楼主 #1 2020-03-25 18:01:03
jerryzheng
Licheepi nano 系统启动失败,卡在 Staring kernel ...
U-Boot 2018.01-05679-g013ca457fd-dirty (Mar 25 2020 - 16:14:47 +0800) Allwinner Technology
Model: Lichee Pi Nano
DRAM:  32 MiB
MMC:   SUNXI SD/MMC: 0
SF: Detected xt25f128b with page size 256 Bytes, erase size 4 KiB, total 16 MiB
In:    serial
Out:   vga
Err:   vga
Net:   No ethernet found.
No controllers found
device 0 offset 0x70000, size 0x10000
SF: 65536 bytes @ 0x70000 Read: OK
device 0 offset 0x80000, size 0x400000
SF: 4194304 bytes @ 0x80000 Read: OK
   Loading Device Tree to 80e5f000, end 80e6409e ... OK
SPI Flash 分区结构:
ID SIZE USAGE ADDR
0 448kb U-boot 0x0000 0000 - 0x0007 0000
1 64kb dtb 0x0007 0000 - 0x0008 0000
2 4mb kernel 0x0008 0000 - 0x0048 0000
3 7.5mb rootfs 0x0048 0000 - 0x00c0 0000
4 4mb overlay 0x00c0 0000 - 0x0100 0000
uboot启动参数:
sf probe 0 60000000; sf read 0x80c00000 0x70000 0x10000; sf read 0x80008000 0x80000 0x400000; bootz 0x80008000 - 0x80c00000
镜像脚本
#!/bin/bash
echo "Hello World!"
echo "coping files............."
cp ../u-boot/u-boot-sunxi-with-spl.bin ./uboot.bin
cp ../linux/arch/arm/boot/zImage ./zImage
cp ../linux/arch/arm/boot/dts/suniv-f1c100s-licheepi-nano.dtb ./licheepi-nano.dtb
cp ../buildroot-2017.08/output/images/rootfs.tar  ./
echo "delete rootfs directory............."
rm -rf rootfs
dd if=/dev/zero of=flashimg.bin bs=1M count=16
dd if=uboot.bin of=flashimg.bin bs=1K conv=notrunc
dd if=licheepi-nano.dtb of=flashimg.bin bs=1K seek=448  conv=notrunc
dd if=zImage of=flashimg.bin bs=1K seek=512  conv=notrunc
mkdir rootfs
echo "decompression rootfs.tar............"
tar -xf rootfs.tar -C ./rootfs
echo "decompression done..........."
fakeroot mkfs.jffs2 -s 0x100 -e 0x10000 --pad=0xAF0000 -d rootfs/ -o rootfs.img
fakeroot mkfs.jffs2 -s 0x100 -e 0x10000 --pad=0x400000 -o jffs2.img -d overlay/
dd if=rootfs.img of=flashimg.bin  bs=1K seek=4608  conv=notrunc
dd if=jffs2.img of=flashimg.bin bs=1M seek=12 conv=notrunc
rm -rf rootfs.img jffs2.img uboot.bin zImage
参考了荔枝派nano(f1c100s)的SPI-Flash系统编译创建全过程
是不是这句影响了启动:*** Warning - bad CRC, using default environment
最近编辑记录 jerryzheng (2020-03-25 18:10:49)
#2 2020-03-25 18:25:54
我思故我在
已发帖子: 244
Re: Licheepi nano 系统启动失败,卡在 Staring kernel ...
大概率是 zImage或dtb 不完整引起
楼主 #3 2020-03-26 09:42:01
jerryzheng
我发现是dtb文件没有更新, 为什么呢? 我明明用了这个命令了
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabi- dtbs -j4
楼主 #4 2020-03-26 10:06:26
jerryzheng
将config删除,再重新menuconfig, dtb文件可以生成最新的了。。。
楼主 #5 2020-03-26 10:25:17
jerryzheng
启动成功 big_smile big_smile big_smile
最近编辑记录 jerryzheng (2020-03-26 10:25:50)
#6 2020-03-28 14:35:34
runoob2020
jerryzheng wrote:
启动成功 :D :D :D
兄弟,能把你启动的镜像分享一下吗?我也遇到这个问题,卡好久了
#7 2022-01-11 14:22:31
jiajia6254
这个板子可以再哪里购买
