楼主 #1 2020-04-09 10:33:02
vanquoc12b4
F1C100S裸機:SPI1從模式無法正常工作。
嗨,大家好,
我對F1C100S的SPI1有問題。
當我將SPI1與SLAVE模式一起使用時。
當我向SPI1_TXD_REG寫1個字(4字節)並從寄存器SPI1_FSR_REG中讀回TX_FIFO中的數字字節時。
SPI1_FSR_REG的返回值:0x20000(僅2個字節).// TX_FIFO中期望有4個字節
但是,當我切換到MASTER模式時,SPI1_FSR_REG的返回值是正確的:0x40000(4個字節)。
您能告訴我程序中的錯誤嗎?
非常感謝你。
main.c
#include <stdint.h>
#include <stdlib.h>
#include <stdio.h>
#define CCU_BASE                (0x01C20000)
#define PIO_BASE                (0x01C20800)
#define SPI1_BASE               (0x01C06000)
#define DMA_BASE                (0x01C02000)
#define TIMER_BASE              (0x01C20C00)
/* PIO: PA(0), PB(1), PC(2), PD(3), PE(4), PF(5) */
#define Pn_CFG0(n)              (*(volatile uint32_t *)(PIO_BASE + n*0x24 + 0x00))          // Port n Configure Register 0 (n=0~5)
#define Pn_CFG1(n)              (*(volatile uint32_t *)(PIO_BASE + n*0x24 + 0x04))          // Port n Configure Register 1 (n=0~5)
#define Pn_CFG2(n)              (*(volatile uint32_t *)(PIO_BASE + n*0x24 + 0x08))          // Port n Configure Register 2 (n=0~5)
#define Pn_CFG3(n)              (*(volatile uint32_t *)(PIO_BASE + n*0x24 + 0x0C))          // Port n Configure Register 3 (n=0~5)
#define Pn_DATA(n)              (*(volatile uint32_t *)(PIO_BASE + n*0x24 + 0x10))          // Port n Data Register (n=0~5)
#define Pn_DRV0(n)              (*(volatile uint32_t *)(PIO_BASE + n*0x24 + 0x14))          // Port n Multi-Driving Register 0 (n=0~5)
#define Pn_DRV1(n)              (*(volatile uint32_t *)(PIO_BASE + n*0x24 + 0x18))          // Port n Multi-Driving Register 1 (n=0~5)
#define Pn_PUL0(n)              (*(volatile uint32_t *)(PIO_BASE + n*0x24 + 0x1C))          // Port n Pull Register 0 (n=0~5)
#define Pn_PUL1(n)              (*(volatile uint32_t *)(PIO_BASE + n*0x24 + 0x20))          // Port n Pull Register 1
#define Pn_INT_CFG0(n)          (*(volatile uint32_t *)(PIO_BASE + 0x200  + n*0x20 + 0x0))  // PIO Interrupt Configure Register 0 (n=0~2) PD(0), PE(1), PF(2)
#define Pn_INT_CFG1(n)          (*(volatile uint32_t *)(PIO_BASE + 0x200  + n*0x20 + 0x4))  // PIO Interrupt Configure Register 1 (n=0~2) PD(0), PE(1), PF(2)
#define Pn_INT_CFG2(n)          (*(volatile uint32_t *)(PIO_BASE + 0x200  + n*0x20 + 0x8))  // PIO Interrupt Configure Register 2 (n=0~2) PD(0), PE(1), PF(2)
#define Pn_INT_CFG3(n)          (*(volatile uint32_t *)(PIO_BASE + 0x200  + n*0x20 + 0xC))  // PIO Interrupt Configure Register 3 (n=0~2) PD(0), PE(1), PF(2)
#define Pn_INT_CTRL(n)          (*(volatile uint32_t *)(PIO_BASE + 0x200  + n*0x20 + 0x10)) // PIO Interrupt Control Register     (n=0~2) PD(0), PE(1), PF(2)
#define Pn_INT_STA(n)           (*(volatile uint32_t *)(PIO_BASE + 0x200  + n*0x20 + 0x14)) // PIO Interrupt Status Register      (n=0~2) PD(0), PE(1), PF(2)
#define Pn_INT_DEB(n)           (*(volatile uint32_t *)(PIO_BASE + 0x200  + n*0x20 + 0x18)) // PIO Interrupt Debounce Register    (n=0~2) PD(0), PE(1), PF(2)
/* CCU */
#define BUS_CLK_GATING_REG0     (*(volatile uint32_t *)(CCU_BASE + 0x0060))
#define BUS_CLK_GATING_REG1     (*(volatile uint32_t *)(CCU_BASE + 0x0064))
#define BUS_CLK_GATING_REG2     (*(volatile uint32_t *)(CCU_BASE + 0x0068))
#define BUS_SOFT_RST_REG0       (*(volatile uint32_t *)(CCU_BASE + 0x02C0))
#define BUS_SOFT_RST_REG1       (*(volatile uint32_t *)(CCU_BASE + 0x02C4))
