楼主 #1 2020-03-20 21:08:48
qiushan
已发帖子: 26
V3s 使用NFS无法启动rootfs,从TF卡中可以
[  109.925015] VFS: Unable to mount root fs via NFS, trying floppy.
[  109.931869] VFS: Cannot open root device "nfs" or unknown-block(2,0): error -6
[  109.939215] Please append a correct "root=" boot option; here are the available partitions:
[  109.947607] b300        15558144 mmcblk0
[  109.947614]  driver: mmcblk
[  109.954439]   b301           32768 mmcblk0p1 d85b0d94-01
[  109.954441]
[  109.961244]   b302        15523840 mmcblk0p2 d85b0d94-02
[  109.961246]
[  109.968066] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0)
[  109.976332] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.14.14-licheepi-zero+ #1
[  109.983637] Hardware name: Allwinner sun8i Family
[  109.988380] [<c010e894>] (unwind_backtrace) from [<c010b548>] (show_stack+0x10/0x14)
[  109.996135] [<c010b548>] (show_stack) from [<c06732e8>] (dump_stack+0x88/0x9c)
[  110.003367] [<c06732e8>] (dump_stack) from [<c011b848>] (panic+0xdc/0x248)
[  110.010249] [<c011b848>] (panic) from [<c09011dc>] (mount_block_root+0x18c/0x260)
[  110.017736] [<c09011dc>] (mount_block_root) from [<c09013d0>] (mount_root+0x120/0x128)
[  110.025655] [<c09013d0>] (mount_root) from [<c0901528>] (prepare_namespace+0x150/0x194)
[  110.033661] [<c0901528>] (prepare_namespace) from [<c0900e28>] (kernel_init_freeable+0x1c4/0x1d4)
[  110.042537] [<c0900e28>] (kernel_init_freeable) from [<c06854a0>] (kernel_init+0x8/0x108)
[  110.050719] [<c06854a0>] (kernel_init) from [<c0107868>] (ret_from_fork+0x14/0x2c)
[  110.058301] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0)
我的bootargs
setenv bootargs 'console=tty1 console=ttyS0,115200 root=/dev/nfs rw nfsroot=192.168.3.3:/home/qiushan/linux/nfs/ubuntu_rootfs ip=192.168.3.4:192.168.3.3:192.168.3.1:255.255.255.0::eth0:off'
#2 2020-03-20 21:44:18
已发帖子: 9,511
Re: V3s 使用NFS无法启动rootfs,从TF卡中可以
TF进入系统之后确认以下问题:
  1. 网卡驱动是否正常.
  2. 是否能ping通nfs服务器ip
  3. nfs 驱动是否配置进系统
  4. 是否能手动挂载 nfs 的共享目录到 V3s
楼主 #3 2020-03-20 21:57:09
qiushan
已发帖子: 26
TF进入系统之后确认以下问题:
  1. 网卡驱动是否正常.
  2. 是否能ping通nfs服务器ip
  3. nfs 驱动是否配置进系统
晕哥,第三步不太明白,我把根文件系统放在nfs目录里了,试过在uboot下可以使用nfs命令下载这个目录下的文件,编译好的文件系统还需要改么
#4 2020-03-20 22:10:09
已发帖子: 9,511
也就是 nfs 服务器是正常的对吧?
  1. 就是 kernel / filesystem / nfs 有没有配置,
    如果u-boot可以连接nfs服务器, 那确保V3s Linux系统能使用你的nfs文件系统.
#5 2020-03-20 22:56:53
Jmhh247
已发帖子: 262
“从TF中可以”
TF卡里面的rootfs和你的NFS目录内的rootfs是否一致,如果两者一致,文件系统就不需要再修改了。
去排查其它方面
楼主 #6 2020-03-21 08:38:37
qiushan
已发帖子: 26
也就是 nfs 服务器是正常的对吧?
kernel是不是也需要做好以太网的驱动。。。我没改kernel,只把nfs client支持给打开了
#7 2020-03-21 09:08:41
已发帖子: 9,511
如果你只是加载nfs rootfs, 那么u-boot不需要驱动ethernet,也不需要支持nfs.
反而kernel 你就必须开启nfs文件系统和ethernet支持。
楼主 #8 2020-03-21 09:10:17
qiushan
已发帖子: 26
原来是这样,谢谢晕哥
#9 2020-03-21 09:23:18
已发帖子: 9,511
只要你的 u-boot 能正常加载并运行flash/tf卡的kernel即可:
所以还是先确认以下问题:
  1. 网卡驱动是否正常.
  2. 是否能ping通nfs服务器ip
  3. nfs 驱动是否配置进系统
#10 2020-04-22 11:04:08
没事瞎转悠hhh
老哥,最后你解决了吗?怎么解决的,我也是这个问题
