硬件上 PWM0 PH0 控制 LCD 背光
ARCH=arm make memuconfig 开启以下配置:
CONFIG_BACKLIGHT_LCD_SUPPORT=y
CONFIG_BACKLIGHT_PWM=y
dts 修改:
backlight: backlight {
compatible = "pwm-backlight";
pwms = <&pwm 0 50000 PWM_POLARITY_INVERTED>;
brightness-levels = <0 1 2 4 8 16 32 64 128 255>;
default-brightness-level = <9>;
};&pwm {
pinctrl-names = "default";
pinctrl-0 = <&pwm0_pin>;
};离线
用户层控制亮度:
echo 0 > /sys/class/backlight/backlight/brightness
echo 1 > /sys/class/backlight/backlight/brightness
echo 9 > /sys/class/backlight/backlight/brightness
感谢分享!
请问你的是什么版本sdk?主线?
