nanopi-neo2 全志H5
网卡rtl8211e
gcc version 7.5.0 (Linaro GCC 7.5-2019.12)
编译了2019-10月的u-boot 后uboot 网络正常可以ping 通网络,网口状态灯能正常闪亮。
但是加载内核后网络就不通了,不知到是什么问题。网口状态灯两个微亮不闪烁。
17478144 bytes read in 1300 ms (12.8 MiB/s)
18191 bytes read in 4 ms (4.3 MiB/s)
## Flattened Device Tree blob at 49000000
Booting using the fdt blob at 0x49000000
EHCI failed to shut down host controller.
Loading Device Tree to 0000000049ff8000, end 0000000049fff70e ... OK
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 5.3.6 (wg@ubuntu) (gcc version 7.5.0 (Linaro GCC 7.5-2019.12)) #1 SMP PREEMPT Tue Mar 10 06:05:31 PDT 2020
[ 0.000000] Machine model: FriendlyARM NanoPi NEO 2
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] cma: Reserved 32 MiB at 0x000000005e000000
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000040000000-0x000000005fffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0x5dee6840-0x5dee7fff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA32 [mem 0x0000000040000000-0x000000005fffffff]
[ 0.000000] Normal empty
[ 0.000000] node 0: [mem 0x0000000040000000-0x000000005fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000005fffffff]
[ 0.000000] psci: PSCIv0.2 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] percpu: Embedded 22 pages/cpu s52184 r8192 d29736 u90112
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129024
[ 0.000000] Policy zone: DMA32
[ 0.000000] Kernel command line: console=ttyS0,115200n8 earlyprintk root=/dev/mmcblk0p2 rw rootwait painc=10
[ 0.000000] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.000000] Memory: 454224K/524288K available (10172K kernel code, 812K rwdata, 3752K rodata, 2240K init, 414K bss, 37296K reserved, 32768K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] random: get_random_bytes called from start_kernel+0x300/0x4a0 with crng_init=0
[ 0.000010] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000232] Console: colour dummy device 80x25
[ 0.000374] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[ 0.000399] pid_max: default: 32768 minimum: 301
[ 0.000593] LSM: Security Framework initializing
[ 0.000724] Mount-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.000752] Mountpoint-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.024069] ASID allocator initialised with 32768 entries
[ 0.032057] rcu: Hierarchical SRCU implementation.
[ 0.040396] EFI services will not be available.
[ 0.048130] smp: Bringing up secondary CPUs ...
[ 0.081174] Detected VIPT I-cache on CPU1
[ 0.081280] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.112890] Detected VIPT I-cache on CPU2
[ 0.112957] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.144989] Detected VIPT I-cache on CPU3
[ 0.145049] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.145210] smp: Brought up 1 node, 4 CPUs
[ 0.145251] SMP: Total of 4 processors activated.
[ 0.145266] CPU features: detected: 32-bit EL0 Support
[ 0.145281] CPU features: detected: CRC32 instructions
[ 0.146390] CPU: All CPU(s) started at EL2
[ 0.146437] alternatives: patching kernel code
[ 0.148847] devtmpfs: initialized
[ 0.157413] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.157454] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.160383] pinctrl core: initialized pinctrl subsystem
[ 0.161453] DMI not present or invalid.
[ 0.162099] NET: Registered protocol family 16
[ 0.162985] audit: initializing netlink subsys (disabled)
[ 0.163346] audit: type=2000 audit(0.160:1): state=initialized audit_enabled=0 res=1
[ 0.164590] cpuidle: using governor menu
[ 0.165242] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.171385] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.171674] Serial: AMBA PL011 UART driver
[ 0.200552] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.200578] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.200595] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.200611] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.205104] cryptd: max_cpu_qlen set to 1000
[ 0.213018] ACPI: Interpreter disabled.
[ 0.215054] vgaarb: loaded
[ 0.215786] SCSI subsystem initialized
[ 0.216602] usbcore: registered new interface driver usbfs
[ 0.216702] usbcore: registered new interface driver hub
[ 0.216850] usbcore: registered new device driver usb
[ 0.217367] pps_core: LinuxPPS API ver. 1 registered
[ 0.217381] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.217418] PTP clock support registered
[ 0.217488] EDAC MC: Ver: 3.0.0
[ 0.218560] FPGA manager framework
[ 0.218742] Advanced Linux Sound Architecture Driver Initialized.
