楼主 #1 2020-03-10 22:09:48
wugang0420
求助 nanopi-neo2 全志H5 Linux 内核启动正常但是网络不通就帮助
nanopi-neo2 全志H5
网卡rtl8211e
gcc version 7.5.0 (Linaro GCC 7.5-2019.12)
编译了2019-10月的u-boot 后uboot 网络正常可以ping 通网络,网口状态灯能正常闪亮。
但是加载内核后网络就不通了,不知到是什么问题。网口状态灯两个微亮不闪烁。
17478144 bytes read in 1300 ms (12.8 MiB/s)
18191 bytes read in 4 ms (4.3 MiB/s)
## Flattened Device Tree blob at 49000000
   Booting using the fdt blob at 0x49000000
EHCI failed to shut down host controller.
   Loading Device Tree to 0000000049ff8000, end 0000000049fff70e ... OK
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.3.6 (wg@ubuntu) (gcc version 7.5.0 (Linaro GCC 7.5-2019.12)) #1 SMP PREEMPT Tue Mar 10 06:05:31 PDT 2020
[    0.000000] Machine model: FriendlyARM NanoPi NEO 2
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 32 MiB at 0x000000005e000000
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000040000000-0x000000005fffffff]
[    0.000000] NUMA: NODE_DATA [mem 0x5dee6840-0x5dee7fff]
[    0.000000] Zone ranges:
[    0.000000]   DMA32    [mem 0x0000000040000000-0x000000005fffffff]
[    0.000000]   Normal   empty
[    0.000000]   node   0: [mem 0x0000000040000000-0x000000005fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000005fffffff]
[    0.000000] psci: PSCIv0.2 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] percpu: Embedded 22 pages/cpu s52184 r8192 d29736 u90112
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 129024
[    0.000000] Policy zone: DMA32
[    0.000000] Kernel command line: console=ttyS0,115200n8 earlyprintk root=/dev/mmcblk0p2  rw rootwait painc=10
[    0.000000] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.000000] Inode-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.000000] Memory: 454224K/524288K available (10172K kernel code, 812K rwdata, 3752K rodata, 2240K init, 414K bss, 37296K reserved, 32768K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000]  Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] random: get_random_bytes called from start_kernel+0x300/0x4a0 with crng_init=0
[    0.000010] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000232] Console: colour dummy device 80x25
[    0.000374] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.000399] pid_max: default: 32768 minimum: 301
[    0.000593] LSM: Security Framework initializing
[    0.000724] Mount-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
[    0.000752] Mountpoint-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
[    0.024069] ASID allocator initialised with 32768 entries
[    0.032057] rcu: Hierarchical SRCU implementation.
[    0.040396] EFI services will not be available.
[    0.048130] smp: Bringing up secondary CPUs ...
[    0.081174] Detected VIPT I-cache on CPU1
[    0.081280] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.112890] Detected VIPT I-cache on CPU2
[    0.112957] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.144989] Detected VIPT I-cache on CPU3
[    0.145049] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.145210] smp: Brought up 1 node, 4 CPUs
[    0.145251] SMP: Total of 4 processors activated.
[    0.145266] CPU features: detected: 32-bit EL0 Support
[    0.145281] CPU features: detected: CRC32 instructions
[    0.146390] CPU: All CPU(s) started at EL2
[    0.146437] alternatives: patching kernel code
[    0.148847] devtmpfs: initialized
[    0.157413] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.157454] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.160383] pinctrl core: initialized pinctrl subsystem
[    0.161453] DMI not present or invalid.
[    0.162099] NET: Registered protocol family 16
[    0.162985] audit: initializing netlink subsys (disabled)
[    0.163346] audit: type=2000 audit(0.160:1): state=initialized audit_enabled=0 res=1
[    0.164590] cpuidle: using governor menu
[    0.165242] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.171385] DMA: preallocated 256 KiB pool for atomic allocations
[    0.171674] Serial: AMBA PL011 UART driver
[    0.200552] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.200578] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.200595] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.200611] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.205104] cryptd: max_cpu_qlen set to 1000
[    0.213018] ACPI: Interpreter disabled.
[    0.215054] vgaarb: loaded
[    0.215786] SCSI subsystem initialized
[    0.216602] usbcore: registered new interface driver usbfs
[    0.216702] usbcore: registered new interface driver hub
[    0.216850] usbcore: registered new device driver usb
[    0.217367] pps_core: LinuxPPS API ver. 1 registered
[    0.217381] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.217418] PTP clock support registered
[    0.217488] EDAC MC: Ver: 3.0.0
[    0.218560] FPGA manager framework
[    0.218742] Advanced Linux Sound Architecture Driver Initialized.
