楼主 #1 2020-04-14 17:33:23
psst
已发帖子: 92
v3s sd卡启动 有时出错
v3s sd卡启动,有时会出这样的错误,系统卡住,连看门狗复位都无法重启。是啥原因??请教大家
[ 6.219424] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 7.175179] sched: RT throttling activated
[ 7.225185] sunxi-mmc 1c0f000.mmc: send stop command failed
楼主 #2 2020-04-14 17:50:54
psst
已发帖子: 92
Re: v3s sd卡启动 有时出错
static irqreturn_t sunxi_mmc_handle_manual_stop(int irq, void *dev_id)
struct sunxi_mmc_host *host = dev_id;
struct mmc_request *mrq;
unsigned long iflags;
spin_lock_irqsave(&host->lock, iflags);
mrq = host->manual_stop_mrq;
spin_unlock_irqrestore(&host->lock, iflags);
if (!mrq) {
dev_err(mmc_dev(host->mmc), "no request for manual stop\n");
return IRQ_HANDLED;
dev_err(mmc_dev(host->mmc), "data error, sending stop command\n");
  • We will never have more than one outstanding request,
  • and we do not complete the request until after
  • we've cleared host->manual_stop_mrq so we do not need to
  • spin lock this function.
  • Additionally we have wait states within this function
  • so having it in a lock is a very bad idea.
    sunxi_mmc_send_manual_stop(host, mrq);
host->manual_stop_mrq = NULL;
mmc_request_done(host->mmc, mrq);
return IRQ_HANDLED;
static void sunxi_mmc_send_manual_stop(struct sunxi_mmc_host *host,
struct mmc_request *req)
u32 arg, cmd_val, ri;
unsigned long expire = jiffies + msecs_to_jiffies(1000);
cmd_val = SDXC_START | SDXC_RESP_EXPIRE |
SDXC_STOP_ABORT_CMD | SDXC_CHECK_RESPONSE_CRC;
if (req->cmd->opcode == SD_IO_RW_EXTENDED) {
cmd_val |= SD_IO_RW_DIRECT;
arg = (1 << 31) | (0 << 28) | (SDIO_CCCR_ABORT << 9) |
((req->cmd->arg >> 28) & 0x7);
} else {
cmd_val |= MMC_STOP_TRANSMISSION;
arg = 0;
mmc_writel(host, REG_CARG, arg);
mmc_writel(host, REG_CMDR, cmd_val);
do {
ri = mmc_readl(host, REG_RINTR);
} while (!(ri & (SDXC_COMMAND_DONE | SDXC_INTERRUPT_ERROR_BIT)) &&
time_before(jiffies, expire));
if (!(ri & SDXC_COMMAND_DONE) || (ri & SDXC_INTERRUPT_ERROR_BIT)) {
dev_err(mmc_dev(host->mmc), "send stop command failed\n");
if (req->stop)
req->stop->resp[0] = -ETIMEDOUT;
} else {
if (req->stop)
req->stop->resp[0] = mmc_readl(host, REG_RESP0);
mmc_writel(host, REG_RINTR, 0xffff);
找到了两个相关的函数,不知道什么原因引起的,不是每次都会出错,偶尔出问题,很要命。
#3 2020-04-14 18:29:03
Re: v3s sd卡启动 有时出错
换张卡呢?用的是开发板吗
楼主 #4 2020-04-14 19:30:50
psst
已发帖子: 92
Re: v3s sd卡启动 有时出错
不是开发板,批量做了,大概10个板会有一个出这种问题,而且出问题的可能过段时间又好了
#5 2020-04-14 19:41:28
歌以咏志
已发帖子: 219
Re: v3s sd卡启动 有时出错
十有八九硬件问题, 对照荔枝派原理图看是不是SDIO没有上拉.
楼主 #6 2020-04-15 11:00:15
psst
已发帖子: 92
Re: v3s sd卡启动 有时出错
有加上拉,硬件没问题
楼主 #7 2020-04-15 14:50:06
psst
已发帖子: 92
Re: v3s sd卡启动 有时出错
总线宽度改成1,是否会降低读写速度,我改成了1,试试看
#8 2020-04-15 15:09:45
歌以咏志
已发帖子: 219
Re: v3s sd卡启动 有时出错
肯定会降速嘛,要是速度一样,干嘛不全用1bit省IO.
#9 2023-10-25 23:27:13
WhyKen395
Re: v3s sd卡启动 有时出错
SD卡兼容性问题,换张卡试试