[ 0.220217] clocksource: Switched to clocksource arch_sys_counter
[ 0.220566] VFS: Disk quotas dquot_6.6.0
[ 0.220685] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.221068] pnp: PnP ACPI: disabled
[ 0.233709] thermal_sys: Registered thermal governor 'step_wise'
[ 0.233718] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.234254] NET: Registered protocol family 2
[ 0.235064] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.235113] TCP established hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.235212] TCP bind hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.235362] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.235547] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.235596] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.235870] NET: Registered protocol family 1
[ 0.236840] RPC: Registered named UNIX socket transport module.
[ 0.236854] RPC: Registered udp transport module.
[ 0.236866] RPC: Registered tcp transport module.
[ 0.236877] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.236900] PCI: CLS 0 bytes, default 64
[ 0.238319] kvm [1]: IPA Size Limit: 40bits
[ 0.239532] kvm [1]: vgic interrupt IRQ1
[ 0.239770] kvm [1]: Hyp mode initialized successfully
[ 0.253418] Initialise system trusted keyrings
[ 0.253726] workingset: timestamp_bits=44 max_order=17 bucket_order=0
[ 0.269351] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.270995] NFS: Registering the id_resolver key type
[ 0.271047] Key type id_resolver registered
[ 0.271060] Key type id_legacy registered
[ 0.271095] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.271421] 9p: Installing v9fs 9p2000 file system support
[ 0.309948] Key type asymmetric registered
[ 0.309967] Asymmetric key parser 'x509' registered
[ 0.310047] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.310063] io scheduler mq-deadline registered
[ 0.310076] io scheduler kyber registered
[ 0.311667] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO
[ 0.315344] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[ 0.322691] sun50i-h5-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.325358] EINJ: ACPI disabled.
[ 0.336573] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.339121] sun50i-h5-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pa not found, using dummy regulator
[ 0.339840] printk: console [ttyS0] disabled
[ 0.360539] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 21, base_baud = 1500000) is a U6_16550A
[ 1.133358] printk: console [ttyS0] enabled
[ 1.139815] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 1.161288] loop: module loaded
[ 1.169046] libphy: Fixed MDIO Bus: probed
[ 1.174179] tun: Universal TUN/TAP device driver, 1.6
[ 1.180311] thunder_xcv, ver 1.0
[ 1.183618] thunder_bgx, ver 1.0
[ 1.186956] nicpf, ver 1.0
[ 1.190409] hclge is initializing
[ 1.193753] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 1.200989] hns3: Copyright (c) 2017 Huawei Corporation.
[ 1.206424] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.212275] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.218285] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.6.0-k
[ 1.225260] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.230923] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.238766] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.244799] sky2: driver version 1.30
[ 1.248828] PPP generic driver version 2.4.2
[ 1.253355] PPP BSD Compression module registered
[ 1.258100] PPP Deflate Compression module registered
[ 1.263204] PPP MPPE Compression module registered
[ 1.268017] NET: Registered protocol family 24
[ 1.272803] VFIO - User Level meta-driver version: 0.3
[ 1.280096] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.286657] ehci-pci: EHCI PCI platform driver
[ 1.291194] ehci-platform: EHCI generic platform driver
[ 1.296785] ehci-platform 1c1a000.usb: EHCI Host Controller
[ 1.302416] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[ 1.310373] ehci-platform 1c1a000.usb: irq 10, io mem 0x01c1a000
[ 1.332260] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[ 1.339555] hub 1-0:1.0: USB hub found
[ 1.343390] hub 1-0:1.0: 1 port detected
[ 1.348431] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.354665] ohci-pci: OHCI PCI platform driver
[ 1.359232] ohci-platform: OHCI generic platform driver
[ 1.364740] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[ 1.371413] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[ 1.379364] ohci-platform 1c1a400.usb: irq 11, io mem 0x01c1a400
[ 1.449327] hub 2-0:1.0: USB hub found
[ 1.453180] hub 2-0:1.0: 1 port detected
[ 1.458824] usbcore: registered new interface driver usb-storage