[    0.220217] clocksource: Switched to clocksource arch_sys_counter
[    0.220566] VFS: Disk quotas dquot_6.6.0
[    0.220685] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.221068] pnp: PnP ACPI: disabled
[    0.233709] thermal_sys: Registered thermal governor 'step_wise'
[    0.233718] thermal_sys: Registered thermal governor 'power_allocator'
[    0.234254] NET: Registered protocol family 2
[    0.235064] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
[    0.235113] TCP established hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.235212] TCP bind hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    0.235362] TCP: Hash tables configured (established 4096 bind 4096)
[    0.235547] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.235596] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.235870] NET: Registered protocol family 1
[    0.236840] RPC: Registered named UNIX socket transport module.
[    0.236854] RPC: Registered udp transport module.
[    0.236866] RPC: Registered tcp transport module.
[    0.236877] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.236900] PCI: CLS 0 bytes, default 64
[    0.238319] kvm [1]: IPA Size Limit: 40bits
[    0.239532] kvm [1]: vgic interrupt IRQ1
[    0.239770] kvm [1]: Hyp mode initialized successfully
[    0.253418] Initialise system trusted keyrings
[    0.253726] workingset: timestamp_bits=44 max_order=17 bucket_order=0
[    0.269351] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.270995] NFS: Registering the id_resolver key type
[    0.271047] Key type id_resolver registered
[    0.271060] Key type id_legacy registered
[    0.271095] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.271421] 9p: Installing v9fs 9p2000 file system support
[    0.309948] Key type asymmetric registered
[    0.309967] Asymmetric key parser 'x509' registered
[    0.310047] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    0.310063] io scheduler mq-deadline registered
[    0.310076] io scheduler kyber registered
[    0.311667] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO
[    0.315344] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[    0.322691] sun50i-h5-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.325358] EINJ: ACPI disabled.
[    0.336573] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.339121] sun50i-h5-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pa not found, using dummy regulator
[    0.339840] printk: console [ttyS0] disabled
[    0.360539] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 21, base_baud = 1500000) is a U6_16550A
[    1.133358] printk: console [ttyS0] enabled
[    1.139815] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    1.161288] loop: module loaded
[    1.169046] libphy: Fixed MDIO Bus: probed
[    1.174179] tun: Universal TUN/TAP device driver, 1.6
[    1.180311] thunder_xcv, ver 1.0
[    1.183618] thunder_bgx, ver 1.0
[    1.186956] nicpf, ver 1.0
[    1.190409] hclge is initializing
[    1.193753] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    1.200989] hns3: Copyright (c) 2017 Huawei Corporation.
[    1.206424] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    1.212275] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    1.218285] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.6.0-k
[    1.225260] igb: Copyright (c) 2007-2014 Intel Corporation.
[    1.230923] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[    1.238766] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    1.244799] sky2: driver version 1.30
[    1.248828] PPP generic driver version 2.4.2
[    1.253355] PPP BSD Compression module registered
[    1.258100] PPP Deflate Compression module registered
[    1.263204] PPP MPPE Compression module registered
[    1.268017] NET: Registered protocol family 24
[    1.272803] VFIO - User Level meta-driver version: 0.3
[    1.280096] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.286657] ehci-pci: EHCI PCI platform driver
[    1.291194] ehci-platform: EHCI generic platform driver
[    1.296785] ehci-platform 1c1a000.usb: EHCI Host Controller
[    1.302416] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[    1.310373] ehci-platform 1c1a000.usb: irq 10, io mem 0x01c1a000
[    1.332260] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    1.339555] hub 1-0:1.0: USB hub found
[    1.343390] hub 1-0:1.0: 1 port detected
[    1.348431] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.354665] ohci-pci: OHCI PCI platform driver
[    1.359232] ohci-platform: OHCI generic platform driver
[    1.364740] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    1.371413] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[    1.379364] ohci-platform 1c1a400.usb: irq 11, io mem 0x01c1a400
[    1.449327] hub 2-0:1.0: USB hub found
[    1.453180] hub 2-0:1.0: 1 port detected
[    1.458824] usbcore: registered new interface driver usb-storage
[    1.468590] sun6i-rtc 1f00000.rtc: registered as rtc0
