https://github.com/petit-miner/Blueberry-PI
Blueberry PI
Another fruit single board computer (SBC), based on the Allwinner V3s system on a chip (SOC). The Allwinner V3s comes in an easy to solder 128pin TQFP package.
The Blueberry PI features:
100 mbps Ethernet
1 USB Host Port / 1 mini USB port
MIPI CSI interface (unfortunately no support in the linux kernel yet)
Pinheader for an OV2640 and an OV7670
Wifi and bluetooth
RGB interface for connecting displays
Audio jack
an onboard microphone
four buttons for play, pause, next and previous
a Raspberry PI compatible header
SPI Flash
SD card slot
The Blueberry PI can boot from an SD card or SPI Flash. Since the V3s doesn't have a standard video output, I'm planning on creating a video addon board which provides VGA or HDMI. In combination with the ADV7611 it is possible to capture HDMI.If you have any questions email me at marcel[dot]thuermer(at)smail[dot]emt[dot]h[minus]brs[dot]de
csi 并口摄像头设备树:
https://github.com/petit-miner/Blueberry-PI/blob/master/Software/devicetree%20examples/sun8i-v3s-blueberrypi-csi.dts
csi 并口摄像头驱动补丁:
https://github.com/petit-miner/Blueberry-PI/blob/master/Software/media-V3s-CSI.patch
https://github.com/petit-miner/Blueberry-PI/tree/master/Software
软件介绍 Software
The mainline linux kernel (4.17) has support for:
basic SOC features
Ethernet
USB
parallel CSI (not in mainline kernel yet, see patch)(主线未包含,详见上面的patch)
RGB and TCON
UART
I²C
SPI
SDIO
Audio
LRADC0
RTC
Watchdog
Whats not implemented:CPU frequency scaling
MIPI CSI
Video Engine (encoding / decoding video)
Have a look at the wiki to find out how to build your own mainline kernel and rootfs. (work in progress)
2020-04-07 28楼更新:
官方git仓库本站下载: BlueberryPI_V3s_368d2eff57bfb12d3ee274370fe14749.7z
转换后DXP版本下载: BlueberryPI_PCB_AD_DXP.7z (仅供参考)
太好了,老外也开始玩v3s了,软件硬件都有源文件!到时候我也去打样一版玩玩
牛逼,有多了一个新玩法
V3S的玩的人越来越多了。
还是外国宁开放啊
坑哥,这个蓝莓派的摄像头补丁是可以用的吗?我补丁打上了之后有很多函数跟结构体是没找到的
请问原理图和PCB是什么格式的?我打不开。
eagle 试一试,歪果仁喜欢用这个软件,据说设计双层PCB免 licence费用。
看来高性价比就是一个大杀器,当时STM32F就是这么火起来的吧
全志的芯片,定价都很有杀伤力.
淘宝搜了下,没有卖的,有人生产吗?想买一块。
蓝莓PI
我设计了这块PCB,因为这款SoC的功率非常低,功耗非常低,再加上它的显示功能,它提供了制造商从未见过的选择。
有两个版本:2层和4层版本。
查看2层和4层版本的子文件夹以查看特定功能。蓝莓PI:
•SoC Allwinner V3s:
- ARM Cortex-A7 @ 1.2GHz
- 64兆字节RAM
•10 / 100M以太网
•Wifi和蓝牙(RTL8723BS)
•1个USB主机端口/ 1个微型USB端口
•MIPI CSI接口
•pinheader适用于OV2640和OV7670并行相机
•并行RGB接口,兼容40pin 并行RGB显示器
•音频插孔(3,5毫米)
•板载麦克风
•26针Raspberry PI兼容接头
•SPI闪存
•SD卡插槽Blueberry PI可以从SD卡或SPI Flash启动。
如果您有任何问题,请发送电子邮件至marcel [dot] thuermer(at)smail [dot] emt [dot] h [minus] brs [dot] de
软件
主线linux内核(4.21)支持:
基本的SOC功能
以太网络
USB
并行CSI
RGB和TCON
UART
I²C
SPI
SDIO
音频
LRADC0
RTC
看门狗什么没有实现:
CPU频率缩放
MIPI CSI
视频引擎(编码/解码视频)
查看文档以了解如何构建自己的主线内核和rootfs。
DVP CSI 摄像头驱动, 但是 MIPI CSI 摄像头没有驱动.