[ 1.468590] sun6i-rtc 1f00000.rtc: registered as rtc0
[ 1.473687] sun6i-rtc 1f00000.rtc: RTC enabled
[ 1.478317] i2c /dev entries driver
[ 1.483842] sdhci: Secure Digital Host Controller Interface driver
[ 1.490046] sdhci: Copyright(c) Pierre Ossman
[ 1.494684] Synopsys Designware Multimedia Card Interface Driver
[ 1.501914] sun50i-h5-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
[ 1.512874] sunxi-mmc 1c0f000.mmc: Got CD GPIO
[ 1.543099] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
[ 1.552502] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.559019] sun8i-h3-r-pinctrl 1f02c00.pinctrl: 1f02c00.pinctrl supply vcc-pl not found, using dummy regulator
[ 1.570220] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.577702] usbcore: registered new interface driver usbhid
[ 1.583398] usbhid: USB HID core driver
[ 1.590513] NET: Registered protocol family 17
[ 1.595381] 9pnet: Installing 9P2000 support
[ 1.599796] Key type dns_resolver registered
[ 1.605453] registered taskstats version 1
[ 1.609585] Loading compiled-in X.509 certificates
[ 1.630799] sun50i-h5-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
[ 1.640901] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.642092] sun50i-h5-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
[ 1.653307] mmc0: new high speed SDHC card at address aaaa
[ 1.661157] ehci-platform 1c1d000.usb: EHCI Host Controller
[ 1.667309] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
[ 1.670026] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 3
[ 1.682391] ehci-platform 1c1d000.usb: irq 12, io mem 0x01c1d000
[ 1.683676] mmcblk0: p1 p2
[ 1.704263] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00
[ 1.711536] hub 3-0:1.0: USB hub found
[ 1.715370] hub 3-0:1.0: 1 port detected
[ 1.720896] ohci-platform 1c1d400.usb: Generic Platform OHCI controller
[ 1.727569] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 4
[ 1.735529] ohci-platform 1c1d400.usb: irq 13, io mem 0x01c1d400
[ 1.805301] hub 4-0:1.0: USB hub found
[ 1.809144] hub 4-0:1.0: 1 port detected
[ 1.814593] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 1.826073] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.831863] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 5
[ 1.840803] hub 5-0:1.0: USB hub found
[ 1.844637] hub 5-0:1.0: 1 port detected
[ 1.854372] sun6i-rtc 1f00000.rtc: setting system clock to 1970-01-01T08:56:54 UTC (32214)
[ 1.863153] ALSA device list:
[ 1.866150] No soundcards found.
[ 1.894349] random: fast init done
[ 1.905601] EXT4-fs (mmcblk0p2): recovery complete
[ 1.911458] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.919695] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 1.931781] devtmpfs: mounted
[ 1.938006] Freeing unused kernel memory: 2240K
[ 1.942718] Run /sbin/init as init process
[ 2.047209] init: Console is alive
[ 2.061917] init: - preinit -
[ 2.233898] random: jshn: uninitialized urandom read (4 bytes read)
Press the [f] key and hit [enter] to enter failsafe mode
Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
[ 2.856071] random: procd: uninitialized urandom read (4 bytes read)
[ 5.319416] mount_root: mounting /dev/root
[ 5.324093] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 5.329751] mount_root: loading kmods from internal overlay
[ 5.340992] mount_root: failed to launch kmodloader from internal overlay
[ 5.469807] block: attempting to load /etc/config/fstab
[ 5.483068] block: extroot: not configured
[ 5.551350] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 5.589196] urandom-seed: Seeding with /etc/urandom.seed
[ 5.627591] procd: - early -
[ 5.641391] random: procd: uninitialized urandom read (4 bytes read)
[ 5.773927] random: jshn: uninitialized urandom read (4 bytes read)
[ 5.915308] random: jshn: uninitialized urandom read (4 bytes read)
[ 6.235558] procd: - ubus -
[ 6.290206] procd: - init -
Please press Enter to activate this console.
[ 6.552350] urngd: v1.0.1 started.
[ 6.631386] random: crng init done
[ 6.634870] random: 5 urandom warning(s) missed due to ratelimiting能够正常启动 运行基本的操作命令
但是 ifconfig -a 没有eth0 。 网口灯两个微微亮不闪烁
root@FriendlyWrt:/# ifconfig -a
lo Link encap:Local Loopback
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:128 errors:0 dropped:0 overruns:0 frame:0
TX packets:128 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:8704 (8.5 KiB) TX bytes:8704 (8.5 KiB)配置内核时也添加了网卡支持
<*> Realtek PHYs 求哪位大神看到了能帮忙解决一下,万分感谢。
wugang0420 wrote:
配置内核时也添加了网卡支持
<*> Realtek PHYs求哪位大神看到了能帮忙解决一下,万分感谢。
设备树有没有添加网卡 ?
我心飞翔 wrote:
设备树有没有添加网卡 ?
问题已经解决了,没来得及回复万分抱歉。问题源于,编译时多选了个phy 芯片导致的
<*> Realtek PHYs 离线
wugang0420 wrote:
我心飞翔 wrote:
设备树有没有添加网卡 ?
<*> Realtek PHYs 什么意思,是需要打开这个吗?还是不需要打开这个选项?