[    1.473687] sun6i-rtc 1f00000.rtc: RTC enabled
[    1.478317] i2c /dev entries driver
[    1.483842] sdhci: Secure Digital Host Controller Interface driver
[    1.490046] sdhci: Copyright(c) Pierre Ossman
[    1.494684] Synopsys Designware Multimedia Card Interface Driver
[    1.501914] sun50i-h5-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
[    1.512874] sunxi-mmc 1c0f000.mmc: Got CD GPIO
[    1.543099] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
[    1.552502] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.559019] sun8i-h3-r-pinctrl 1f02c00.pinctrl: 1f02c00.pinctrl supply vcc-pl not found, using dummy regulator
[    1.570220] ledtrig-cpu: registered to indicate activity on CPUs
[    1.577702] usbcore: registered new interface driver usbhid
[    1.583398] usbhid: USB HID core driver
[    1.590513] NET: Registered protocol family 17
[    1.595381] 9pnet: Installing 9P2000 support
[    1.599796] Key type dns_resolver registered
[    1.605453] registered taskstats version 1
[    1.609585] Loading compiled-in X.509 certificates
[    1.630799] sun50i-h5-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
[    1.640901] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.642092] sun50i-h5-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
[    1.653307] mmc0: new high speed SDHC card at address aaaa
[    1.661157] ehci-platform 1c1d000.usb: EHCI Host Controller
[    1.667309] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
[    1.670026] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 3
[    1.682391] ehci-platform 1c1d000.usb: irq 12, io mem 0x01c1d000
[    1.683676]  mmcblk0: p1 p2
[    1.704263] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00
[    1.711536] hub 3-0:1.0: USB hub found
[    1.715370] hub 3-0:1.0: 1 port detected
[    1.720896] ohci-platform 1c1d400.usb: Generic Platform OHCI controller
[    1.727569] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 4
[    1.735529] ohci-platform 1c1d400.usb: irq 13, io mem 0x01c1d400
[    1.805301] hub 4-0:1.0: USB hub found
[    1.809144] hub 4-0:1.0: 1 port detected
[    1.814593] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    1.826073] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    1.831863] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 5
[    1.840803] hub 5-0:1.0: USB hub found
[    1.844637] hub 5-0:1.0: 1 port detected
[    1.854372] sun6i-rtc 1f00000.rtc: setting system clock to 1970-01-01T08:56:54 UTC (32214)
[    1.863153] ALSA device list:
[    1.866150]   No soundcards found.
[    1.894349] random: fast init done
[    1.905601] EXT4-fs (mmcblk0p2): recovery complete
[    1.911458] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.919695] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    1.931781] devtmpfs: mounted
[    1.938006] Freeing unused kernel memory: 2240K
[    1.942718] Run /sbin/init as init process
[    2.047209] init: Console is alive
[    2.061917] init: - preinit -
[    2.233898] random: jshn: uninitialized urandom read (4 bytes read)
Press the [f] key and hit [enter] to enter failsafe mode
Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
[    2.856071] random: procd: uninitialized urandom read (4 bytes read)
[    5.319416] mount_root: mounting /dev/root
[    5.324093] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    5.329751] mount_root: loading kmods from internal overlay
[    5.340992] mount_root: failed to launch kmodloader from internal overlay
[    5.469807] block: attempting to load /etc/config/fstab
[    5.483068] block: extroot: not configured
[    5.551350] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[    5.589196] urandom-seed: Seeding with /etc/urandom.seed
[    5.627591] procd: - early -
[    5.641391] random: procd: uninitialized urandom read (4 bytes read)
[    5.773927] random: jshn: uninitialized urandom read (4 bytes read)
[    5.915308] random: jshn: uninitialized urandom read (4 bytes read)
[    6.235558] procd: - ubus -
[    6.290206] procd: - init -
Please press Enter to activate this console.
[    6.552350] urngd: v1.0.1 started.
[    6.631386] random: crng init done
[    6.634870] random: 5 urandom warning(s) missed due to ratelimiting
能够正常启动 运行基本的操作命令
但是 ifconfig -a 没有eth0 。 网口灯两个微微亮不闪烁
root@FriendlyWrt:/# ifconfig -a
          RX packets:128 errors:0 dropped:0 overruns:0 frame:0
          TX packets:128 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:8704 (8.5 KiB)  TX bytes:8704 (8.5 KiB)
配置内核时也添加了网卡支持
 <*>   Realtek PHYs
求哪位大神看到了能帮忙解决一下,万分感谢。
#2 2020-03-10 22:25:43
我心飞翔
已发帖子: 82
Re: 求助 nanopi-neo2 全志H5 Linux 内核启动正常但是网络不通就帮助
wugang0420 wrote:
配置内核时也添加了网卡支持
 <*>   Realtek PHYs
设备树有没有添加网卡 ?
楼主 #3 2020-03-31 19:24:55
wugang0420
我心飞翔 wrote:
设备树有没有添加网卡 ?
问题已经解决了,没来得及回复万分抱歉。问题源于,编译时多选了个phy 芯片导致的
 <*>   Realtek PHYs
#4 2024-04-03 21:46:03
sxlyq_666
已发帖子: 76
wugang0420 wrote:
我心飞翔 wrote:
设备树有没有添加网卡 ?
 <*>   Realtek PHYs
什么意思,是需要打开这个吗?还是不需要打开这个选项?