下载这些 eagle 转 AD 脚本, 勉勉强强搞定
https://github.com/Altium-Designer-addons/scripts-libraries/tree/master/EagleToAD/02_with_polygons
看来摄像头就是用这个了
ov7670:
https://item.szlcsc.com/334780.html
ov2640:
https://item.szlcsc.com/334779.html
淘宝售价更便宜:
看着转换后有部分丝印像是错位了吗?
jimmy 说:看着转换后有部分丝印像是错位了吗?
用 egale 脚本转出来的, 估计是要改改才能用吧。
被坑了一把, 里面有个德语字母, 在一般的软件里面和 l(小写L) 渲染一模一样
Can not convert to Altium
destination file is not correct
无法转换为Altium
目标文件不正确
最近编辑记录 GBg (2019-12-08 15:38:15)
样板打好了吗?想买块PCB自己焊接试试。
啥情况啊 ,我又该掏钱买板子了!蓝莓派我去 这名字取得 荔枝派 香橙派 树莓派 香蕉派 。。。。。。要是所有的水果都能做派 我还差好多啊火龙果派 榴莲派有木有!
V3s芯片哪里可以买到呢?
你好,可以分享一下这个转成AD的文件嘛,那个脚本我不会用。。。
费了九牛二虎之力终于找到以前转出来的DXP格式文件了,PCB能将就看,SCH不忍直视。
我安装了eagle,也能打开BlueberryPI_PCB,但是pcb器件的名称没有显示,请问这个如何设置
板子有的买么
板子有的买么
估计没有,我自己打样了,请大神指教pcb如何显示器件名称
晕哥 全能啊 软件 硬件 eagle AD 有都看到了,有PADS和allegro么:)
继续发问,我安装了eagle,也能打开BlueberryPI_PCB,但是pcb器件的名称没有显示,请问这个如何设置
最近编辑记录 kekemuyu (2020-04-01 15:41:25)
继续发问2,我安装了eagle,也能打开BlueberryPI_PCB,但是pcb器件的名称没有显示,请问这个如何设置
牛逼,有多了一个新玩法
怎么下载,不会下载
https://whycan.cn/files/members/3/Vorentwurf_26_05_18.png
2020-04-07 28楼更新:
官方git仓库本站下载: BlueberryPI_V3s_368d2eff57bfb12d3ee274370fe14749.7z转换后DXP版本下载: BlueberryPI_PCB_AD_DXP.7z (仅供参考)
AD 20打开出错,AD 15打开第4页是空的?
还是乱码
是不是我AD问题?
最近编辑记录 xblzy0423 (2020-04-07 16:40:24)
关注
感谢开源,前来学习
whycan.cn = 我还要宠爱你.菜鸟
这解释666
我就是一只老菜鸟,哈哈!
有项目方案也是用的v3s,刚入坑,mark下,积分不够,字数来凑
V3S 会不会那天停产的?
一年停产365次, 闰年停产366次.
csi 并口摄像头驱动补丁:仓库没了,有谁下载了补发一下呗!~
v3s的电路很简单 闭着眼睛 自动布线都能跑的很好把
V3S值得研究。
蓝莓派(Blueberry-PI) 在哪购买?
最近编辑记录 njitnjit (2020-05-06 13:23:37)
准备打个板自己玩一下,看起来比较好焊接!
我看到github就去下载,然后发现时eagle pcb,又找半天转换成,最后往下拖,发现有转换好的dxp版本~!
开源生态环境在china发展也越来越好了,支持蓝莓派!
双层板的cortex-a7就很爽了,不用担心bga的焊接问题,估计会很火
我怎么在淘宝看到有人卖这个pcb
打板倒是方便,就是焊接不太在行
可以直接下载下来去打样吗???有人试过有没有问题??
有项目用再试试。
打样成本高一些!
打样成本高一些!
不高,现在打样便宜得很。几十块的事
谢谢分享,感觉非常不错。哈哈。
这个v3s支持rgb屏吗,最大多少寸呢
发现是eagle pcb,去下了eagle软件!
下载了,为啥总是打不开哦。头大了 地方
什么格式的软件设计的?
GOOD
有人试过有没有问题??
这个有人测试过没有,我最近想打样做一个DEMO
Thank you so much
原理图怎么不来份 PDF 版本的
V3S的玩的人越来越多了,大神NB
tell me why such a large hole is made under the chip? is this made for a heat sink?
最近编辑记录 KappaPROject (2020-07-31 18:53:56)
V3s肚子下那个焊盘是芯片唯一的数字地,手工感觉必须有洞。
请问可以分享修改好的ad pcb文件吗,自己用脚本eagle转ad一堆错误
