楼主 #1 2020-04-06 16:36:48
ubuntu
已发帖子: 338
请问有没有哪位朋友用过 A33 Linux5.x IO中断呢?
原帖: https://whycan.cn/t_2393.html#p37627
我的A33 linux5.x 按 4# 的操作步奏,中断申请到了, 但是根本不触发。
arch/arm/boot/dts/sun8i-a23-a33.dtsi
                pio: pinctrl@1c20800 {
                        /* compatible gets set in SoC specific dtsi file */
                        reg = <0x01c20800 0x400>;
                        key_pins: key_pins@0 {
                                pins = "PB5";
                                function = "gpio_in";
                                allwinner,drive = <0>;
                                allwinner,pull = <1>;
arch/arm/boot/dts/sun8i-a33.dtsi
        keys{
                compatible = "gpio-keys";
                pinctrl-names = "default";
                pinctrl-0 = <&key_pins>;
                #address-cells = <1>;
                #size-cells = <0>;
                autorepeat;
                g-keys_up {
                        label = "GPIO KEY_UP";
                        linux,code = <103>; /* KEY_UP, see /usr/include/linux/input-event-codes.h */
//                        gpios = <&pio 1 5 1>; /* PA7 GPIO_ACTIVE_LOW */
                        interrupt-parent = <&pio>;
                        interrupts = <1 5 IRQ_TYPE_EDGE_FALLING>;//PB0
                /*status = "okay";*/
        iio-hwmon {
                compatible = "iio-hwmon";
                io-channels = <&ths>;
根本不触发:
# cat /proc/interrupts
           CPU0       CPU1       CPU2       CPU3
 18:          0          0          0          0     GICv2  29 Level     arch_timer
 19:        401       1735        205        225     GICv2  30 Level     arch_timer
 22:          0          0          0          0     GICv2  50 Level     timer@1c20c00
 23:          0          0          0          0     GICv2  82 Level     1c02000.dma-controller
 25:       4072          0          0          0     GICv2  92 Level     sunxi-mmc
 26:          0          0          0          0     GICv2 103 Level     musb-hdrc.1.auto
 27:          0          0          0          0     GICv2 104 Level     ehci_hcd:usb1
 28:          0          0          0          0     GICv2 105 Level     ohci_hcd:usb2
 34:       1705          0          0          0     GICv2  32 Level     ttyS0
 56:          0          0          0          0  sunxi_pio_edge   5 Edge      GPIO KEY_UP
 60:          0          0          0          0  sunxi_pio_edge   9 Edge      1c0f000.mmc cd
IPI0:          0          0          0          0  CPU wakeup interrupts
IPI1:          0          0          0          0  Timer broadcast interrupts
IPI2:        749        723        125       1223  Rescheduling interrupts
IPI3:          1         12         22         43  Function call interrupts
IPI4:          0          0          0          0  CPU stop interrupts
IPI5:          0          0          0          0  IRQ work interrupts
IPI6:          0          0          0          0  completion interrupts
Err:          0
楼主 #2 2020-04-06 17:11:01
ubuntu
已发帖子: 338
Re: 请问有没有哪位朋友用过 A33 Linux5.x IO中断呢?
https://github.com/torvalds/linux/blob/master/drivers/pinctrl/sunxi/pinctrl-sun8i-a33.c
https://patchwork.kernel.org/patch/8572141/
diff --git a/drivers/pinctrl/sunxi/pinctrl-sun8i-a33.c b/drivers/pinctrl/sunxi/pinctrl-sun8i-a33.c
index 00265f0..8b381d6 100644
--- a/drivers/pinctrl/sunxi/pinctrl-sun8i-a33.c
+++ b/drivers/pinctrl/sunxi/pinctrl-sun8i-a33.c
@@ -485,6 +485,7 @@  static const struct sunxi_pinctrl_desc sun8i_a33_pinctrl_data = {
 	.pins = sun8i_a33_pins,
 	.npins = ARRAY_SIZE(sun8i_a33_pins),
 	.irq_banks = 2,
+	.irq_bank_base = 1,
2016 的bug patch 也没有并入?
