https://bluscape.blog/2019/10/01/littlefs-explorer-lfse-for-windows/
The only problem I had with LFS is that I could not edit the file system in a Windows environment because it is not recognized by Windows. There is a FUSE driver for Linux, but I’m developing under Windows, so I needed an interface from where I could format the SD card to LFS, browse, edit, add and remove files. So I decided to write a file explorer for LFS in Windows.
好用吗?有没有测试效果?
这个好啊 littlefs挺好的就是电脑制作文件不是很方便 有这个就好多了
相见恨晚,以前都是用命令行生成的镜像烧录文件。
