楼主 #1 2020-03-08 23:48:48
checkout
已发帖子: 173
widora-neo-16128m开发板跑主线openwrt,不能进入kernel shell......
今日翻出widora-neo开发板,试试编译主线openwrt,发现启动卡住,不能进入shell...
感觉是flash驱动的原因,不知有没大佬遇到类似情况
Widora by mango,V1.0.6
Board: Ralink APSoC DRAM:  128 MB
relocate_code Pointer at: 87fb4000
Software System Reset Occurred
flash manufacture id: ef, device id 40 18
find flash: W25Q128BV
Ralink UBoot Version: 4.3.0.0
ASIC 7628_MP (Port5<->None)
DRAM component: 1024 Mbits DDR, width 16
DRAM bus: 16 bit
Total memory: 128 MBytes
Flash component: SPI Flash
Date:Aug 10 2016  Time:21:39:21
icache: sets:512, ways:4, linesz:32 ,total:65536
dcache: sets:256, ways:4, linesz:32 ,total:32768
 ##### The CPU freq = 575 MHZ ####
 estimate memory size =128 Mbytes
RESET MT7628 PHY!!!!!!MT7688 gpio init : wled and wdt by mango
if you press the WPS button for more than 2 seconds will automatically enter the Update mode,more than 7 seconds enter gpio test mode
0
1
2
3
4
5
6
7
8
9
Continuing normal boot...
Please choose the operation:
   1: Load system code to SDRAM via TFTP.
   2: Load system code then write to Flash via TFTP.
   3: Boot system code via Flash (default).
   4: Entr boot command line interface.
   5: Entr ALL LED test mode.
   6: Entr Web failsafe mode.
   7: Load Boot Loader code then write to Flash via Serial.
   9: Load Boot Loader code then write to Flash via TFTP.        0
3: System Boot system code via Flash.
## Booting image at bc050000 ...
   Image Name:   MIPS OpenWrt Linux-4.14.169
   Image Type:   MIPS Linux Kernel Image (lzma compressed)
   Data Size:    1672728 Bytes =  1.6 MB
   Load Address: 80000000
   Entry Point:  80000000
   Verifying Checksum ... OK
   Uncompressing Kernel Image ... OK
No initrd
## Transferring control to Linux (at address 80000000) ...
## Giving linux memsize in MB, 128
[    0.000000] Linux version 4.14.169 (root@ubuntu) (gcc version 8.3.0 (OpenWrt GCC 8.3.0 r12261-d1130ad)) #0 Fri Feb 21 21:35:12 2020
[    0.000000] Board has DDR2
[    0.000000] Analog PMU set to hw control
[    0.000000] Digital PMU set to hw control
[    0.000000] SoC Type: MediaTek MT7688 ver:1 eco:2
[    0.000000] bootconsole [early0] enabled
[    0.000000] CPU0 revision is: 00019655 (MIPS 24KEc)
[    0.000000] MIPS: machine is Widora-NEO (16M)
[    0.000000] Determined physical RAM map:
[    0.000000]  memory: 08000000 @ 00000000 (usable)
[    0.000000] Initrd not found or empty - disabling initrd
[    0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[    0.000000] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x0000000000000000-0x0000000007ffffff]
[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000007ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000007ffffff]
[    0.000000] random: get_random_bytes called from start_kernel+0x98/0x4a0 with crng_init=0
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 32480
[    0.000000] Kernel command line: console=ttyS0,115200 rootfstype=squashfs,jffs2
[    0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[    0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[    0.000000] Writing ErrCtl register=00038f60
[    0.000000] Readback ErrCtl register=00038f60
[    0.000000] Memory: 123280K/131072K available (3918K kernel code, 182K rwdata, 896K rodata, 1204K init, 205K bss, 7792K reserved, 0K cma-reserved)
[    0.000000] NR_IRQS: 256
[    0.000000] intc: using register map from devicetree
[    0.000000] CPU Clock: 580MHz
[    0.000000] timer_probe: no matching timers found
[    0.000000] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6590553264 ns