#define BUS_SOFT_RST_REG2       (*(volatile uint32_t *)(CCU_BASE + 0x02D0))
/* SPI1 */
#define SPI1_GCR_REG            (*(volatile uint32_t *)(SPI1_BASE + 0x0004))
#define SPI1_TCR_REG            (*(volatile uint32_t *)(SPI1_BASE + 0x0008))
#define SPI1_IER_REG            (*(volatile uint32_t *)(SPI1_BASE + 0x0010))
#define SPI1_ISR_REG            (*(volatile uint32_t *)(SPI1_BASE + 0x0014))
#define SPI1_FCR_REG            (*(volatile uint32_t *)(SPI1_BASE + 0x0018))
#define SPI1_FSR_REG            (*(volatile uint32_t *)(SPI1_BASE + 0x001C))
#define SPI1_WCR_REG            (*(volatile uint32_t *)(SPI1_BASE + 0x0020))
#define SPI1_CCR_REG            (*(volatile uint32_t *)(SPI1_BASE + 0x0024))
#define SPI1_MBC_REG            (*(volatile uint32_t *)(SPI1_BASE + 0x0030))
#define SPI1_MTC_REG            (*(volatile uint32_t *)(SPI1_BASE + 0x0034))
#define SPI1_BCC_REG            (*(volatile uint32_t *)(SPI1_BASE + 0x0038))
#define SPI1_TXD_REG            (*(volatile uint32_t *)(SPI1_BASE + 0x0200))
#define SPI1_RXD_REG            (*(volatile uint32_t *)(SPI1_BASE + 0x0300))
/* WDOG */
#define WDOG_IRQ_EN_REG         (*(volatile uint32_t *)(TIMER_BASE + 0x00A0))
#define WDOG_IRQ_STA_REG        (*(volatile uint32_t *)(TIMER_BASE + 0x00A4))
#define WDOG_CTRL_REG           (*(volatile uint32_t *)(TIMER_BASE + 0x00B0))
#define WDOG_CFG_REG            (*(volatile uint32_t *)(TIMER_BASE + 0x00B4))
#define WDOG_MODE_REG           (*(volatile uint32_t *)(TIMER_BASE + 0x00B8))
extern void sys_uart_putc(char c);
int boot_main(int argc, char **argv) {
    /* Do initial mem pool */
    do_init_mem_pool();
    do_init_dma_pool();
    printf("Start main while!\n\r");
    //usb_device_init(USB_TYPE_USB_COM);
    volatile int i;
    for(i = 0;i <1000;i++)
    usb_reg_debugdump();//0x53555741
    // Config SPI1 Interface Pin
    Pn_CFG0(0) = 0x6666;
    // Config SPI1 reset rule
    BUS_SOFT_RST_REG0 |= (1 << 21);
    // Config SPI1 CLK gate
    BUS_CLK_GATING_REG0 |= (1 << 21);
    // Reset SPI1, SPI1 Slave Mode, Enable SPI1
    SPI1_GCR_REG = (1 << 31) | (0 << 1) | (1 << 0);
    // Wait SPI1 reset complete
    while(SPI1_GCR_REG & (1<<31));
    // SS_LEVEL no active level: high, SS active level: low, CPOL=0, CPHA=1
    SPI1_TCR_REG = (1<<7)|(1<<2)|(0<<1)|(1<<0);
    // TX FIFO reset, RX FIFO reset
    SPI1_FCR_REG = (1<<31) | (1<<15);
    // Wait TX FIFO reset complete
    while(SPI1_FCR_REG & (1<<31)) asm("nop");
    // Wait RX FIFO reset complete
    while(SPI1_FCR_REG & (1<<15)) asm("nop");
    printf("SPI1_FSR_REG:0x%X\n", SPI1_FSR_REG);
    SPI1_TXD_REG = 0x01;
    // Output: 0x20000 with SPI1_GCR_REG = (1 << 31) | (0 << 1) | (1 << 0): Slave Mode
    // Output: 0x40000 with SPI1_GCR_REG = (1 << 31) | (1 << 1) | (1 << 0): Master Mode
    //SPI1_FSR_REG[23:16]
    //TX FIFO Counter
    //These bits indicate the number of words in TX FIFO
    //0: 0 byte in TX FIFO
    //1: 1 byte in TX FIFO
    //64: 64 bytes in TX FIFO
    //Other: /
    printf("WDOG reset system\n");
    WDOG_CFG_REG = 0x01; // Reset whole sytem
    WDOG_MODE_REG = 0x01; // Start WDOG
    while(1)
void __fatal_error(const char *msg) {
    while (1);
#ifndef NDEBUG
void __assert_func(const char *file, int line, const char *func, const char *expr) {
    //printf("Assertion '%s' failed, at file %s:%d\n", expr, file, line);
    __fatal_error("Assertion failed");
