICASE | REG_EXTENDED);
/* ^------^ capture page number */
r = regexec(®, line, 2, match, 0);
if (r == 0) {
printf("Match!\n");
printf("0: [%.*s]\n", match[0].rm_eo - match[0].rm_so, line + match[0].rm_so);
printf("1: [%.*s]\n", match[1].rm_eo - match[1].rm_so, line + match[1].rm_so);
} else {
printf("NO match!\n");
}这个可以直接编译运行.
windows下的VC编译估计通不过, 但是用mingw应该可以, 未测试.
运行结果:
Match!
0: [----------------------- Page 1-----------------------]
1: [1]离线
https://www.mitchr.me/SS/exampleCode/AUPG/regex_example.c.html
/* -*- Mode:C; Coding:us-ascii-unix; fill-column:132 -*- */
@file regex_example.c
@author Mitch Richling <https://www.mitchr.me/>
@Copyright Copyright 1994,2014 by Mitch Richling. All rights reserved.
@brief UNIX regex tools@EOL
@Keywords UNIX regular expressions regex
@Std ISOC POSIX.2 (IEEE Std 103.2) BSD4.3
@Tested
- Solaris 2.8
- MacOS X.2
- Linux (RH 7.3)
This is an example program intended to illustrate very basic use of regular expressions.
Grumpy programmer note: IEEE Std 1003.2, generally referred to as 'POSIX.2' is a bit vague regarding several details like how
back references work. It also has a couple of errors (like how a single ')' is treated in a regular expression. Because of
this, most actual implementations of the standard will have several minor inconsistencies that one must watch out for. My best
advice is to "read the man page" on the platforms you wish to run on and to avoid exotic things. For example, avoid things like
the BSD REG_NOSPEC and REG_PEND options. Another option is to simply carry your favorite regular expression library with you.
For example, C++11 has very good regex support, and the BOOST library has a very nice regex class for older C++ versions. PCRE
is probably the most popular alternative, FOSS regular expression library available.
#include <sys/types.h> /* UNIX types POSIX */
#include <regex.h> /* Regular Exp POSIX */
#include <stdio.h> /* I/O lib C89 */
#include <string.h> /* Strings C89 */
#include <stdlib.h> /* Standard Lib C89 */
#define MAX_SUB_EXPR_CNT 256
#define MAX_SUB_EXPR_LEN 256
#define MAX_ERR_STR_LEN 256
int main(int argc, char *argv[]) {
int i; /* Loop variable. */
char p[MAX_SUB_EXPR_LEN]; /* For string manipulation */
regex_t aCmpRegex; /* Pointer to our compiled regex */
char *aStrRegex; /* Pointer to the string holding the regex */
regmatch_t pMatch[MAX_SUB_EXPR_CNT]; /* Hold partial matches. */
char **aLineToMatch; /* Holds each line that we wish to match */
int result; /* Return from regcomp() and regexec() */
char outMsgBuf[MAX_ERR_STR_LEN]; /* Holds error messages from regerror() */
char *testStrings[] = { "This should match... hello",
"This could match... hello!",
"More than one hello.. hello",
"No chance of a match...",
NULL};
/* use aStrRegex for readability. */
aStrRegex = "(.*)(hello)+";
printf("Regex to use: %s\n", aStrRegex);
/* Compile the regex */
if( (result = regcomp(&aCmpRegex, aStrRegex, REG_EXTENDED)) ) {
printf("Error compiling regex(%d).\n", result);
regerror(result, &aCmpRegex, outMsgBuf, sizeof(outMsgBuf));
printf("Error msg: %s\n", outMsgBuf);
exit(1);
} /* end if */
/* Possible last argument to regcomp (||'ed together):
REG_EXTENDED Use extended regular expressions
REG_BASIC Use basic regular expressions
REG_NOSPEC Special character support off (Not POSIX.2)
REG_ICASE Ignore upper/lower case distinctions