[    0.000013] sched_clock: 32 bits at 290MHz, resolution 3ns, wraps every 7405115902ns
[    0.007536] Calibrating delay loop... 385.84 BogoMIPS (lpj=1929216)
[    0.073501] pid_max: default: 32768 minimum: 301
[    0.078257] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.084614] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.098253] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.107760] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.113749] pinctrl core: initialized pinctrl subsystem
[    0.119878] NET: Registered protocol family 16
[    0.154336] mt7621_gpio 10000600.gpio: registering 32 gpios
[    0.160018] mt7621_gpio 10000600.gpio: registering 32 gpios
[    0.165530] mt7621_gpio 10000600.gpio: registering 32 gpios
[    0.176052] clocksource: Switched to clocksource MIPS
[    0.182260] NET: Registered protocol family 2
[    0.187331] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    0.194024] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[    0.200215] TCP: Hash tables configured (established 1024 bind 1024)
[    0.206481] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.212082] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.218522] NET: Registered protocol family 1
[    0.226584] Crashlog allocated RAM at address 0x3f00000
[    0.233417] workingset: timestamp_bits=14 max_order=15 bucket_order=1
[    0.246962] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.252539] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    0.275421] io scheduler noop registered
[    0.279223] io scheduler deadline registered (default)
[    0.285019] Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
[    0.292363] console [ttyS0] disabled
[    0.295805] 10000c00.uartlite: ttyS0 at MMIO 0x10000c00 (irq = 28, base_baud = 2500000) is a 16550A
[    0.304586] console [ttyS0] enabled
[    0.311590] bootconsole [early0] disabled
[    0.320365] 10000d00.uart1: ttyS1 at MMIO 0x10000d00 (irq = 29, base_baud = 2500000) is a 16550A
[    0.329979] 10000e00.uart2: ttyS2 at MMIO 0x10000e00 (irq = 30, base_baud = 2500000) is a 16550A
[    0.340417] spi-mt7621 10000b00.spi: sys_freq: 193333333
[    0.362775] m25p80 spi0.0: w25q128 (16384 Kbytes)
[    0.367629] 4 fixed-partitions partitions found on MTD device spi0.0
[    0.374069] Creating 4 MTD partitions on "spi0.0":
[    0.378955] 0x000000000000-0x000000030000 : "u-boot"
[    0.384960] 0x000000030000-0x000000040000 : "u-boot-env"
[    0.391287] 0x000000040000-0x000000050000 : "factory"
[    0.397413] 0x000000050000-0x000001000000 : "firmware"
[    0.406738] 2 uimage-fw partitions found on MTD device firmware
[    0.412753] Creating 2 MTD partitions on "firmware":
[    0.417847] 0x000000000000-0x000000198658 : "kernel"
[    0.423836] 0x000000198658-0x000000fb0000 : "rootfs"
[    0.429762] mtd: device 5 (rootfs) set to be root filesystem
[    0.437259] 1 squashfs-split partitions found on MTD device rootfs
[    0.443536] Creating 1 MTD partitions on "rootfs":
[    0.448458] 0x0000002379a8-0x000000e179a8 : "rootfs_data"
[    0.455878] libphy: Fixed MDIO Bus: probed
[    0.471525] rt3050-esw 10110000.esw: link changed 0x00
[    0.478465] mtk_soc_eth 10100000.ethernet eth0: mediatek frame engine at 0xb0100000, irq 5
[    0.488783] NET: Registered protocol family 10
[    0.497874] Segment Routing with IPv6
[    0.501708] NET: Registered protocol family 17
[    0.506362] 8021q: 802.1Q VLAN Support v1.8
[    0.517645] VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
[    0.531543] Freeing unused kernel memory: 1204K
[    0.536170] This architecture does not have kernel memory protection.
