先上个拆机图
3516Cv300的usb可以做uvc,之后找了接口定义,这个pcb也留有usb接口。理论接出来后,可以做uvc摄像头开发。
之后装上ttl,这个找G T R 就不说了。
从uboot打印和环境变量等,可以得到如下配置信息:
有线网口rtl8201f,108030编码,128Mddr3  8M spi flash
Block:64KB Chip:8MB Name:"XM25Q64AHIG"
at hifmc100_setTB() sr: 0x8 <<111>>.
unlock all.
SPI Nor total size: 8MB
sensor ar0237
uboot环境变量:
bootargs=init=linuxrc mem=${osmem} console=ttyAMA0,115200 root=/dev/mtdblock1 rootfstype=squashfs mtdparts=hi_sfc:0x30000(boot),0x2E0000(romfs),0x300000(user),0x160000(web),0x40000(custom),0x50000(mtd)
bootcmd=setenv setargs setenv bootargs ${bootargs};run setargs;sf probe 0;sf read 83000000 30000 2E0000;squashfsload;bootm 0x82000000
bootdelay=1
baudrate=115200
ipaddr=192.168.1.10
serverip=192.168.1.107
netmask=255.255.255.0
bootfile="uImage"
da=tftp 0x82000000 u-boot.bin.img;sf probe 0;flwrite
du=tftp 0x82000000 user-x.cramfs.img;sf probe 0;flwrite
dr=tftp 0x82000000 romfs-x.cramfs.img;sf probe 0;flwrite
dw=tftp 0x82000000 web-x.cramfs.img;sf probe 0;flwrite
dl=tftp 0x82000000 logo-x.cramfs.img;sf probe 0;flwrite
dc=tftp 0x82000000 custom-x.cramfs.img;sf probe 0;flwrite
up=tftp 0x82000000 update.img;sf probe 0;flwrite
ua=mw.b 0x82000000 ff 1000000;tftp 0x82000000 upall_verify.img;sf probe 0;flwrite
tk=tftp 0x82000000 uImage;setenv setargs setenv bootargs ${bootargs};run setargs;bootm 0x82000000
dd=mw.b 0x82000000 ff 1000000;tftp 0x82000000 mtd-x.jffs2.img;sf probe 0;flwrite
ethaddr=00:12:17:95:cf:8c
NID=0x0001
osmem=65M
appSystemLanguage=SimpChinese
appVideoStandard=PAL
stdin=serial
stdout=serial
stderr=serial
verify=n
ver=U-Boot 2010.06-svn706 (Oct 09 2017 - 14:57:23)
Environment size: 1291/65532 bytes备份官方flash镜像:
sf probe 0; sf read 82000000 0 800000
把整个flash镜像通道tftp上传到服务器:
 tftp 82000000 xx.bin 800000
如果不放心,可以通过crc32校验下上传的文件与读出来的是否一致:crc32 82000000 800000
通过uboot环境变量,可以知道flash上的分区表,以解开,编辑,重新打包romfs为例:
获取romfs:   dd if=xx.bin of=romfs.bin bs=1k skip=192 count=2944
查看squashfs压缩类型和块大小:Compression xz             Block size 262144
解包:            unsquashfs romfs.bin
打包:             sudo mksquashfs ./squashfs-root/ romfs.bin  -b 256k -noappend -all-root  -comp lzma
烧写:    sf probe 0; tftp 82000000 romfs.bin ; sf erase 0x30000 0x2E0000; sf write 82000000  0x30000  0x2E0000
erase时提示保护,但是运行sa时,就解锁了。
锁flash: sf lock level/all     解锁: sf lock 0
锁全部:sf lock 8    sf lock all
其它地方找的相关型号,接口定义:
IPG80H20PS-S
最近编辑记录 xyyangkun (2020-04-18 12:40:22)
前排强势围观
牛逼!!!
牛逼!!!
UVC搞通没,我也在弄没调好
有实际使用效果图么
这个摄像头实际效果怎么样啊?上个图片看下?
才看到这么好的帖子,楼主的UVC还有后续吗
我买了个雄迈30x80  xm530芯片 结果试机的时候尾插红线碰到了电路板结果开机只能进uboot了,上电听不到马达声,
然后我按这个教程刷内核,sf write 0x82000000 0x0 0x2500 结果开机uboot都进不去,网络灯也不闪了,请问还有救吗
这个产品开源吗?
有实际使用效果图么
我也买了雄迈的板子,但是在备份flash 这步卡死了。自带的uboot 不支持上传怎么破?
雄迈的系统还有密码,晕死了。