REG_NOSUB No sub-strings (just check for match/no match)
REG_NEWLINE Compile for newline-sensitive matching
REG_PEND Specify alternate string ending (Not POSIX.2) */
/* Apply our regular expression to some strings. */
for(aLineToMatch=testStrings; *aLineToMatch != NULL; aLineToMatch++) {
printf("String: %s\n", *aLineToMatch);
printf(" %s\n", "0123456789012345678901234567890123456789");
printf(" %s\n", "0 1 2 3");
/* compare and check result (MAX_SUB_EXPR_CNT max sub-expressions).*/
if( !(result = regexec(&aCmpRegex, *aLineToMatch, MAX_SUB_EXPR_CNT, pMatch, 0)) ) {
/* Last argument to regexec (||'ed together):
REG_NOTBOL Start of the string is NOT the start of a line
REG_NOTEOL $ shouldn't match end of string (gotta have a newline)
REG_STARTEND Not POSIX.2 */
printf("Result: We have a match!\n");
for(i=0;i<=(int)aCmpRegex.re_nsub;i++) {
printf("Match(%2d/%2d): (%2d,%2d): ",
i,
(int)(aCmpRegex.re_nsub),
(int)(pMatch[i].rm_so),
(int)(pMatch[i].rm_eo));
if( (pMatch[i].rm_so >= 0) && (pMatch[i].rm_eo >= 1) &&
(pMatch[i].rm_so != pMatch[i].rm_eo) ) {
strncpy(p, &((*aLineToMatch)[pMatch[i].rm_so]), pMatch[i].rm_eo-pMatch[i].rm_so);
p[pMatch[i].rm_eo-pMatch[i].rm_so] = '\0';
printf("'%s'", p);
} /* end if */
printf("\n");
} /* end for */
printf("\n");
} else {
switch(result) {
case REG_NOMATCH : printf("String did not match the pattern\n"); break;
////Some typical return codes:
//case REG_BADPAT : printf("invalid regular expression\n"); break;
//case REG_ECOLLATE : printf("invalid collating element\n"); break;
//case REG_ECTYPE : printf("invalid character class\n"); break;
//case REG_EESCAPE : printf("`\' applied to unescapable character\n"); break;
//case REG_ESUBREG : printf("invalid backreference number\n"); break;
//case REG_EBRACK : printf("brackets `[ ]' not balanced\n"); break;
//case REG_EPAREN : printf("parentheses `( )' not balanced\n"); break;
//case REG_EBRACE : printf("braces `{ }' not balanced\n"); break;
//case REG_BADBR : printf("invalid repetition count(s) in `{ }'\n"); break;
//case REG_ERANGE : printf("invalid character range in `[ ]'\n"); break;
//case REG_ESPACE : printf("Ran out of memory\n"); break;
//case REG_BADRPT : printf("`?', `*', or `+' operand invalid\n"); break;
//case REG_EMPTY : printf("empty (sub)expression\n"); break;
//case REG_ASSERT : printf("can't happen - you found a bug\n"); break;
//case REG_INVARG : printf("A bad option was passed\n"); break;
//case REG_ILLSEQ : printf("illegal byte sequence\n"); break;
default : printf("Unknown error\n"); break;
} /* end switch */
printf("Result: Error msg: %s\n\n", outMsgBuf);
} /* end if/else */
} /* end for */
/* Free up resources for the regular expression */
regfree(&aCmpRegex);
exit(0);
} /* end func main */另外一个demo, 运行结果:
Regex to use: (.*)(hello)+
String: This should match... hello
0 1 2 3
Match( 0/ 2): ( 0,26): 'This should match... hello'
Match( 1/ 2): ( 0,21): 'This should match... '
Match( 2/ 2): (21,26): 'hello'
String: This could match... hello!
0 1 2 3
Match( 0/ 2): ( 0,25): 'This could match... hello'
Match( 1/ 2): ( 0,20): 'This could match... '
Match( 2/ 2): (20,25): 'hello'
String: More than one hello.. hello
0 1 2 3
Match( 0/ 2): ( 0,27): 'More than one hello.. hello'
Match( 1/ 2): ( 0,22): 'More than one hello.. '
Match( 2/ 2): (22,27): 'hello'
String: No chance of a match...