[    1.271959] init: Console is alive
[    1.275663] init: - watchdog -
[    2.236100] random: fast init done
[    2.435398] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[    2.565565] usbcore: registered new interface driver usbfs
[    2.571328] usbcore: registered new interface driver hub
[    2.576877] usbcore: registered new device driver usb
[    2.588572] exFAT: Version 1.2.9
[    2.601381] JFS: nTxBlock = 972, nTxLock = 7780
[    2.614778] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.623366] ehci-platform: EHCI generic platform driver
[    2.639085] phy phy-10120000.usbphy.0: remote usb device wakeup disabled
[    2.645889] phy phy-10120000.usbphy.0: UTMI 16bit 30MHz
[    2.651217] ehci-platform 101c0000.ehci: EHCI Host Controller
[    2.657119] ehci-platform 101c0000.ehci: new USB bus registered, assigned bus number 1
[    2.665272] ehci-platform 101c0000.ehci: irq 26, io mem 0x101c0000
[    2.696078] ehci-platform 101c0000.ehci: USB 2.0 started, EHCI 1.00
[    2.703517] hub 1-0:1.0: USB hub found
[    2.707870] hub 1-0:1.0: 1 port detected
[    2.715363] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.723531] ohci-platform: OHCI generic platform driver
[    2.729193] ohci-platform 101c1000.ohci: Generic Platform OHCI controller
[    2.736151] ohci-platform 101c1000.ohci: new USB bus registered, assigned bus number 2
[    2.744271] ohci-platform 101c1000.ohci: irq 26, io mem 0x101c1000
[    2.821177] hub 2-0:1.0: USB hub found
[    2.825502] hub 2-0:1.0: 1 port detected
[    2.833088] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[    2.851018] init: - preinit -
[    4.055839] rt3050-esw 10110000.esw: link changed 0x00
Press the [f] key and hit [enter] to enter failsafe mode
Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
[    8.248467] rt3050-esw 10110000.esw: link changed 0x01
[    8.305860] mount_root: jffs2 not ready yet, using temporary tmpfs overlay
[    8.345129] urandom-seed: Seed file not found (/etc/urandom.seed)
[    8.479867] procd: - early -
[    8.482907] procd: - watchdog -
[    9.212368] procd: - watchdog -
[    9.215915] procd: - ubus -
[    9.318572] random: ubusd: uninitialized urandom read (4 bytes read)
[    9.325816] random: ubusd: uninitialized urandom read (4 bytes read)
[    9.332919] random: ubusd: uninitialized urandom read (4 bytes read)
[    9.340544] procd: - init -
Please press Enter to activate this console.
[   10.143120] kmodloader: loading kernel modules from /etc/modules.d/*
[   10.217603] ip6_tables: (C) 2000-2006 Netfilter Core Team
[   10.239857] Loading modules backported from Linux version v5.4-rc8-0-gaf42d3466bdc
[   10.247614] Backport generated by backports.git v5.4-rc8-1-0-g368e8c51
[   10.278981] ip_tables: (C) 2000-2006 Netfilter Core Team
[   10.304287] nf_conntrack version 0.5.0 (2048 buckets, 8192 max)
[   10.445472] xt_time: kernel timezone is -0000
[   10.586690] mt76_wmac 10300000.wmac: ASIC revision: 76280001
[   10.671518] urngd: v1.0.2 started.
[   10.873865] random: crng init done
[   10.877356] random: 7 urandom warning(s) missed due to ratelimiting
[   11.628204] mt76_wmac 10300000.wmac: Firmware Version: 20151201
[   11.634225] mt76_wmac 10300000.wmac: Build Time: 20151201183641
[   11.676068] mt76_wmac 10300000.wmac: firmware init done
[   11.891925] PPP generic driver version 2.4.2
[   11.917182] NET: Registered protocol family 24
[   11.932445] kmodloader: done loading kernel modules from /etc/modules.d/*
[   27.796972] rt3050-esw 10110000.esw: link changed 0x00
[   29.836569] jffs2_scan_eraseblock(): End of filesystem marker found at 0x0
[   29.843594] jffs2_build_filesystem(): unlocking the mtd device...
[   29.856115] done.
[   29.864342] jffs2_build_filesystem(): erasing all blocks after the end marker...