楼主 #3 2020-04-06 17:11:39
ubuntu
已发帖子: 338
https://lore.kernel.org/patchwork/patch/934382/
这里貌似有icenowy 关于 A33/V3s 外部IO中断的 patch
楼主 #4 2020-04-06 19:56:34
ubuntu
已发帖子: 338
PB4 用 sysfs 控制输出高低电平正常:
#PB4 = 32 + 4 = 36
echo 36 > /sys/class/gpio/export
#设置为输出
echo "out" > /sys/class/gpio/gpio36/direction
#PB4输出高电平
echo 1 > /sys/class/gpio/gpio36/value
#PB4输出低电平
echo 0 > /sys/class/gpio/gpio36/value
hello.c
#include <linux/kernel.h>
#include <linux/module.h>
#include <linux/input.h>
#include <linux/input-polldev.h>
#include <linux/input/touchscreen.h>
#include <linux/i2c.h>
#include <linux/gpio.h>
#include <linux/interrupt.h>
#define GPIO 36    //PG0
#define GPIO_INT_NAME  "pb4_int"
#define GPIO_HIGH gpio_get_value(GPIO)
#define GPIO_LOW (gpio_get_value(GPIO) == 0)
MODULE_LICENSE("Dual BSD/GPL");
short int irq_any_gpio    = 0;
int count =0;
enum { falling, rising } type;
static irqreturn_t r_irq_handler(int irq, void *dev_id)
    count++;
    printk("interrupt received (irq: %d)\n", irq);
    if (irq == gpio_to_irq(GPIO))
        type = GPIO_LOW ? falling : rising;
        if(type == falling)
            printk("gpio pin is low\n");
            printk("gpio pin is high\n");
    return IRQ_HANDLED;
void r_int_config(void) {
   if (gpio_request(GPIO, GPIO_INT_NAME ))
      printk("GPIO request failure: %s\n", GPIO_INT_NAME );
      return;
   if ( (irq_any_gpio = gpio_to_irq(GPIO)) < 0 ) {
      printk("GPIO to IRQ mapping failure %s\n",GPIO_INT_NAME );
      return;
   printk(KERN_NOTICE "Mapped int %d\n", irq_any_gpio);
   if (request_irq(irq_any_gpio,(irq_handler_t ) r_irq_handler, IRQF_TRIGGER_FALLING , GPIO_INT_NAME, NULL))
      printk("Irq Request failure\n");
      return;
   return;
static void release_hello(void) {
   free_irq(gpio_to_irq(GPIO), NULL);
    gpio_free(GPIO);;
   return;
static int init_hello(void)
        printk("<1>Hello World\n");
    r_int_config();
module_init(init_hello);    // Do some better naming
module_exit(release_hello);
Makefile
Makefile
# Makefile for kernel test
PWD         := $(shell pwd)
KVERSION    := $(shell uname -r)
KERNEL_DIR   = /usr/src/linux-headers-$(KVERSION)/
MODULE_NAME  = hello
obj-m       := $(MODULE_NAME).o
all:
        make -C $(KERNEL_DIR) M=$(PWD) modules
clean:
        make -C $(KERNEL_DIR) M=$(PWD) clean
编译指令:
ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- make  -C /home/ren/A33/mainline/linux/ M=${PWD} modules
安装模块:
insmod hello.ko
然后短路 PB4 & GND, 然而还是纹丝不动.
楼主 #5 2020-04-07 10:55:16
ubuntu
已发帖子: 338
SUNXI_FUNCTION_IRQ_BANK(0x4, 0, 4)), / PB_EINT4 /
改为:
SUNXI_FUNCTION_IRQ_BANK(0x6, 0, 4)), / PB_EINT4 /
也没有什么用, 向各路江湖豪杰求救!
#6 2020-04-07 11:36:58
拉轰的脚踏车
已发帖子: 288
用 devmem 去读 PB_CFG0 寄存器
PB0_SELECT
000: Input 001: Output
010: UART2_TX 011: UART0_TX
100: PB_EINT0 101: Reserved
110: Reserved 111: IO Disable
看是否处于中断复用?
查了一下, PB_CFG0 地址应该是 0x01C20824
楼主 #7 2020-04-07 11:41:33
ubuntu
已发帖子: 338
看是否处于中断复用?
insmod hello.ko 之前:
devmem 0x01C20824: 0x77477733
insmod hello.ko 之后:
devmem 0x01C20824: 0x77447733
看来这个PB4的复用应该没有错误, 只能检查别的问题了。
看来还是去 Icenowy 的仓库围观一下:
https://github.com/Icenowy/linux/commits/a33-cedrus-pr
https://github.com/Icenowy/linux/commits/a33-best-practice
楼主 #8 2020-04-08 23:53:41
ubuntu
已发帖子: 338
# insmod /mnt/udisk/hello.ko
[   31.697182] hello: loading out-of-tree module taints kernel.
[   31.703544] <1>Hello World
[   31.706404] Mapped int 57
           CPU0       CPU1       CPU2       CPU3
 19:        370        294        146        209     GICv2  30 Level     arch_timer
 24:       1175          0          0          0     GICv2  92 Level     sunxi-mmc
 34:        166          0          0          0     GICv2  32 Level     ttyS0
 42:          0          0          0          0     GICv2  72 Level     1f00000.rtc
 57:          0          0          0          0  sunxi_pio_edge   4 Edge      pb4_int
 62:          0          0          0          0  sunxi_pio_edge   9 Edge      1c0f000.mmc cd
IPI2:        710        836         99        271  Rescheduling interrupts
IPI3:          4         23         44         41  Function call interrupts
Err:          0
# [   52.420296] interrupt received (irq: 57)
[   52.424250] gpio pin is low
[   52.427083] interrupt received (irq: 57)
[   52.431010] gpio pin is low
[   52.854042] interrupt received (irq: 57)
[   52.857980] gpio pin is low
[   52.860807] interrupt received (irq: 57)
[   52.864733] gpio pin is low
[   52.886404] interrupt received (irq: 57)
[   52.890338] gpio pin is low
[   52.897023] interrupt received (irq: 57)
[   52.900955] gpio pin is low
[   52.927779] interrupt received (irq: 57)
[   52.931710] gpio pin is low
[   53.154994] interrupt received (irq: 57)
[   53.158927] gpio pin is high
[   53.161838] interrupt received (irq: 57)
[   53.165764] gpio pin is low
[   53.168574] interrupt received (irq: 57)
[   53.172500] gpio pin is low
[   53.577491] interrupt received (irq: 57)
[   53.581424] gpio pin is high
[   53.584343] interrupt received (irq: 57)
[   53.588270] gpio pin is high
           CPU0       CPU1       CPU2       CPU3
 19:        512        351        156        209     GICv2  30 Level     arch_timer
 24:       1579          0          0          0     GICv2  92 Level     sunxi-mmc
 34:        207          0          0          0     GICv2  32 Level     ttyS0
 57:         12          0          0          0  sunxi_pio_edge   4 Edge      pb4_int
IPI2:        710        897        100        271  Rescheduling interrupts
IPI3:          5         26         44         41  Function call interrupts
IPI5:          4          0          0          0  IRQ work interrupts
Err:          0
试了一下 linux4.20 居然可以触发中断, 估计后面被改出问题了吧.