0 1 2 3
Result: Error msg: No match离线
https://www.ibm.com/support/knowledgecenter/ssw_ibm_i_74/rtref/regexec.htm
ibm 的一个演示代码:
#include <regex.h>
#include <stdio.h>
#include <stdlib.h>
int main(void)
regex_t preg;
char *string = "a very simple simple simple string";
char *pattern = "\\(sim[a-z]le\\) \\1";
int rc;
size_t nmatch = 2;
regmatch_t pmatch[2];
if (0 != (rc = regcomp(&preg, pattern, 0))) {
printf("regcomp() failed, returning nonzero (%d)\n", rc);
exit(EXIT_FAILURE);
if (0 != (rc = regexec(&preg, string, nmatch, pmatch, 0))) {
printf("Failed to match '%s' with '%s',returning %d.\n",
string, pattern, rc);
else {
printf("With the whole expression, "
"a matched substring \"%.*s\" is found at position %d to %d.\n",
pmatch[0].rm_eo - pmatch[0].rm_so, &string[pmatch[0].rm_so],
pmatch[0].rm_so, pmatch[0].rm_eo - 1);
printf("With the sub-expression, "
pmatch[1].rm_eo - pmatch[1].rm_so, &string[pmatch[1].rm_so],
pmatch[1].rm_so, pmatch[1].rm_eo - 1);
regfree(&preg);
The output should be similar to :
With the whole expression, a matched substring "simple simple" is found
at position 7 to 19.
With the sub-expression, a matched substring "simple" is found
at position 7 to 12.
}运行结果:
With the whole expression, a matched substring "simple simple" is found at position 7 to 19.
With the sub-expression, a matched substring "simple" is found at position 7 to 12.离线
在一楼的基础上写一个简单的 AT 输出字符串处理函数:
#include <assert.h>
#include <stdio.h>
#include <regex.h>
int main(void) {
int r;
regex_t reg;
regmatch_t match[7];
char *line = "+CCLK: \"20/03/08,17:31:52+32\"";
regcomp(®, "\\+CCLK: \"([0-9]{2})/([0-9]{2})/([0-9]{2}),([0-9]{2}):([0-9]{2}):([0-9]{2})", REG_ICASE | REG_EXTENDED);
r = regexec(®, line, 7, match, 0);
if (r == 0) {
printf("Match!\n");
printf("2: [%.*s]\n", match[2].rm_eo - match[2].rm_so, line + match[2].rm_so);
printf("3: [%.*s]\n", match[3].rm_eo - match[3].rm_so, line + match[3].rm_so);
printf("4: [%.*s]\n", match[4].rm_eo - match[4].rm_so, line + match[4].rm_so);
printf("5: [%.*s]\n", match[5].rm_eo - match[5].rm_so, line + match[5].rm_so);
printf("6: [%.*s]\n", match[6].rm_eo - match[6].rm_so, line + match[6].rm_so);
} else {
}输出结果:
Match!
0: [+CCLK: "20/03/08,17:31:52]
1: [20]
2: [03]
3: [08]
4: [17]
5: [31]
6: [52]离线
https://stackoverflow.com/questions/7899119/what-does-s-mean-in-printf
void f(const char *str, int str_len)
printf("%.*s\n", str_len, str);
}#include <stdio.h>
int main() {
int precision = 8;
int biggerPrecision = 16;
const char *greetings = "Hello world";
printf("|%.8s|\n", greetings);
printf("|%.*s|\n", precision , greetings);
printf("|%16s|\n", greetings);
printf("|%*s|\n", biggerPrecision , greetings);
}|Hello wo|
|Hello wo|
| Hello world|
| Hello world|意外的收获, printf 的一种使用方法.
我一直有个疑问,正则表达式,是一个标准的东西么?还是每个软件用的正则表达式,都有自己的规则?
规则基本大同小异: https://tool.oschina.net/uploads/apidocs/jquery/regexp.html
但是有些库实现的功能更多, 比如java/python库还带替换功能, 这个c库没有这个功能.
GNU C Library带的。
刚刚发现C++11也早就开始自带regex库了。
这么吊?