[   29.864386] jffs2: Erase at 0x00bd0000 failed immediately: errno -22
[   32.035467] rt3050-esw 10110000.esw: link changed 0x01
[   34.348859] br-lan: port 1(eth0) entered blocking state
[   34.354173] br-lan: port 1(eth0) entered disabled state
[   34.359892] device eth0 entered promiscuous mode
[   34.415166] br-lan: port 1(eth0) entered blocking state
[   34.420547] br-lan: port 1(eth0) entered forwarding state
[   34.426276] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
[   35.376187] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
[   89.749292] done.
[   89.751299] jffs2: notice: (1082) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
[   89.914802] overlayfs: upper fs does not support tmpfile.
#2 2020-03-09 09:09:43
Re: widora-neo-16128m开发板跑主线openwrt,不能进入kernel shell......
看着问题不大,看样子敲回车应该会激活命令交互
楼主 #3 2020-03-09 12:53:41
checkout
已发帖子: 173
谢谢mango的回复。今天开电脑又试了试,是没问题的:D。。。估计是putty的原因,之前敲回车没反应
主要是widora官方的openwrt声卡驱动有点问题,准备试试主线的有没问题
openwrt(widora-neo)使用portaudio播放音频,出现多次调用postinit(),伴有杂音,偶尔会造成系统奔溃
mango 说:
#4 2020-03-09 15:43:51
checkout 说:
终端软件的流控一定要关掉,其他没什么注意的了:)
楼主 #5 2020-03-09 16:41:14
checkout
已发帖子: 173
跑是能跑起来了,但从U盘拷贝文件到本地,重启后,老是莫名奇妙的丢失文件,或者文件大小自己变小了...
感觉哪里没有设置对,导致文件系统有问题
启动log里面,kernel+rootfs分区好像不大对.正常来说应该从firmware分区的0x50000开始自动分区,但这里显示是从0x0开始。
[    0.450902] 2 uimage-fw partitions found on MTD device firmware
[    0.456916] Creating 2 MTD partitions on "firmware":
[    0.462027] 0x000000000000-0x0000001baeb2 : "kernel"
[    0.468108] 0x0000001baeb2-0x000000fb0000 : "rootfs"
关于jffs2的log:
root@OpenWrt:/mnt/usb# dmesg | grep jffs2
[    0.283821] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    9.198050] jffs2: notice: (453) jffs2_build_xattr_subsystem: complete building xattr subsystem, 6 of xdatum (3 unchecked, 3 orphan) and 10 of xref (3 dead, 0 orphan) found.
[    9.215573] mount_root: switching to jffs2 overlay
[   60.033694] jffs2: Erase at 0x00830000 failed immediately: errno -22
[   60.333680] jffs2: notice: (1433) jffs2_get_inode_nodes: Node header CRC failed at 0x7f6f18. {ffff,ffff,ffffffff,ffffffff}
[   60.347235] jffs2: notice: (1433) jffs2_get_inode_nodes: Node header CRC failed at 0x7f63fc. {ffff,ffff,ffffffff,ffffffff}
[   60.361339] jffs2: notice: (1433) jffs2_get_inode_nodes: Node header CRC failed at 0x7f5784. {ffff,ffff,ffffffff,ffffffff}
[   60.376280] jffs2: notice: (1433) jffs2_get_inode_nodes: Node header CRC failed at 0x7f4b70. {ffff,ffff,ffffffff,ffffffff}
[   60.389267] jffs2: notice: (1433) jffs2_get_inode_nodes: Node header CRC failed at 0x7f3eec. {ffff,ffff,ffffffff,ffffffff}
[   60.404380] jffs2: notice: (1433) jffs2_get_inode_nodes: Node header CRC failed at 0x7f3290. {ffff,ffff,ffffffff,ffffffff}
[   60.417355] jffs2: notice: (1433) jffs2_get_inode_nodes: Node header CRC failed at 0x7f26b4. {ffff,ffff,ffffffff,ffffffff}
[   60.432495] jffs2: notice: (1433) jffs2_get_inode_nodes: Node header CRC failed at 0x7f1b24. {ffff,ffff,ffffffff,ffffffff}
[   60.445325] jffs2: notice: (1433) jffs2_get_inode_nodes: Node header CRC failed at 0x7f0f64. {ffff,ffff,ffffffff,ffffffff}
[   60.460436] jffs2: notice: (1433) jffs2_get_inode_nodes: Node header CRC failed at 0x7f031c. {ffff,ffff,ffffffff,ffffffff}
[   60.473391] jffs2: notice: (1433) jffs2_get_inode_nodes: Node header CRC failed at 0x7f000c. {ffff,ffff,ffffffff,ffffffff}
完整的启动log:
[    0.000000] On node 0 totalpages: 32768
[    0.000000] free_area_init_node: node 0, pgdat 8054e050, node_mem_map 81000040
[    0.000000]   Normal zone: 288 pages used for memmap
