楼主 #1 2020-04-18 13:57:10
hzy831225
荔枝派F1C100S,我启动好像是正常的,USB的HOST功能一直不行
荔枝派F1C100S,我启动好像是正常的,OTG功能,USB插入电脑有反映WIN可以驱动加载,但是HOST功能一直不行
我插入U盘、USB网卡都没反映,lsus,出来一直具返回一行“Bus 001 Device 001: ID 1d6b:0002”;
我看PE2,插入电脑高电压,插U盘是低电压,理论是对的
以下为启动代码 :
[ 0.000000] Linux version 4.15.0-next-20180202-licheepi-nano (f1c200s@ubuntu) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #15 Sat Apr 18 13:40:27 CST 2020
[ 0.000000] random: fast init done
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 8128
[ 0.000000] Kernel command line: console=ttyS0,115200 panic=5 rootwait root=/dev/mtdblock3 rw rootfstype=jffs2
[ 0.000000] Memory: 24780K/32768K available (4096K kernel code, 214K rwdata, 944K rodata, 1024K init, 217K bss, 7988K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] vmalloc : 0xc2800000 - 0xff800000 ( 976 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc2000000 ( 32 MB)
[ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (5088 kB)
[ 0.000000] .init : 0x(ptrval) - 0x(ptrval) (1024 kB)
[ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 215 kB)
[ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 218 kB)
[ 0.000047] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000110] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000625] Console: colour dummy device 80x30
[ 0.000709] Calibrating delay loop... 203.16 BogoMIPS (lpj=1015808)
[ 0.070230] pid_max: default: 32768 minimum: 301
[ 0.070671] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.070712] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.072084] CPU: Testing write buffer coherency: ok
[ 0.073731] Setting up static identity map for 0x80100000 - 0x80100058
[ 0.076226] devtmpfs: initialized
[ 0.082180] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.082238] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.082516] pinctrl core: initialized pinctrl subsystem
[ 0.084535] NET: Registered protocol family 16
[ 0.085793] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.087507] cpuidle: using governor menu
[ 0.106809] SCSI subsystem initialized
[ 0.107153] usbcore: registered new interface driver usbfs
[ 0.107300] usbcore: registered new interface driver hub
[ 0.107473] usbcore: registered new device driver usb
[ 0.107904] pps_core: LinuxPPS API ver. 1 registered
[ 0.107931] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.107996] PTP clock support registered
[ 0.109464] clocksource: Switched to clocksource timer
[ 0.136044] NET: Registered protocol family 2
[ 0.137485] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes)
[ 0.137559] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.137620] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.137670] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.137927] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.137985] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.138471] NET: Registered protocol family 1
[ 0.138921] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.140906] Initialise system trusted keyrings
[ 0.141498] workingset: timestamp_bits=30 max_order=13 bucket_order=0
[ 0.155708] jffs2: version 2.2. (NAND) ? 2001-2006 Red Hat, Inc.
[ 0.169944] Key type asymmetric registered
[ 0.169987] Asymmetric key parser 'x509' registered
[ 0.170209] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.170243] io scheduler noop registered
[ 0.170261] io scheduler deadline registered
[ 0.171030] io scheduler cfq registered (default)
[ 0.171064] io scheduler mq-deadline registered
[ 0.171083] io scheduler kyber registered
[ 0.183856] suniv-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.351846] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.358423] console [ttyS0] disabled
[ 0.378673] 1c25000.serial: ttyS0 at MMIO 0x1c25000 (irq = 22, base_baud = 6250000) is a 16550A
[ 0.813852] console [ttyS0] enabled
[ 0.819374] SCSI Media Changer driver v0.25
[ 0.827051] m25p80 spi0.0: found xt25q128, expected w25q128
[ 0.832783] m25p80 spi0.0: xt25q128 (16384 Kbytes)
[ 0.837632] 4 ofpart partitions found on MTD device spi0.0
[ 0.843181] Creating 4 MTD partitions on "spi0.0":
[ 0.847985] 0x000000000000-0x000000070000 : "u-boot"
[ 0.855605] 0x000000070000-0x000000080000 : "dtb"
[ 0.862883] 0x000000080000-0x000000380000 : "kernel"
[ 0.870452] 0x000000380000-0x000001000000 : "rootfs"
[ 0.878311] PPP generic driver version 2.4.2
[ 0.883229] PPP BSD Compression module registered
[ 0.887943] PPP Deflate Compression module registered
[ 0.893119] PPP MPPE Compression module registered
[ 0.897908] NET: Registered protocol family 24
[ 0.902460] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256).
[ 0.909552] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.916064] ehci-platform: EHCI generic platform driver
[ 0.921596] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.927816] ohci-platform: OHCI generic platform driver
[ 0.933474] usbcore: registered new interface driver usb-storage
[ 0.940465] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 0.952269] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 0.958061] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 0.968017] hub 1-0:1.0: USB hub found
[ 0.972043] hub 1-0:1.0: 1 port detected
[ 0.978324] using random self ethernet address
[ 0.982929] using random host ethernet address
[ 0.989174] usb0: HOST MAC 2a:74:ae:fb:3b:fa
[ 0.993712] usb0: MAC 2a:7e:20:87:c3:39
[ 0.997650] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[ 1.005218] g_cdc gadget: g_cdc ready
[ 1.009217] i2c /dev entries driver
[ 1.014961] usbcore: registered new interface driver usbhid
[ 1.020651] usbhid: USB HID core driver
[ 1.025404] NET: Registered protocol family 17
[ 1.030069] Key type dns_resolver registered
[ 1.036290] Loading compiled-in X.509 certificates
[ 1.048269] vcc3v3: disabling
[ 1.147018] random: crng init done
[ 2.444995] VFS: Mounted root (jffs2 filesystem) on device 31:3.
[ 2.452735] devtmpfs: mounted
[ 2.460244] Freeing unused kernel memory: 1024K
Starting logging: OK
Starting network: OK
最近编辑记录 hzy831225 (2020-04-18 16:10:49)
#2 2020-04-18 14:06:47
湘楚浪子
Re: 荔枝派F1C100S,我启动好像是正常的,USB的HOST功能一直不行
是不是cdc得编译成模块才能 otg?
楼主 #3 2020-04-18 15:32:46
hzy831225
不会吧,其实我也不需要USB连WIN。我直想接个U盘,接入个USB网口
楼主 #4 2020-04-18 15:47:22
hzy831225
还是说,PE2需要进行人工拉低电平
#5 2020-04-18 15:56:06
湘楚浪子
我记得这个固件可以测试otg,你试一试: https://whycan.cn/t_3400.html
楼主 #6 2020-04-18 16:10:16
hzy831225
收到,谢谢,这个好像是V3S的
#8 2023-09-25 14:04:00
flyaqiao
楼主这个问题解决了没,我好像类似问题,同样固件,生成的SD卡固件USB HOST都正常的.但生成的NOR FLASH里的固件,就发现不了USB设备.
