楼主 #1 2020-04-14 17:33:23
psst
已发帖子: 91
v3s sd卡启动 有时出错
v3s sd卡启动,有时会出这样的错误,系统卡住,连看门狗复位都无法重启。是啥原因??请教大家
[    6.219424] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[    7.175179] sched: RT throttling activated
[    7.225185] sunxi-mmc 1c0f000.mmc: send stop command failed
楼主 #2 2020-04-14 17:50:54
psst
已发帖子: 91
Re: v3s sd卡启动 有时出错
static irqreturn_t sunxi_mmc_handle_manual_stop(int irq, void *dev_id)
    struct sunxi_mmc_host *host = dev_id;
    struct mmc_request *mrq;
    unsigned long iflags;
    spin_lock_irqsave(&host->lock, iflags);
    mrq = host->manual_stop_mrq;
    spin_unlock_irqrestore(&host->lock, iflags);
    if (!mrq) {
        dev_err(mmc_dev(host->mmc), "no request for manual stop\n");
        return IRQ_HANDLED;
    dev_err(mmc_dev(host->mmc), "data error, sending stop command\n");
     * We will never have more than one outstanding request,
     * and we do not complete the request until after
     * we've cleared host->manual_stop_mrq so we do not need to
     * spin lock this function.
     * Additionally we have wait states within this function
     * so having it in a lock is a very bad idea.
    sunxi_mmc_send_manual_stop(host, mrq);
    host->manual_stop_mrq = NULL;
    mmc_request_done(host->mmc, mrq);
    return IRQ_HANDLED;
static void sunxi_mmc_send_manual_stop(struct sunxi_mmc_host *host,
                       struct mmc_request *req)
    u32 arg, cmd_val, ri;
    unsigned long expire = jiffies + msecs_to_jiffies(1000);
    cmd_val = SDXC_START | SDXC_RESP_EXPIRE |
          SDXC_STOP_ABORT_CMD | SDXC_CHECK_RESPONSE_CRC;
    if (req->cmd->opcode == SD_IO_RW_EXTENDED) {
        cmd_val |= SD_IO_RW_DIRECT;
        arg = (1 << 31) | (0 << 28) | (SDIO_CCCR_ABORT << 9) |
              ((req->cmd->arg >> 28) & 0x7);
    } else {
        cmd_val |= MMC_STOP_TRANSMISSION;
        arg = 0;
    mmc_writel(host, REG_CARG, arg);
    mmc_writel(host, REG_CMDR, cmd_val);
    do {
        ri = mmc_readl(host, REG_RINTR);
    } while (!(ri & (SDXC_COMMAND_DONE | SDXC_INTERRUPT_ERROR_BIT)) &&
         time_before(jiffies, expire));
    if (!(ri & SDXC_COMMAND_DONE) || (ri & SDXC_INTERRUPT_ERROR_BIT)) {
        dev_err(mmc_dev(host->mmc), "send stop command failed\n");
        if (req->stop)
            req->stop->resp[0] = -ETIMEDOUT;
    } else {
        if (req->stop)
            req->stop->resp[0] = mmc_readl(host, REG_RESP0);
    mmc_writel(host, REG_RINTR, 0xffff);
找到了两个相关的函数,不知道什么原因引起的,不是每次都会出错,偶尔出问题,很要命。
#3 2020-04-14 18:29:03
Re: v3s sd卡启动 有时出错
换张卡呢?用的是开发板吗
楼主 #4 2020-04-14 19:30:50
psst
已发帖子: 91
Re: v3s sd卡启动 有时出错
不是开发板,批量做了,大概10个板会有一个出这种问题,而且出问题的可能过段时间又好了
#5 2020-04-14 19:41:28
歌以咏志
已发帖子: 219
Re: v3s sd卡启动 有时出错
十有八九硬件问题, 对照荔枝派原理图看是不是SDIO没有上拉.
楼主 #6 2020-04-15 11:00:15
psst
已发帖子: 91
Re: v3s sd卡启动 有时出错
有加上拉,硬件没问题
楼主 #7 2020-04-15 14:50:06
psst
已发帖子: 91
Re: v3s sd卡启动 有时出错
总线宽度改成1,是否会降低读写速度,我改成了1,试试看
#8 2020-04-15 15:09:45
歌以咏志
已发帖子: 219
Re: v3s sd卡启动 有时出错
psst 说:
肯定会降速嘛,要是速度一样,干嘛不全用1bit省IO.
#9 2023-10-25 23:27:13
WhyKen395
Re: v3s sd卡启动 有时出错
SD卡兼容性问题,换张卡试试