[    0.000000]   Normal zone: 32768 pages, LIFO batch:7
[    0.000000] Writing ErrCtl register=00038f61
[    0.000000] Readback ErrCtl register=00038f61
[    0.000000] Memory: 122820K/131072K available (4290K kernel code, 193K rwdata, 952K rodata, 1212K init, 217K bss, 8252K reserved, 0K cma-reserved)
[    0.000011] sched_clock: 32 bits at 290MHz, resolution 3ns, wraps every 7405115902ns
[    0.007542] Calibrating delay loop... 385.84 BogoMIPS (lpj=1929216)
[    0.073500] pid_max: default: 32768 minimum: 301
[    0.078236] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.084586] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.098213] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.107725] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.113713] pinctrl core: initialized pinctrl subsystem
[    0.119822] NET: Registered protocol family 16
[    0.157368] mt7621_gpio 10000600.gpio: registering 32 gpios
[    0.163027] mt7621_gpio 10000600.gpio: registering 32 gpios
[    0.168576] mt7621_gpio 10000600.gpio: registering 32 gpios
[    0.175450] Bluetooth: Core ver 2.22
[    0.178933] NET: Registered protocol family 31
[    0.183155] Bluetooth: HCI device and connection manager initialized
[    0.189363] Bluetooth: HCI socket layer initialized
[    0.194009] Bluetooth: L2CAP socket layer initialized
[    0.198910] Bluetooth: SCO socket layer initialized
[    0.207594] clocksource: Switched to clocksource MIPS
[    0.213763] NET: Registered protocol family 2
[    0.218810] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    0.225504] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[    0.231691] TCP: Hash tables configured (established 1024 bind 1024)
[    0.237958] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.243558] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.249977] NET: Registered protocol family 1
[    0.254156] PCI: CLS 0 bytes, default 32
[    0.258021] Crashlog allocated RAM at address 0x3f00000
[    0.264778] workingset: timestamp_bits=14 max_order=15 bucket_order=1
[    0.278247] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.311618] jitterentropy: Initialization failed with host not compliant with requirements: 2
[    0.320088] io scheduler noop registered
[    0.323815] io scheduler deadline registered (default)
[    0.329782] Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
[    0.337086] console [ttyS0] disabled
[    0.340599] 10000c00.uartlite: ttyS0 at MMIO 0x10000c00 (irq = 28, base_baud = 2500000) is a 16550A
[    0.349332] console [ttyS0] enabled
[    0.356321] bootconsole [early0] disabled
[    0.365090] 10000d00.uart1: ttyS1 at MMIO 0x10000d00 (irq = 29, base_baud = 2500000) is a 16550A
[    0.374729] 10000e00.uart2: ttyS2 at MMIO 0x10000e00 (irq = 30, base_baud = 2500000) is a 16550A
[    0.385203] spi-mt7621 10000b00.spi: sys_freq: 193333333
[    0.407136] m25p80 spi0.0: w25q128 (16384 Kbytes)
[    0.412005] 4 fixed-partitions partitions found on MTD device spi0.0
[    0.418462] Creating 4 MTD partitions on "spi0.0":
[    0.423334] 0x000000000000-0x000000030000 : "u-boot"
[    0.429395] 0x000000030000-0x000000040000 : "u-boot-env"
[    0.435633] 0x000000040000-0x000000050000 : "factory"
[    0.441722] 0x000000050000-0x000001000000 : "firmware"
[    0.473950] mtd: device 5 (rootfs) set to be root filesystem
[    0.481382] 1 squashfs-split partitions found on MTD device rootfs
[    0.487711] Creating 1 MTD partitions on "rootfs":
[    0.492583] 0x0000005b514e-0x000000df514e : "rootfs_data"
[    0.500001] libphy: Fixed MDIO Bus: probed
[    0.514084] rt3050-esw 10110000.esw: link changed 0x00
[    0.522879] mtk_soc_eth 10100000.ethernet eth0: mediatek frame engine at 0xb0100000, irq 5
[    0.531993] Bluetooth: HCI UART driver ver 2.3
[    0.536506] Bluetooth: HCI UART protocol H4 registered
[    0.541763] Bluetooth: HCI UART protocol BCSP registered
[    0.548395] NET: Registered protocol family 10
[    0.557102] Segment Routing with IPv6
[    0.561016] NET: Registered protocol family 17
[    0.566147] Bluetooth: RFCOMM TTY layer initialized
[    0.571185] Bluetooth: RFCOMM socket layer initialized
[    0.576419] Bluetooth: RFCOMM ver 1.11
[    0.580250] 8021q: 802.1Q VLAN Support v1.8
[    0.590922] VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
[    0.604822] Freeing unused kernel memory: 1212K
[    0.609461] This architecture does not have kernel memory protection.
[    1.419704] init: Console is alive
[    1.423415] init: - watchdog -
[    2.277605] random: fast init done
[    3.228382] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[    3.359943] usbcore: registered new interface driver usbfs
[    3.365605] usbcore: registered new interface driver hub
[    3.371205] usbcore: registered new device driver usb
[    3.382899] exFAT: Version 1.2.9
[    3.395979] JFS: nTxBlock = 969, nTxLock = 7752
[    3.409573] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.425352] SCSI subsystem initialized
[    3.435001] ehci-platform: EHCI generic platform driver
[    3.450719] phy phy-10120000.usbphy.0: remote usb device wakeup disabled
[    3.457522] phy phy-10120000.usbphy.0: UTMI 16bit 30MHz
[    3.462850] ehci-platform 101c0000.ehci: EHCI Host Controller
[    3.468728] ehci-platform 101c0000.ehci: new USB bus registered, assigned bus number 1
[    3.476885] ehci-platform 101c0000.ehci: irq 26, io mem 0x101c0000
[    3.507616] ehci-platform 101c0000.ehci: USB 2.0 started, EHCI 1.00
[    3.515031] hub 1-0:1.0: USB hub found
[    3.519350] hub 1-0:1.0: 1 port detected
[    3.527051] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    3.535335] ohci-platform: OHCI generic platform driver
[    3.541020] ohci-platform 101c1000.ohci: Generic Platform OHCI controller
[    3.547992] ohci-platform 101c1000.ohci: new USB bus registered, assigned bus number 2
[    3.556108] ohci-platform 101c1000.ohci: irq 26, io mem 0x101c1000
[    3.632721] hub 2-0:1.0: USB hub found
[    3.637049] hub 2-0:1.0: 1 port detected
[    3.644242] uhci_hcd: USB Universal Host Controller Interface driver
[    3.657394] usbcore: registered new interface driver usb-storage
[    3.664543] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[    3.674351] init: - preinit -
[    4.146742] usb 1-1: new high-speed USB device number 2 using ehci-platform
[    4.429140] usb-storage 1-1:1.0: USB Mass Storage device detected
[    4.438292] random: procd: uninitialized urandom read (4 bytes read)
[    4.453161] scsi host0: usb-storage 1-1:1.0
[    4.828157] rt3050-esw 10110000.esw: link changed 0x00
[    5.469352] scsi 0:0:0:0: Direct-Access     Generic  STORAGE DEVICE   1402 PQ: 0 ANSI: 6
[    5.630657] sd 0:0:0:0: [sda] 15548416 512-byte logical blocks: (7.96 GB/7.41 GiB)
[    5.640016] sd 0:0:0:0: [sda] Write Protect is off
[    5.644891] sd 0:0:0:0: [sda] Mode Sense: 21 00 00 00
[    5.646516] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[    5.665188]  sda: sda1
[    5.673642] sd 0:0:0:0: [sda] Attached SCSI removable disk
[    7.845728] rt3050-esw 10110000.esw: link changed 0x01
[    9.263638] overlayfs: upper fs does not support tmpfile.
[    9.274925] urandom-seed: Seeding with /etc/urandom.seed
[    9.405787] procd: - early -
[    9.408944] procd: - watchdog -
[   10.173102] procd: - watchdog -
[   10.176657] procd: - ubus -
[   10.238277] random: ubusd: uninitialized urandom read (4 bytes read)
[   10.245531] random: ubusd: uninitialized urandom read (4 bytes read)
[   10.252634] random: ubusd: uninitialized urandom read (4 bytes read)
[   10.260231] procd: - init -
[   11.345862] kmodloader: loading kernel modules from /etc/modules.d/*
[   11.494522] ip6_tables: (C) 2000-2006 Netfilter Core Team
[   11.549686] i2c /dev entries driver
[   11.557842] gdma-rt2880 10002800.gdma: revision: 3, channels: 16
[   11.629652] i2c-mt7621 10000900.i2c: clock 100KHz, re-start not support
[   11.655947] hidraw: raw HID events driver (C) Jiri Kosina
[   11.679777] ralink-i2s 10000a00.i2s: mclk 480MHz
[   11.738698] mt76x8-wm8960 sound: wm8960-hifi <-> 10000a00.i2s mapping ok
[   11.785316] urngd: v1.0.2 started.
[   11.873109] Loading modules backported from Linux version v5.4-rc8-0-gaf42d3466bdc
[   11.880864] Backport generated by backports.git v5.4-rc8-1-0-g368e8c51
[   11.922955] ip_tables: (C) 2000-2006 Netfilter Core Team
[   11.950883] nf_conntrack version 0.5.0 (2048 buckets, 8192 max)
[   12.103307] usbcore: registered new interface driver usbhid
[   12.109039] usbhid: USB HID core driver
[   12.130160] usbcore: registered new interface driver usblp
[   12.153222] usbcore: registered new interface driver usbserial
[   12.159328] usbcore: registered new interface driver usbserial_generic
[   12.166026] usbserial: USB Serial support registered for generic
[   12.189870] random: crng init done
[   12.193336] random: 6 urandom warning(s) missed due to ratelimiting
[   12.238624] xt_time: kernel timezone is -0000
[   12.300637] usbcore: registered new interface driver ch341
[   12.306307] usbserial: USB Serial support registered for ch341-uart
[   12.330647] usbcore: registered new interface driver cp210x
[   12.336391] usbserial: USB Serial support registered for cp210x
[   12.481167] mt76_wmac 10300000.wmac: ASIC revision: 76280001
[   13.589838] mt76_wmac 10300000.wmac: Firmware Version: 20151201
[   13.595859] mt76_wmac 10300000.wmac: Build Time: 20151201183641
[   13.637626] mt76_wmac 10300000.wmac: firmware init done
[   13.817553] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[   13.843004] usbcore: registered new interface driver pl2303
[   13.848860] usbserial: USB Serial support registered for pl2303
[   13.871789] PPP generic driver version 2.4.2
[   13.889446] NET: Registered protocol family 24
[   13.911954] kmodloader: done loading kernel modules from /etc/modules.d/*
[   19.972488] rt3050-esw 10110000.esw: link changed 0x00
[   23.000948] rt3050-esw 10110000.esw: link changed 0x01
[   25.788141] br-lan: port 1(eth0) entered blocking state
[   25.793456] br-lan: port 1(eth0) entered disabled state
[   25.799199] device eth0 entered promiscuous mode
[   25.826896] br-lan: port 1(eth0) entered blocking state
[   25.832275] br-lan: port 1(eth0) entered forwarding state
[   25.838000] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
[   26.827759] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
[   29.128724] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
